[petsc-users] Fwd: Fieldsplit with sub pc MUMPS in parallel
Karin&NiKo niko.karin at gmail.com
Wed Jan 4 15:39:44 CST 2017
Dear Petsc team,
I am (still) trying to solve Biot's poroelasticity problem :
 [image: Images intégrées 1]
I am using a mixed P2-P1 finite element discretization. The matrix of the
discretized system in binary format is attached to this email.
I am using the fieldsplit framework to solve the linear system. Since I am
facing some troubles, I have decided to go back to simple things. Here are
the options I am using :
-ksp_rtol 1.0e-5
-ksp_type fgmres
-pc_type fieldsplit
-pc_fieldsplit_schur_factorization_type full
-pc_fieldsplit_type schur
-pc_fieldsplit_schur_precondition selfp
-fieldsplit_0_pc_type lu
-fieldsplit_0_pc_factor_mat_solver_package mumps
-fieldsplit_0_ksp_type preonly
-fieldsplit_0_ksp_converged_reason
-fieldsplit_1_pc_type lu
-fieldsplit_1_pc_factor_mat_solver_package mumps
-fieldsplit_1_ksp_type preonly
-fieldsplit_1_ksp_converged_reason
On a single proc, everything runs fine : the solver converges in 3
iterations, according to the theory (see Run-1-proc.txt [contains
-log_view]).
On 2 procs, the solver converges in 28 iterations (see Run-2-proc.txt).
On 3 procs, the solver converges in 91 iterations (see Run-3-proc.txt).
I do not understand this behavior : since MUMPS is a parallel direct
solver, shouldn't the solver converge in max 3 iterations whatever the
number of procs?
Thanks for your precious help,
Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/5acf8079/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/5acf8079/attachment-0001.png>
  0 KSP unpreconditioned resid norm 2.375592557658e+10 true resid norm 2.375592557658e+10 ||r(i)||/||b|| 1.000000000000e+00
  Linear fieldsplit_0_ solve converged due to CONVERGED_ITS iterations 1
  Linear fieldsplit_1_ solve converged due to CONVERGED_ITS iterations 1
  1 KSP unpreconditioned resid norm 6.196553125161e+04 true resid norm 6.196553125161e+04 ||r(i)||/||b|| 2.608424203547e-06
  2 KSP unpreconditioned resid norm 2.675633869591e+03 true resid norm 2.675633869591e+03 ||r(i)||/||b|| 1.126301671962e-07
KSP Object: 1 MPI processes
  type: fgmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=1000, initial guess is zero
  tolerances:  relative=1e-06, absolute=1e-50, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (lumped, if requested) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: lu
          LU: out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          matrix ordering: nd
          factor fill ratio given 0., needed 0.
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=624, cols=624
                package used to perform factorization: mumps
                total: nonzeros=140616, allocated nonzeros=140616
                total number of mallocs used during MatSetValues calls =0
                  MUMPS run parameters:
                    SYM (matrix type):                   0
                    PAR (host participation):            1
                    ICNTL(1) (output for error):         6
                    ICNTL(2) (output of diagnostic msg): 0
                    ICNTL(3) (output for global info):   0
                    ICNTL(4) (level of printing):        0
                    ICNTL(5) (input mat struct):         0
                    ICNTL(6) (matrix prescaling):        7
                    ICNTL(7) (sequentia matrix ordering):7
                    ICNTL(8) (scalling strategy):        77
                    ICNTL(10) (max num of refinements):  0
                    ICNTL(11) (error analysis):          0
                    ICNTL(12) (efficiency control):                         1
                    ICNTL(13) (efficiency control):                         0
                    ICNTL(14) (percentage of estimated workspace increase): 20
                    ICNTL(18) (input mat struct):                           0
                    ICNTL(19) (Shur complement info):                       0
                    ICNTL(20) (rhs sparse pattern):                         0
                    ICNTL(21) (solution struct):                            0
                    ICNTL(22) (in-core/out-of-core facility):               0
                    ICNTL(23) (max size of memory can be allocated locally):0
                    ICNTL(24) (detection of null pivot rows):               0
                    ICNTL(25) (computation of a null space basis):          0
                    ICNTL(26) (Schur options for rhs or solution):          0
                    ICNTL(27) (experimental parameter):                     -32
                    ICNTL(28) (use parallel or sequential ordering):        1
                    ICNTL(29) (parallel ordering):                          0
                    ICNTL(30) (user-specified set of entries in inv(A)):    0
                    ICNTL(31) (factors is discarded in the solve phase):    0
                    ICNTL(33) (compute determinant):                        0
                    CNTL(1) (relative pivoting threshold):      0.01
                    CNTL(2) (stopping criterion of refinement): 1.49012e-08
                    CNTL(3) (absolute pivoting threshold):      0.
                    CNTL(4) (value of static pivoting):         -1.
                    CNTL(5) (fixation for null pivots):         0.
                    RINFO(1) (local estimated flops for the elimination after analysis):
                      [0] 1.99982e+07
                    RINFO(2) (local estimated flops for the assembly after factorization):
                      [0]  153549.
                    RINFO(3) (local estimated flops for the elimination after factorization):
                      [0]  1.99982e+07
                    INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
                    [0] 3
                    INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
                      [0] 3
                    INFO(23) (num of pivots eliminated on this processor after factorization):
                      [0] 624
                    RINFOG(1) (global estimated flops for the elimination after analysis): 1.99982e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 153549.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 1.99982e+07
                    (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 140616
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 4995
                    INFOG(5) (estimated maximum front size in the complete tree): 252
                    INFOG(6) (number of nodes in the complete tree): 23
                    INFOG(7) (ordering option effectively use after analysis): 2
                    INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 140616
                    INFOG(10) (total integer space store the matrix factors after factorization): 4995
                    INFOG(11) (order of largest frontal matrix after factorization): 252
                    INFOG(12) (number of off-diagonal pivots): 0
                    INFOG(13) (number of delayed pivots after factorization): 0
                    INFOG(14) (number of memory compress after factorization): 0
                    INFOG(15) (number of steps of iterative refinement after solution): 0
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 3
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 3
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 3
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 3
                    INFOG(20) (estimated number of entries in the factors): 140616
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 3
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 3
                    INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
                    INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
                    INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
                    INFOG(28) (after factorization: number of null pivots encountered): 0
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 140616
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 2, 2
                    INFOG(32) (after analysis: type of analysis done): 1
                    INFOG(33) (value used for ICNTL(8)): 7
                    INFOG(34) (exponent of the determinant if determinant is requested): 0
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         1 MPI processes
          type: seqaij
          rows=624, cols=624
          total: nonzeros=68940, allocated nonzeros=68940
            using I-node routines: found 208 nodes, limit used is 5
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: preonly
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: lu
          matrix ordering: nd
                type: seqaij
                rows=64, cols=64
                total: nonzeros=3584, allocated nonzeros=3584
                      [0] 123808.
                      [0]  1024.
                      [0]  123808.
