[petsc-users] TS prestep function
Dave May dave.mayhem23 at gmail.com
Wed Mar 30 13:38:32 CDT 2016
On 30 March 2016 at 19:54, Christian Peco Regales, Ph.D. <cp226 at duke.edu>
wrote:
> I have started to use the TS environment to solve a diffusion problem with
> XFEM in which, at the beginning of every step, a number of values have to
> be recomputed in order to properly fill the Jacobian (e.g. change some
> quadrature weights). However, I see that the the function is expected with
> the format func(TS ts), with no possibility of getting a user context to
> perform the computations I need.
There are a number of ways to get around this:
[1] Set an application context on the TS
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetApplicationContext.html
and retrieve via
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSGetApplicationContext.html
[2] It sounds like your information is related to geometry, so you could
bundle it into a DM and use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetDM.html
[3] The "nastiest" way is to use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscContainerCreate.html#PetscContainerCreate
and then compose the PetscContainer object with the TS object via
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObjectCompose.html
  Dave
> Is there a way to get around that? Thanks!
> Christian
> _______________________________
> Postdoctoral Research Associate
> Civil and Environmental Engineering
> Pratt School of Engineering
> Duke University
> 2407 CIEMAS (office)
> Durham, NC 27708, USA
> email: christian.peco at duke.edu
> web: http://www.christianpeco.com <http://christianpeco.com>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160330/0b0433f7/attachment.html>
