[petsc-users] PetscFE and TS
Julian Andrej juan at tf.uni-kiel.de
Mon Nov 14 03:24:43 CST 2016
I think i'm understanding the concept now. Although i have another set
of questions. If i am formulating a DAE (like in the linear stokes
equation for example) it seems i am missing something to formulate the
correct jacobian. The residual formulation with snes_mf or snes_fd
works fine in terms of nonlinear convergence. If i use the hand coded
jacobian the convergence is way slower, which is a reason for an
incorrect jacobian formulation from my side (at least what i think
right now). I should be able to test my jacobian with -snes_type test,
even if i am using TS, right? This gives me a huge difference. I guess
i am missing something in the formulation and thus in the
implementation of the callbacks here.
There is a small example attached.
I appreciate your time and help.
On Thu, Nov 10, 2016 at 4:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Nov 10, 2016 at 9:38 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> > On Thu, Nov 10, 2016 at 1:31 AM, Julian Andrej <juan at tf.uni-kiel.de>
>> > wrote:
>> >> I'm getting the correct solution now, thanks! There are still a few
>> >> open questions.
>> >> 1. The mass term is necessary _and_ using the u_tShift value if i
>> >> provide the jacobian. After reading the manual countless times, i
>> >> still don't get what the u_tShift value tells me in this context. Are
>> >> there any resources which you could point me to?
>> > The manual is always a lagging resource because we are trying things
>> > out.
>> This has been explained in the manual similarly to your email for
>> several years.  If anyone has a suggestion for how to make it better,
>> we'd like to hear.  The typical syndrome is that once you learn it, the
>> description suddenly makes sense and you wonder why you were ever
>> confused.  It takes feedback from people just learning the material to
>> make the explanation more clear.
>> > I learned about this by reading examples. The idea is the
>> > following. We have an implicit definition of our timestepping method
>> >   F(u, grad u, u_t, x, t) = 0
>> It doesn't make sense to write grad u as a separate argument here.
> Sorry, that is just how I think of it, not the actual interface.
>> Also, is `x` meant to be coordinates or some other statically prescribed
> Coordinates, as distinct from u. Again this is my fault.
>> data?  It can't be actively changing if you expect a generic TS to be
>> convergent.  (It's not an argument to the function.)  So really, you
>> have:
>>   F(u, u_t, t) = 0
>> > which is not unlike a Lagrangian description of a mechanical system. The
>> > Jacobian can be considered
>> > formally to have two parts,
>> >   dF/du and dF/du_t
>> > just as in the Lagrangian setting. The u_tShift variable is the
>> > multiplier
>> > for dF/du_t so that you actually
>> > form
>> >   dF/du + u_tShift dF/du_t
>> We're taking the total derivative of F with respect to u where u_t has
>> been _defined_ as an affine function of u, i.e., shift*u+affine.
>> u_tShift comes from the chain rule.  When computing the total
>> derivative, we have
>>   dF/du + dF/du_t du_t/du.
>> >> 2. Is DMProjectFunction necessary _before_ TSSolve? This acts like an
>> >> initial condition if i'm not mistaken.
>> > Yes, this is the initial condition.
>> >> 3. A more in depth question i guess. Where is the "mass action"
>> >> formed? As i could see by stepping through the debugger, there is just
>> >> a formed action for the residual equation. It seems way over my
>> >> understanding how this formulation works out. I'd also appreciate
>> >> resources on that if thats possible.
>> > Jed is the only one who understands this completely.
>> That's a stretch -- several other people have developed sophisticated TS
>> implementations.
> Matt does not understand this completely.
>> > However, I guess by "mass action" you mean the dF/du_t term. In the
>> > explicit methods, you just have u_t + ..., so
>> >   dF/du_t = M
>> > for finite element methods. So you are putting that there in
>> > FormIJacobian(). In the simplest
>> > case of backwards Euler then u_tShift would be 1/dt.
>> Specifically, for implicit methods, and many semi-implicit methods, we
>> don't need M separate.
> Yes.
>    Matt
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161114/2124fb4e/attachment-0001.c>