                    [0] 1
                      [0] 1
                      [0] 64
                    RINFOG(1) (global estimated flops for the elimination after analysis): 123808.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1024.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 123808.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3584
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 222
                    INFOG(5) (estimated maximum front size in the complete tree): 48
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3584
                    INFOG(10) (total integer space store the matrix factors after factorization): 222
                    INFOG(11) (order of largest frontal matrix after factorization): 48
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 1
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 1
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 1
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 1
                    INFOG(20) (estimated number of entries in the factors): 3584
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 1
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 1
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3584
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_1_)         1 MPI processes
          type: schurcomplement
          rows=64, cols=64
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
                rows=64, cols=64
                total: nonzeros=1000, allocated nonzeros=1000
                  not using I-node routines
            A10
                type: seqaij
                rows=64, cols=624
                total: nonzeros=8400, allocated nonzeros=8400
            KSP of A00
                type: preonly
                type: lu
                  matrix ordering: nd
                        type: seqaij
                        rows=624, cols=624
                              [0] 1.99982e+07
                              [0]  153549.
                              [0]  1.99982e+07
                            [0] 3
                              [0] 3
                              [0] 624
                  type: seqaij
                  rows=624, cols=624
            A01
                type: seqaij
                rows=624, cols=64
          type: seqaij
          rows=64, cols=64
          total: nonzeros=2744, allocated nonzeros=2744
            using I-node routines: found 28 nodes, limit used is 5
    type: seqaij
    rows=688, cols=688
    total: nonzeros=86740, allocated nonzeros=86740
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
        on a arch-linux2-c-debug named dsp0780450 with 1 processor, by B07947 Wed Jan  4 22:21:05 2017
Using Petsc Release Version 3.7.2, Jun, 05, 2016
                         Max       Max/Min        Avg      Total
Time (sec):           1.568e-01      1.00000   1.568e-01
Objects:              7.000e+01      1.00000   7.000e+01
Flops:                1.231e+06      1.00000   1.231e+06  1.231e+06
Flops/sec:            7.847e+06      1.00000   7.847e+06  7.847e+06
Memory:               3.043e+06      1.00000              3.043e+06
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.5683e-01 100.0%  1.2308e+06 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecMDot                2 1.0 1.0014e-05 1.0 4.12e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   412
VecNorm                7 1.0 2.7895e-05 1.0 9.63e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   345
VecScale               5 1.0 3.2425e-04 1.0 2.19e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     7
VecCopy               10 1.0 4.2439e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                29 1.0 9.0361e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY                5 1.0 1.9193e-04 1.0 6.62e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0    35
VecAYPX                3 1.0 1.9312e-05 1.0 2.06e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   107
VecMAXPY               5 1.0 3.5524e-05 1.0 1.10e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   310
VecScatterBegin        9 1.0 5.2929e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult                9 1.0 1.1399e-03 1.0 9.30e+05 1.0 0.0e+00 0.0e+00 0.0e+00  1 76  0  0  0   1 76  0  0  0   816
MatSolve               6 1.0 1.6625e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatLUFactorSym         2 1.0 2.3232e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatLUFactorNum         2 1.0 7.0572e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatConvert             1 1.0 1.1921e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 9.2983e-05 1.0 1.11e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   120
MatAssemblyBegin       8 1.0 9.7752e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         8 1.0 4.3797e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow            128 1.0 1.3161e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 1.0 1.7309e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       4 1.0 6.2459e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatGetOrdering         2 1.0 8.4996e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatView                6 1.0 2.7837e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 18  0  0  0  0  18  0  0  0  0     0
MatAXPY                1 1.0 6.2799e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             1 1.0 1.5202e-03 1.0 2.54e+05 1.0 0.0e+00 0.0e+00 0.0e+00  1 21  0  0  0   1 21  0  0  0   167
MatMatMultSym          1 1.0 8.8406e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMatMultNum          1 1.0 6.2108e-04 1.0 2.54e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0 21  0  0  0   0 21  0  0  0   409
KSPGMRESOrthog         2 1.0 5.2691e-05 1.0 8.25e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   157
KSPSetUp               3 1.0 1.8287e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.5977e-02 1.0 9.65e+05 1.0 0.0e+00 0.0e+00 0.0e+00 10 78  0  0  0  10 78  0  0  0    60
PCSetUp                3 1.0 2.1162e-02 1.0 2.65e+05 1.0 0.0e+00 0.0e+00 0.0e+00 13 22  0  0  0  13 22  0  0  0    13
PCApply                2 1.0 1.4143e-02 1.0 6.84e+04 1.0 0.0e+00 0.0e+00 0.0e+00  9  6  0  0  0   9  6  0  0  0     5
KSPSolve_FS_0          2 1.0 1.0471e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
KSPSolve_FS_Schu       2 1.0 1.9639e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
KSPSolve_FS_Low        2 1.0 1.0584e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  7  0  0  0  0   7  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    26             26       172600     0.
      Vector Scatter     3              3         1992     0.
              Matrix    11             11      2316912     0.
       Krylov Solver     5              5        24280     0.
      Preconditioner     5              5         4840     0.
           Index Set    15             13        17584     0.
              Viewer     1              0            0     0.
    Distributed Mesh     1              1         4624     0.
Star Forest Bipartite Graph     2              2         1616     0.
     Discrete System     1              1          872     0.
