[petsc-users] Tao TRON solver tolerances
Justin Chang jychang48 at gmail.com
Tue Mar 8 01:05:45 CST 2016
Hi all,
So I am solving a convex optimization problem of the following form:
min 1/2 x^T*H*x - x^T*f
s.t. 0 < x < 1
Using the TAOTRON solver, I also have CG/ILU for KSP/PC. The following TAO
solver tolerances are used for my specific problem:
-tao_gatol 1e-12
-tao_grtol 1e-7
I noticed that the KSP tolerance truly defines the performance of this
solver. Attached are three run cases with -ksp_rtol 1e-7, 1e-3, and 1e-1
with "-ksp_converged_reason -ksp_monitor_true_residual -tao_view
-tao_converged_reason -log_view". It seems that the lower the KSP
tolerance, the faster the time-to-solution where the number of KSP/TAO
solve iterations remains roughly the same.
So my question is, is this "normal"? That is, if using TRON, one may relax
the KSP tolerances because the convergence of the solver is primarily due
to the objective functional from TRON and not necessarily the KSP solve
itself? Is there a general rule of thumb for this, because it would seem to
me that for any TRON solve I do, i could just set a really low KSP rtol and
still get roughly the same performance.
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160308/9e9ff939/attachment-0001.html>
MESHID = 2
  1 processors:
TSTEP	ANALYSIS TIME	ITER	FLOPS/s
iter =   0, Function value: -8.83019e-08,  Residual: 0.214312
  0 KSP preconditioned resid norm 2.721099185886e+01 true resid norm 2.014138134175e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.869407744459e+00 true resid norm 5.822300398427e-02 ||r(i)||/||b|| 2.890715537151e-01
  2 KSP preconditioned resid norm 2.242110432761e+00 true resid norm 2.437887036293e-02 ||r(i)||/||b|| 1.210387209759e-01
Linear solve converged due to CONVERGED_RTOL iterations 2
iter =   1, Function value: -3.0227,  Residual: 0.106411
  0 KSP preconditioned resid norm 1.186015682827e+01 true resid norm 9.951846352790e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.164408153341e+00 true resid norm 5.442552117697e-02 ||r(i)||/||b|| 5.468886802268e-01
  2 KSP preconditioned resid norm 3.853466576672e+00 true resid norm 4.181722382562e-02 ||r(i)||/||b|| 4.201956334856e-01
  3 KSP preconditioned resid norm 2.431361972872e+00 true resid norm 2.470649935207e-02 ||r(i)||/||b|| 2.482604581726e-01
  4 KSP preconditioned resid norm 1.609420674026e+00 true resid norm 1.813070633647e-02 ||r(i)||/||b|| 1.821843474441e-01
  5 KSP preconditioned resid norm 9.854058612210e-01 true resid norm 1.107435193707e-02 ||r(i)||/||b|| 1.112793701238e-01
Linear solve converged due to CONVERGED_RTOL iterations 5
iter =   2, Function value: -3.99311,  Residual: 0.0561794
  0 KSP preconditioned resid norm 4.745132151277e+00 true resid norm 5.157265414092e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.328460972818e+00 true resid norm 2.524613942204e-02 ||r(i)||/||b|| 4.895256961772e-01
  2 KSP preconditioned resid norm 1.986092654798e+00 true resid norm 2.326548422397e-02 ||r(i)||/||b|| 4.511205523843e-01
  3 KSP preconditioned resid norm 1.581250833192e+00 true resid norm 1.833592737837e-02 ||r(i)||/||b|| 3.555358490620e-01
  4 KSP preconditioned resid norm 1.264530116640e+00 true resid norm 1.498893001019e-02 ||r(i)||/||b|| 2.906371653713e-01
  5 KSP preconditioned resid norm 9.039045119540e-01 true resid norm 1.088737764483e-02 ||r(i)||/||b|| 2.111075690439e-01
  6 KSP preconditioned resid norm 6.770469952665e-01 true resid norm 8.290769243775e-03 ||r(i)||/||b|| 1.607590181634e-01
  7 KSP preconditioned resid norm 4.831932891684e-01 true resid norm 6.012308310732e-03 ||r(i)||/||b|| 1.165793851583e-01
  8 KSP preconditioned resid norm 3.779260278323e-01 true resid norm 4.752323454993e-03 ||r(i)||/||b|| 9.214812644717e-02
Linear solve converged due to CONVERGED_RTOL iterations 8
iter =   3, Function value: -4.22244,  Residual: 0.0325071
  0 KSP preconditioned resid norm 1.940628934982e+00 true resid norm 2.873883700031e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.015778944284e+00 true resid norm 1.553407311454e-02 ||r(i)||/||b|| 5.405254608727e-01
  2 KSP preconditioned resid norm 8.599452198867e-01 true resid norm 1.386942785729e-02 ||r(i)||/||b|| 4.826022659561e-01
  3 KSP preconditioned resid norm 7.020844649773e-01 true resid norm 1.064542414722e-02 ||r(i)||/||b|| 3.704194483272e-01
  4 KSP preconditioned resid norm 6.268936884604e-01 true resid norm 9.121337013737e-03 ||r(i)||/||b|| 3.173871306497e-01
  5 KSP preconditioned resid norm 5.564638147818e-01 true resid norm 8.110633817555e-03 ||r(i)||/||b|| 2.822185816868e-01
  6 KSP preconditioned resid norm 4.912179620266e-01 true resid norm 7.198522694011e-03 ||r(i)||/||b|| 2.504806542427e-01
  7 KSP preconditioned resid norm 3.956512930624e-01 true resid norm 5.694860378165e-03 ||r(i)||/||b|| 1.981590409558e-01
  8 KSP preconditioned resid norm 3.006404654133e-01 true resid norm 4.340865664011e-03 ||r(i)||/||b|| 1.510452793885e-01
  9 KSP preconditioned resid norm 2.289271612498e-01 true resid norm 3.323460860340e-03 ||r(i)||/||b|| 1.156435404921e-01
 10 KSP preconditioned resid norm 1.804442605262e-01 true resid norm 2.511590540611e-03 ||r(i)||/||b|| 8.739360401342e-02
Linear solve converged due to CONVERGED_RTOL iterations 10
iter =   4, Function value: -4.28596,  Residual: 0.0248212
  0 KSP preconditioned resid norm 1.242236085862e+00 true resid norm 2.153752870715e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.957410723366e-01 true resid norm 1.052346229945e-02 ||r(i)||/||b|| 4.886104827782e-01
  2 KSP preconditioned resid norm 4.938478940613e-01 true resid norm 8.455413879932e-03 ||r(i)||/||b|| 3.925897903563e-01
  3 KSP preconditioned resid norm 3.996372234663e-01 true resid norm 6.708749489546e-03 ||r(i)||/||b|| 3.114911455612e-01
  4 KSP preconditioned resid norm 3.533933541706e-01 true resid norm 5.541768408825e-03 ||r(i)||/||b|| 2.573075344055e-01
  5 KSP preconditioned resid norm 3.011467876410e-01 true resid norm 4.649589019097e-03 ||r(i)||/||b|| 2.158831257903e-01
  6 KSP preconditioned resid norm 2.820617262411e-01 true resid norm 4.230731348737e-03 ||r(i)||/||b|| 1.964353202386e-01
  7 KSP preconditioned resid norm 2.474494234788e-01 true resid norm 3.760788996797e-03 ||r(i)||/||b|| 1.746156231726e-01
  8 KSP preconditioned resid norm 2.007715137983e-01 true resid norm 3.102224817428e-03 ||r(i)||/||b|| 1.440381048174e-01
  9 KSP preconditioned resid norm 1.593316367603e-01 true resid norm 2.462750533118e-03 ||r(i)||/||b|| 1.143469414065e-01
 10 KSP preconditioned resid norm 1.196765532100e-01 true resid norm 1.858819975947e-03 ||r(i)||/||b|| 8.630609394523e-02
iter =   5, Function value: -4.31231,  Residual: 0.0178714
  0 KSP preconditioned resid norm 8.724820160650e-01 true resid norm 1.544152460821e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.086541001524e-01 true resid norm 7.145592176529e-03 ||r(i)||/||b|| 4.627517267777e-01
  2 KSP preconditioned resid norm 3.121531275140e-01 true resid norm 5.477393530594e-03 ||r(i)||/||b|| 3.547184406702e-01
  3 KSP preconditioned resid norm 2.484547325551e-01 true resid norm 4.127131397922e-03 ||r(i)||/||b|| 2.672748645382e-01
  4 KSP preconditioned resid norm 2.256450612299e-01 true resid norm 3.594296333391e-03 ||r(i)||/||b|| 2.327682288238e-01
  5 KSP preconditioned resid norm 1.984197481212e-01 true resid norm 3.051442614320e-03 ||r(i)||/||b|| 1.976127805863e-01
  6 KSP preconditioned resid norm 1.851089001362e-01 true resid norm 2.880086620499e-03 ||r(i)||/||b|| 1.865156902297e-01
  7 KSP preconditioned resid norm 1.595287233540e-01 true resid norm 2.475260836854e-03 ||r(i)||/||b|| 1.602989924673e-01
  8 KSP preconditioned resid norm 1.340161905551e-01 true resid norm 2.026197933587e-03 ||r(i)||/||b|| 1.312174791672e-01
  9 KSP preconditioned resid norm 1.109874347554e-01 true resid norm 1.693574409327e-03 ||r(i)||/||b|| 1.096766318286e-01
 10 KSP preconditioned resid norm 8.838638640722e-02 true resid norm 1.344541648458e-03 ||r(i)||/||b|| 8.707311503057e-02
 11 KSP preconditioned resid norm 7.078139183917e-02 true resid norm 1.102015180203e-03 ||r(i)||/||b|| 7.136699310228e-02
Linear solve converged due to CONVERGED_RTOL iterations 11
iter =   6, Function value: -4.32451,  Residual: 0.012743
  0 KSP preconditioned resid norm 6.585450027189e-01 true resid norm 1.106508779676e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.124040704236e-01 true resid norm 5.371194417470e-03 ||r(i)||/||b|| 4.854181472507e-01
  2 KSP preconditioned resid norm 2.450872206945e-01 true resid norm 4.128857181184e-03 ||r(i)||/||b|| 3.731427402133e-01
  3 KSP preconditioned resid norm 1.881012686091e-01 true resid norm 3.046303666750e-03 ||r(i)||/||b|| 2.753076814847e-01
  4 KSP preconditioned resid norm 1.654668210997e-01 true resid norm 2.597468829383e-03 ||r(i)||/||b|| 2.347445295594e-01
  5 KSP preconditioned resid norm 1.456341868261e-01 true resid norm 2.162923592241e-03 ||r(i)||/||b|| 1.954727908146e-01
  6 KSP preconditioned resid norm 1.390883474576e-01 true resid norm 2.101080391977e-03 ||r(i)||/||b|| 1.898837524445e-01
  7 KSP preconditioned resid norm 1.291359255246e-01 true resid norm 1.993398122762e-03 ||r(i)||/||b|| 1.801520384995e-01
  8 KSP preconditioned resid norm 1.104861736197e-01 true resid norm 1.650746908258e-03 ||r(i)||/||b|| 1.491851613452e-01
  9 KSP preconditioned resid norm 9.133820903286e-02 true resid norm 1.362255111735e-03 ||r(i)||/||b|| 1.231129058130e-01
 10 KSP preconditioned resid norm 7.227228862579e-02 true resid norm 1.065877252166e-03 ||r(i)||/||b|| 9.632795254263e-02
 11 KSP preconditioned resid norm 5.834541793924e-02 true resid norm 8.722602027492e-04 ||r(i)||/||b|| 7.882993960560e-02
iter =   7, Function value: -4.33142,  Residual: 0.0100395
