[petsc-users] SNES Multblock type
Arthur Besen Soprano arthursoprano at gmail.com
Fri Nov 25 14:38:03 CST 2016
I was just recently checking some of snes sources code and found a
src\snes\impls\multiblock\multiblock.c which seemed to be a Non-linear (SNES)
equivalent of the fieldsplit for linear problems (KSP). However I was not
able to use it and did not see any options available with the "-help "
argument.
My question is: Is this module disabled? If not, how can I use it?
(using -snes_type multiblock or -npc_snes_type multiblock does not work...)
Arthur
Arthur B. Soprano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161125/51d99e34/attachment.html>