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-ksp_rtol 1.0e-5
-ksp_type fgmres
-ksp_view
-log_summary
-pc_type fieldsplit
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --prefix=/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/Install --with-mpi=yes --with-x=yes --download-ml=/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/ml-6.2-p3.tar.gz --with-mumps-lib="-L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/lib -lzmumps -ldmumps -lmumps_common -lpord -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Scotch_aster-604_aster6/MPI/lib -lesmumps -lptscotch -lptscotcherr -lptscotcherrexit -lscotch -lscotcherr -lscotcherrexit -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Parmetis_aster-403_aster/lib -lparmetis -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Metis_aster-510_aster1/lib -lmetis -L/usr/lib -lscalapack-openmpi -L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi -lblacsF77init-openmpi -L/usr/lib/x86_64-linux-gnu -lgomp " --with-mumps-include=/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/include --with-scalapack-lib="-L/usr/lib -lscalapack-openmpi" --with-blacs-lib="-L/usr/lib -lblacs-openmpi -lblacsCinit-openmpi -lblacsF77init-openmpi" --with-blas-lib="-L/usr/lib -lopenblas -lcblas" --with-lapack-lib="-L/usr/lib -llapack"
Libraries compiled on Wed Nov 30 11:59:58 2016 on dsp0780450
Machine characteristics: Linux-3.16.0-4-amd64-x86_64-with-debian-8.6
Using PETSc directory: /home/B07947/dev/codeaster-prerequisites/petsc-3.7.2
Using PETSc arch: arch-linux2-c-debug
Using C compiler: mpicc  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/arch-linux2-c-debug/include -I/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/include -I/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/include -I/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/arch-linux2-c-debug/include -I/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/include -I/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/Install/include -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/arch-linux2-c-debug/lib -L/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/arch-linux2-c-debug/lib -lpetsc -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Mumps-502_consortium_aster1/MPI/lib -lzmumps -ldmumps -lmumps_common -lpord -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Scotch_aster-604_aster6/MPI/lib -lesmumps -lptscotch -lptscotcherr -lptscotcherrexit -lscotch -lscotcherr -lscotcherrexit -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Parmetis_aster-403_aster/lib -lparmetis -L/home/B07947/dev/codeaster-prerequisites/v13/prerequisites/Metis_aster-510_aster1/lib -lmetis -L/usr/lib -lscalapack-openmpi -lblacs-openmpi -lblacsCinit-openmpi -lblacsF77init-openmpi -L/usr/lib/x86_64-linux-gnu -lgomp -Wl,-rpath,/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/Install/lib -L/home/B07947/dev/codeaster-prerequisites/petsc-3.7.2/Install/lib -lml -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.9 -L/usr/lib/gcc/x86_64-linux-gnu/4.9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -lscalapack-openmpi -llapack -lopenblas -lcblas -lX11 -lssl -lcrypto -lm -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.9 -L/usr/lib/gcc/x86_64-linux-gnu/4.9 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lmpi -lhwloc -lgcc_s -lpthread -ldl
  1 KSP unpreconditioned resid norm 1.303564177055e+10 true resid norm 1.303564177055e+10 ||r(i)||/||b|| 5.487322196112e-01
  2 KSP unpreconditioned resid norm 1.071183507871e+10 true resid norm 1.071183507871e+10 ||r(i)||/||b|| 4.509121332352e-01
  3 KSP unpreconditioned resid norm 1.055458147519e+10 true resid norm 1.055458147519e+10 ||r(i)||/||b|| 4.442925804412e-01
  4 KSP unpreconditioned resid norm 6.525228688268e+09 true resid norm 6.525228688268e+09 ||r(i)||/||b|| 2.746779394991e-01
  5 KSP unpreconditioned resid norm 3.448826301973e+09 true resid norm 3.448826301973e+09 ||r(i)||/||b|| 1.451775175358e-01
  6 KSP unpreconditioned resid norm 2.198988275290e+09 true resid norm 2.198988275290e+09 ||r(i)||/||b|| 9.256588501262e-02
  7 KSP unpreconditioned resid norm 2.004030973880e+09 true resid norm 2.004030973880e+09 ||r(i)||/||b|| 8.435920408237e-02
  8 KSP unpreconditioned resid norm 1.484494627562e+09 true resid norm 1.484494627562e+09 ||r(i)||/||b|| 6.248944596060e-02
  9 KSP unpreconditioned resid norm 1.349414519794e+09 true resid norm 1.349414519794e+09 ||r(i)||/||b|| 5.680328116218e-02
 10 KSP unpreconditioned resid norm 1.261837655142e+09 true resid norm 1.261837655142e+09 ||r(i)||/||b|| 5.311675401045e-02
 11 KSP unpreconditioned resid norm 9.178806138105e+08 true resid norm 9.178806138106e+08 ||r(i)||/||b|| 3.863796469861e-02
 12 KSP unpreconditioned resid norm 5.407955744874e+08 true resid norm 5.407955744874e+08 ||r(i)||/||b|| 2.276466024210e-02
 13 KSP unpreconditioned resid norm 5.265237838393e+08 true resid norm 5.265237838393e+08 ||r(i)||/||b|| 2.216389263142e-02
 14 KSP unpreconditioned resid norm 3.590262609540e+08 true resid norm 3.590262609540e+08 ||r(i)||/||b|| 1.511312450431e-02
 15 KSP unpreconditioned resid norm 1.793849911732e+08 true resid norm 1.793849911732e+08 ||r(i)||/||b|| 7.551168258837e-03
 16 KSP unpreconditioned resid norm 1.434526359423e+08 true resid norm 1.434526359423e+08 ||r(i)||/||b|| 6.038604367567e-03
 17 KSP unpreconditioned resid norm 1.236301089463e+08 true resid norm 1.236301089464e+08 ||r(i)||/||b|| 5.204179839167e-03
 18 KSP unpreconditioned resid norm 6.088689145868e+07 true resid norm 6.088689145872e+07 ||r(i)||/||b|| 2.563019119691e-03
 19 KSP unpreconditioned resid norm 3.931575158104e+07 true resid norm 3.931575158114e+07 ||r(i)||/||b|| 1.654987150654e-03
 20 KSP unpreconditioned resid norm 3.835858071661e+07 true resid norm 3.835858071665e+07 ||r(i)||/||b|| 1.614695272259e-03
 21 KSP unpreconditioned resid norm 2.077211508217e+07 true resid norm 2.077211508226e+07 ||r(i)||/||b|| 8.743972115632e-04
 22 KSP unpreconditioned resid norm 8.335358693348e+06 true resid norm 8.335358693410e+06 ||r(i)||/||b|| 3.508749287221e-04
 23 KSP unpreconditioned resid norm 2.472991237989e+06 true resid norm 2.472991238011e+06 ||r(i)||/||b|| 1.040999741323e-04
 24 KSP unpreconditioned resid norm 6.209407637559e+05 true resid norm 6.209407637614e+05 ||r(i)||/||b|| 2.613835279791e-05
 25 KSP unpreconditioned resid norm 1.765314903856e+05 true resid norm 1.765314903114e+05 ||r(i)||/||b|| 7.431050823187e-06
 26 KSP unpreconditioned resid norm 4.334232432165e+04 true resid norm 4.334232435112e+04 ||r(i)||/||b|| 1.824484767449e-06
 27 KSP unpreconditioned resid norm 1.788850623345e+04 true resid norm 1.788850627330e+04 ||r(i)||/||b|| 7.530123890830e-07
KSP Object: 2 MPI processes
  type: fgmres
PC Object: 2 MPI processes
  type: fieldsplit
    Split info:
      KSP Object:      (fieldsplit_0_)       2 MPI processes
        type: preonly
      PC Object:      (fieldsplit_0_)       2 MPI processes
        type: lu
          matrix ordering: natural
              Mat Object:               2 MPI processes
                type: mpiaij
                rows=624, cols=624
                total: nonzeros=146498, allocated nonzeros=146498
                    ICNTL(18) (input mat struct):                           3
                    ICNTL(21) (solution struct):                            1
                      [0] 1.51255e+07
                      [1] 6.89106e+06
                      [0]  87833.
                      [1]  72313.
                      [0]  1.51255e+07
                      [1]  6.89106e+06
                    [0] 8
                    [1] 8
                      [0] 8
                      [1] 8
                      [0] 413
                      [1] 211
                    RINFOG(1) (global estimated flops for the elimination after analysis): 2.20165e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 160146.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 2.20165e+07
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 146498
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 5065
                    INFOG(5) (estimated maximum front size in the complete tree): 263
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 146498
                    INFOG(10) (total integer space store the matrix factors after factorization): 5065
                    INFOG(11) (order of largest frontal matrix after factorization): 263
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 8
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 16
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 8
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 16
                    INFOG(20) (estimated number of entries in the factors): 146498
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 8
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 15
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 146498
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 2, 3
        Mat Object:        (fieldsplit_0_)         2 MPI processes
          type: mpiaij
          rows=624, cols=624
          total: nonzeros=73470, allocated nonzeros=73470
            using I-node (on process 0) routines: found 112 nodes, limit used is 5
      KSP Object:      (fieldsplit_1_)       2 MPI processes
        type: preonly
      PC Object:      (fieldsplit_1_)       2 MPI processes
        type: lu
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=3038, allocated nonzeros=3038
                      [0] 71763.