  0 KSP preconditioned resid norm 4.844498651731e-01 true resid norm 8.783633194377e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.225839755798e-01 true resid norm 3.983362860863e-03 ||r(i)||/||b|| 4.534983158692e-01
  2 KSP preconditioned resid norm 1.789285946937e-01 true resid norm 3.119887218350e-03 ||r(i)||/||b|| 3.551932496848e-01
  3 KSP preconditioned resid norm 1.415228072598e-01 true resid norm 2.378930476398e-03 ||r(i)||/||b|| 2.708367282369e-01
  4 KSP preconditioned resid norm 1.242740497928e-01 true resid norm 1.972701944215e-03 ||r(i)||/||b|| 2.245883793824e-01
  5 KSP preconditioned resid norm 1.051804755179e-01 true resid norm 1.639604035928e-03 ||r(i)||/||b|| 1.866658135244e-01
  6 KSP preconditioned resid norm 1.038457207482e-01 true resid norm 1.578293594766e-03 ||r(i)||/||b|| 1.796857359409e-01
  7 KSP preconditioned resid norm 1.014306499320e-01 true resid norm 1.579982235591e-03 ||r(i)||/||b|| 1.798779844999e-01
  8 KSP preconditioned resid norm 9.365403832022e-02 true resid norm 1.437831541215e-03 ||r(i)||/||b|| 1.636943972268e-01
  9 KSP preconditioned resid norm 8.073642564701e-02 true resid norm 1.252875180321e-03 ||r(i)||/||b|| 1.426374659091e-01
 10 KSP preconditioned resid norm 6.451791116641e-02 true resid norm 9.986451561283e-04 ||r(i)||/||b|| 1.136938592526e-01
 11 KSP preconditioned resid norm 5.131501196541e-02 true resid norm 8.013561140981e-04 ||r(i)||/||b|| 9.123287554985e-02
 12 KSP preconditioned resid norm 4.001747598157e-02 true resid norm 6.143371253542e-04 ||r(i)||/||b|| 6.994111795873e-02
Linear solve converged due to CONVERGED_RTOL iterations 12
iter =   8, Function value: -4.3355,  Residual: 0.00804573
  0 KSP preconditioned resid norm 3.927967759982e-01 true resid norm 6.996544917363e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.800224761582e-01 true resid norm 3.153228793600e-03 ||r(i)||/||b|| 4.506837061497e-01
  2 KSP preconditioned resid norm 1.357792561257e-01 true resid norm 2.423708844490e-03 ||r(i)||/||b|| 3.464151053294e-01
  3 KSP preconditioned resid norm 1.082240584444e-01 true resid norm 1.829982585479e-03 ||r(i)||/||b|| 2.615551828929e-01
  4 KSP preconditioned resid norm 9.363099041109e-02 true resid norm 1.570490319062e-03 ||r(i)||/||b|| 2.244665527930e-01
  5 KSP preconditioned resid norm 8.174815908543e-02 true resid norm 1.289998130047e-03 ||r(i)||/||b|| 1.843764522752e-01
  6 KSP preconditioned resid norm 7.429374880715e-02 true resid norm 1.154098942305e-03 ||r(i)||/||b|| 1.649526953570e-01
  7 KSP preconditioned resid norm 7.219161853252e-02 true resid norm 1.129425436021e-03 ||r(i)||/||b|| 1.614261681103e-01
  8 KSP preconditioned resid norm 7.140040463483e-02 true resid norm 1.109123697083e-03 ||r(i)||/||b|| 1.585244874696e-01
  9 KSP preconditioned resid norm 6.611837149181e-02 true resid norm 1.040265174441e-03 ||r(i)||/||b|| 1.486826979212e-01
 10 KSP preconditioned resid norm 5.723451778786e-02 true resid norm 8.745407982162e-04 ||r(i)||/||b|| 1.249960957223e-01
 11 KSP preconditioned resid norm 4.752885127324e-02 true resid norm 7.436279136968e-04 ||r(i)||/||b|| 1.062850196032e-01
 12 KSP preconditioned resid norm 3.826257032419e-02 true resid norm 5.906179588884e-04 ||r(i)||/||b|| 8.441566028150e-02
iter =   9, Function value: -4.33807,  Residual: 0.00609756
  0 KSP preconditioned resid norm 3.014204700543e-01 true resid norm 5.359088645381e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.335648892797e-01 true resid norm 2.404129486454e-03 ||r(i)||/||b|| 4.486078968904e-01
  2 KSP preconditioned resid norm 1.026709162654e-01 true resid norm 1.868672524106e-03 ||r(i)||/||b|| 3.486922213381e-01
  3 KSP preconditioned resid norm 8.186335101742e-02 true resid norm 1.414883222636e-03 ||r(i)||/||b|| 2.640156407668e-01
  4 KSP preconditioned resid norm 7.114741869343e-02 true resid norm 1.177159623060e-03 ||r(i)||/||b|| 2.196566806325e-01
  5 KSP preconditioned resid norm 6.077811101007e-02 true resid norm 9.883812187486e-04 ||r(i)||/||b|| 1.844308396728e-01
  6 KSP preconditioned resid norm 5.638312083581e-02 true resid norm 9.012450232314e-04 ||r(i)||/||b|| 1.681713221908e-01
  7 KSP preconditioned resid norm 5.440497120591e-02 true resid norm 8.954491957738e-04 ||r(i)||/||b|| 1.670898272126e-01
  8 KSP preconditioned resid norm 5.279744965994e-02 true resid norm 8.220781002841e-04 ||r(i)||/||b|| 1.533988621354e-01
  9 KSP preconditioned resid norm 5.186699669966e-02 true resid norm 8.142183035325e-04 ||r(i)||/||b|| 1.519322327751e-01
 10 KSP preconditioned resid norm 4.854397247258e-02 true resid norm 7.493637905932e-04 ||r(i)||/||b|| 1.398304525601e-01
 11 KSP preconditioned resid norm 4.216185475436e-02 true resid norm 6.692323036225e-04 ||r(i)||/||b|| 1.248780059272e-01
 12 KSP preconditioned resid norm 3.418515268876e-02 true resid norm 5.421796129518e-04 ||r(i)||/||b|| 1.011701147021e-01
 13 KSP preconditioned resid norm 2.777127852232e-02 true resid norm 4.527426091689e-04 ||r(i)||/||b|| 8.448126894842e-02
Linear solve converged due to CONVERGED_RTOL iterations 13
iter =  10, Function value: -4.33961,  Residual: 0.00500503
  0 KSP preconditioned resid norm 2.364109097575e-01 true resid norm 4.341645005845e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.075164754673e-01 true resid norm 1.984083890306e-03 ||r(i)||/||b|| 4.569889725287e-01
  2 KSP preconditioned resid norm 8.249562330338e-02 true resid norm 1.511522880572e-03 ||r(i)||/||b|| 3.481452026910e-01
  3 KSP preconditioned resid norm 6.341806612782e-02 true resid norm 1.157742542537e-03 ||r(i)||/||b|| 2.666598814455e-01
  4 KSP preconditioned resid norm 5.488390196976e-02 true resid norm 9.561094185789e-04 ||r(i)||/||b|| 2.202182392369e-01
  5 KSP preconditioned resid norm 4.699055957820e-02 true resid norm 8.116723202675e-04 ||r(i)||/||b|| 1.869504114626e-01
  6 KSP preconditioned resid norm 4.251478965931e-02 true resid norm 7.020592632127e-04 ||r(i)||/||b|| 1.617035161252e-01
  7 KSP preconditioned resid norm 4.111471419652e-02 true resid norm 6.818479737396e-04 ||r(i)||/||b|| 1.570483014668e-01
  8 KSP preconditioned resid norm 3.966182002913e-02 true resid norm 6.777014814735e-04 ||r(i)||/||b|| 1.560932504986e-01
  9 KSP preconditioned resid norm 3.786696314412e-02 true resid norm 6.233329856217e-04 ||r(i)||/||b|| 1.435706937768e-01
 10 KSP preconditioned resid norm 3.592246077746e-02 true resid norm 5.802390462398e-04 ||r(i)||/||b|| 1.336449768368e-01
 11 KSP preconditioned resid norm 3.451852041643e-02 true resid norm 5.559778331473e-04 ||r(i)||/||b|| 1.280569536198e-01
 12 KSP preconditioned resid norm 3.089067169545e-02 true resid norm 4.955418187357e-04 ||r(i)||/||b|| 1.141368808524e-01
 13 KSP preconditioned resid norm 2.659663552837e-02 true resid norm 4.320291892634e-04 ||r(i)||/||b|| 9.950817919976e-02
 14 KSP preconditioned resid norm 2.205795227573e-02 true resid norm 3.562783170277e-04 ||r(i)||/||b|| 8.206067436377e-02
Linear solve converged due to CONVERGED_RTOL iterations 14
iter =  11, Function value: -4.3406,  Residual: 0.00390632
  0 KSP preconditioned resid norm 1.747564104597e-01 true resid norm 3.395819827250e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.787815596856e-02 true resid norm 1.493210285798e-03 ||r(i)||/||b|| 4.397201152475e-01
  2 KSP preconditioned resid norm 6.186264636865e-02 true resid norm 1.134482127872e-03 ||r(i)||/||b|| 3.340819553406e-01
  3 KSP preconditioned resid norm 4.576006410759e-02 true resid norm 8.543626673755e-04 ||r(i)||/||b|| 2.515924609780e-01
  4 KSP preconditioned resid norm 3.878702900095e-02 true resid norm 7.155901004428e-04 ||r(i)||/||b|| 2.107267572622e-01
  5 KSP preconditioned resid norm 3.318034878195e-02 true resid norm 5.953898616426e-04 ||r(i)||/||b|| 1.753302271413e-01
  6 KSP preconditioned resid norm 2.942467993480e-02 true resid norm 5.187434008216e-04 ||r(i)||/||b|| 1.527594004426e-01
  7 KSP preconditioned resid norm 2.703947889515e-02 true resid norm 4.630148110579e-04 ||r(i)||/||b|| 1.363484621129e-01
  8 KSP preconditioned resid norm 2.720330355809e-02 true resid norm 4.870594319460e-04 ||r(i)||/||b|| 1.434291148304e-01
  9 KSP preconditioned resid norm 2.664515458323e-02 true resid norm 4.697630852266e-04 ||r(i)||/||b|| 1.383356918577e-01
 10 KSP preconditioned resid norm 2.506812781995e-02 true resid norm 4.241419599700e-04 ||r(i)||/||b|| 1.249011966320e-01
 11 KSP preconditioned resid norm 2.418386634738e-02 true resid norm 3.970510826002e-04 ||r(i)||/||b|| 1.169234832231e-01
 12 KSP preconditioned resid norm 2.253268729861e-02 true resid norm 3.681670226612e-04 ||r(i)||/||b|| 1.084177139514e-01
 13 KSP preconditioned resid norm 2.086412868143e-02 true resid norm 3.434711644824e-04 ||r(i)||/||b|| 1.011452850726e-01
 14 KSP preconditioned resid norm 1.802390740608e-02 true resid norm 2.981089954033e-04 ||r(i)||/||b|| 8.778704718405e-02
 15 KSP preconditioned resid norm 1.523179504165e-02 true resid norm 2.520494847704e-04 ||r(i)||/||b|| 7.422345636476e-02
Linear solve converged due to CONVERGED_RTOL iterations 15
iter =  12, Function value: -4.34116,  Residual: 0.00294104
  0 KSP preconditioned resid norm 1.269253589305e-01 true resid norm 2.536068316040e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.809228196354e-02 true resid norm 1.138219826417e-03 ||r(i)||/||b|| 4.488127623448e-01
  2 KSP preconditioned resid norm 4.556056028734e-02 true resid norm 8.657705419405e-04 ||r(i)||/||b|| 3.413829731891e-01
  3 KSP preconditioned resid norm 3.433911748363e-02 true resid norm 6.647369933728e-04 ||r(i)||/||b|| 2.621132045886e-01
  4 KSP preconditioned resid norm 2.827313089667e-02 true resid norm 5.358088790468e-04 ||r(i)||/||b|| 2.112754122821e-01
  5 KSP preconditioned resid norm 2.344783293039e-02 true resid norm 4.357245597546e-04 ||r(i)||/||b|| 1.718110498044e-01
  6 KSP preconditioned resid norm 2.062192561669e-02 true resid norm 3.836228029287e-04 ||r(i)||/||b|| 1.512667464447e-01
