[petsc-users] Norm of RHS in BCGS
Tue Mar 22 08:45:50 CDT 2016
On Tue, Mar 22, 2016 at 8:25 AM, Norihiro Watanabe <norihiro.w at gmail.com>
wrote:
> Thank you Matt!
> Actually I don't want to change a norm type used in a convergence
> check. I just want to output a relative error which PETSc actually
> used for a convergence check (for log output in my program without
> -ksp_*) and thought I need to have a norm of a preconditioned RHS to
> compute it by myself. Or is there any function available in PETSc
> which returns the relative error or the tolerance multiplied by the
> norm of a preconditioned RHS? I couldn't find it.
If you want the action of the preconditioner, you can pull it out
  KSPGetPC()
and apply it
  PCApply()
but I still do not understand why you want this. Do you want to check the
norms
yourself? The PCApply() could be expensive to calculate again.
     Matt
> Best,
> Nori
> On Tue, Mar 22, 2016 at 1:51 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Tue, Mar 22, 2016 at 2:50 AM, Norihiro Watanabe <norihiro.w at gmail.com
> > wrote:
> >> Hi,
> >> Is it correct that a norm of a preconditioned RHS vector is used to
> >> compute a relative error in BCGS?
> > Yes, but you can verify this using -ksp_view
> >> I'm testing BCGS + BoomerAMG. With "-info", PETSc says "initial right
> >> hand side norm" is 2.223619476717e+10 (see below) but an actual norm
> >> of the RHS I passed is 4.059007e-02. If yes, is there any way to get a
> > Do you mean unpreconditioned? You can try
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetNormType.html
> > or use
> >   -ksp_monitor_true_residual
> >   Thanks,
> >     Matt
> >> [0] KSPConvergedDefault(): Linear solver has converged. Residual norm
> >> 2.036064453512e-02 is less than relative tolerance 9.999999960042e-13
> >> times initial right hand side norm 2.223619476717e+10 at iteration 6
> >> Regards,
> >> Nori
> >> Norihiro Watanabe
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
> Norihiro Watanabe
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160322/b20d4642/attachment.html>