                      [1] 15274.
                      [0]  1205.
                      [1]  256.
                      [0]  71763.
                      [1]  15274.
                    [0] 1
                    [1] 1
                      [0] 1
                      [1] 1
                      [0] 52
                      [1] 12
                    RINFOG(1) (global estimated flops for the elimination after analysis): 87037.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1461.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 87037.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3038
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 318
                    INFOG(5) (estimated maximum front size in the complete tree): 45
                    INFOG(6) (number of nodes in the complete tree): 4
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3038
                    INFOG(10) (total integer space store the matrix factors after factorization): 318
                    INFOG(11) (order of largest frontal matrix after factorization): 45
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 2
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 2
                    INFOG(20) (estimated number of entries in the factors): 3038
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 2
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3038
        Mat Object:        (fieldsplit_1_)         2 MPI processes
          rows=64, cols=64
            A11
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=1110, allocated nonzeros=1110
                  not using I-node (on process 0) routines
            A10
                type: mpiaij
                rows=64, cols=624
                total: nonzeros=6080, allocated nonzeros=6080
            KSP of A00
                type: preonly
                type: lu
                        type: mpiaij
                        rows=624, cols=624
                              [0] 1.51255e+07
                              [1] 6.89106e+06
                              [0]  87833.
                              [1]  72313.
                              [0]  1.51255e+07
                              [1]  6.89106e+06
                            [0] 8
                            [1] 8
                              [0] 8
                              [1] 8
                              [0] 413
                              [1] 211
                  type: mpiaij
                  rows=624, cols=624
            A01
                type: mpiaij
                rows=624, cols=64
                  using I-node (on process 0) routines: found 111 nodes, limit used is 5
          type: mpiaij
          rows=64, cols=64
          total: nonzeros=2846, allocated nonzeros=2846
            using I-node (on process 0) routines: found 37 nodes, limit used is 5
    type: mpiaij
    rows=688, cols=688
    total: nonzeros=86740, allocated nonzeros=94187
      using I-node (on process 0) routines: found 117 nodes, limit used is 5
        on a arch-linux2-c-debug named dsp0780450 with 2 processors, by B07947 Wed Jan  4 22:23:35 2017
Time (sec):           3.263e-01      1.00000   3.263e-01
Objects:              2.620e+02      1.00769   2.610e+02
Flops:                7.742e+06      1.75026   6.083e+06  1.217e+07
Flops/sec:            2.372e+07      1.75027   1.864e+07  3.728e+07
Memory:               3.540e+06      1.24844              6.376e+06
MPI Messages:         4.890e+02      1.00411   4.880e+02  9.760e+02
MPI Message Lengths:  1.677e+06      1.01260   3.415e+03  3.333e+06
MPI Reductions:       1.975e+03      1.00000
 0:      Main Stage: 3.2632e-01 100.0%  1.2165e+07 100.0%  9.760e+02 100.0%  3.415e+03      100.0%  1.973e+03  99.9%
Phase summary info:
      #                          WARNING!!!                    #
VecMDot               27 1.0 3.4330e-03 4.2 3.07e+05 1.4 0.0e+00 0.0e+00 5.4e+01  1  4  0  0  3   1  4  0  0  3   151
VecNorm               57 1.0 4.5562e-04 1.2 4.63e+04 1.4 0.0e+00 0.0e+00 1.1e+02  0  1  0  0  6   0  1  0  0  6   172
VecScale              55 1.0 6.2103e-03 1.1 1.31e+04 1.7 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     3
VecCopy               29 1.0 1.5283e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               121 1.0 4.5204e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               55 1.0 3.2640e-03 1.0 4.12e+04 1.3 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0    22
VecAYPX               28 1.0 1.8382e-04 1.1 1.14e+04 1.4 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   105
VecMAXPY              55 1.0 1.5895e-03 1.2 6.36e+05 1.4 0.0e+00 0.0e+00 0.0e+00  0  9  0  0  0   0  9  0  0  0   678
VecAssemblyBegin       1 1.0 5.9128e-05 1.0 0.00e+00 0.0 2.0e+00 1.0e+03 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 1.0014e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin      379 1.0 2.6152e-03 1.1 0.00e+00 0.0 3.0e+02 1.8e+03 8.1e+01  1  0 31 16  4   1  0 31 16  4     0
VecScatterEnd        298 1.0 2.0123e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMult              109 1.0 1.4856e-02 1.4 6.46e+06 1.8 1.6e+02 1.3e+03 0.0e+00  4 83 17  7  0   4 83 17  7  0   683
MatSolve              81 1.0 3.3831e-02 1.0 0.00e+00 0.0 1.4e+02 2.4e+03 9.5e+01 10  0 14 10  5  10  0 14 10  5     0
MatLUFactorSym         2 1.0 4.2470e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01  1  0  0  0  1   1  0  0  0  1     0
MatLUFactorNum         2 1.0 9.1913e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 28  0  0  0  0  28  0  0  0  0     0
MatConvert             1 1.0 4.1819e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.6798e-04 1.2 8.40e+0316.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    33
MatAssemblyBegin      14 1.0 3.8922e-03 3.9 0.00e+00 0.0 3.0e+00 9.5e+04 3.2e+01  1  0  0  9  2   1  0  0  9  2     0
MatAssemblyEnd        14 1.0 1.0869e-02 1.0 0.00e+00 0.0 1.2e+01 3.3e+02 1.6e+02  3  0  1  0  8   3  0  1  0  8     0
MatGetRow            128 0.0 2.7323e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 2.0 3.8147e-06 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 4.1627e-02 1.0 0.00e+00 0.0 8.0e+00 2.9e+02 1.8e+02 13  0  1  0  9  13  0  1  0  9     0
MatGetOrdering         2 2.0 4.3321e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                6 1.0 1.7805e-02 1.4 0.00e+00 0.0 7.2e+01 2.1e+03 1.8e+01  5  0  7  4  1   5  0  7  4  1     0
MatAXPY                1 1.0 1.7102e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.7e+01  1  0  0  0  2   1  0  0  0  2     0
MatMatMult             1 1.0 5.5580e-03 1.0 2.20e+05 0.0 4.0e+00 2.8e+03 3.7e+01  2  2  0  0  2   2  2  0  0  2    40
MatMatMultSym          1 1.0 4.2591e-03 1.0 0.00e+00 0.0 3.0e+00 2.3e+03 3.3e+01  1  0  0  0  2   1  0  0  0  2     0
MatMatMultNum          1 1.0 1.2820e-03 1.0 2.20e+05 0.0 1.0e+00 4.2e+03 4.0e+00  0  2  0  0  0   0  2  0  0  0   171
MatGetLocalMat         2 1.0 3.0327e-04 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 4.1389e-04 1.0 0.00e+00 0.0 4.0e+00 2.8e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        27 1.0 4.7998e-03 2.1 6.13e+05 1.4 0.0e+00 0.0e+00 4.3e+02  1  9  0  0 22   1  9  0  0 22   217
KSPSetUp               3 1.0 3.2687e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  1   0  0  0  0  1     0
KSPSolve               1 1.0 1.8870e-01 1.0 7.51e+06 1.7 3.0e+02 1.8e+03 1.5e+03 58 98 31 16 77  58 98 31 16 77    63
PCSetUp                3 1.0 1.5060e-01 1.0 2.28e+05436.0 1.8e+01 1.1e+03 3.8e+02 46  2  2  1 19  46  2  2  1 19     2
PCApply               27 1.0 1.6088e-01 1.0 6.38e+0514.7 2.0e+02 1.9e+03 4.3e+02 49  6 20 11 22  49  6 20 11 22     4
KSPSolve_FS_0         27 1.0 1.9183e-02 1.1 0.00e+00 0.0 5.4e+01 3.0e+03 1.1e+02  6  0  6  5  5   6  0  6  5  5     0
KSPSolve_FS_Schu      27 1.0 3.1643e-02 1.1 0.00e+00 0.0 2.9e+01 3.3e+02 1.5e+02  9  0  3  0  7   9  0  3  0  7     0
KSPSolve_FS_Low       27 1.0 1.0088e-01 1.0 0.00e+00 0.0 5.8e+01 2.8e+03 1.5e+02 31  0  6  5  7  31  0  6  5  7     0
              Vector   154            154       692384     0.