  7 KSP preconditioned resid norm 1.878393491291e-02 true resid norm 3.359546817721e-04 ||r(i)||/||b|| 1.324706750395e-01
  8 KSP preconditioned resid norm 1.823608390763e-02 true resid norm 3.212608041473e-04 ||r(i)||/||b|| 1.266767153375e-01
  9 KSP preconditioned resid norm 1.815816434403e-02 true resid norm 3.300728123964e-04 ||r(i)||/||b|| 1.301513883947e-01
 10 KSP preconditioned resid norm 1.724348490858e-02 true resid norm 3.012362342909e-04 ||r(i)||/||b|| 1.187808042810e-01
 11 KSP preconditioned resid norm 1.644315792321e-02 true resid norm 2.840324848441e-04 ||r(i)||/||b|| 1.119971741485e-01
 12 KSP preconditioned resid norm 1.539350847902e-02 true resid norm 2.533482074977e-04 ||r(i)||/||b|| 9.989802163266e-02
 13 KSP preconditioned resid norm 1.442282393653e-02 true resid norm 2.380954915861e-04 ||r(i)||/||b|| 9.388370576620e-02
 14 KSP preconditioned resid norm 1.338532412048e-02 true resid norm 2.181743171858e-04 ||r(i)||/||b|| 8.602856469044e-02
 15 KSP preconditioned resid norm 1.221850738038e-02 true resid norm 2.084925892766e-04 ||r(i)||/||b|| 8.221095147867e-02
iter =  13, Function value: -4.34146,  Residual: 0.00221753
  0 KSP preconditioned resid norm 9.473751270336e-02 true resid norm 1.909704210823e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.098346688738e-02 true resid norm 7.993849698937e-04 ||r(i)||/||b|| 4.185909866897e-01
  2 KSP preconditioned resid norm 3.147349124242e-02 true resid norm 6.253145723838e-04 ||r(i)||/||b|| 3.274405370424e-01
  3 KSP preconditioned resid norm 2.378922461333e-02 true resid norm 4.511846746496e-04 ||r(i)||/||b|| 2.362589306201e-01
  4 KSP preconditioned resid norm 1.985385606519e-02 true resid norm 3.836304045900e-04 ||r(i)||/||b|| 2.008847246688e-01
  5 KSP preconditioned resid norm 1.665027084316e-02 true resid norm 3.062258292002e-04 ||r(i)||/||b|| 1.603524920062e-01
  6 KSP preconditioned resid norm 1.429886591495e-02 true resid norm 2.772412865586e-04 ||r(i)||/||b|| 1.451749883502e-01
  7 KSP preconditioned resid norm 1.254670895261e-02 true resid norm 2.243650167112e-04 ||r(i)||/||b|| 1.174867895455e-01
  8 KSP preconditioned resid norm 1.225840302025e-02 true resid norm 2.271283663539e-04 ||r(i)||/||b|| 1.189337935512e-01
  9 KSP preconditioned resid norm 1.272415101076e-02 true resid norm 2.402247841755e-04 ||r(i)||/||b|| 1.257916188350e-01
 10 KSP preconditioned resid norm 1.292755831832e-02 true resid norm 2.381278572875e-04 ||r(i)||/||b|| 1.246935813086e-01
 11 KSP preconditioned resid norm 1.215071659815e-02 true resid norm 2.219278455830e-04 ||r(i)||/||b|| 1.162105860820e-01
 12 KSP preconditioned resid norm 1.080209989258e-02 true resid norm 1.914458622085e-04 ||r(i)||/||b|| 1.002489606105e-01
 13 KSP preconditioned resid norm 9.986110973588e-03 true resid norm 1.748694884789e-04 ||r(i)||/||b|| 9.156888668300e-02
 14 KSP preconditioned resid norm 9.156264188533e-03 true resid norm 1.536430336021e-04 ||r(i)||/||b|| 8.045383820770e-02
iter =  14, Function value: -4.34162,  Residual: 0.00156036
  0 KSP preconditioned resid norm 6.713096290304e-02 true resid norm 1.342490878243e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.056343317500e-02 true resid norm 6.209434475362e-04 ||r(i)||/||b|| 4.625308503763e-01
  2 KSP preconditioned resid norm 2.413003317910e-02 true resid norm 4.901365410386e-04 ||r(i)||/||b|| 3.650948762349e-01
  3 KSP preconditioned resid norm 1.784129496231e-02 true resid norm 3.533841764796e-04 ||r(i)||/||b|| 2.632302254017e-01
  4 KSP preconditioned resid norm 1.509269101819e-02 true resid norm 2.888061883045e-04 ||r(i)||/||b|| 2.151271140721e-01
  5 KSP preconditioned resid norm 1.249447123177e-02 true resid norm 2.437343259740e-04 ||r(i)||/||b|| 1.815538041443e-01
  6 KSP preconditioned resid norm 1.062803951770e-02 true resid norm 2.008814504101e-04 ||r(i)||/||b|| 1.496333819959e-01
  7 KSP preconditioned resid norm 9.694555842257e-03 true resid norm 1.786364367197e-04 ||r(i)||/||b|| 1.330634268096e-01
  8 KSP preconditioned resid norm 9.563414684320e-03 true resid norm 1.804822937697e-04 ||r(i)||/||b|| 1.344383762264e-01
  9 KSP preconditioned resid norm 9.704981715287e-03 true resid norm 1.839496949251e-04 ||r(i)||/||b|| 1.370211879323e-01
 10 KSP preconditioned resid norm 9.783862413149e-03 true resid norm 1.850154077014e-04 ||r(i)||/||b|| 1.378150203475e-01
 11 KSP preconditioned resid norm 9.520103796076e-03 true resid norm 1.793309452756e-04 ||r(i)||/||b|| 1.335807551336e-01
 12 KSP preconditioned resid norm 8.746398790501e-03 true resid norm 1.614504296672e-04 ||r(i)||/||b|| 1.202618448168e-01
 13 KSP preconditioned resid norm 7.912808926215e-03 true resid norm 1.429323415866e-04 ||r(i)||/||b|| 1.064680169549e-01
 14 KSP preconditioned resid norm 6.925586071034e-03 true resid norm 1.238413598242e-04 ||r(i)||/||b|| 9.224744974527e-02
 15 KSP preconditioned resid norm 6.357804411682e-03 true resid norm 1.127345454971e-04 ||r(i)||/||b|| 8.397416125813e-02
iter =  15, Function value: -4.34171,  Residual: 0.00108123
  0 KSP preconditioned resid norm 4.091066173772e-02 true resid norm 9.205007375890e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.728655515714e-02 true resid norm 3.621621547874e-04 ||r(i)||/||b|| 3.934403743511e-01
  2 KSP preconditioned resid norm 1.312952276461e-02 true resid norm 2.693997658761e-04 ||r(i)||/||b|| 2.926665399331e-01
  3 KSP preconditioned resid norm 1.004715817716e-02 true resid norm 2.071999047139e-04 ||r(i)||/||b|| 2.250947731521e-01
  4 KSP preconditioned resid norm 8.313225063985e-03 true resid norm 1.623374316661e-04 ||r(i)||/||b|| 1.763577420821e-01
  5 KSP preconditioned resid norm 6.922329050111e-03 true resid norm 1.346166507364e-04 ||r(i)||/||b|| 1.462428493963e-01
  6 KSP preconditioned resid norm 5.897122308306e-03 true resid norm 1.157989984308e-04 ||r(i)||/||b|| 1.258000061293e-01
  7 KSP preconditioned resid norm 5.051886677466e-03 true resid norm 9.686063834150e-05 ||r(i)||/||b|| 1.052260301227e-01
  8 KSP preconditioned resid norm 4.990655930937e-03 true resid norm 9.587954730827e-05 ||r(i)||/||b|| 1.041602069319e-01
  9 KSP preconditioned resid norm 5.256056069039e-03 true resid norm 1.039298284360e-04 ||r(i)||/||b|| 1.129057524802e-01
 10 KSP preconditioned resid norm 5.388899329733e-03 true resid norm 1.014432042850e-04 ||r(i)||/||b|| 1.102043704502e-01
 11 KSP preconditioned resid norm 5.568998571499e-03 true resid norm 1.039508376503e-04 ||r(i)||/||b|| 1.129285761601e-01
 12 KSP preconditioned resid norm 5.314829123567e-03 true resid norm 9.585391683975e-05 ||r(i)||/||b|| 1.041323628820e-01
 13 KSP preconditioned resid norm 4.921864652163e-03 true resid norm 8.926201545095e-05 ||r(i)||/||b|| 9.697115038142e-02
 14 KSP preconditioned resid norm 4.230993871273e-03 true resid norm 7.629079023767e-05 ||r(i)||/||b|| 8.287966225589e-02
 15 KSP preconditioned resid norm 3.724966780398e-03 true resid norm 6.689643138772e-05 ||r(i)||/||b|| 7.267395739730e-02
iter =  16, Function value: -4.34174,  Residual: 0.000716126
  0 KSP preconditioned resid norm 2.657708116285e-02 true resid norm 6.067231827511e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.206582807212e-02 true resid norm 2.480656122767e-04 ||r(i)||/||b|| 4.088612720415e-01
  2 KSP preconditioned resid norm 8.471076282395e-03 true resid norm 1.766667490069e-04 ||r(i)||/||b|| 2.911818009093e-01
  3 KSP preconditioned resid norm 6.431100488802e-03 true resid norm 1.308967705201e-04 ||r(i)||/||b|| 2.157438091067e-01
  4 KSP preconditioned resid norm 5.302874374075e-03 true resid norm 1.099545540100e-04 ||r(i)||/||b|| 1.812268875427e-01
  5 KSP preconditioned resid norm 4.232576702283e-03 true resid norm 8.329816074698e-05 ||r(i)||/||b|| 1.372918706836e-01
  6 KSP preconditioned resid norm 3.680835249549e-03 true resid norm 7.277393297652e-05 ||r(i)||/||b|| 1.199458584169e-01
  7 KSP preconditioned resid norm 3.091116068705e-03 true resid norm 5.903744039608e-05 ||r(i)||/||b|| 9.730539737806e-02
  8 KSP preconditioned resid norm 2.859903952853e-03 true resid norm 5.558654845147e-05 ||r(i)||/||b|| 9.161764381480e-02
  9 KSP preconditioned resid norm 2.959547218210e-03 true resid norm 6.029256120238e-05 ||r(i)||/||b|| 9.937408511241e-02
 10 KSP preconditioned resid norm 2.960691089167e-03 true resid norm 5.706028380906e-05 ||r(i)||/||b|| 9.404665163829e-02
 11 KSP preconditioned resid norm 2.919227733677e-03 true resid norm 5.529431686412e-05 ||r(i)||/||b|| 9.113598826633e-02
 12 KSP preconditioned resid norm 2.836355055820e-03 true resid norm 5.347171431598e-05 ||r(i)||/||b|| 8.813197820053e-02
 13 KSP preconditioned resid norm 2.712688618055e-03 true resid norm 5.076214586420e-05 ||r(i)||/||b|| 8.366607261325e-02
 14 KSP preconditioned resid norm 2.448623059457e-03 true resid norm 4.647915303924e-05 ||r(i)||/||b|| 7.660685195593e-02
iter =  17, Function value: -4.34175,  Residual: 0.000390283
  0 KSP preconditioned resid norm 1.463210012272e-02 true resid norm 3.337911064811e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.953212140664e-03 true resid norm 1.254784058875e-04 ||r(i)||/||b|| 3.759189608446e-01
  2 KSP preconditioned resid norm 4.378466206900e-03 true resid norm 9.143895341207e-05 ||r(i)||/||b|| 2.739406522122e-01
  3 KSP preconditioned resid norm 3.284562245867e-03 true resid norm 6.623843167459e-05 ||r(i)||/||b|| 1.984427697097e-01
  4 KSP preconditioned resid norm 2.655713575004e-03 true resid norm 5.460415615247e-05 ||r(i)||/||b|| 1.635878101371e-01
  5 KSP preconditioned resid norm 2.176701317881e-03 true resid norm 4.282073391863e-05 ||r(i)||/||b|| 1.282860240647e-01
  6 KSP preconditioned resid norm 1.809985345342e-03 true resid norm 3.627734130945e-05 ||r(i)||/||b|| 1.086827677702e-01
