[petsc-users] examples of DMPlex*FVM methods
Wed Apr 5 11:56:46 CDT 2017
On Wed, Apr 5, 2017 at 11:50 AM, Ingo Gaertner <ingogaertner.tus at gmail.com>
wrote:
> Hi Jed,
> thank you for your reply. Two followup questions below:
> 2017-04-04 22:18 GMT+02:00 Jed Brown <jed at jedbrown.org>:
>> Ingo Gaertner <ingogaertner.tus at gmail.com> writes:
>> > We have never talked about Riemann solvers in our CFD course, and I
>> don't
>> > understand what's going on in ex11.
>> > However, if you could answer a few of my questions, you'll give me a
>> good
>> > start with PETSc. For the simple poisson problem that I am trying to
>> > implement, I have to discretize div(k grad u) integrated over each FV
>> cell,
>> > where k is the known diffusivity, and u is the vector to solve for.
>> Note that ex11 solves hyperbolic conservation laws, but you are solving
>> an elliptic equation.
> I begin to understand. Petscs FVM methods don't provide a FVM library that
> can be used to implement the FV control volume approach (see Ferziger) for
> general CFD problems? They are around just because they have been used to
> tackle one or two specific problems, is this correct?
> I thought they could be used similar to the OpenFvm or OpenFoam libraries
> which seem to solve Poisson, Navier-Stokes, Euler and other problems. If
> such methods have not been prepared for Petsc, I'll just follow Ferzigers
> book and start my work on a lower level than I thought would be necessary.
> More work, more fun :)
Yes, that is correct.
As a side note, I think using FV to solve an elliptic equation should be a
felony. Continuous FEM is excellent for this, whereas FV needs
a variety of twisted hacks and is always worse in terms of computation and
accuracy. Hyperbolic problems are what FV is designed for
and I don't think I would ever support it for anything but that.
    Matt
> > (My second question is more general about the PETSc installation. When I
>> > configure PETSc with "--prefix=/somewhere --download-triangle
>> > --download-parmetis" etc., these extra libraries are built correctly
>> during
>> > the make step, but they are not copied to /somewhere during the "make
>> > install" step.
>> Where are they put during configure?
> My bad, Petsc installation works as expected. But the build system that I
> am using is doing something weird. I'll have to find out, what's going
> wrong there, but it is not related to Petsc.
> Thank you!
> Ingo
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virenfrei.
> www.avast.com
> <#m_-9031669297911553285_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170405/a8ddc62a/attachment-0001.html>