      Vector Scatter    14             14        19448     0.
              Matrix    37             37      2353112     0.
           Index Set    42             40        39600     0.
              Viewer     1              0            0     0.
Average time for MPI_Barrier(): 6.19888e-07
Average time for zero size MPI_Send(): 1.43051e-06
-ksp_rtol 1.0e-5
-ksp_type fgmres
-ksp_view
-log_summary
-pc_type fieldsplit
  1 KSP unpreconditioned resid norm 2.354387765268e+10 true resid norm 2.354387765268e+10 ||r(i)||/||b|| 9.910738934074e-01
  2 KSP unpreconditioned resid norm 7.565226261144e+09 true resid norm 7.565226261144e+09 ||r(i)||/||b|| 3.184563883548e-01
  3 KSP unpreconditioned resid norm 7.046563779272e+09 true resid norm 7.046563779272e+09 ||r(i)||/||b|| 2.966234153478e-01
  4 KSP unpreconditioned resid norm 6.712061059639e+09 true resid norm 6.712061059639e+09 ||r(i)||/||b|| 2.825426034445e-01
  5 KSP unpreconditioned resid norm 4.119098261045e+09 true resid norm 4.119098261045e+09 ||r(i)||/||b|| 1.733924551905e-01
  6 KSP unpreconditioned resid norm 4.093786883357e+09 true resid norm 4.093786883357e+09 ||r(i)||/||b|| 1.723269788062e-01
  7 KSP unpreconditioned resid norm 2.519521928135e+09 true resid norm 2.519521928135e+09 ||r(i)||/||b|| 1.060586723937e-01
  8 KSP unpreconditioned resid norm 2.373916289395e+09 true resid norm 2.373916289395e+09 ||r(i)||/||b|| 9.992943788879e-02
  9 KSP unpreconditioned resid norm 2.092596303640e+09 true resid norm 2.092596303640e+09 ||r(i)||/||b|| 8.808734043616e-02
 10 KSP unpreconditioned resid norm 2.075761860693e+09 true resid norm 2.075761860693e+09 ||r(i)||/||b|| 8.737869859045e-02
 11 KSP unpreconditioned resid norm 1.710779772940e+09 true resid norm 1.710779772940e+09 ||r(i)||/||b|| 7.201486498286e-02
 12 KSP unpreconditioned resid norm 1.648406379841e+09 true resid norm 1.648406379841e+09 ||r(i)||/||b|| 6.938927193247e-02
 13 KSP unpreconditioned resid norm 1.168410200806e+09 true resid norm 1.168410200806e+09 ||r(i)||/||b|| 4.918394768662e-02
 14 KSP unpreconditioned resid norm 1.166360451836e+09 true resid norm 1.166360451836e+09 ||r(i)||/||b|| 4.909766399445e-02
 15 KSP unpreconditioned resid norm 8.277208864954e+08 true resid norm 8.277208864951e+08 ||r(i)||/||b|| 3.484271256141e-02
 16 KSP unpreconditioned resid norm 8.276908129860e+08 true resid norm 8.276908129857e+08 ||r(i)||/||b|| 3.484144662423e-02
 17 KSP unpreconditioned resid norm 6.225378714956e+08 true resid norm 6.225378714955e+08 ||r(i)||/||b|| 2.620558266562e-02
 18 KSP unpreconditioned resid norm 5.761996033674e+08 true resid norm 5.761996033668e+08 ||r(i)||/||b|| 2.425498436208e-02
 19 KSP unpreconditioned resid norm 4.207038617987e+08 true resid norm 4.207038617981e+08 ||r(i)||/||b|| 1.770942834629e-02
 20 KSP unpreconditioned resid norm 3.481124393225e+08 true resid norm 3.481124393216e+08 ||r(i)||/||b|| 1.465370979546e-02
 21 KSP unpreconditioned resid norm 3.417301046733e+08 true resid norm 3.417301046727e+08 ||r(i)||/||b|| 1.438504694633e-02
 22 KSP unpreconditioned resid norm 2.567284390162e+08 true resid norm 2.567284390162e+08 ||r(i)||/||b|| 1.080692217984e-02
 23 KSP unpreconditioned resid norm 2.564957247063e+08 true resid norm 2.564957247063e+08 ||r(i)||/||b|| 1.079712612668e-02
 24 KSP unpreconditioned resid norm 2.418470506609e+08 true resid norm 2.418470506610e+08 ||r(i)||/||b|| 1.018049369962e-02
 25 KSP unpreconditioned resid norm 1.561397633279e+08 true resid norm 1.561397633288e+08 ||r(i)||/||b|| 6.572665957613e-03
 26 KSP unpreconditioned resid norm 1.559442432818e+08 true resid norm 1.559442432828e+08 ||r(i)||/||b|| 6.564435588086e-03
 27 KSP unpreconditioned resid norm 7.736290224512e+07 true resid norm 7.736290224773e+07 ||r(i)||/||b|| 3.256572849513e-03
 28 KSP unpreconditioned resid norm 5.012849210895e+07 true resid norm 5.012849211088e+07 ||r(i)||/||b|| 2.110146874694e-03
 29 KSP unpreconditioned resid norm 4.745677367047e+07 true resid norm 4.745677367368e+07 ||r(i)||/||b|| 1.997681526687e-03
 30 KSP unpreconditioned resid norm 2.290461197130e+07 true resid norm 2.290461197130e+07 ||r(i)||/||b|| 9.641641575896e-04
 31 KSP unpreconditioned resid norm 2.222737485540e+07 true resid norm 2.222737485540e+07 ||r(i)||/||b|| 9.356560233254e-04
 32 KSP unpreconditioned resid norm 2.201309723363e+07 true resid norm 2.201309723363e+07 ||r(i)||/||b|| 9.266360581351e-04
 33 KSP unpreconditioned resid norm 2.194874591650e+07 true resid norm 2.194874591650e+07 ||r(i)||/||b|| 9.239272048461e-04
 34 KSP unpreconditioned resid norm 2.128835019268e+07 true resid norm 2.128835019267e+07 ||r(i)||/||b|| 8.961280049498e-04
 35 KSP unpreconditioned resid norm 2.120111549764e+07 true resid norm 2.120111549764e+07 ||r(i)||/||b|| 8.924558813461e-04
 36 KSP unpreconditioned resid norm 1.976723092962e+07 true resid norm 1.976723092962e+07 ||r(i)||/||b|| 8.320968537262e-04
 37 KSP unpreconditioned resid norm 1.944717353711e+07 true resid norm 1.944717353711e+07 ||r(i)||/||b|| 8.186241144095e-04
 38 KSP unpreconditioned resid norm 1.903474216858e+07 true resid norm 1.903474216858e+07 ||r(i)||/||b|| 8.012629146873e-04
 39 KSP unpreconditioned resid norm 1.898023583422e+07 true resid norm 1.898023583422e+07 ||r(i)||/||b|| 7.989684835911e-04
 40 KSP unpreconditioned resid norm 1.694730587985e+07 true resid norm 1.694730587985e+07 ||r(i)||/||b|| 7.133927838434e-04
 41 KSP unpreconditioned resid norm 1.638896360821e+07 true resid norm 1.638896360821e+07 ||r(i)||/||b|| 6.898894995852e-04
 42 KSP unpreconditioned resid norm 1.519868139235e+07 true resid norm 1.519868139236e+07 ||r(i)||/||b|| 6.397848546613e-04
