[petsc-users] nondeterministic behavior with ./program -help | head
Wed Apr 26 18:32:34 CDT 2017
> On Apr 26, 2017, at 5:44 PM, Jed Brown <jed at jedbrown.org> wrote:
> PETSc is the only package I know for which "./app -help" does everything
> that "./app" would do, with extra output.  It is an unfortunate
> consequence of extensibility that we can't exit immediately.  What if we
> had a function the user could call to exit early and cleanly after all
> options have been processed?  Maybe something like:
>  PetscInitialize
>  if (PetscHelpActive()) {
>    TSSetDuration(ts,1,PETSC_DEFAULT);
>    PetscExitSilently();
> where PetscExitSilently doesn't print -malloc or -log_view or the like.
   Yuck!
> We should probably also have "-help snes,ksp_fieldsplit" that would only
> print help for options with those prefixes.
   This would be useful.
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  Ed
>>   I think want you want is something like
>>   ./program -intro
>> that causes the help message to PetscInitialize() to be printed and then have the program end.
>> We can add this, -intro is not a great name, any idea for a better name?
>>  Barry
>>> On Apr 26, 2017, at 4:30 PM, Ed Bueler <elbueler at alaska.edu> wrote:
>>>> Is  ./ex5 -help -no_signal_handler  | head  good enough?
>>> Umm.  It eliminates the nondeterminism.  Should discovery of options for petsc user applications go via error messages?  (Or asking users to remember "-no_signal_handler" to avoid?)  I don't understand signal handling well-enough to recommend a better way ... maybe there is no better way for |head.
>>> The best alternative I can think of is if my codes supply the program name for the "const char man[]" argument of PetscOptionsXXX().  Then I can suggest this to users:
>>> ./program -help |grep program
>>> Is this a mis-use of the "man" argument?
>>> Ed
>>> PS  Amused to find "This routine should not be used from within a signal handler." in the man page for MPI_Abort(), which I reached by clicking on the call to MPI_Abort() in the view of PetscSignalHandlerDefault().  ;-)
>>> On Wed, Apr 26, 2017 at 12:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Is
>>> good enough?
>>> Normally we won't want to turn off catching of PIPE errors  since it might hide other errors.
>>> Barry
>>>> On Apr 26, 2017, at 3:31 PM, Ed Bueler <elbueler at alaska.edu> wrote:
>>>> Dear Petsc --
>>>> Copied at the bottom is the behavior I get for ex5.c in snes examples/tutorials.  When I do
>>>> $./ex5 -help |head
>>>> I get a "Caught signal number 13 Broken Pipe" or just a version string.  Randomly, one or the other.
>>>> I know this has come up on petsc-users before:
>>>>    http://lists.mcs.anl.gov/pipermail/petsc-users/2014-May/021848.html
>>>> The claim was that the SIGPIPE error is standard behavior.
>>>> My real issue (feature request?) is that when writing a petsc application I want a rational help system.  Suppose "program.c" has options with prefix "prg_".  The user doesn't know the prefix yet (I could have used "prog_" as the prefix ...)  The petsc-canonical help system is (I believe)
>>>> ./program -help |grep prg_
>>>> for program.c-specific options.  Works great if you know to look for "prg_".  My plan for my applications is to put the prefix in the first line or two of my help string, the user can discover the prefix by
>>>> ./program -help |head
>>>> and then use "-help |grep -prg_" and etc.
>>>> So my question is:  Can petsc be set up to not generate an error message when the help system is used in a correct way?  (I.e. catching return codes when writing, or handling SIGPIPE differently?)  Or, on the other hand, can someone suggest a better help system that irritates less?
>>>> Thanks!
>>>> Ed
>>>> ~/petsc/src/snes/examples/tutorials[master*]$ ./ex5 -help |head
>>>> Bratu nonlinear PDE in 2d.
>>>> We solve the  Bratu (SFI - solid fuel ignition) problem in a 2D rectangular
>>>> domain, using distributed arrays (DMDAs) to partition the parallel grid.
>>>> The command line options include:
>>>>  -par <parameter>, where <parameter> indicates the problem's nonlinearity
>>>>     problem SFI:  <parameter> = Bratu parameter (0 <= par <= 6.81)
>>>>  -m_par/n_par <parameter>, where <parameter> indicates an integer
>>>>       that MMS3 will be evaluated with 2^m_par, 2^n_par--------------------------------------------------------------------------
>>>> Petsc Development GIT revision: v3.7.6-3453-ge45481d470  GIT Date: 2017-04-26 13:00:15 -0500
>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>> [0]PETSC ERROR: Caught signal number 13 Broken Pipe: Likely while reading or writing to a socket
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>> [0]PETSC ERROR:       is given.
>>>> [0]PETSC ERROR: [0] PetscVFPrintfDefault line 240 /home/ed/petsc/src/sys/fileio/mprint.c
>>>> [0]PETSC ERROR: [0] PetscHelpPrintfDefault line 622 /home/ed/petsc/src/sys/fileio/mprint.c
>>>> [0]PETSC ERROR: [0] PetscOptionsBegin_Private line 29 /home/ed/petsc/src/sys/objects/aoptions.c
>>>> [0]PETSC ERROR: [0] PetscObjectOptionsBegin_Private line 61 /home/ed/petsc/src/sys/objects/aoptions.c
>>>> [0]PETSC ERROR: [0] PetscDSSetFromOptions line 218 /home/ed/petsc/src/dm/dt/interface/dtds.c
>>>> [0]PETSC ERROR: [0] DMSetFromOptions line 747 /home/ed/petsc/src/dm/interface/dm.c
>>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>> [0]PETSC ERROR: Signal received
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-3453-ge45481d470  GIT Date: 2017-04-26 13:00:15 -0500
>>>> [0]PETSC ERROR: ./ex5 on a linux-c-dbg named bueler-leopard by ed Wed Apr 26 11:22:07 2017
>>>> [0]PETSC ERROR: Configure options --download-mpich --with-debugging=1
>>>> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>> [unset]: aborting job:
>>>> Ed Bueler
>>>> Dept of Math and Stat and Geophysical Institute
>>>> University of Alaska Fairbanks
>>>> Fairbanks, AK 99775-6660
>>>> 301C Chapman
>>> Ed Bueler
>>> 301C Chapman
