[petsc-users] including petsc Mat and Vec in a user-defined structure in FORTRAN
Lailai Zhu lailaizhu00 at gmail.com
Fri Apr 14 11:24:56 CDT 2017
thanks, Barray,
indeed this is due to this naive mistake. Thanks again.
best,
lailai
On 04/13/2017 10:34 PM, Barry Smith wrote:
>    VecCreate() does not take a size argument (perhaps you mean VecCreateSeq()?) hence when you try to get the size it is confused.
>     Barry
>> On Apr 13, 2017, at 8:29 PM, Lailai Zhu <lailaizhu00 at gmail.com> wrote:
>> Dear petsc developers and users,
>> I am currently using fortran version of petsc 3.7.*.
>> I tried to define Mat or Vec variables in a user-defined structure like below,
>> module myMOD
>>     type, public :: myStr
>>        Mat A
>>        Vec x,b
>>     end type myStr
>> interface myStr !! user-defined constructor
>>    module procedure new_Str
>> end interface myStr
>> contains
>>     function new_Str()
>>          type(myStr) :: new_Str
>>          call  VecCreate(petsc_comm_self,10,new_str%x,ierr)
>>          call  vecgetsize(new_str%x, size, ierr)
>>     end function new_Str
>> end module myMOD
>> then i define an instance of myStr in another file like below
>> type(myStr),save :: mystr1
>> mystr1 = myStr()
>> It compiles and the veccreate executes without problem, however error occurs on the vecgetsize part,
>> telling me
>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0]PETSC ERROR: Null argument, when expecting valid pointer
>> [0]PETSC ERROR: Null Object: Parameter # 1
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
>> [0]PETSC ERROR: ./nek5000 on a pet3.7.5-mpich-intel named quququ by user Thu Apr 13 21:11:05 2017
>> [0]PETSC ERROR: Configure options --with-c++-support --with-shared-libraries=1 --known-mpi-shared-libraries=1 --with-batch=0 --with-mpi=1 --with-debugging=1 -download-fblaslapack=1 --download-blacs=1 --download-scalapack=1 --download-plapack=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --download-dscpack=1
>> [0]PETSC ERROR: #1 VecGetSize() line 667 in /home/user/petsc/3.7.5/mpich_intel/src/vec/vec/interface/vector.c
>> It seems to me that the petsc vector x belong to the derived type variable is recognized in the veccreate subroutine, but
>> not known by the vecgetsize one. Is there way to work this around? or perhaps one cannot use petsc objects in such ways?
>> Thanks in advance,
>> best,
>> lailai