 43 KSP unpreconditioned resid norm 1.435025731851e+07 true resid norm 1.435025731851e+07 ||r(i)||/||b|| 6.040706463847e-04
 44 KSP unpreconditioned resid norm 1.398045017059e+07 true resid norm 1.398045017059e+07 ||r(i)||/||b|| 5.885037030245e-04
 45 KSP unpreconditioned resid norm 9.779767739199e+06 true resid norm 9.779767739203e+06 ||r(i)||/||b|| 4.116769817146e-04
 46 KSP unpreconditioned resid norm 9.762980432404e+06 true resid norm 9.762980432407e+06 ||r(i)||/||b|| 4.109703240539e-04
 47 KSP unpreconditioned resid norm 8.724157152360e+06 true resid norm 8.724157152364e+06 ||r(i)||/||b|| 3.672413067738e-04
 48 KSP unpreconditioned resid norm 8.701406903245e+06 true resid norm 8.701406903245e+06 ||r(i)||/||b|| 3.662836404835e-04
 49 KSP unpreconditioned resid norm 7.415213990246e+06 true resid norm 7.415213990273e+06 ||r(i)||/||b|| 3.121416577253e-04
 50 KSP unpreconditioned resid norm 7.191611476981e+06 true resid norm 7.191611477012e+06 ||r(i)||/||b|| 3.027291634598e-04
 51 KSP unpreconditioned resid norm 5.811126704500e+06 true resid norm 5.811126704556e+06 ||r(i)||/||b|| 2.446179874501e-04
 52 KSP unpreconditioned resid norm 4.174772896367e+06 true resid norm 4.174772896381e+06 ||r(i)||/||b|| 1.757360656365e-04
 53 KSP unpreconditioned resid norm 4.033730917892e+06 true resid norm 4.033730917902e+06 ||r(i)||/||b|| 1.697989373177e-04
 54 KSP unpreconditioned resid norm 3.072328590301e+06 true resid norm 3.072328590311e+06 ||r(i)||/||b|| 1.293289364966e-04
 55 KSP unpreconditioned resid norm 2.184704206300e+06 true resid norm 2.184704206347e+06 ||r(i)||/||b|| 9.196460055008e-05
 56 KSP unpreconditioned resid norm 2.087788381502e+06 true resid norm 2.087788381688e+06 ||r(i)||/||b|| 8.788495211261e-05
 57 KSP unpreconditioned resid norm 1.295154635850e+06 true resid norm 1.295154636297e+06 ||r(i)||/||b|| 5.451922435611e-05
 58 KSP unpreconditioned resid norm 1.293544515105e+06 true resid norm 1.293544515547e+06 ||r(i)||/||b|| 5.445144670860e-05
 59 KSP unpreconditioned resid norm 1.034191001856e+06 true resid norm 1.034191002189e+06 ||r(i)||/||b|| 4.353402265279e-05
 60 KSP unpreconditioned resid norm 8.496752472634e+05 true resid norm 8.496752472634e+05 ||r(i)||/||b|| 3.576687612210e-05
 61 KSP unpreconditioned resid norm 8.496711167836e+05 true resid norm 8.496711167853e+05 ||r(i)||/||b|| 3.576670225062e-05
 62 KSP unpreconditioned resid norm 8.482716981331e+05 true resid norm 8.482716981338e+05 ||r(i)||/||b|| 3.570779405750e-05
 63 KSP unpreconditioned resid norm 8.475428645046e+05 true resid norm 8.475428645056e+05 ||r(i)||/||b|| 3.567711398040e-05
 64 KSP unpreconditioned resid norm 8.465314549473e+05 true resid norm 8.465314549483e+05 ||r(i)||/||b|| 3.563453893722e-05
 65 KSP unpreconditioned resid norm 8.211742970257e+05 true resid norm 8.211742970257e+05 ||r(i)||/||b|| 3.456713544495e-05
 66 KSP unpreconditioned resid norm 8.199302190668e+05 true resid norm 8.199302190672e+05 ||r(i)||/||b|| 3.451476628112e-05
 67 KSP unpreconditioned resid norm 7.928265198998e+05 true resid norm 7.928265198998e+05 ||r(i)||/||b|| 3.337384255326e-05
 68 KSP unpreconditioned resid norm 7.879389590406e+05 true resid norm 7.879389590406e+05 ||r(i)||/||b|| 3.316810184897e-05
 69 KSP unpreconditioned resid norm 7.459634072370e+05 true resid norm 7.459634072382e+05 ||r(i)||/||b|| 3.140115104476e-05
 70 KSP unpreconditioned resid norm 7.257146826826e+05 true resid norm 7.257146826828e+05 ||r(i)||/||b|| 3.054878583212e-05
 71 KSP unpreconditioned resid norm 6.685588318458e+05 true resid norm 6.685588318459e+05 ||r(i)||/||b|| 2.814282397420e-05
 72 KSP unpreconditioned resid norm 6.124291328776e+05 true resid norm 6.124291328784e+05 ||r(i)||/||b|| 2.578005773356e-05
 73 KSP unpreconditioned resid norm 6.094795320798e+05 true resid norm 6.094795320799e+05 ||r(i)||/||b|| 2.565589499408e-05
 74 KSP unpreconditioned resid norm 5.357696539008e+05 true resid norm 5.357696539018e+05 ||r(i)||/||b|| 2.255309531825e-05
 75 KSP unpreconditioned resid norm 5.242423536496e+05 true resid norm 5.242423536500e+05 ||r(i)||/||b|| 2.206785637378e-05
 76 KSP unpreconditioned resid norm 3.951117863892e+05 true resid norm 3.951117863909e+05 ||r(i)||/||b|| 1.663213605874e-05
 77 KSP unpreconditioned resid norm 3.370805526075e+05 true resid norm 3.370805526076e+05 ||r(i)||/||b|| 1.418932516525e-05
 78 KSP unpreconditioned resid norm 3.130844272170e+05 true resid norm 3.130844272167e+05 ||r(i)||/||b|| 1.317921401157e-05
 79 KSP unpreconditioned resid norm 2.798298725063e+05 true resid norm 2.798298725051e+05 ||r(i)||/||b|| 1.177937149210e-05
 80 KSP unpreconditioned resid norm 2.379383176697e+05 true resid norm 2.379383176686e+05 ||r(i)||/||b|| 1.001595652005e-05
 81 KSP unpreconditioned resid norm 2.174610490053e+05 true resid norm 2.174610490057e+05 ||r(i)||/||b|| 9.153970797925e-06
 82 KSP unpreconditioned resid norm 2.135469574287e+05 true resid norm 2.135469574286e+05 ||r(i)||/||b|| 8.989208050016e-06
 83 KSP unpreconditioned resid norm 1.169940105631e+05 true resid norm 1.169940105627e+05 ||r(i)||/||b|| 4.924834866383e-06
 84 KSP unpreconditioned resid norm 7.882375855358e+04 true resid norm 7.882375855376e+04 ||r(i)||/||b|| 3.318067245987e-06
 85 KSP unpreconditioned resid norm 7.804803294150e+04 true resid norm 7.804803294074e+04 ||r(i)||/||b|| 3.285413262015e-06
 86 KSP unpreconditioned resid norm 5.378742608807e+04 true resid norm 5.378742608692e+04 ||r(i)||/||b|| 2.264168824470e-06
 87 KSP unpreconditioned resid norm 3.900919284375e+04 true resid norm 3.900919284392e+04 ||r(i)||/||b|| 1.642082634001e-06
 88 KSP unpreconditioned resid norm 3.889074491459e+04 true resid norm 3.889074491442e+04 ||r(i)||/||b|| 1.637096596765e-06
