[petsc-users] PetscDSSetJacobianPreconditioner causing DIVERGED_LINE_SEARCH for multi-field problem
Sander Arens Sander.Arens at UGent.be
Mon Mar 21 03:49:28 CDT 2016
Matt,
I think the problem is in DMCreateSubDM_Section_Private. The block size can
be counted there (very similar as in DMCreateMatrix_Plex) and then passed
down to the IS. I can create a pull request for this if you'd like (or
should I just add this to my other pull request for the Neumann bc's)?
On 3 March 2016 at 18:02, Sander Arens <Sander.Arens at ugent.be> wrote:
> Ok, thanks for clearing that up!
> On 3 March 2016 at 18:00, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Mar 3, 2016 at 10:48 AM, Sander Arens <Sander.Arens at ugent.be>
>> wrote:
>>> So is the block size here refering to the dimension of the
>>> near-nullspace or has it something to do with the coarsening?
>>> I would have thought to also see the block size in this part:
>> Dang, that is a problem. It should have the correct block size when FS
>> pulls it out of the overall matrix. This should be
>> passed down using the block size of the IS. Something has been broken
>> here. I will put it on my list of things to look at.
>>   Thanks,
>>     Matt
>>>                   Mat Object:                           1 MPI processes
>>>                   type: seqaij
>>>                   rows=1701, cols=1701
>>>                   total: nonzeros=109359, allocated nonzeros=109359
>>>                   total number of mallocs used during MatSetValues calls
>>> =0
>>>                   has attached near null space
>>>                      using I-node routines: found 567 nodes, limit used
>>> is 5
>>> Thanks,
>>> Sander
>>> On 3 March 2016 at 17:29, Matthew Knepley <knepley at gmail.com> wrote:
>>>> You can see the block size in the output
>>>>                     type: seqaij
>>>>                     rows=12, cols=12, bs=6
>>>>                     total: nonzeros=144, allocated nonzeros=144
>>>> calls =0
>>>>                       using I-node routines: found 3 nodes, limit used
>>>> is 5
>>>>               linear system matrix = precond matrix:
>>>>                 type: seqaij
>>>> =0
>>>>                   using I-node routines: found 3 nodes, limit used is 5
>>>>   Thanks,
>>>>     Matt
>>>> On Thu, Mar 3, 2016 at 10:28 AM, Sander Arens <Sander.Arens at ugent.be>
>>>> wrote:
>>>>> Sure, here it is.
>>>>> Thanks,
>>>>> Sander
>>>>> On 3 March 2016 at 15:33, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Thu, Mar 3, 2016 at 8:05 AM, Sander Arens <Sander.Arens at ugent.be>
>>>>>> wrote:
>>>>>>> Yes, the matrix is created by one of the assembly functions in Plex,
>>>>>>> so that answers my question. I was confused by this because I couldn't see
>>>>>>> this information when using -snes_view.
>>>>>> Hmm, then something is wrong because the block size should be printed
>>>>>> for the matrix at the end of the solver in -snes_view, Can you
>>>>>> send that to me?
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thanks for the helpful replies,
>>>>>>> Sander
>>>>>>> On 3 March 2016 at 14:52, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>>> On Thu, Mar 3, 2016 at 7:49 AM, Sander Arens <Sander.Arens at ugent.be
>>>>>>>> > wrote:
>>>>>>>>> And how can I do this? Because when I look at all the options with
>>>>>>>>> -help I can strangely enough only find -fieldsplit_pressure_mat_block_size
>>>>>>>>> and not -fieldsplit_displacement_mat_block_size.
>>>>>>>> Maybe I am missing something here. The matrix from which you
>>>>>>>> calculate the preconditioner using GAMG must be created somewhere. Why
>>>>>>>> is the block size not specified at creation time? If the matrix is
>>>>>>>> created by one of the assembly functions in Plex, and the PetscSection has
>>>>>>>> a number of field components, then the block size will already be
>>>>>>>> set.
