[petsc-users] How to get a matrix and vector for a coupled system of equations?
Dave May dave.mayhem23 at gmail.com
Thu Nov 24 15:30:32 CST 2016
When you create the DMDA, set the number of DOFs (degrees of freedom) per
point to be 2 instead of 1.
You must be using and ancient version of petsc given the function names you
quoted. Consider upgrading to 3.7
Dave
On Thu, 24 Nov 2016 at 20:24, Rolf Kuiper <kuiper at mpia.de> wrote:
> Dear PETSc users,
> maybe this is an easy question, but I can’t find the information right
> away in the user’s guide nor online.
> What I am currently doing and which works fine:
> To solve a partial differential equation for the quantity q on a parallel
> distributed grid, which is represented by the Distributed Array MyDA, I am
> currently creating the associated sparse matrix for the KSP solver via
> DAGetMatrix(MyDA, MATMPIAIJ, &MyMatrix);
> The solution vector and right hand side vector are created via
> DACreateGlobalVector(MyDA, &MyRightHandSideVector);
> VecDuplicate(MyRightHandSideVector, &GlobalSolutionVector);
> The DA is constructed using DACreate3d() with the corresponding regular
> structured grid information.
> And here is my problem:
> Now, I would like to solve a coupled system of equations for the
> quantities q1 and q2 on the same grid. I.e., the matrix should just get the
> double number of rows and columns, the vectors contain twice the number of
> entries (e.g. first all q1s and then all q2s). And I would like to be sure
> that the entries of q1 and q2, which are associated with the same grid cell
> are located on the same processor.
> Is there already a pre-defined structures available (such as MATMPIAIJ)
> within PETSc to enlarge such a single equation to store the entries of
> coupled equations? Such as
> DACreateTwiceTheGlobalVector()?
> The equation is (simplified) of the form
> d/dt q1 + grad q2 = 0
> d/dt q2 + f(q1) = 0
> with an arbitrary function f depending on q1.
> Thanks a lot for your help in advance,
> Rolf
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161124/b39576f2/attachment.html>
