[petsc-users] AMG preconditioners
Jed Brown jed at jedbrown.org
Wed Mar 9 10:19:14 CST 2016
Manav Bhatia <bhatiamanav at gmail.com> writes:
> Thanks!
> I am intrigued by this.
> I am solving a system of equations where the natural block size is
> 2x2. This is obtained by rewriting a complex linear system of
> equations in real numbers.
What equations are you solving?  Is this system a leading cost in your
application?  (Using complex scalars is another option.  Yes, it's lame
that PETSc can't currently use both in the same library.)
> I use MatSetValuesBlocked to set the values of each 2x2 block in my
> matrix. I am assuming that this method works only for blocked matrix.
No, just call MatSetBlockSize and MatSetValuesBlocked (and variants)
will work for any matrix type.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160309/243dba0a/attachment.pgp>