  7 KSP preconditioned resid norm 1.671822205568e-03 true resid norm 3.134253340574e-05 ||r(i)||/||b|| 9.389864737908e-02
  8 KSP preconditioned resid norm 1.730122795767e-03 true resid norm 3.488673498476e-05 ||r(i)||/||b|| 1.045166701790e-01
  9 KSP preconditioned resid norm 1.863476415530e-03 true resid norm 3.800859799482e-05 ||r(i)||/||b|| 1.138694149030e-01
 10 KSP preconditioned resid norm 1.895181284617e-03 true resid norm 3.750233032315e-05 ||r(i)||/||b|| 1.123526948291e-01
 11 KSP preconditioned resid norm 1.887184454742e-03 true resid norm 3.639149265995e-05 ||r(i)||/||b|| 1.090247521679e-01
 12 KSP preconditioned resid norm 1.752339462009e-03 true resid norm 3.317162220026e-05 ||r(i)||/||b|| 9.937838832786e-02
 13 KSP preconditioned resid norm 1.651797928389e-03 true resid norm 3.089273083278e-05 ||r(i)||/||b|| 9.255109028654e-02
 14 KSP preconditioned resid norm 1.473025608447e-03 true resid norm 2.790010717354e-05 ||r(i)||/||b|| 8.358553188451e-02
 15 KSP preconditioned resid norm 1.285396944788e-03 true resid norm 2.494276452832e-05 ||r(i)||/||b|| 7.472567136757e-02
iter =  18, Function value: -4.34176,  Residual: 0.000221268
  0 KSP preconditioned resid norm 7.856682822254e-03 true resid norm 1.888109931492e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.135270791267e-03 true resid norm 6.991202817395e-05 ||r(i)||/||b|| 3.702751995945e-01
  2 KSP preconditioned resid norm 2.218933015390e-03 true resid norm 4.844277762920e-05 ||r(i)||/||b|| 2.565675696167e-01
  3 KSP preconditioned resid norm 1.571522532195e-03 true resid norm 3.247549146301e-05 ||r(i)||/||b|| 1.720000033968e-01
  4 KSP preconditioned resid norm 1.247112933454e-03 true resid norm 2.586716290383e-05 ||r(i)||/||b|| 1.370003010544e-01
  5 KSP preconditioned resid norm 9.788243976253e-04 true resid norm 1.964760930240e-05 ||r(i)||/||b|| 1.040596682147e-01
  6 KSP preconditioned resid norm 8.011021804226e-04 true resid norm 1.638368719111e-05 ||r(i)||/||b|| 8.677295171138e-02
  7 KSP preconditioned resid norm 6.591982417773e-04 true resid norm 1.309563057529e-05 ||r(i)||/||b|| 6.935841158859e-02
Linear solve converged due to CONVERGED_RTOL iterations 7
iter =  19, Function value: -4.34176,  Residual: 0.000102701
  0 KSP preconditioned resid norm 3.429190965449e-03 true resid norm 8.715160652501e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.434311663947e-03 true resid norm 3.103086400409e-05 ||r(i)||/||b|| 3.560561330007e-01
  2 KSP preconditioned resid norm 1.053762592208e-03 true resid norm 2.208124684907e-05 ||r(i)||/||b|| 2.533659186504e-01
  3 KSP preconditioned resid norm 8.068283526000e-04 true resid norm 1.517650946581e-05 ||r(i)||/||b|| 1.741391819490e-01
  4 KSP preconditioned resid norm 7.662529384600e-04 true resid norm 1.525702671004e-05 ||r(i)||/||b|| 1.750630575658e-01
  5 KSP preconditioned resid norm 7.959531067619e-04 true resid norm 1.570028905586e-05 ||r(i)||/||b|| 1.801491639900e-01
  6 KSP preconditioned resid norm 7.536694004422e-04 true resid norm 1.502645711346e-05 ||r(i)||/||b|| 1.724174425763e-01
  7 KSP preconditioned resid norm 6.825156968620e-04 true resid norm 1.452568267560e-05 ||r(i)||/||b|| 1.666714275821e-01
  8 KSP preconditioned resid norm 6.502855938557e-04 true resid norm 1.343621650213e-05 ||r(i)||/||b|| 1.541706118552e-01
  9 KSP preconditioned resid norm 6.192398826140e-04 true resid norm 1.230171857097e-05 ||r(i)||/||b|| 1.411530901319e-01
 10 KSP preconditioned resid norm 5.930844572842e-04 true resid norm 1.168092253097e-05 ||r(i)||/||b|| 1.340299163345e-01
 11 KSP preconditioned resid norm 5.991549064583e-04 true resid norm 1.176759628689e-05 ||r(i)||/||b|| 1.350244333535e-01
 12 KSP preconditioned resid norm 5.853895100617e-04 true resid norm 1.142250594801e-05 ||r(i)||/||b|| 1.310647778447e-01
 13 KSP preconditioned resid norm 5.209546030685e-04 true resid norm 1.011803961803e-05 ||r(i)||/||b|| 1.160969948973e-01
 14 KSP preconditioned resid norm 4.423272486127e-04 true resid norm 8.627376370560e-06 ||r(i)||/||b|| 9.899274051918e-02
 15 KSP preconditioned resid norm 4.043775603666e-04 true resid norm 7.888183144271e-06 ||r(i)||/||b|| 9.051104688481e-02
 16 KSP preconditioned resid norm 3.601606825286e-04 true resid norm 6.932677165733e-06 ||r(i)||/||b|| 7.954732496806e-02
 17 KSP preconditioned resid norm 3.204466047350e-04 true resid norm 6.179505453231e-06 ||r(i)||/||b|| 7.090523857937e-02
Linear solve converged due to CONVERGED_RTOL iterations 17
iter =  20, Function value: -4.34176,  Residual: 4.55416e-05
  0 KSP preconditioned resid norm 1.438682776749e-03 true resid norm 3.844799940215e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.089293961259e-04 true resid norm 1.340839840480e-05 ||r(i)||/||b|| 3.487411208203e-01
  2 KSP preconditioned resid norm 4.622706374230e-04 true resid norm 9.841148913902e-06 ||r(i)||/||b|| 2.559599736509e-01
  3 KSP preconditioned resid norm 3.355050244055e-04 true resid norm 7.017484134459e-06 ||r(i)||/||b|| 1.825188369636e-01
  4 KSP preconditioned resid norm 2.845831399181e-04 true resid norm 5.732764582707e-06 ||r(i)||/||b|| 1.491043662050e-01
  5 KSP preconditioned resid norm 2.286164775932e-04 true resid norm 4.835735621852e-06 ||r(i)||/||b|| 1.257734003601e-01
  6 KSP preconditioned resid norm 1.817665502920e-04 true resid norm 3.772088923163e-06 ||r(i)||/||b|| 9.810884784168e-02
  7 KSP preconditioned resid norm 1.442303629690e-04 true resid norm 2.978303378356e-06 ||r(i)||/||b|| 7.746315607230e-02
  8 KSP preconditioned resid norm 1.194506703629e-04 true resid norm 2.373116358758e-06 ||r(i)||/||b|| 6.172275269609e-02
iter =  21, Function value: -4.34176,  Residual: 1.6774e-05
  0 KSP preconditioned resid norm 5.344946439561e-04 true resid norm 1.423016797066e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.656909077159e-04 true resid norm 3.738015940921e-06 ||r(i)||/||b|| 2.626824889648e-01
  2 KSP preconditioned resid norm 1.315452507202e-04 true resid norm 2.531809935108e-06 ||r(i)||/||b|| 1.779184855954e-01
  3 KSP preconditioned resid norm 9.672515990631e-05 true resid norm 1.932462105630e-06 ||r(i)||/||b|| 1.358003721118e-01
  4 KSP preconditioned resid norm 9.158697364759e-05 true resid norm 1.775273053083e-06 ||r(i)||/||b|| 1.247541881967e-01
  5 KSP preconditioned resid norm 9.935270670260e-05 true resid norm 2.190584381305e-06 ||r(i)||/||b|| 1.539394605756e-01
  6 KSP preconditioned resid norm 1.154177758923e-04 true resid norm 2.595766444746e-06 ||r(i)||/||b|| 1.824129167061e-01
  7 KSP preconditioned resid norm 1.092024185062e-04 true resid norm 2.287364912714e-06 ||r(i)||/||b|| 1.607405420252e-01
  8 KSP preconditioned resid norm 9.816936429818e-05 true resid norm 2.104671520724e-06 ||r(i)||/||b|| 1.479020855596e-01
  9 KSP preconditioned resid norm 9.265175504977e-05 true resid norm 1.963568913548e-06 ||r(i)||/||b|| 1.379863482705e-01
 10 KSP preconditioned resid norm 8.656522105138e-05 true resid norm 1.845455093663e-06 ||r(i)||/||b|| 1.296861075335e-01
 11 KSP preconditioned resid norm 8.410971308097e-05 true resid norm 1.708185075236e-06 ||r(i)||/||b|| 1.200396986710e-01
 12 KSP preconditioned resid norm 8.111397603877e-05 true resid norm 1.721965942453e-06 ||r(i)||/||b|| 1.210081248516e-01
 13 KSP preconditioned resid norm 7.602298282947e-05 true resid norm 1.550742188904e-06 ||r(i)||/||b|| 1.089756770335e-01
 14 KSP preconditioned resid norm 6.337971365825e-05 true resid norm 1.303081343883e-06 ||r(i)||/||b|| 9.157174719017e-02
 15 KSP preconditioned resid norm 5.146539909823e-05 true resid norm 1.041756105678e-06 ||r(i)||/||b|| 7.320757617376e-02
iter =  22, Function value: -4.34176,  Residual: 2.40396e-06
  0 KSP preconditioned resid norm 8.733125062330e-05 true resid norm 2.098718745258e-06 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.062776294490e-05 true resid norm 7.264615749494e-07 ||r(i)||/||b|| 3.461452739157e-01
  2 KSP preconditioned resid norm 3.419958090507e-05 true resid norm 5.958586335411e-07 ||r(i)||/||b|| 2.839154293006e-01
  3 KSP preconditioned resid norm 2.736481374734e-05 true resid norm 5.749969858640e-07 ||r(i)||/||b|| 2.739752466419e-01
  4 KSP preconditioned resid norm 2.654682566261e-05 true resid norm 5.319475026305e-07 ||r(i)||/||b|| 2.534629777489e-01
  5 KSP preconditioned resid norm 2.446732124913e-05 true resid norm 4.706119067035e-07 ||r(i)||/||b|| 2.242377201646e-01
  6 KSP preconditioned resid norm 2.213311130786e-05 true resid norm 4.559669864079e-07 ||r(i)||/||b|| 2.172596911512e-01
  7 KSP preconditioned resid norm 1.923264290264e-05 true resid norm 3.613519809240e-07 ||r(i)||/||b|| 1.721774209815e-01
  8 KSP preconditioned resid norm 1.870548067815e-05 true resid norm 3.877983028150e-07 ||r(i)||/||b|| 1.847785958415e-01
  9 KSP preconditioned resid norm 1.605774724722e-05 true resid norm 3.312796139470e-07 ||r(i)||/||b|| 1.578485038529e-01
 10 KSP preconditioned resid norm 1.194961089627e-05 true resid norm 2.214807563218e-07 ||r(i)||/||b|| 1.055314137839e-01
 11 KSP preconditioned resid norm 9.997801906888e-06 true resid norm 1.920600557586e-07 ||r(i)||/||b|| 9.151300344200e-02
 12 KSP preconditioned resid norm 9.025223549114e-06 true resid norm 1.688161624342e-07 ||r(i)||/||b|| 8.043772554833e-02
 13 KSP preconditioned resid norm 8.794638859002e-06 true resid norm 1.714140620437e-07 ||r(i)||/||b|| 8.167557583930e-02
 14 KSP preconditioned resid norm 8.471152217056e-06 true resid norm 1.642328286332e-07 ||r(i)||/||b|| 7.825385321604e-02
iter =  23, Function value: -4.34176,  Residual: 2.45834e-07
Tao Object: 1 MPI processes
  type: tron
      Total PG its: 69,      PG tolerance: 0.001
  TaoLineSearch Object:   1 MPI processes
    type: more-thuente
  KSP Object:   1 MPI processes
    type: cg
  total KSP iterations: 272
  Active Set subset type: subvec
  convergence tolerances: gatol=1e-12,   steptol=1e-12,   gttol=0.
