[petsc-users] KSP Solver giving inf's
Kaushik Kulkarni kaushikggg at gmail.com
Sat Apr 8 11:21:49 CDT 2017
Yes that worked. Thanks a lot.
On Sat, Apr 8, 2017 at 9:49 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Apr 8, 2017 10:20, "Kaushik Kulkarni" <kaushikggg at gmail.com> wrote:
> Hello Matthew,
> The same happened for:
> PetscReal   loc[]  = { 0.0,  2.0,  1.0,
>                            1.0, -2.0, -3.0,
>                           -1.0,  1.0,  2.0};
> PetscReal   b_array[] = { -8.0,
>                                     0.0,
>                                     3.0};
> And this time I checked the matrix to be non-singular(determinant=1). I am
> again getting (inf, inf, inf) as the solution.
> On running with -ksp_converged_reason the following message comes:
> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
> PCSETUP_FAILED due to FACTOR_NUMERIC_ZEROPIVOT
> 1) Always check the return code of every call using CHKERRQ(ierr)
> 2) You get Info because x I'd uninitialized and the solve failed
> 3) You are using LU but have a zero on the diagonal. Use -pc_type jacobi
> and it will work
>    Matt
> I am once again appending the whole code for reference.
> Thanks.
> static char help[] = "KSP try.\n\n";
> #include "petsc.h"
> #include "petscksp.h"
> int main(int argc, char *argv[])
>     /// matrix creation variables.
>     PetscInt    *idxm = new PetscInt[3];
>     PetscInt    *idxn = new PetscInt[3];
>                                  1.0, -2.0, -3.0,
>                                 -1.0,  1.0,  2.0};
>                                0.0,
>                                3.0};
>     PetscInt i;
>     KSP      ksp;
>     /// Declaring the vectors
>     Vec     x, b;
>     // Declaring matrices
>     Mat A;
>     PetscInitialize(&argc,&argv,(char*)0,help);
>     // Creating vectors
>     VecCreateSeq(PETSC_COMM_SELF, 3, &x);
>     VecCreateSeq(PETSC_COMM_SELF, 3, &b);
>     // Creating matrix
>     MatCreateSeqAIJ(PETSC_COMM_SELF, 3, 3, 3, NULL, &A);
>     // Creating the indices
>     for(i=0; i<3; i++) {
>         idxm[i] = i;
>         idxn[i] = i;
>     // Assembling the vector b and x
>     VecSetValues(b, 3, idxm, b_array, INSERT_VALUES);
>     VecAssemblyBegin(b);
>     VecAssemblyEnd(b);
>     //Assembling the Matrix
>     MatSetValues(A, 3, idxm, 3, idxn, loc, INSERT_VALUES);
>     MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>     MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>     // KSP related operations
>     KSPCreate(PETSC_COMM_SELF, &ksp);
>     KSPSetType(ksp, KSPGMRES);
>     KSPSetOperators(ksp, A, A);
>     KSPSetFromOptions(ksp);
>     KSPSolve(ksp,b,x);
>     KSPDestroy(&ksp);
>     VecView(x, PETSC_VIEWER_STDOUT_SELF);
>     PetscFinalize();
>     return 0;
> }//End of file
> On Sat, Apr 8, 2017 at 7:01 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Apr 8, 2017 at 8:26 AM, Kaushik Kulkarni <kaushikggg at gmail.com>
>> wrote:
>>> I guess there is a miscalculation:
>>> 2*row1 + row2 = (4, 0, 0)
>> You are right here, but I think it is still rank deficient.
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Kaushik
>>> On Apr 8, 2017 6:52 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
>>> On Sat, Apr 8, 2017 at 6:54 AM, Kaushik Kulkarni <kaushikggg at gmail.com>
>>> wrote:
>>>> Hello,
>>>> I just started with PETSc and was trying the KSP Solvers. I was trying
>>>> for the problem -
>>> Note that the problem below is rank deficient (2 * row 1 + row 2 = 0).
>>> Its not clear to me whether b is
>>> in the range space of the operator.
>>>   Thanks,
>>>     Matt
>>>>     PetscReal   loc[]  = { 1.0, -2.0, -6.0,
>>>>                                    2.0,  4.0, 12.0,
>>>>                                    1.0, -4.0,-12.0};
>>>>     PetscReal   b_array[] = {  12.0,
>>>>                               -17.0,
>>>>                                22.0};
>>>>     PetscInt i;
>>>>     KSP      ksp;
>>>>     Vec     x, b;
>>>>     Mat A;
>>>>     // Creating vectors
>>>>     // Creating matrix
>>>>         idxm[i] = i;
>>>>         idxn[i] = i;
>>>>     VecAssemblyEnd(b);
>>>>     KSPSolve(ksp,b,x);
>>>>     KSPDestroy(&ksp);
>>>>     PetscFinalize();
>>>>     return 0;
>>>> But the obtained solution is found out to be- (inf, inf, inf).
>>>> I wanted to know whether I am doing something wrong or is the problem
>>>> inherently not solvable using GMRES. Currently I am running the code in a
>>>> sequential manner(no parallelism intended).
>>>> Thank you.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> Kaushik Kulkarni
> Fourth Year Undergraduate
> Department of Mechanical Engineering
> Indian Institute of Technology Bombay
> Mumbai, India
> https://kaushikcfd.github.io/About/
> +91-9967687150 <+91%2099676%2087150>
Kaushik Kulkarni
Mumbai, India
+91-9967687150
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170408/4d00f13e/attachment-0001.html>
