[petsc-users] Nested Fieldsplit for custom index sets
Mon Jan 23 10:41:15 CST 2017
   It is "relative" to the level in which you are doing the fieldsplit, it does not go all the way up to the original problem.
> On Jan 23, 2017, at 10:22 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
> Hello
> May I know if the nested IS is identified based on relative local index or the global one? It's hard to identify that in the attached example.
> Giang
> On Thu, Jul 28, 2016 at 10:35 AM, Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> wrote:
> Dear Artur,
> On 28/07/16 02:20, Safin, Artur wrote:
> > Barry, Lawrence,
> >> I think the SubKSPs (and therefore SubPCs) are not set up until you call KSPSetUp(ksp) which your code does not do explicitly and is therefore done in KSPSolve.
> > I added KSPSetUp(), but unfortunately the issue did not go away.
> > I have created a MWE that replicates the issue. The program tries to solve a tridiagonal system, where the first fieldsplit partitions the global matrix
> > [ P  x ]
> > [ x  T ],
> > and the nested fieldsplit partitions P into
> > [ A  x ]
> > [ x  B ].
> Two things:
> 1. Always check the return value from all PETSc calls.  This will
> normally give you a very useful backtrace when something goes wrong.
> That is, annotate all your calls with:
> PetscErrorCode ierr;
> ierr = SomePetscFunction(...); CHKERRQ(ierr);
> If I do this, I see that the call to KSPSetUp fails:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 1
> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.2-931-g1e46b98
> GIT Date: 2016-07-06 16:57:50 -0500
> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 470 in
> /data/lmitche1/src/deps/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 487 in
> [0]PETSC ERROR: #3 PCSetUp() line 968 in
> /data/lmitche1/src/deps/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #4 KSPSetUp() line 393 in
> /data/lmitche1/src/deps/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #5 main() line 65 in /homes/lmitche1/tmp/ex.c
> The reason is you need to call KSPSetUp *after* setting the outermost
> fieldsplit ISes.
> If I move the call to KSPSetUp, then things seem to work.  I've
> attached the working code.
> Cheers,
> Lawrence
> $ cat options.txt
> -pc_type fieldsplit
> -pc_fieldsplit_type multiplicative
> -fieldsplit_T_ksp_type bcgs
> -fieldsplit_P_ksp_type gmres
> -fieldsplit_P_pc_type fieldsplit
> -fieldsplit_P_pc_fieldsplit_type multiplicative
> -fieldsplit_P_fieldsplit_A_ksp_type gmres
> -fieldsplit_P_fieldsplit_B_pc_type lu
> -fieldsplit_P_fieldsplit_B_ksp_type preonly
> -ksp_converged_reason
> -ksp_monitor_true_residual
> -ksp_view
> $ ./ex -options_file options.txt
>   0 KSP preconditioned resid norm 5.774607007892e+00 true resid norm
> 1.414213562373e+00 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 1.921795888956e-01 true resid norm
> 4.802975385197e-02 ||r(i)||/||b|| 3.396216464745e-02
>   2 KSP preconditioned resid norm 1.436304589027e-12 true resid norm
> 2.435255920058e-13 ||r(i)||/||b|| 1.721985974998e-13
> Linear solve converged due to CONVERGED_RTOL iterations 2
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with MULTIPLICATIVE composition: total splits = 2
>     Solver info for each split is in the following KSP objects:
>     Split number 0 Defined by IS
>     KSP Object: (fieldsplit_P_) 1 MPI processes
>       type: gmres
>     PC Object: (fieldsplit_P_) 1 MPI processes
>       type: fieldsplit
>         KSP Object: (fieldsplit_P_fieldsplit_A_) 1 MPI processes
>           type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
>         PC Object: (fieldsplit_P_fieldsplit_A_) 1 MPI processes
>           type: ilu
>             ILU: out-of-place factorization
>             0 levels of fill
>             tolerance for zero pivot 2.22045e-14
>             matrix ordering: natural
>             factor fill ratio given 1., needed 1.
>               Factored matrix follows:
>                 Mat Object: 1 MPI processes
>                   type: seqaij
>                   rows=25, cols=25
>                   package used to perform factorization: petsc
>                   total: nonzeros=73, allocated nonzeros=73
>                   total number of mallocs used during MatSetValues
> calls =0
>                     not using I-node routines
>           linear system matrix = precond matrix:
>           Mat Object: (fieldsplit_P_fieldsplit_A_) 1 MPI processes
>             type: seqaij
>             rows=25, cols=25
>             total number of mallocs used during MatSetValues calls =0
>         Split number 1 Defined by IS
>         KSP Object: (fieldsplit_P_fieldsplit_B_) 1 MPI processes
>           type: preonly
>           using NONE norm type for convergence test
>         PC Object: (fieldsplit_P_fieldsplit_B_) 1 MPI processes
>           type: lu
>             matrix ordering: nd
>             factor fill ratio given 5., needed 1.43836
>                   type: seqaij
>                   rows=25, cols=25
>                   total: nonzeros=105, allocated nonzeros=105
> calls =0
>           Mat Object: (fieldsplit_P_fieldsplit_B_) 1 MPI processes
>             type: seqaij
>             rows=25, cols=25
>       Mat Object: (fieldsplit_P_) 1 MPI processes
>         type: seqaij
>         rows=50, cols=50
>         total: nonzeros=148, allocated nonzeros=148
>     KSP Object: (fieldsplit_T_) 1 MPI processes
>       type: bcgs
>     PC Object: (fieldsplit_T_) 1 MPI processes
>       type: ilu
>         0 levels of fill
>               type: seqaij
>               rows=50, cols=50
>       Mat Object: (fieldsplit_T_) 1 MPI processes
>         type: seqaij
>         rows=50, cols=50
>     type: seqaij
>     rows=100, cols=100
>     total: nonzeros=298, allocated nonzeros=500
