[petsc-users] TS prestep function
Christian Peco Regales, Ph.D. cp226 at duke.edu
Wed Mar 30 14:13:06 CDT 2016
Dave, Hong, thank you. Setting and getting the context from TS is definitely the way to go, as I have to compute an exchange of particle forces and geometry information. Working fine now.
Christian
_______________________________
Postdoctoral Research Associate
Civil and Environmental Engineering
Pratt School of Engineering
Duke University
2407 CIEMAS (office)
Durham, NC 27708, USA
email: christian.peco at duke.edu
web: http://www.christianpeco.com<http://christianpeco.com>
Sent: Wednesday, March 30, 2016 2:38 PM
To: Christian Peco Regales, Ph.D.
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] TS prestep function
On 30 March 2016 at 19:54, Christian Peco Regales, Ph.D. <cp226 at duke.edu<mailto:cp226 at duke.edu>> wrote:
I have started to use the TS environment to solve a diffusion problem with XFEM in which, at the beginning of every step, a number of values have to be recomputed in order to properly fill the Jacobian (e.g. change some quadrature weights). However, I see that the the function is expected with the format func(TS ts), with no possibility of getting a user context to perform the computations I need.
There are a number of ways to get around this:
[1] Set an application context on the TS
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetApplicationContext.html
and retrieve via
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSGetApplicationContext.html
[2] It sounds like your information is related to geometry, so you could bundle it into a DM and use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetDM.html
[3] The "nastiest" way is to use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscContainerCreate.html#PetscContainerCreate
and then compose the PetscContainer object with the TS object via
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObjectCompose.html
  Dave
Is there a way to get around that? Thanks!
Christian
Duke University
email: christian.peco at duke.edu<mailto:christian.peco at duke.edu>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160330/6c6f948b/attachment-0001.html>
