[petsc-users] Understanding DMPlexDistribute overlap
Francesco Caimmi francesco.caimmi at polimi.it
Wed Apr 5 04:27:37 CDT 2017
Dear all,
I was playing with DMPlex objects and I was trying to exactly figure out what
the `overlap` parameter in DMPlexDistribute does.
From the tutorial "Flexible, Scalable Mesh and Data Management
using PETSc DMPlex" (slide 10) and from the work by Knepley et al.
"Unstructured Overlapping Mesh Distribution in Parallel" I somehow got the
idea that it should control the "depth" of the mesh overlap.
That is, given the partition boundary, if overlay is set to 0 only the
entities adjacent (in the DMPlex topological sense and with the "style" defined
by the AdjacencyUse routines) to entities at the boundary are shared, if
overlay is 1 the first and the second neighbors (always in the DMPlex
topological sense) are shared and so on, up to the point were we have a full
duplicate of the mesh on each process (i.e. there is no upper bound on
`overlap`).
Is this correct or am I -totally- misunderstanding the meaning of the
parameter?
I am asking this because I see some behavior I cannot explain at varying the
value of the overlap, but before going into the details I would like to be
sure to understand  exactly what the overlap parameter is supposed to do.
Many thanks,
Francesco Caimmi
Laboratorio di Ingegneria dei Polimeri
http://www.chem.polimi.it/polyenglab/
Politecnico di Milano - Dipartimento di Chimica,
Materiali e Ingegneria Chimica “Giulio Natta”
P.zza Leonardo da Vinci, 32
I-20133 Milano
Tel. +39.02.2399.4711
Fax +39.02.7063.8173
Skype: fmglcaimmi (please arrange meetings by e-mail)