 89 KSP unpreconditioned resid norm 2.953428329101e+04 true resid norm 2.953428328769e+04 ||r(i)||/||b|| 1.243238584516e-06
 90 KSP unpreconditioned resid norm 2.172827479107e+04 true resid norm 2.172827478767e+04 ||r(i)||/||b|| 9.146465254586e-07
KSP Object: 3 MPI processes
  type: fgmres
PC Object: 3 MPI processes
  type: fieldsplit
    Split info:
      KSP Object:      (fieldsplit_0_)       3 MPI processes
        type: preonly
      PC Object:      (fieldsplit_0_)       3 MPI processes
        type: lu
              Mat Object:               3 MPI processes
                type: mpiaij
                rows=624, cols=624
                total: nonzeros=148148, allocated nonzeros=148148
                      [0] 4.02519e+06
                      [1] 2.70367e+06
                      [2] 1.62473e+07
                      [0]  55439.
                      [1]  30276.
                      [2]  65773.
                      [0]  4.02519e+06
                      [1]  2.70367e+06
                      [2]  1.62473e+07
                    [0] 9
                    [1] 9
                    [2] 10
                      [0] 9
                      [1] 9
                      [2] 10
                      [0] 278
                      [1] 87
                      [2] 259
                    RINFOG(1) (global estimated flops for the elimination after analysis): 2.29761e+07
                    RINFOG(2) (global estimated flops for the assembly after factorization): 151488.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 2.29761e+07
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 148148
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 4993
                    INFOG(5) (estimated maximum front size in the complete tree): 286
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 148148
                    INFOG(10) (total integer space store the matrix factors after factorization): 4993
                    INFOG(11) (order of largest frontal matrix after factorization): 286
                    INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 10
                    INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 28
                    INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 10
                    INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 28
                    INFOG(20) (estimated number of entries in the factors): 148148
                    INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 10
                    INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 28
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 148148
                    INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 1, 2
        Mat Object:        (fieldsplit_0_)         3 MPI processes
          type: mpiaij
          rows=624, cols=624
          total: nonzeros=72004, allocated nonzeros=72004
            using I-node (on process 0) routines: found 84 nodes, limit used is 5
      KSP Object:      (fieldsplit_1_)       3 MPI processes
        type: preonly
      PC Object:      (fieldsplit_1_)       3 MPI processes
        type: lu
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=3736, allocated nonzeros=3736
                      [0] 0.
                      [1] 0.
                      [2] 137244.
                      [0]  0.
                      [1]  0.
                      [2]  1225.
                      [0]  0.
                      [1]  0.
                      [2]  137244.
                    [0] 1
                    [1] 1
                    [2] 1
                      [0] 1
                      [1] 1
                      [2] 1
                      [0] 0
                      [1] 0
                      [2] 64
                    RINFOG(1) (global estimated flops for the elimination after analysis): 137244.
                    RINFOG(2) (global estimated flops for the assembly after factorization): 1225.
                    RINFOG(3) (global estimated flops for the elimination after factorization): 137244.
                    INFOG(3) (estimated real workspace for factors on all processors after analysis): 3736
                    INFOG(4) (estimated integer workspace for factors on all processors after analysis): 228
                    INFOG(5) (estimated maximum front size in the complete tree): 55
                    INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 3736
                    INFOG(10) (total integer space store the matrix factors after factorization): 228
                    INFOG(11) (order of largest frontal matrix after factorization): 55
                    INFOG(20) (estimated number of entries in the factors): 3736
                    INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 3736
        Mat Object:        (fieldsplit_1_)         3 MPI processes
          rows=64, cols=64
            A11
                type: mpiaij
                rows=64, cols=64
                total: nonzeros=1498, allocated nonzeros=1498
                  using I-node (on process 0) routines: found 49 nodes, limit used is 5
            A10
                type: mpiaij
                rows=64, cols=624
                total: nonzeros=6619, allocated nonzeros=6619
            KSP of A00
                type: preonly
                type: lu
                        type: mpiaij
                        rows=624, cols=624
                              [0] 4.02519e+06
                              [1] 2.70367e+06
                              [2] 1.62473e+07
                              [0]  55439.
                              [1]  30276.
                              [2]  65773.
