[petsc-users] What are the differences between ex11.c and ex11_sa.c
Fri Nov 25 10:03:30 CST 2016
On Fri, Nov 25, 2016 at 9:09 AM, leejearl <leejearl at 126.com> wrote:
> Hi, Matt:
>     Thank you for your kind reply, and I can not make it.
> I replace the code in the routine SetInitialCondition in ex11.c as
> #undef __FUNCT__
> #define __FUNCT__ "SetInitialCondition"
> PetscErrorCode SetInitialCondition(DM dm, Vec X, User user)
>   DM                 dmCell;
>   Model              mod = user->model;
>   Vec                cellgeom;
>   const PetscScalar *cgeom;
>   PetscScalar       *x;
>   PetscInt           cStart, cEnd, cEndInterior, c;
>   PetscErrorCode     ierr;
>   PetscFunctionBeginUser;
>   ierr = DMPlexGetHybridBounds(dm, &cEndInterior, NULL, NULL,
> NULL);CHKERRQ(ierr);
>   ierr = DMPlexTSGetGeometryFVM(dm, NULL, &cellgeom, NULL);CHKERRQ(ierr);
>   ierr = VecGetDM(cellgeom, &dmCell);CHKERRQ(ierr);
>   ierr = DMPlexGetHeightStratum(dm, 0, &cStart, &cEnd);CHKERRQ(ierr);
>   ierr = VecGetArrayRead(cellgeom, &cgeom);CHKERRQ(ierr);
>   ierr = VecGetArray(X, &x);CHKERRQ(ierr);
>   for (c = cStart; c < cEndInterior; ++c) {
>     const PetscFVCellGeom *cg;
>     PetscScalar    *xc;
>     ierr = DMPlexPointLocalRead(dmCell,c,cgeom,&cg);CHKERRQ(ierr);
>     ierr = DMPlexPointGlobalRef(dm,c,x,&xc);CHKERRQ(ierr);
>     /*if (xc) {ierr = (*mod->solution)(mod,0.0,cg->
> centroid,xc,mod->solutionctx);CHKERRQ(ierr);}*/
>     xc[0] = =1.0;
>     xc[1] = =2.0;
>     xc[2] = =3.0;
>     xc[3] = =4.0;
>   ierr = VecRestoreArrayRead(cellgeom, &cgeom);CHKERRQ(ierr);
>   ierr = VecRestoreArray(X, &x);CHKERRQ(ierr);
>   PetscFunctionReturn(0);
> I find it works in serial computation. Can you tell me whether I have a
> wrong use of the xc in the routine?
If you want to initialize 4 fields to the constants 1, 2, 3, 4 then this
should work.
   Matt
> Thanks
> leejearl
> On 2016年11月25日 22:53, Matthew Knepley wrote:
> On Fri, Nov 25, 2016 at 8:43 AM, leejearl <leejearl at 126.com> wrote:
>> Hello, Petsc developer:
>>     I find two files ex11.c and ex11_sa.c in the directory of
>> "/petsc/src/ts/examples/tutorials".
>> Can you tell me what are the differences between them? What is the
>> meaning of the “suffix”?
> I think Jed wanted his original version, but I don'y know what _sa means.
>   Thanks,
>     Matt
>>    Thanks!
>> leejearl
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161125/a83852e8/attachment.html>
