[petsc-users] Correlation between da_refine and pg_mg_levels
Jed Brown jed at jedbrown.org
Sun Apr 2 11:29:38 CDT 2017
Justin Chang <jychang48 at gmail.com> writes:
> Thanks guys,
> So I want to run SNES ex48 across 1032 processes on Edison,
How did you decide on 1032 processes?  What shape did the DMDA produce?
Of course this should work, but we didn't explicitly test that in the
paper since we were running on BG/P.
  https://github.com/jedbrown/tme-ice/tree/master/shaheen/b
> but I keep getting segmentation violations. These are the parameters I
> am trying:
> srun -n 1032 -c 2 ./ex48 -M 80 -N 80 -P 9 -da_refine 1 -pc_type mg
> -thi_mat_type baij -mg_coarse_pc_type gamg
> The above works perfectly fine if I used 96 processes. I also tried to use
> a finer coarse mesh on 1032 but the error persists.
> Any ideas why this is happening? What are the ideal parameters to use if I
> want to use 1k+ cores?
> Thanks,
> Justin
> On Fri, Mar 31, 2017 at 12:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> >> Yeah based on my experiments it seems setting pc_mg_levels to $DAREFINE
>> + 1
>> >> has decent performance.
>> >> 1) is there ever a case where you'd want $MGLEVELS <= $DAREFINE? In
>> some of
>> >> the PETSc tutorial slides (e.g., http://www.mcs.anl.gov/
>> >> petsc/documentation/tutorials/TutorialCEMRACS2016.pdf on slide 203/227)
>> >> they say to use $MGLEVELS = 4 and $DAREFINE = 5, but when I ran this, it
>> >> was almost twice as slow as if $MGLEVELS >= $DAREFINE
>> > Smaller coarse grids are generally more scalable -- when the problem
>> > data is distributed, multigrid is a good solution algorithm.  But if
>> > multigrid stops being effective because it is not preserving sufficient
>> > coarse grid accuracy (e.g., for transport-dominated problems in
>> > complicated domains) then you might want to stop early and use a more
>> > robust method (like direct solves).
>> Basically for symmetric positive definite operators you can make the
>> coarse problem as small as you like (even 1 point) in theory. For
>> indefinite and non-symmetric problems the theory says the "coarse grid must
>> be sufficiently fine" (loosely speaking the coarse grid has to resolve the
>> eigenmodes for the eigenvalues to the left of the x = 0).
>> https://www.jstor.org/stable/2158375?seq=1#page_scan_tab_contents
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170402/c149fa92/attachment.pgp>