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Thanks,
>>>>>>>>> Sander
>>>>>>>>> On 3 March 2016 at 14:21, Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Thu, Mar 3, 2016 at 6:20 AM, Sander Arens <
>>>>>>>>>>> Ok, I forgot to call SNESSetJacobian(snes, J, P, NULL, NULL)
>>>>>>>>>>> with J != P, which caused to write the mass matrix into the (otherwise
>>>>>>>>>>> zero) (1,1) block of the Jacobian and which was the reason for the
>>>>>>>>>>> linesearch to fail.
>>>>>>>>>>> However, after fixing that and trying to solve it with
>>>>>>>>>>> FieldSplit with LU factorization for the (0,0) block it failed because
>>>>>>>>>>> there were zero pivots for all rows.
>>>>>>>>>>> Anyway, I found out that attaching the mass matrix to the
>>>>>>>>>>> Lagrange multiplier field also worked.
>>>>>>>>>>> Another related question for my elasticity problem: after
>>>>>>>>>>> creating the rigid body modes with DMPlexCreateRigidBody and attaching it
>>>>>>>>>>> to the displacement field, does the matrix block size of the (0,0) block
>>>>>>>>>>> still have to be set for good performance with gamg? If so, how can I do
>>>>>>>>>>> this?
>>>>>>>>>> Yes, it should be enough to set the block size of the
>>>>>>>>>> preconditioner matrix.
>>>>>>>>>>   Matt
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Sander
>>>>>>>>>>> On 2 March 2016 at 12:25, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> On Wed, Mar 2, 2016 at 5:13 AM, Sander Arens <
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> I'm trying to set a mass matrix preconditioner for the Schur
>>>>>>>>>>>>> complement of an incompressible finite elasticity problem. I tried using
>>>>>>>>>>>>> the command PetscDSSetJacobianPreconditioner(prob, 1, 1, g0_pre_mass_pp,
>>>>>>>>>>>>> NULL, NULL, NULL) (field 1 is the Lagrange multiplier field).
>>>>>>>>>>>>> However, this causes a DIVERGED_LINE_SEARCH due to to Nan or
>>>>>>>>>>>>> Inf in the function evaluation after Newton iteration 1. (Btw, I'm using
>>>>>>>>>>>>> the next branch).
>>>>>>>>>>>>> Is this because I didn't use PetscDSSetJacobianPreconditioner
>>>>>>>>>>>>> for the other blocks (which uses the Jacobian itself for preconditioning)?
>>>>>>>>>>>>> If so, how can I tell Petsc to use the Jacobian for those blocks?
>>>>>>>>>>>> 1) I put that code in very recently, and do not even have
>>>>>>>>>>>> sufficient test, so it may be buggy
>>>>>>>>>>>> 2) If you are using FieldSplit, you can control which blocks
>>>>>>>>>>>> come from A and which come from the preconditioner P
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetDiagUseAmat.html#PCFieldSplitSetDiagUseAmat
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetOffDiagUseAmat.html#PCFieldSplitSetOffDiagUseAmat
>>>>>>>>>>>>> I guess when using PetscDSSetJacobianPreconditioner the
>>>>>>>>>>>>> preconditioner is recomputed at every Newton step, so for a constant mass
>>>>>>>>>>>>> matrix this might not be ideal. How can I avoid recomputing this at every
>>>>>>>>>>>>> Newton iteration?
>>>>>>>>>>>> Maybe we need another flag like
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagPreconditioner.html
>>>>>>>>>>>> or we need to expand
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagJacobian.html
>>>>>>>>>>>> to separately cover the preconditioner matrix. However, both
>>>>>>>>>>>> matrices are computed by one call so this would
>>>>>>>>>>>> involve interface changes to user code, which we do not like to
>>>>>>>>>>>> do. Right now it seems like a small optimization.
>>>>>>>>>>>> I would want to wait and see whether it would really be
>>>>>>>>>>>> maningful.
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>     Matt
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Sander
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160321/12c8ab78/attachment-0001.html>
