[petsc-users] Patching in generalized eigen value problems
Daralagodu Dattatreya Jois, Sathwik Bharadw sdaralagodudatta at wpi.edu
Sun Apr 9 14:21:08 CDT 2017
Dear petsc users,
I am solving for generalized eigen value problems using petsc and slepc.
Our equation will be of the form,
A X=λ B X.
I am constructing the A and B matrix of type MATMPIAIJ. Let us consider that
both of my matrices are of dimension 10*10. When we are solving for a closed
geometry, we require to add all the entries of the last (9th) row and column to
the first (0th) row and column respectively for both matrices. In a high density mesh,
I will have a large number of such row to row and column to column additions.
For example, I may have to add last 200 rows and columns to first 200 rows and columns
respectively. We will then zero the copied row and column expect the diagonal
element (9th row/column in the former case).
I understand that MatGetRow, MatGetColumnVector, MatGetValues or any other
MatGet- or VecGet- functions are not collective. Can you suggest any
efficient algorithm or function to achieve this way of patching?
One way I can think of is to obtain the column vector using MatGetColumnVector and
row vector by MatZeroRows and then scatter these vectors to all processes. Once we have
entire row/column vector entries in each process, we can add the values to the matrix by
their global index. Of course, care should be taken to add the values of diagonal element
only once. But this will be a quite slow process.
Any ideas are appreciated.
Sathwik Bharadwaj
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170409/cf106607/attachment.html>