  Residual in Function/Gradient:=2.45834e-07
  Objective value=-4.34176
  total number of iterations=23,                          (max: 50)
  total number of function/gradient evaluations=93,      (max: 10000)
  total number of Hessian evaluations=23
  Solution converged:    ||g(X)||/|f(X)| <= grtol
TAO solve converged due to CONVERGED_GRTOL iterations 23
it: 1	7.392125e+00	272	4.851840e+08
  Time summary:
Creating DMPlex: 	0.523867
Distributing DMPlex: 	1.3113e-05
Refining DMPlex: 	2.10119
Setting up problem: 	2.84659
Overall analysis time: 	7.55529
Overall FLOPS/s: 	3.5727e+08
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main on a arch-darwin-c-opt named Justins-MacBook-Pro-2.local with 1 processor, by justin Tue Mar  8 00:55:52 2016
Using Petsc Development GIT revision: pre-tsfc-438-gf0bfc80  GIT Date: 2016-03-01 11:52:01 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.308e+01      1.00000   1.308e+01
Objects:              1.415e+03      1.00000   1.415e+03
Flops:                3.658e+09      1.00000   3.658e+09  3.658e+09
Flops/sec:            2.798e+08      1.00000   2.798e+08  2.798e+08
MPI Messages:         5.500e+00      1.00000   5.500e+00  5.500e+00
MPI Message Lengths:  4.494e+06      1.00000   8.170e+05  4.494e+06
MPI Reductions:       1.000e+00      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.3076e+01 100.0%  3.6584e+09 100.0%  5.500e+00 100.0%  8.170e+05      100.0%  1.000e+00 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
CreateMesh            94 1.0 2.9656e+00 1.0 3.94e+08 1.0 0.0e+00 0.0e+00 0.0e+00 23 11  0  0  0  23 11  0  0  0   133
BuildTwoSided          5 1.0 5.3954e-04 1.0 0.00e+00 0.0 5.0e-01 4.0e+00 0.0e+00  0  0  9  0  0   0  0  9  0  0     0
VecView                1 1.0 1.2989e-02 1.0 4.02e+05 1.0 1.0e+00 1.0e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0    31
VecDot               508 1.0 6.7075e-02 1.0 1.27e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  1891
VecTDot              544 1.0 6.3299e-02 1.0 1.12e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  1775
VecNorm              660 1.0 6.8642e-02 1.0 1.38e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  2018
VecScale             276 1.0 1.9268e-02 1.0 3.40e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1764
VecCopy              801 1.0 7.9906e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecSet              1144 1.0 1.3466e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              752 1.0 7.7411e-02 1.0 1.64e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  2122
VecAYPX              567 1.0 5.9691e-02 1.0 8.76e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  1467
VecWAXPY               1 1.0 2.0695e-04 1.0 1.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   603
VecScatterBegin       46 1.0 5.3043e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult              684 1.0 1.7788e+00 1.0 1.82e+09 1.0 0.0e+00 0.0e+00 0.0e+00 14 50  0  0  0  14 50  0  0  0  1021
MatSolve             295 1.0 8.5658e-01 1.0 7.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00  7 20  0  0  0   7 20  0  0  0   856
MatLUFactorNum        23 1.0 6.6945e-01 1.0 2.52e+08 1.0 0.0e+00 0.0e+00 0.0e+00  5  7  0  0  0   5  7  0  0  0   377
MatILUFactorSym       23 1.0 1.5076e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatAssemblyBegin      25 1.0 1.4544e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        25 1.0 7.3532e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetRowIJ           23 1.0 5.9605e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      23 1.0 5.4542e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatGetOrdering        23 1.0 6.7198e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 9.6512e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           3 1.0 4.7663e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
DMPlexStratify        11 1.0 6.3193e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
DMPlexPrealloc         1 1.0 1.0380e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  8  0  0  0  0   8  0  0  0  0     0
DMPlexResidualFE       1 1.0 6.3734e-01 1.0 4.01e+07 1.0 0.0e+00 0.0e+00 0.0e+00  5  1  0  0  0   5  1  0  0  0    63
DMPlexJacobianFE       1 1.0 1.8459e+00 1.0 8.14e+07 1.0 0.0e+00 0.0e+00 0.0e+00 14  2  0  0  0  14  2  0  0  0    44
SFSetGraph             6 1.0 2.0802e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin           9 1.0 2.4407e-03 1.0 0.00e+00 0.0 4.5e+00 7.8e+05 0.0e+00  0  0 82 78  0   0  0 82 78  0     0
SFBcastEnd             9 1.0 6.9332e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          1 1.0 3.6621e-04 1.0 0.00e+00 0.0 1.0e+00 1.0e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0     0
SFReduceEnd            1 1.0 3.8004e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       1 1.0 6.4219e-01 1.0 4.01e+07 1.0 2.0e+00 1.0e+06 0.0e+00  5  1 36 44  0   5  1 36 44  0    62
SNESJacobianEval       1 1.0 1.8474e+00 1.0 8.14e+07 1.0 2.5e+00 6.0e+05 0.0e+00 14  2 45 33  0  14  2 45 33  0    44
KSPSetUp              46 1.0 5.2261e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              23 1.0 3.4166e+00 1.0 2.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 26 77  0  0  0  26 77  0  0  0   827
PCSetUp               46 1.0 8.2769e-01 1.0 2.52e+08 1.0 0.0e+00 0.0e+00 0.0e+00  6  7  0  0  0   6  7  0  0  0   305
PCSetUpOnBlocks       23 1.0 8.2752e-01 1.0 2.52e+08 1.0 0.0e+00 0.0e+00 0.0e+00  6  7  0  0  0   6  7  0  0  0   305
PCApply              295 1.0 8.7405e-01 1.0 7.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00  7 20  0  0  0   7 20  0  0  0   839
TaoSolve               1 1.0 4.8958e+00 1.0 3.46e+09 1.0 0.0e+00 0.0e+00 0.0e+00 37 95  0  0  0  37 95  0  0  0   707
TaoHessianEval        23 1.0 1.0967e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
TaoLineSearchApply      92 1.0 6.2689e-01 1.0 5.05e+08 1.0 0.0e+00 0.0e+00 0.0e+00  5 14  0  0  0   5 14  0  0  0   806
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     4              3         2432     0.
              Object     7              7         4088     0.
           Container    15             15         8640     0.
              Vector   822            822    839619600     0.
      Vector Scatter    46             46        30544     0.
              Matrix    47             47    831590120     0.
    Distributed Mesh    29             29       135576     0.
    GraphPartitioner    11             11         6732     0.
Star Forest Bipartite Graph    62             62        50488     0.
     Discrete System    29             29        25056     0.
           Index Set   269            269     37207752     0.
   IS L to G Mapping     1              1       561392     0.
             Section    56             54        36288     0.
                SNES     1              1         1340     0.
      SNESLineSearch     1              1         1000     0.
              DMSNES     1              1          672     0.
       Krylov Solver     3              3         3680     0.
      Preconditioner     3              3         2824     0.
        Linear Space     2              2         1296     0.
          Dual Space     2              2         1328     0.
            FE Space     2              2         1512     0.
                 Tao     1              1         1944     0.
       TaoLineSearch     1              1          888     0.
