[petsc-users] PetscFE and TS
Thu Nov 10 09:45:33 CST 2016
On Thu, Nov 10, 2016 at 9:38 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Thu, Nov 10, 2016 at 1:31 AM, Julian Andrej <juan at tf.uni-kiel.de>
> wrote:
> >> I'm getting the correct solution now, thanks! There are still a few
> >> open questions.
> >> 1. The mass term is necessary _and_ using the u_tShift value if i
> >> provide the jacobian. After reading the manual countless times, i
> >> still don't get what the u_tShift value tells me in this context. Are
> >> there any resources which you could point me to?
> > The manual is always a lagging resource because we are trying things
> > out.
> This has been explained in the manual similarly to your email for
> several years.  If anyone has a suggestion for how to make it better,
> we'd like to hear.  The typical syndrome is that once you learn it, the
> description suddenly makes sense and you wonder why you were ever
> confused.  It takes feedback from people just learning the material to
> make the explanation more clear.
> > I learned about this by reading examples. The idea is the
> > following. We have an implicit definition of our timestepping method
> >   F(u, grad u, u_t, x, t) = 0
> It doesn't make sense to write grad u as a separate argument here.
Sorry, that is just how I think of it, not the actual interface.
> Also, is `x` meant to be coordinates or some other statically prescribed
Coordinates, as distinct from u. Again this is my fault.
> data?  It can't be actively changing if you expect a generic TS to be
> convergent.  (It's not an argument to the function.)  So really, you
> have:
>   F(u, u_t, t) = 0
> > which is not unlike a Lagrangian description of a mechanical system. The
> > Jacobian can be considered
> > formally to have two parts,
> >   dF/du and dF/du_t
> > just as in the Lagrangian setting. The u_tShift variable is the
> multiplier
> > for dF/du_t so that you actually
> > form
> >   dF/du + u_tShift dF/du_t
> We're taking the total derivative of F with respect to u where u_t has
> been _defined_ as an affine function of u, i.e., shift*u+affine.
> u_tShift comes from the chain rule.  When computing the total
> derivative, we have
>   dF/du + dF/du_t du_t/du.
> >> 2. Is DMProjectFunction necessary _before_ TSSolve? This acts like an
> >> initial condition if i'm not mistaken.
> > Yes, this is the initial condition.
> >> 3. A more in depth question i guess. Where is the "mass action"
> >> formed? As i could see by stepping through the debugger, there is just
> >> a formed action for the residual equation. It seems way over my
> >> understanding how this formulation works out. I'd also appreciate
> >> resources on that if thats possible.
> > Jed is the only one who understands this completely.
> That's a stretch -- several other people have developed sophisticated TS
> implementations.
Matt does not understand this completely.
> > However, I guess by "mass action" you mean the dF/du_t term. In the
> > explicit methods, you just have u_t + ..., so
> >   dF/du_t = M
> > for finite element methods. So you are putting that there in
> > FormIJacobian(). In the simplest
> > case of backwards Euler then u_tShift would be 1/dt.
> Specifically, for implicit methods, and many semi-implicit methods, we
> don't need M separate.
Yes.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161110/a9828a4a/attachment.html>
