[petsc-users] VecSetSizes hangs in MPI
Wed Jan 4 17:23:32 CST 2017
On Wed, Jan 4, 2017 at 5:21 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> I did a PetscBarrier just before calling the vicariate routine and im
> pretty sure im calling it from every processor, code looks like this:
>From the gdb trace.
  Proc 0: Is in some MPI routine you call yourself, line 113
  Proc 1: Is in VecCreate(), line 130
You need to fix your communication code.
   Matt
> call PetscBarrier(PETSC_NULL_OBJECT,ierr)
> print*,'entering POInit from',rank
> !call exit()
> call PetscObjsInit()
> And output gives:
>  entering POInit from           0
>  entering POInit from           1
>  entering POInit from           2
>  entering POInit from           3
> Still hangs in the same way,
> Thanks,
> Manuel
> On Wed, Jan 4, 2017 at 2:55 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
>> Thanks for the answers !
>> heres the screenshot of what i got from bt in gdb (great hint in how to
>> debug in petsc, didn't know that)
>> I don't really know what to look at here,
>> Thanks,
>> Manuel
>> On Wed, Jan 4, 2017 at 2:39 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
>>> Are you certain ALL ranks in PETSC_COMM_WORLD call these function(s).
>>> These functions cannot be inside if statements like
>>> if (rank == 0){
>>>   VecCreateMPI(...)
>>> On Wed, 4 Jan 2017 at 23:34, Manuel Valera <mvalera at mail.sdsu.edu>
>>> wrote:
>>>> Thanks Dave for the quick answer, appreciate it,
>>>> I just tried that and it didn't make a difference, any other
>>>> suggestions ?
>>>> Thanks,
>>>> Manuel
>>>> On Wed, Jan 4, 2017 at 2:29 PM, Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>> You need to swap the order of your function calls.
>>>> Call VecSetSizes() before VecSetType()
>>>> Thanks,
>>>>   Dave
>>>> On Wed, 4 Jan 2017 at 23:21, Manuel Valera <mvalera at mail.sdsu.edu>
>>>> wrote:
>>>> Hello all, happy new year,
>>>> I'm working on parallelizing my code, it worked and provided some
>>>> results when i just called more than one processor, but created artifacts
>>>> because i didn't need one image of the whole program in each processor,
>>>> conflicting with each other.
>>>> Since the pressure solver is the main part i need in parallel im
>>>> chosing mpi to run everything in root processor until its time to solve for
>>>> pressure, at this point im trying to create a distributed vector using
>>>> either
>>>>      call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,nbdp,xp,ierr)
>>>> or
>>>>      call VecCreate(PETSC_COMM_WORLD,xp,ierr); CHKERRQ(ierr)
>>>>      call VecSetType(xp,VECMPI,ierr)
>>>>      call VecSetSizes(xp,PETSC_DECIDE,nbdp,ierr); CHKERRQ(ierr)
>>>> In both cases program hangs at this point, something it never happened
>>>> on the naive way i described before. I've made sure the global size, nbdp,
>>>> is the same in every processor. What can be wrong?
>>>> Thanks for your kind help,
>>>> Manuel.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/f11b8315/attachment-0001.html>
