[petsc-users] VecSetSizes hangs in MPI
Manuel Valera mvalera at mail.sdsu.edu
Wed Jan 4 17:30:51 CST 2017
Thanks i had no idea how to debug and read those logs, that solved this
issue at least (i was sending a message from root to everyone else, but
trying to catch from everyone else including root)
Until next time, many thanks,
Manuel
On Wed, Jan 4, 2017 at 3:23 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
>> I did a PetscBarrier just before calling the vicariate routine and im
>> pretty sure im calling it from every processor, code looks like this:
> From the gdb trace.
>   Proc 0: Is in some MPI routine you call yourself, line 113
>   Proc 1: Is in VecCreate(), line 130
> You need to fix your communication code.
>    Matt
>> call PetscBarrier(PETSC_NULL_OBJECT,ierr)
>> print*,'entering POInit from',rank
>> !call exit()
>> call PetscObjsInit()
>> And output gives:
>>  entering POInit from           0
>>  entering POInit from           1
>>  entering POInit from           2
>>  entering POInit from           3
>> Still hangs in the same way,
>> Thanks,
>> Manuel
>> On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <mvalera at mail.sdsu.edu>
>> wrote:
>>> Thanks for the answers !
>>> heres the screenshot of what i got from bt in gdb (great hint in how to
>>> debug in petsc, didn't know that)
>>> I don't really know what to look at here,
>>> Thanks,
>>> Manuel
>>> On Wed, Jan 4, 2017 at 2:39 PM, Dave May <dave.mayhem23 at gmail.com>
>>> wrote:
>>>> Are you certain ALL ranks in PETSC_COMM_WORLD call these function(s).
>>>> These functions cannot be inside if statements like
>>>> if (rank == 0){
>>>>   VecCreateMPI(...)
>>>> On Wed, 4 Jan 2017 at 23:34, Manuel Valera <mvalera at mail.sdsu.edu>
>>>> wrote:
>>>>> Thanks Dave for the quick answer, appreciate it,
>>>>> I just tried that and it didn't make a difference, any other
>>>>> suggestions ?
>>>>> Thanks,
>>>>> Manuel
>>>>> On Wed, Jan 4, 2017 at 2:29 PM, Dave May <dave.mayhem23 at gmail.com>
>>>>> wrote:
>>>>> You need to swap the order of your function calls.
>>>>> Call VecSetSizes() before VecSetType()
>>>>> Thanks,
>>>>>   Dave
>>>>> On Wed, 4 Jan 2017 at 23:21, Manuel Valera <mvalera at mail.sdsu.edu>
>>>>> wrote:
>>>>> Hello all, happy new year,
>>>>> I'm working on parallelizing my code, it worked and provided some
>>>>> results when i just called more than one processor, but created artifacts
>>>>> because i didn't need one image of the whole program in each processor,
>>>>> conflicting with each other.
>>>>> Since the pressure solver is the main part i need in parallel im
>>>>> chosing mpi to run everything in root processor until its time to solve for
>>>>> pressure, at this point im trying to create a distributed vector using
>>>>> either
>>>>>      call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,nbdp,xp,ierr)
>>>>> or
>>>>>      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>>>>      call VecSetType(xp,VECMPI,ierr)
>>>>>      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>>>>> In both cases program hangs at this point, something it never happened
>>>>> on the naive way i described before. I've made sure the global size, nbdp,
>>>>> is the same in every processor. What can be wrong?
>>>>> Thanks for your kind help,
>>>>> Manuel.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/4095aba3/attachment-0001.html>
