[petsc-users] A question of DMPlexGetAdjacency
leejearl leejearl at 126.com
Mon Nov 14 18:51:33 CST 2016
Hi, Lawrence:
     Thank you for your kind reply. I have modified by codes following
your advices.
Now, it works well.
     Many thanks for your helps.
leejearl
On 2016年11月14日 23:09, Lawrence Mitchell wrote:
>> On 14 Nov 2016, at 14:59, leejearl <leejearl at 126.com> wrote:
>> Hi all:
>>     I am not sure the using of the function "DMPlexGetAdjacency".
>>     My codes are as follows:
>>     PetscInt adj, *adjSize=NULL;
>>     ierr = DMPlexGetAdjacency(dm, p,  &adj, &adj);
> Your calling sequence is wrong:
> PetscInt adjSize;
> PetscInt *adj = NULL;
> ierr = DMPlexGetAdjacency(dm, p, &adjSize, &adj); CHKERRQ(ierr);
> adjSize is now the size of the adj array.  You should remember to free it afterwards:
> /* use adj here *
> ierr = PetscFree(adj); CHKERRQ(ierr);
> Lawrence
