[petsc-users] examples of DMPlex*FVM methods
Jed Brown jed at jedbrown.org
Wed Apr 5 12:03:46 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> As a side note, I think using FV to solve an elliptic equation should be a
> felony. Continuous FEM is excellent for this, whereas FV needs
> a variety of twisted hacks and is always worse in terms of computation and
> accuracy.
Unless you need exact (no discretization error) local conservation,
e.g., for a projection in a staggered grid incompressible flow problem,
in which case you can use either FV or mixed FEM (algebraically
equivalent to FV in some cases).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170405/58b6e25f/attachment.pgp>