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-al 1
-am 0
-at 0.001
-bcloc 0,1,0,1,0,0,0,1,0,1,1,1,0,0,0,1,0,1,1,1,0,1,0,1,0,1,0,0,0,1,0,1,1,1,0,1,0.45,0.55,0.45,0.55,0.45,0.55
-bcnum 7
-bcval 0,0,0,0,0,0,1
-dim 3
-dm_refine 1
-dt 0.001
-edges 3,3
-floc 0.25,0.75,0.25,0.75,0.25,0.75
-fnum 0
-ftime 0,99
-fval 1
-ksp_atol 1.0e-12
-ksp_rtol 1.0e-1
-ksp_type cg
-log_view
-lower 0,0
-mat_petscspace_order 0
-mesh datafiles/cube_with_hole2_mesh.dat
-mu 1
-nonneg 1
-numsteps 0
-options_left 0
-pc_type bjacobi
-petscpartitioner_type parmetis
-progress 0
-simplex 1
-solution_petscspace_order 1
-tao_gatol 1e-12
-tao_grtol 1e-7
-tao_monitor
-tao_type tron
-tao_view
-trans datafiles/cube_with_hole2_trans.dat
-upper 1,1
-vtuname figures/cube_with_hole_2
-vtuprint 1
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco --download-ctetgen --download-exodusii --download-fblaslapack --download-hdf5 --download-hypre --download-metis --download-ml --download-mumps --download-netcdf --download-parmetis --download-scalapack --download-superlu_dist --download-triangle --with-debugging=0 --with-mpi-dir=/usr/local/opt/open-mpi --with-shared-libraries=1 COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 PETSC_ARCH=arch-darwin-c-opt
Libraries compiled on Tue Mar  1 13:44:59 2016 on Justins-MacBook-Pro-2.local
Machine characteristics: Darwin-15.3.0-x86_64-i386-64bit
Using PETSc directory: /Users/justin/Software/petsc
Using PETSc arch: arch-darwin-c-opt
Using C compiler: /usr/local/opt/open-mpi/bin/mpicc    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -O2  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /usr/local/opt/open-mpi/bin/mpif90   -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O2   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/Users/justin/Software/petsc/arch-darwin-c-opt/include -I/Users/justin/Software/petsc/include -I/Users/justin/Software/petsc/include -I/Users/justin/Software/petsc/arch-darwin-c-opt/include -I/opt/X11/include -I/usr/local/opt/open-mpi/include -I/usr/local/Cellar/open-mpi/1.10.2/include
Using C linker: /usr/local/opt/open-mpi/bin/mpicc
Using Fortran linker: /usr/local/opt/open-mpi/bin/mpif90
Using libraries: -Wl,-rpath,/Users/justin/Software/petsc/arch-darwin-c-opt/lib -L/Users/justin/Software/petsc/arch-darwin-c-opt/lib -lpetsc -Wl,-rpath,/Users/justin/Software/petsc/arch-darwin-c-opt/lib -L/Users/justin/Software/petsc/arch-darwin-c-opt/lib -lsuperlu_dist -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lHYPRE -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.2/lib -L/usr/local/Cellar/open-mpi/1.10.2/lib -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/7.0.2/lib/darwin -lclang_rt.osx -lmpi_cxx -lc++ -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -lclang_rt.osx -lscalapack -lml -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -lflapack -lfblas -ltriangle -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11 -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lchaco -lctetgen -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -Wl,-rpath,/usr/local/Cellar/gcc/5.3.0/lib/gcc/5/gcc/x86_64-apple-darwin15.0.0/5.3.0 -L/usr/local/Cellar/gcc/5.3.0/lib/gcc/5/gcc/x86_64-apple-darwin15.0.0/5.3.0 -Wl,-rpath,/usr/local/Cellar/gcc/5.3.0/lib/gcc/5 -L/usr/local/Cellar/gcc/5.3.0/lib/gcc/5 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.2/lib -L/usr/local/Cellar/open-mpi/1.10.2/lib -ldl -lmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -lclang_rt.osx -ldl
  3 KSP preconditioned resid norm 1.159188546876e+00 true resid norm 1.299762353990e-02 ||r(i)||/||b|| 6.453193710683e-02
  4 KSP preconditioned resid norm 7.177070910360e-01 true resid norm 8.470337152644e-03 ||r(i)||/||b|| 4.205440038558e-02
  5 KSP preconditioned resid norm 5.036877443493e-01 true resid norm 6.119771032345e-03 ||r(i)||/||b|| 3.038406814562e-02
  6 KSP preconditioned resid norm 3.607350191643e-01 true resid norm 4.645502549467e-03 ||r(i)||/||b|| 2.306446847237e-02
  7 KSP preconditioned resid norm 2.882809204229e-01 true resid norm 3.925653521457e-03 ||r(i)||/||b|| 1.949048803977e-02
  8 KSP preconditioned resid norm 2.316382761182e-01 true resid norm 3.297365650418e-03 ||r(i)||/||b|| 1.637109984896e-02
  9 KSP preconditioned resid norm 1.988660674034e-01 true resid norm 2.872013000564e-03 ||r(i)||/||b|| 1.425926529980e-02
 10 KSP preconditioned resid norm 1.647703203546e-01 true resid norm 2.407596118385e-03 ||r(i)||/||b|| 1.195348063539e-02
 11 KSP preconditioned resid norm 1.392203719999e-01 true resid norm 2.011397078071e-03 ||r(i)||/||b|| 9.986390922959e-03
 12 KSP preconditioned resid norm 1.194926809320e-01 true resid norm 1.735371271678e-03 ||r(i)||/||b|| 8.615949632416e-03
 13 KSP preconditioned resid norm 1.021184952736e-01 true resid norm 1.495155793005e-03 ||r(i)||/||b|| 7.423303137139e-03
 14 KSP preconditioned resid norm 8.644061423831e-02 true resid norm 1.263475286700e-03 ||r(i)||/||b|| 6.273031949807e-03
 15 KSP preconditioned resid norm 6.765317790725e-02 true resid norm 9.953412375312e-04 ||r(i)||/||b|| 4.941772466559e-03
 16 KSP preconditioned resid norm 4.917452989312e-02 true resid norm 7.233557843802e-04 ||r(i)||/||b|| 3.591391137016e-03
 17 KSP preconditioned resid norm 3.423977253678e-02 true resid norm 4.971749871193e-04 ||r(i)||/||b|| 2.468425470347e-03
 18 KSP preconditioned resid norm 2.631060560074e-02 true resid norm 3.738334338599e-04 ||r(i)||/||b|| 1.856046651006e-03
Linear solve converged due to CONVERGED_RTOL iterations 18
iter =   1, Function value: -3.07167,  Residual: 0.109573
  0 KSP preconditioned resid norm 1.259893577029e+01 true resid norm 1.026313269991e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.076163196315e+00 true resid norm 5.540100624654e-02 ||r(i)||/||b|| 5.398060014075e-01
  2 KSP preconditioned resid norm 3.926924644678e+00 true resid norm 4.093556215397e-02 ||r(i)||/||b|| 3.988603027058e-01
  3 KSP preconditioned resid norm 2.760436063515e+00 true resid norm 2.793697358691e-02 ||r(i)||/||b|| 2.722070775441e-01
  4 KSP preconditioned resid norm 2.073295425125e+00 true resid norm 2.286240563018e-02 ||r(i)||/||b|| 2.227624478671e-01
  5 KSP preconditioned resid norm 1.585303136673e+00 true resid norm 1.796871465337e-02 ||r(i)||/||b|| 1.750802136031e-01
  6 KSP preconditioned resid norm 1.243715771571e+00 true resid norm 1.504912614755e-02 ||r(i)||/||b|| 1.466328711474e-01
  7 KSP preconditioned resid norm 9.978347072228e-01 true resid norm 1.254777197887e-02 ||r(i)||/||b|| 1.222606424935e-01
  8 KSP preconditioned resid norm 8.378703439118e-01 true resid norm 1.080192649377e-02 ||r(i)||/||b|| 1.052497985714e-01
  9 KSP preconditioned resid norm 7.117394454418e-01 true resid norm 9.313542726985e-03 ||r(i)||/||b|| 9.074756216554e-02
 10 KSP preconditioned resid norm 5.914981815645e-01 true resid norm 7.796816311280e-03 ||r(i)||/||b|| 7.596916593845e-02
 11 KSP preconditioned resid norm 5.021987913492e-01 true resid norm 6.666647757941e-03 ||r(i)||/||b|| 6.495724018065e-02
 12 KSP preconditioned resid norm 4.242144520453e-01 true resid norm 5.716567748961e-03 ||r(i)||/||b|| 5.570002762421e-02
 13 KSP preconditioned resid norm 3.706960844432e-01 true resid norm 4.949256142252e-03 ||r(i)||/||b|| 4.822363976931e-02
 14 KSP preconditioned resid norm 2.940898689805e-01 true resid norm 3.979396209126e-03 ||r(i)||/||b|| 3.877369927371e-02
 15 KSP preconditioned resid norm 2.218752385394e-01 true resid norm 3.037567667273e-03 ||r(i)||/||b|| 2.959688582511e-02
 16 KSP preconditioned resid norm 1.573384342405e-01 true resid norm 2.138833159848e-03 ||r(i)||/||b|| 2.083996399916e-02
 17 KSP preconditioned resid norm 1.116846441808e-01 true resid norm 1.508201731330e-03 ||r(i)||/||b|| 1.469533499594e-02
 18 KSP preconditioned resid norm 8.187753940027e-02 true resid norm 1.094592530108e-03 ||r(i)||/||b|| 1.066528673177e-02
 19 KSP preconditioned resid norm 6.581477182981e-02 true resid norm 8.933986961570e-04 ||r(i)||/||b|| 8.704931742377e-03
 20 KSP preconditioned resid norm 5.544477126199e-02 true resid norm 7.558950098713e-04 ||r(i)||/||b|| 7.365148945972e-03
 21 KSP preconditioned resid norm 4.524136257213e-02 true resid norm 6.145063423091e-04 ||r(i)||/||b|| 5.987512392920e-03
 22 KSP preconditioned resid norm 3.636916512230e-02 true resid norm 4.939585184330e-04 ||r(i)||/||b|| 4.812940969157e-03
 23 KSP preconditioned resid norm 2.897442891895e-02 true resid norm 3.916147831637e-04 ||r(i)||/||b|| 3.815743151865e-03
 24 KSP preconditioned resid norm 2.420348670195e-02 true resid norm 3.236188924346e-04 ||r(i)||/||b|| 3.153217461929e-03
 25 KSP preconditioned resid norm 2.052196491025e-02 true resid norm 2.706003920443e-04 ||r(i)||/||b|| 2.636625677134e-03
 26 KSP preconditioned resid norm 1.673907701468e-02 true resid norm 2.246244711370e-04 ||r(i)||/||b|| 2.188654066014e-03
 27 KSP preconditioned resid norm 1.346767941881e-02 true resid norm 1.761799869892e-04 ||r(i)||/||b|| 1.716629728374e-03
 28 KSP preconditioned resid norm 1.094577819283e-02 true resid norm 1.418412281312e-04 ||r(i)||/||b|| 1.382046128395e-03
Linear solve converged due to CONVERGED_RTOL iterations 28
iter =   2, Function value: -4.18852,  Residual: 0.0427957
  0 KSP preconditioned resid norm 3.843101011618e+00 true resid norm 3.958473238638e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.720102823578e+00 true resid norm 1.708629740305e-02 ||r(i)||/||b|| 4.316385730811e-01
  2 KSP preconditioned resid norm 1.182450086575e+00 true resid norm 1.337238853737e-02 ||r(i)||/||b|| 3.378168230833e-01
  3 KSP preconditioned resid norm 7.235300419283e-01 true resid norm 8.206989410596e-03 ||r(i)||/||b|| 2.073271414466e-01