                              [0]  4.02519e+06
                              [1]  2.70367e+06
                              [2]  1.62473e+07
                            [0] 9
                            [1] 9
                            [2] 10
                              [0] 9
                              [1] 9
                              [2] 10
                              [0] 278
                              [1] 87
                              [2] 259
                  type: mpiaij
                  rows=624, cols=624
            A01
                type: mpiaij
                rows=624, cols=64
          type: mpiaij
          rows=64, cols=64
          total: nonzeros=3254, allocated nonzeros=3254
            using I-node (on process 0) routines: found 36 nodes, limit used is 5
    type: mpiaij
    rows=688, cols=688
    total: nonzeros=86740, allocated nonzeros=100623
      using I-node (on process 0) routines: found 89 nodes, limit used is 5
        on a arch-linux2-c-debug named dsp0780450 with 3 processors, by B07947 Wed Jan  4 22:24:59 2017
Time (sec):           6.375e-01      1.00000   6.375e-01
Objects:              3.880e+02      1.00518   3.867e+02
Flops:                1.960e+07      3.76942   1.356e+07  4.069e+07
Flops/sec:            3.074e+07      3.76942   2.128e+07  6.383e+07
Memory:               2.840e+06      2.46007              6.751e+06
MPI Messages:         1.442e+03      1.39324   1.209e+03  3.627e+03
MPI Message Lengths:  2.737e+06      1.92279   1.757e+03  6.373e+06
MPI Reductions:       5.530e+03      1.00000
 0:      Main Stage: 6.3745e-01 100.0%  4.0689e+07 100.0%  3.627e+03 100.0%  1.757e+03      100.0%  5.528e+03 100.0%
Phase summary info:
      #                          WARNING!!!                    #
VecMDot               90 1.0 1.0739e-02 2.8 8.55e+05 2.8 0.0e+00 0.0e+00 1.8e+02  1  5  0  0  3   1  5  0  0  3   178
VecNorm              185 1.0 4.0359e-03 2.1 1.14e+05 2.8 0.0e+00 0.0e+00 3.7e+02  0  1  0  0  7   0  1  0  0  7    63
VecScale             183 1.0 2.8165e-02 1.2 3.43e+04 3.4 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     2
VecCopy               92 1.0 4.0483e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               373 1.0 1.3938e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY              181 1.0 1.4770e-02 1.2 9.96e+04 2.5 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   2  1  0  0  0    16
VecAYPX               91 1.0 4.9877e-04 1.3 2.79e+04 2.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   126
VecWAXPY               2 1.0 1.1921e-05 1.4 6.14e+02 2.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   115
VecMAXPY             181 1.0 5.1925e-03 1.6 1.73e+06 2.8 0.0e+00 0.0e+00 0.0e+00  1 10  0  0  0   1 10  0  0  0   747
VecAssemblyBegin       1 1.0 4.1962e-05 1.1 0.00e+00 0.0 6.0e+00 7.2e+02 6.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 1.0014e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     1263 1.0 8.3861e-03 1.0 0.00e+00 0.0 2.6e+03 9.1e+02 2.7e+02  1  0 72 38  5   1  0 72 38  5     0
VecScatterEnd        993 1.0 9.8801e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMult              363 1.0 4.3428e-02 1.7 1.64e+07 3.9 1.5e+03 7.9e+02 0.0e+00  6 84 40 18  0   6 84 40 18  0   782
MatSolve             270 1.0 1.1593e-01 1.0 0.00e+00 0.0 1.2e+03 1.0e+03 2.8e+02 18  0 33 19  5  18  0 33 19  5     0
MatLUFactorSym         2 1.0 1.4674e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01  2  0  0  0  0   2  0  0  0  0     0
MatLUFactorNum         2 1.0 1.6366e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 26  0  0  0  0  26  0  0  0  0     0
MatConvert             1 1.0 3.1614e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               2 1.0 2.5296e-04 1.5 8.44e+0319.6 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    39
MatAssemblyBegin      14 1.0 3.6721e-03 3.6 0.00e+00 0.0 9.0e+00 5.3e+04 3.2e+01  0  0  0  8  1   0  0  0  8  1     0
MatAssemblyEnd        14 1.0 9.9134e-03 1.1 0.00e+00 0.0 3.2e+01 2.0e+02 1.6e+02  2  0  1  0  3   2  0  1  0  3     0
MatGetRow            128 0.0 2.0242e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 2.0 5.2452e-06 5.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrix        4 1.0 3.2568e-02 1.0 0.00e+00 0.0 2.0e+01 1.8e+02 1.8e+02  5  0  1  0  3   5  0  1  0  3     0
MatGetOrdering         2 2.0 2.8801e-04 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                6 1.0 5.2862e-03 1.2 0.00e+00 0.0 1.4e+02 2.1e+03 1.8e+01  1  0  4  5  0   1  0  4  5  0     0
MatAXPY                1 1.0 1.1809e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.7e+01  0  0  0  0  1   0  0  0  0  1     0
MatMatMult             1 1.0 4.0901e-03 1.0 2.82e+05 0.0 8.0e+00 3.7e+03 3.7e+01  1  1  0  0  1   1  1  0  0  1    69
MatMatMultSym          1 1.0 3.1250e-03 1.0 0.00e+00 0.0 6.0e+00 3.0e+03 3.3e+01  0  0  0  0  1   0  0  0  0  1     0
MatMatMultNum          1 1.0 9.5606e-04 1.0 2.82e+05 0.0 2.0e+00 5.7e+03 4.0e+00  0  1  0  0  0   0  1  0  0  0   295
MatGetLocalMat         2 1.0 1.9097e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          2 1.0 2.4199e-04 1.5 0.00e+00 0.0 8.0e+00 3.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog        90 1.0 1.7338e-02 1.8 1.71e+06 2.8 0.0e+00 0.0e+00 1.6e+03  2  9  0  0 28   2  9  0  0 28   221
KSPSetUp               3 1.0 3.6407e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 5.1757e-01 1.0 1.93e+07 3.7 2.6e+03 9.1e+02 5.1e+03 81 99 73 38 92  81 99 73 38 92    78
PCSetUp                3 1.0 2.2046e-01 1.0 2.90e+05673.4 3.6e+01 1.1e+03 3.8e+02 35  1  1  1  7  35  1  1  1  7     1
PCApply               90 1.0 4.1464e-01 1.0 2.15e+0622.0 1.5e+03 9.1e+02 1.2e+03 65  6 43 22 23  65  6 43 22 23     6
KSPSolve_FS_0         90 1.0 6.7575e-02 1.0 0.00e+00 0.0 5.4e+02 1.1e+03 3.6e+02 10  0 15  9  7  10  0 15  9  7     0
KSPSolve_FS_Schu      90 1.0 8.9136e-02 1.1 0.00e+00 0.0 9.2e+01 7.5e+02 4.0e+02 14  0  3  1  7  14  0  3  1  7     0
KSPSolve_FS_Low       90 1.0 2.1874e-01 1.0 0.00e+00 0.0 5.5e+02 1.1e+03 4.0e+02 34  0 15  9  7  34  0 15  9  7     0
              Vector   280            280      1105608     0.
      Vector Scatter    14             14        17840     0.
              Matrix    37             37      1853640     0.
           Index Set    42             40        37772     0.
              Viewer     1              0            0     0.
Average time to get PetscTime(): 0.
Average time for MPI_Barrier(): 1.19209e-06
Average time for zero size MPI_Send(): 6.35783e-07
-ksp_rtol 1.0e-5
-ksp_type fgmres
-ksp_view
-log_summary
-pc_type fieldsplit
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170104/5acf8079/attachment-0001.bin>
