[petsc-users] Nested Fieldsplit for custom index sets
Hoang Giang Bui hgbk2008 at gmail.com
Mon Jan 23 10:22:13 CST 2017
Hello
May I know if the nested IS is identified based on relative local index or
the global one? It's hard to identify that in the attached example.
Giang
On Thu, Jul 28, 2016 at 10:35 AM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> Dear Artur,
> On 28/07/16 02:20, Safin, Artur wrote:
> > Barry, Lawrence,
> >> I think the SubKSPs (and therefore SubPCs) are not set up until you
> call KSPSetUp(ksp) which your code does not do explicitly and is therefore
> done in KSPSolve.
> > I added KSPSetUp(), but unfortunately the issue did not go away.
> > I have created a MWE that replicates the issue. The program tries to
> solve a tridiagonal system, where the first fieldsplit partitions the
> global matrix
> > [ P  x ]
> > [ x  T ],
> > and the nested fieldsplit partitions P into
> > [ A  x ]
> > [ x  B ].
> Two things:
> 1. Always check the return value from all PETSc calls.  This will
> normally give you a very useful backtrace when something goes wrong.
> That is, annotate all your calls with:
> PetscErrorCode ierr;
> ierr = SomePetscFunction(...); CHKERRQ(ierr);
> If I do this, I see that the call to KSPSetUp fails:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 1
> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.2-931-g1e46b98
> GIT Date: 2016-07-06 16:57:50 -0500
> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 470 in
> /data/lmitche1/src/deps/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 487 in
> [0]PETSC ERROR: #3 PCSetUp() line 968 in
> /data/lmitche1/src/deps/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #4 KSPSetUp() line 393 in
> /data/lmitche1/src/deps/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #5 main() line 65 in /homes/lmitche1/tmp/ex.c
> The reason is you need to call KSPSetUp *after* setting the outermost
> fieldsplit ISes.
> If I move the call to KSPSetUp, then things seem to work.  I've
> attached the working code.
> Cheers,
> Lawrence
> $ cat options.txt
> -pc_type fieldsplit
> -pc_fieldsplit_type multiplicative
> -fieldsplit_T_ksp_type bcgs
> -fieldsplit_P_ksp_type gmres
> -fieldsplit_P_pc_type fieldsplit
> -fieldsplit_P_pc_fieldsplit_type multiplicative
> -fieldsplit_P_fieldsplit_A_ksp_type gmres
> -fieldsplit_P_fieldsplit_B_pc_type lu
> -fieldsplit_P_fieldsplit_B_ksp_type preonly
> -ksp_converged_reason
> -ksp_monitor_true_residual
> -ksp_view
> $ ./ex -options_file options.txt
>   0 KSP preconditioned resid norm 5.774607007892e+00 true resid norm
> 1.414213562373e+00 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 1.921795888956e-01 true resid norm
> 4.802975385197e-02 ||r(i)||/||b|| 3.396216464745e-02
>   2 KSP preconditioned resid norm 1.436304589027e-12 true resid norm
> 2.435255920058e-13 ||r(i)||/||b|| 1.721985974998e-13
> Linear solve converged due to CONVERGED_RTOL iterations 2
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with MULTIPLICATIVE composition: total splits = 2
>     Solver info for each split is in the following KSP objects:
>     Split number 0 Defined by IS
>     KSP Object: (fieldsplit_P_) 1 MPI processes
>       type: gmres
>     PC Object: (fieldsplit_P_) 1 MPI processes
>       type: fieldsplit
>         KSP Object: (fieldsplit_P_fieldsplit_A_) 1 MPI processes
>           type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
>         PC Object: (fieldsplit_P_fieldsplit_A_) 1 MPI processes
>           type: ilu
>             ILU: out-of-place factorization
>             0 levels of fill
>             tolerance for zero pivot 2.22045e-14
>             matrix ordering: natural
>             factor fill ratio given 1., needed 1.
>               Factored matrix follows:
>                 Mat Object: 1 MPI processes
>                   type: seqaij
>                   rows=25, cols=25
>                   package used to perform factorization: petsc
>                   total: nonzeros=73, allocated nonzeros=73
>                   total number of mallocs used during MatSetValues
> calls =0
>                     not using I-node routines
>           linear system matrix = precond matrix:
>           Mat Object: (fieldsplit_P_fieldsplit_A_) 1 MPI processes
>             type: seqaij
>             rows=25, cols=25
>             total number of mallocs used during MatSetValues calls =0
>         Split number 1 Defined by IS
>         KSP Object: (fieldsplit_P_fieldsplit_B_) 1 MPI processes
>           type: preonly
>           using NONE norm type for convergence test
>         PC Object: (fieldsplit_P_fieldsplit_B_) 1 MPI processes
>           type: lu
>             matrix ordering: nd
>             factor fill ratio given 5., needed 1.43836
>                   type: seqaij
>                   rows=25, cols=25
>                   total: nonzeros=105, allocated nonzeros=105
> calls =0
>           Mat Object: (fieldsplit_P_fieldsplit_B_) 1 MPI processes
>             type: seqaij
>             rows=25, cols=25
>       Mat Object: (fieldsplit_P_) 1 MPI processes
>         type: seqaij
>         rows=50, cols=50
>         total: nonzeros=148, allocated nonzeros=148
>     KSP Object: (fieldsplit_T_) 1 MPI processes
>       type: bcgs
>     PC Object: (fieldsplit_T_) 1 MPI processes
>       type: ilu
>         0 levels of fill
>               type: seqaij
>               rows=50, cols=50
>       Mat Object: (fieldsplit_T_) 1 MPI processes
>         type: seqaij
>         rows=50, cols=50
>     type: seqaij
>     rows=100, cols=100
>     total: nonzeros=298, allocated nonzeros=500
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170123/8a097468/attachment-0001.html>