  4 KSP preconditioned resid norm 5.090769370962e-01 true resid norm 5.835318610305e-03 ||r(i)||/||b|| 1.474133651668e-01
  5 KSP preconditioned resid norm 3.581545686067e-01 true resid norm 4.177525375005e-03 ||r(i)||/||b|| 1.055337531205e-01
  6 KSP preconditioned resid norm 2.736002623517e-01 true resid norm 3.303573873295e-03 ||r(i)||/||b|| 8.345575867609e-02
  7 KSP preconditioned resid norm 2.223025682394e-01 true resid norm 2.723729237575e-03 ||r(i)||/||b|| 6.880756982235e-02
  8 KSP preconditioned resid norm 1.970747498224e-01 true resid norm 2.494115709301e-03 ||r(i)||/||b|| 6.300701202060e-02
  9 KSP preconditioned resid norm 1.710239077957e-01 true resid norm 2.204781682215e-03 ||r(i)||/||b|| 5.569777915117e-02
 10 KSP preconditioned resid norm 1.384021788462e-01 true resid norm 1.781077039986e-03 ||r(i)||/||b|| 4.499404019208e-02
 11 KSP preconditioned resid norm 1.152419555230e-01 true resid norm 1.506967821135e-03 ||r(i)||/||b|| 3.806942046308e-02
 12 KSP preconditioned resid norm 9.427701098251e-02 true resid norm 1.249974228786e-03 ||r(i)||/||b|| 3.157718022658e-02
 13 KSP preconditioned resid norm 8.069938415637e-02 true resid norm 1.059343602856e-03 ||r(i)||/||b|| 2.676141883481e-02
 14 KSP preconditioned resid norm 6.836574657713e-02 true resid norm 8.924434542061e-04 ||r(i)||/||b|| 2.254514304897e-02
 15 KSP preconditioned resid norm 5.737419719744e-02 true resid norm 7.401804372944e-04 ||r(i)||/||b|| 1.869863436412e-02
 16 KSP preconditioned resid norm 4.522280674323e-02 true resid norm 5.820760341821e-04 ||r(i)||/||b|| 1.470455903303e-02
 17 KSP preconditioned resid norm 3.485704960179e-02 true resid norm 4.362448140807e-04 ||r(i)||/||b|| 1.102053210371e-02
 18 KSP preconditioned resid norm 2.586106216043e-02 true resid norm 3.249895469420e-04 ||r(i)||/||b|| 8.209972061194e-03
 19 KSP preconditioned resid norm 1.991574719885e-02 true resid norm 2.522562682768e-04 ||r(i)||/||b|| 6.372564700315e-03
 20 KSP preconditioned resid norm 1.579635521928e-02 true resid norm 2.061059732069e-04 ||r(i)||/||b|| 5.206703715847e-03
 21 KSP preconditioned resid norm 1.265840158049e-02 true resid norm 1.653328123841e-04 ||r(i)||/||b|| 4.176681321735e-03
 22 KSP preconditioned resid norm 1.055538254587e-02 true resid norm 1.390133173705e-04 ||r(i)||/||b|| 3.511791263703e-03
 23 KSP preconditioned resid norm 8.735494021200e-03 true resid norm 1.138313761372e-04 ||r(i)||/||b|| 2.875638390734e-03
 24 KSP preconditioned resid norm 7.052120087071e-03 true resid norm 9.361109274806e-05 ||r(i)||/||b|| 2.364828233126e-03
 25 KSP preconditioned resid norm 5.301434900698e-03 true resid norm 7.056387963448e-05 ||r(i)||/||b|| 1.782603427648e-03
 26 KSP preconditioned resid norm 4.051222768559e-03 true resid norm 5.375399903260e-05 ||r(i)||/||b|| 1.357947769052e-03
 27 KSP preconditioned resid norm 3.180852206834e-03 true resid norm 4.219439827144e-05 ||r(i)||/||b|| 1.065926071183e-03
Linear solve converged due to CONVERGED_RTOL iterations 27
iter =   3, Function value: -4.29603,  Residual: 0.017982
  0 KSP preconditioned resid norm 1.483993572318e+00 true resid norm 1.646264132252e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.092791633738e-01 true resid norm 8.233097564164e-03 ||r(i)||/||b|| 5.001079354686e-01
  2 KSP preconditioned resid norm 5.573668376524e-01 true resid norm 7.011191178333e-03 ||r(i)||/||b|| 4.258849501108e-01
  3 KSP preconditioned resid norm 4.194486171586e-01 true resid norm 5.146687745269e-03 ||r(i)||/||b|| 3.126283106362e-01
  4 KSP preconditioned resid norm 3.212283343262e-01 true resid norm 4.040788089896e-03 ||r(i)||/||b|| 2.454519910100e-01
  5 KSP preconditioned resid norm 2.499341997262e-01 true resid norm 3.091776717162e-03 ||r(i)||/||b|| 1.878056295215e-01
  6 KSP preconditioned resid norm 1.960765070701e-01 true resid norm 2.465640700445e-03 ||r(i)||/||b|| 1.497718775585e-01
  7 KSP preconditioned resid norm 1.537721413676e-01 true resid norm 1.985677497814e-03 ||r(i)||/||b|| 1.206171876622e-01
  8 KSP preconditioned resid norm 1.237135385169e-01 true resid norm 1.615522466691e-03 ||r(i)||/||b|| 9.813264074953e-02
  9 KSP preconditioned resid norm 1.031356278030e-01 true resid norm 1.387963820462e-03 ||r(i)||/||b|| 8.430991074094e-02
 10 KSP preconditioned resid norm 8.445344452882e-02 true resid norm 1.169948964343e-03 ||r(i)||/||b|| 7.106690484367e-02
 11 KSP preconditioned resid norm 7.082902906248e-02 true resid norm 9.903292630782e-04 ||r(i)||/||b|| 6.015615864288e-02
 12 KSP preconditioned resid norm 5.647649358471e-02 true resid norm 7.943929244234e-04 ||r(i)||/||b|| 4.825428124567e-02
 13 KSP preconditioned resid norm 4.703756084744e-02 true resid norm 6.542733096547e-04 ||r(i)||/||b|| 3.974291226036e-02
 14 KSP preconditioned resid norm 3.788801110225e-02 true resid norm 5.416578646445e-04 ||r(i)||/||b|| 3.290224539507e-02
 15 KSP preconditioned resid norm 3.132446471206e-02 true resid norm 4.399485567978e-04 ||r(i)||/||b|| 2.672405649730e-02
 16 KSP preconditioned resid norm 2.604037352711e-02 true resid norm 3.701158808932e-04 ||r(i)||/||b|| 2.248216878703e-02
 17 KSP preconditioned resid norm 2.137792300687e-02 true resid norm 3.000413235104e-04 ||r(i)||/||b|| 1.822558832646e-02
 18 KSP preconditioned resid norm 1.722438803955e-02 true resid norm 2.443160681325e-04 ||r(i)||/||b|| 1.484063604048e-02
 19 KSP preconditioned resid norm 1.433809948402e-02 true resid norm 2.028909369783e-04 ||r(i)||/||b|| 1.232432469392e-02
 20 KSP preconditioned resid norm 1.227089009856e-02 true resid norm 1.756378759653e-04 ||r(i)||/||b|| 1.066887582159e-02
 21 KSP preconditioned resid norm 1.033696822353e-02 true resid norm 1.487104742963e-04 ||r(i)||/||b|| 9.033208668215e-03
 22 KSP preconditioned resid norm 8.325629069824e-03 true resid norm 1.179874615063e-04 ||r(i)||/||b|| 7.166982454078e-03
 23 KSP preconditioned resid norm 6.264225530508e-03 true resid norm 8.753289562494e-05 ||r(i)||/||b|| 5.317062669962e-03
 24 KSP preconditioned resid norm 4.637253673903e-03 true resid norm 6.466322035183e-05 ||r(i)||/||b|| 3.927876401181e-03
 25 KSP preconditioned resid norm 3.495340317598e-03 true resid norm 4.849221243186e-05 ||r(i)||/||b|| 2.945591262171e-03
 26 KSP preconditioned resid norm 2.698221268934e-03 true resid norm 3.846740494807e-05 ||r(i)||/||b|| 2.336648426851e-03
 27 KSP preconditioned resid norm 2.072217752009e-03 true resid norm 2.960014152852e-05 ||r(i)||/||b|| 1.798018978159e-03
 28 KSP preconditioned resid norm 1.712795923670e-03 true resid norm 2.470250340539e-05 ||r(i)||/||b|| 1.500518836646e-03
 29 KSP preconditioned resid norm 1.437855367610e-03 true resid norm 2.078819276287e-05 ||r(i)||/||b|| 1.262749540345e-03
Linear solve converged due to CONVERGED_RTOL iterations 29
iter =   4, Function value: -4.31835,  Residual: 0.0133318
  0 KSP preconditioned resid norm 9.610750892886e-01 true resid norm 1.208969118888e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.387333144663e-01 true resid norm 5.702569185136e-03 ||r(i)||/||b|| 4.716885730200e-01
  2 KSP preconditioned resid norm 3.432509810827e-01 true resid norm 4.437889118014e-03 ||r(i)||/||b|| 3.670804364378e-01
  3 KSP preconditioned resid norm 2.711551577991e-01 true resid norm 3.452911216931e-03 ||r(i)||/||b|| 2.856078921276e-01
  4 KSP preconditioned resid norm 2.305065702176e-01 true resid norm 2.993078759854e-03 ||r(i)||/||b|| 2.475728050528e-01
  5 KSP preconditioned resid norm 1.879375710168e-01 true resid norm 2.488448996239e-03 ||r(i)||/||b|| 2.058323043460e-01
  6 KSP preconditioned resid norm 1.544275792776e-01 true resid norm 2.144586514838e-03 ||r(i)||/||b|| 1.773896852560e-01
  7 KSP preconditioned resid norm 1.268445721718e-01 true resid norm 1.700290201866e-03 ||r(i)||/||b|| 1.406396718743e-01
  8 KSP preconditioned resid norm 1.040271686305e-01 true resid norm 1.421885358976e-03 ||r(i)||/||b|| 1.176113878147e-01
  9 KSP preconditioned resid norm 8.538125841640e-02 true resid norm 1.189047278263e-03 ||r(i)||/||b|| 9.835216298627e-02
 10 KSP preconditioned resid norm 6.909498643524e-02 true resid norm 9.710179371303e-04 ||r(i)||/||b|| 8.031784451395e-02
 11 KSP preconditioned resid norm 5.903249903128e-02 true resid norm 8.292710757638e-04 ||r(i)||/||b|| 6.859323888491e-02
 12 KSP preconditioned resid norm 4.912828585881e-02 true resid norm 7.026383169101e-04 ||r(i)||/||b|| 5.811879773706e-02
 13 KSP preconditioned resid norm 4.093055826527e-02 true resid norm 5.754798371688e-04 ||r(i)||/||b|| 4.760087153409e-02
 14 KSP preconditioned resid norm 3.329785742574e-02 true resid norm 4.666316262990e-04 ||r(i)||/||b|| 3.859748102814e-02
 15 KSP preconditioned resid norm 2.758475948545e-02 true resid norm 3.854456961338e-04 ||r(i)||/||b|| 3.188217880108e-02
 16 KSP preconditioned resid norm 2.233768787114e-02 true resid norm 3.090104259890e-04 ||r(i)||/||b|| 2.555982788652e-02
 17 KSP preconditioned resid norm 1.835393111141e-02 true resid norm 2.601197722896e-04 ||r(i)||/||b|| 2.151583264002e-02
 18 KSP preconditioned resid norm 1.526932916278e-02 true resid norm 2.130051164362e-04 ||r(i)||/||b|| 1.761873923066e-02
 19 KSP preconditioned resid norm 1.226957985320e-02 true resid norm 1.757032490729e-04 ||r(i)||/||b|| 1.453331158983e-02
 20 KSP preconditioned resid norm 1.014319338951e-02 true resid norm 1.445305608837e-04 ||r(i)||/||b|| 1.195485960937e-02
 21 KSP preconditioned resid norm 8.548801572873e-03 true resid norm 1.193402946236e-04 ||r(i)||/||b|| 9.871244249264e-03
 22 KSP preconditioned resid norm 7.152436852356e-03 true resid norm 1.009706387357e-04 ||r(i)||/||b|| 8.351796349322e-03
