[petsc-users] A question of DMPlexGetAdjacency
leejearl leejearl at 126.com
Tue Nov 15 01:00:42 CST 2016
Hi Lawrence:
     Thank you for your prompt reply.  It works well, but I encounter
another problem.
  The code is as follows:
         PetscScalar *arrayConVar, *arrayDeltaX, *arrayDeltaY;
         ierr = DMPlexGetAdjacency(dm, c, &adjSize, &adj); CHKERRQ(ierr);
         /*PetscSynchronizedPrintf(PETSC_COMM_WORLD, "adjSize = %d\n",
adjSize);*/
         adjSizeInterior = -1;
         for(i = 0; i < adjSize; i++)
             if(adj[i] < cEndInterior)
                 adjSizeInterior++;
                 /*PetscSynchronizedPrintf(PETSC_COMM_WORLD, "adj[%d]=
%d\n", i, adj[i]);*/
         PetscSynchronizedPrintf(PETSC_COMM_WORLD, "adjSizeInterior =
%d\n", adjSizeInterior);
         PetscSynchronizedFlush(PETSC_COMM_WORLD,PETSC_STDOUT);
         ierr = PetscMalloc3(adjSizeInterior*4, &arrayConVar,
adjSizeInterior, &arrayDeltaX, adjSizeInterior, &arrayDeltaY);
CHKERRQ(ierr);
         PetscFree3(arrayConVar, arrayDeltaX, arrayDeltaY); CHKERRQ(ierr);
         ierr = PetscFree(adj); CHKERRQ(ierr);
The error messages are like as :
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Invalid mesh exceeded adjacency allocation (0)
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-1864-ga10654c
GIT Date: 2016-11-01 22:25:06 -0500
[0]PETSC ERROR: ./cavity on a arch-linux2-c-debug named leejearl by
leejearl Tue Nov 15 14:48:57 2016
[0]PETSC ERROR: Configure options --prefix=/home/leejearl/Install/Petsc
--with-mpi-dir=/home/leejearl/Install/openmpi/1.8.5_gnu
--download-exodusii=../externalpackages/exodus-5.24.tar.bz2
--download-netcdf=../externalpackages/netcdf-4.3.2.tar.gz
--download-hdf5=../externalpackages/hdf5-1.8.12.tar.gz
--download-triangle=../externalpackages/Triangle.tar.gz
--download-sowing=../externalpackages/git.sowing.tar.gz
[0]PETSC ERROR: #1 DMPlexGetAdjacency_Cone_Internal() line 193 in
/home/leejearl/Software/petsc/petsc/src/dm/impls/plex/plexdistribute.c
[0]PETSC ERROR: #2 DMPlexGetAdjacency_Internal() line 298 in
[0]PETSC ERROR: #3 DMPlexGetAdjacency() line 372 in
[0]PETSC ERROR: #4 CalcConVarGradient() line 126 in
/home/leejearl/Desktop/PETSc/GKSCavity_Petsc/cavity.c
It is very strange that PetscMalloc3 can arouse such an error. If I
comment the statement relative with PetscMalloc3, it is ok! I can not
understand what happened.
Can anyone figure me out the problems of my codes?
I attach the code and the grid, so you can compile in your workstation.
Thanks
leejearl
On 2016年11月14日 23:09, Lawrence Mitchell wrote:
>> On 14 Nov 2016, at 14:59, leejearl <leejearl at 126.com> wrote:
>> Hi all:
>>     I am not sure the using of the function "DMPlexGetAdjacency".
>>     My codes are as follows:
>>     PetscInt adj, *adjSize=NULL;
>>     ierr = DMPlexGetAdjacency(dm, p,  &adj, &adj);
> Your calling sequence is wrong:
> PetscInt adjSize;
> PetscInt *adj = NULL;
> ierr = DMPlexGetAdjacency(dm, p, &adjSize, &adj); CHKERRQ(ierr);
> adjSize is now the size of the adj array.  You should remember to free it afterwards:
> /* use adj here *
> Lawrence
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161115/73231b2a/attachment-0001.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161115/73231b2a/attachment-0001.obj>
All: cavity
CFLAGS	        =
FFLAGS	        =
CPPFLAGS        =
FPPFLAGS        =
LOCDIR          = ./
EXAMPLESC       = cavity.c
MANSEC          = DM
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
cavity: cavity.o  chkopts
	-${CLINKER} -o cavity cavity.o ${PETSC_DM_LIB}
	${RM} -f cavity.o
include ${PETSC_DIR}/lib/petsc/conf/test
