[petsc-users] How to get a matrix and vector for a coupled system of equations?
Rolf Kuiper kuiper at mpia.de
Mon Nov 28 04:43:57 CST 2016
Hi Dave,
Thanks a lot for your prompt reply! This is even easier than I thought (and that is most likely the reason, why I could not think into this direction) :)
And yes, I might/should upgrade our PETSc version used (3.1), but it will take me some days to check the full code package.
Now, I will create my DA (now in 3.6 called DMDA) for the coupled system via
DACreate3d(PETSC_COMM_WORLD, Periodicity, DA_STENCIL_BOX, Nx, Ny, Nz, Px, Py, Pz, 4, 1, lx, ly, lz, &MyDA);
instead of
DACreate3d(PETSC_COMM_WORLD, Periodicity, DA_STENCIL_BOX, Nx, Ny, Nz, Px, Py, Pz, 1, 1, lx, ly, lz, &MyDA);
which I have used for the single equation.
I would like to ask one follow-up question:
Currently, I loop over my matrix (and vectors) via three for-loops over the 3 spatial directions, and set the columns indices in the following way:
for(k){
        row.k    = k;
        col[0].k = k;
        col[1].k = k;
        col[2].k = k;
        col[3].k = k;
        col[4].k = k+1;
        col[5].k = k-1;
        for(j){
            row.j    = j;
            col[0].j = j;
            col[1].j = j;
            col[2].j = j+1;
            col[3].j = j-1;
            col[4].j = j;
            col[5].j = j;
            for(i){
                row.i    = i;
                col[0].i = i+1;
                col[1].i = i-1;
                col[2].i = i;
                col[3].i = i;
                col[4].i = i;
                col[5].i = i;
Now for the coupled equations, I should overall additionally loop over the number of DOFs (just 2 in my previous email example). Could you give me an easy example or pseudo-code for the associated assignment of columns (I have the same stencil in each of the submatrices, so for the 2 DOFs in 3D, I would get 7+6=13 column entries per row)? Or can you link me to an existing example within the PETSc help?
Again, Thanks a lot!
Rolf
> Am 24.11.2016 um 22:30 schrieb Dave May <dave.mayhem23 at gmail.com>:
> When you create the DMDA, set the number of DOFs (degrees of freedom) per point to be 2 instead of 1.
> You must be using and ancient version of petsc given the function names you quoted. Consider upgrading to 3.7
> Thanks,
>   Dave
> On Thu, 24 Nov 2016 at 20:24, Rolf Kuiper <kuiper at mpia.de <mailto:kuiper at mpia.de>> wrote:
> Dear PETSc users,
> maybe this is an easy question, but I can’t find the information right away in the user’s guide nor online.
> What I am currently doing and which works fine:
> To solve a partial differential equation for the quantity q on a parallel distributed grid, which is represented by the Distributed Array MyDA, I am currently creating the associated sparse matrix for the KSP solver via
> DAGetMatrix(MyDA, MATMPIAIJ, &MyMatrix);
> The solution vector and right hand side vector are created via
> DACreateGlobalVector(MyDA, &MyRightHandSideVector);
> VecDuplicate(MyRightHandSideVector, &GlobalSolutionVector);
> The DA is constructed using DACreate3d() with the corresponding regular structured grid information.
> And here is my problem:
> Now, I would like to solve a coupled system of equations for the quantities q1 and q2 on the same grid. I.e., the matrix should just get the double number of rows and columns, the vectors contain twice the number of entries (e.g. first all q1s and then all q2s). And I would like to be sure that the entries of q1 and q2, which are associated with the same grid cell are located on the same processor.
> Is there already a pre-defined structures available (such as MATMPIAIJ) within PETSc to enlarge such a single equation to store the entries of coupled equations? Such as
> DACreateTwiceTheGlobalVector()?
> The equation is (simplified) of the form
> d/dt q1 + grad q2 = 0
> d/dt q2 + f(q1) = 0
> with an arbitrary function f depending on q1.
> Thanks a lot for your help in advance,
> Rolf
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161128/29d06f44/attachment.html>