 23 KSP preconditioned resid norm 5.723902282154e-03 true resid norm 8.195717261152e-05 ||r(i)||/||b|| 6.779095622135e-03
 24 KSP preconditioned resid norm 4.375788433630e-03 true resid norm 6.163494107916e-05 ||r(i)||/||b|| 5.098140235033e-03
 25 KSP preconditioned resid norm 3.278700649025e-03 true resid norm 4.596398305918e-05 ||r(i)||/||b|| 3.801915395610e-03
 26 KSP preconditioned resid norm 2.548090856296e-03 true resid norm 3.660914317258e-05 ||r(i)||/||b|| 3.028128891021e-03
 27 KSP preconditioned resid norm 1.918468965927e-03 true resid norm 2.759637819924e-05 ||r(i)||/||b|| 2.282637146648e-03
 28 KSP preconditioned resid norm 1.495501063256e-03 true resid norm 2.184798795078e-05 ||r(i)||/||b|| 1.807158479852e-03
 29 KSP preconditioned resid norm 1.226498586352e-03 true resid norm 1.768993845039e-05 ||r(i)||/||b|| 1.463225005007e-03
 30 KSP preconditioned resid norm 1.061578420809e-03 true resid norm 1.544284526297e-05 ||r(i)||/||b|| 1.277356470211e-03
 31 KSP preconditioned resid norm 8.917490629859e-04 true resid norm 1.299521925286e-05 ||r(i)||/||b|| 1.074900843192e-03
Linear solve converged due to CONVERGED_RTOL iterations 31
iter =   5, Function value: -4.32865,  Residual: 0.0102632
  0 KSP preconditioned resid norm 6.435870087995e-01 true resid norm 9.247148480210e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.030399541184e-01 true resid norm 4.503372852756e-03 ||r(i)||/||b|| 4.870012482652e-01
  2 KSP preconditioned resid norm 2.402179843757e-01 true resid norm 3.635502209170e-03 ||r(i)||/||b|| 3.931484626802e-01
  3 KSP preconditioned resid norm 1.834283297965e-01 true resid norm 2.713151213066e-03 ||r(i)||/||b|| 2.934040930425e-01
  4 KSP preconditioned resid norm 1.634048283213e-01 true resid norm 2.324314223983e-03 ||r(i)||/||b|| 2.513546991224e-01
  5 KSP preconditioned resid norm 1.407906295925e-01 true resid norm 1.981974232657e-03 ||r(i)||/||b|| 2.143335577338e-01
  6 KSP preconditioned resid norm 1.282427280050e-01 true resid norm 1.762612162633e-03 ||r(i)||/||b|| 1.906114264743e-01
  7 KSP preconditioned resid norm 1.118367988914e-01 true resid norm 1.560545550995e-03 ||r(i)||/||b|| 1.687596510789e-01
  8 KSP preconditioned resid norm 9.408551285381e-02 true resid norm 1.332116372492e-03 ||r(i)||/||b|| 1.440569896053e-01
  9 KSP preconditioned resid norm 7.989871907909e-02 true resid norm 1.177307651586e-03 ||r(i)||/||b|| 1.273157508075e-01
 10 KSP preconditioned resid norm 6.544231377818e-02 true resid norm 9.366989667598e-04 ||r(i)||/||b|| 1.012959799191e-01
 11 KSP preconditioned resid norm 5.636089502456e-02 true resid norm 8.268325126130e-04 ||r(i)||/||b|| 8.941486279608e-02
 12 KSP preconditioned resid norm 4.747708784864e-02 true resid norm 6.789087196234e-04 ||r(i)||/||b|| 7.341817005278e-02
 13 KSP preconditioned resid norm 3.961610596116e-02 true resid norm 5.852668840291e-04 ||r(i)||/||b|| 6.329160662680e-02
 14 KSP preconditioned resid norm 3.172094687613e-02 true resid norm 4.570215925147e-04 ||r(i)||/||b|| 4.942297547106e-02
 15 KSP preconditioned resid norm 2.611527312631e-02 true resid norm 3.804242284704e-04 ||r(i)||/||b|| 4.113962583001e-02
 16 KSP preconditioned resid norm 2.116055794635e-02 true resid norm 3.125281031158e-04 ||r(i)||/||b|| 3.379724071530e-02
 17 KSP preconditioned resid norm 1.744683233100e-02 true resid norm 2.598489469605e-04 ||r(i)||/||b|| 2.810044064033e-02
 18 KSP preconditioned resid norm 1.474553648080e-02 true resid norm 2.165874863095e-04 ||r(i)||/||b|| 2.342208376702e-02
 19 KSP preconditioned resid norm 1.255028714073e-02 true resid norm 1.807786013058e-04 ||r(i)||/||b|| 1.954965919414e-02
 20 KSP preconditioned resid norm 1.043839811711e-02 true resid norm 1.548305523355e-04 ||r(i)||/||b|| 1.674359968014e-02
 21 KSP preconditioned resid norm 8.362782871978e-03 true resid norm 1.243939008000e-04 ||r(i)||/||b|| 1.345213619812e-02
 22 KSP preconditioned resid norm 6.904368389635e-03 true resid norm 1.036676454744e-04 ||r(i)||/||b|| 1.121076899503e-02
 23 KSP preconditioned resid norm 5.486725197810e-03 true resid norm 8.257502313361e-05 ||r(i)||/||b|| 8.929782333476e-03
 24 KSP preconditioned resid norm 4.438263095230e-03 true resid norm 6.862202734919e-05 ||r(i)||/||b|| 7.420885205429e-03
 25 KSP preconditioned resid norm 3.442612079764e-03 true resid norm 5.304306747739e-05 ||r(i)||/||b|| 5.736153971239e-03
 26 KSP preconditioned resid norm 2.678114573711e-03 true resid norm 4.183180142759e-05 ||r(i)||/||b|| 4.523751458854e-03
 27 KSP preconditioned resid norm 2.060747538122e-03 true resid norm 3.078198543719e-05 ||r(i)||/||b|| 3.328808389210e-03
 28 KSP preconditioned resid norm 1.579616668233e-03 true resid norm 2.429026836533e-05 ||r(i)||/||b|| 2.626784723670e-03
 29 KSP preconditioned resid norm 1.234270772301e-03 true resid norm 1.923202377453e-05 ||r(i)||/||b|| 2.079778843791e-03
 30 KSP preconditioned resid norm 9.964136289778e-04 true resid norm 1.556535515034e-05 ||r(i)||/||b|| 1.683259999951e-03
 31 KSP preconditioned resid norm 8.268586412931e-04 true resid norm 1.282343688537e-05 ||r(i)||/||b|| 1.386744996343e-03
 32 KSP preconditioned resid norm 6.876607848451e-04 true resid norm 1.078507077050e-05 ||r(i)||/||b|| 1.166313138973e-03
 33 KSP preconditioned resid norm 5.823264724413e-04 true resid norm 9.247191580772e-06 ||r(i)||/||b|| 1.000004660957e-03
Linear solve converged due to CONVERGED_RTOL iterations 33
iter =   6, Function value: -4.33452,  Residual: 0.00824
  0 KSP preconditioned resid norm 4.580429629641e-01 true resid norm 7.293449405477e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.126275047773e-01 true resid norm 3.365940515921e-03 ||r(i)||/||b|| 4.615018667838e-01
  2 KSP preconditioned resid norm 1.607116558503e-01 true resid norm 2.594815654042e-03 ||r(i)||/||b|| 3.557734495413e-01
  3 KSP preconditioned resid norm 1.256328112808e-01 true resid norm 1.935137668528e-03 ||r(i)||/||b|| 2.653254394381e-01
  4 KSP preconditioned resid norm 1.077437255417e-01 true resid norm 1.649271067684e-03 ||r(i)||/||b|| 2.261304598131e-01
  5 KSP preconditioned resid norm 9.146357097985e-02 true resid norm 1.374490100940e-03 ||r(i)||/||b|| 1.884554241108e-01
  6 KSP preconditioned resid norm 8.362771902356e-02 true resid norm 1.217255358340e-03 ||r(i)||/||b|| 1.668970730675e-01
  7 KSP preconditioned resid norm 7.581663206661e-02 true resid norm 1.101452969704e-03 ||r(i)||/||b|| 1.510194845359e-01
  8 KSP preconditioned resid norm 6.998972666501e-02 true resid norm 1.015714068261e-03 ||r(i)||/||b|| 1.392638807501e-01
  9 KSP preconditioned resid norm 6.251274854997e-02 true resid norm 9.070776793019e-04 ||r(i)||/||b|| 1.243688176709e-01
 10 KSP preconditioned resid norm 5.408278696807e-02 true resid norm 7.923228224938e-04 ||r(i)||/||b|| 1.086348555320e-01
 11 KSP preconditioned resid norm 4.620643282733e-02 true resid norm 6.935884107807e-04 ||r(i)||/||b|| 9.509744597115e-02
 12 KSP preconditioned resid norm 3.869842941321e-02 true resid norm 5.830791548764e-04 ||r(i)||/||b|| 7.994559535006e-02
 13 KSP preconditioned resid norm 3.256453475437e-02 true resid norm 4.918515913668e-04 ||r(i)||/||b|| 6.743744475659e-02
 14 KSP preconditioned resid norm 2.709104074098e-02 true resid norm 4.126465083090e-04 ||r(i)||/||b|| 5.657768846647e-02
 15 KSP preconditioned resid norm 2.208861076936e-02 true resid norm 3.380633285978e-04 ||r(i)||/||b|| 4.635163827200e-02
 16 KSP preconditioned resid norm 1.794721974156e-02 true resid norm 2.701816765321e-04 ||r(i)||/||b|| 3.704443007848e-02
 17 KSP preconditioned resid norm 1.461692115243e-02 true resid norm 2.231806229797e-04 ||r(i)||/||b|| 3.060014686770e-02
 18 KSP preconditioned resid norm 1.188465256956e-02 true resid norm 1.786589087466e-04 ||r(i)||/||b|| 2.449580422296e-02
 19 KSP preconditioned resid norm 1.026170638346e-02 true resid norm 1.498923257873e-04 ||r(i)||/||b|| 2.055163715467e-02
 20 KSP preconditioned resid norm 8.810836405727e-03 true resid norm 1.335935464209e-04 ||r(i)||/||b|| 1.831692234960e-02
 21 KSP preconditioned resid norm 7.320019812282e-03 true resid norm 1.119977746816e-04 ||r(i)||/||b|| 1.535594044123e-02
 22 KSP preconditioned resid norm 6.001486062474e-03 true resid norm 9.512544671775e-05 ||r(i)||/||b|| 1.304258676921e-02
 23 KSP preconditioned resid norm 4.859632398865e-03 true resid norm 7.502174448089e-05 ||r(i)||/||b|| 1.028618151852e-02
 24 KSP preconditioned resid norm 3.864032476843e-03 true resid norm 6.045355476453e-05 ||r(i)||/||b|| 8.288746710045e-03
 25 KSP preconditioned resid norm 2.953626939392e-03 true resid norm 4.629350599701e-05 ||r(i)||/||b|| 6.347271835772e-03
 26 KSP preconditioned resid norm 2.293871331969e-03 true resid norm 3.626119871120e-05 ||r(i)||/||b|| 4.971748852328e-03
 27 KSP preconditioned resid norm 1.742326125749e-03 true resid norm 2.772353617591e-05 ||r(i)||/||b|| 3.801155617133e-03
 28 KSP preconditioned resid norm 1.354937057615e-03 true resid norm 2.195469985970e-05 ||r(i)||/||b|| 3.010194304386e-03
 29 KSP preconditioned resid norm 1.075416894315e-03 true resid norm 1.723365042026e-05 ||r(i)||/||b|| 2.362894353845e-03
 30 KSP preconditioned resid norm 9.231117147460e-04 true resid norm 1.473226719898e-05 ||r(i)||/||b|| 2.019931363055e-03
 31 KSP preconditioned resid norm 7.980046566862e-04 true resid norm 1.277610864821e-05 ||r(i)||/||b|| 1.751723764425e-03
 32 KSP preconditioned resid norm 6.822576558920e-04 true resid norm 1.084839674523e-05 ||r(i)||/||b|| 1.487416466766e-03
 33 KSP preconditioned resid norm 5.861395322911e-04 true resid norm 9.443538063319e-06 ||r(i)||/||b|| 1.294797226704e-03
 34 KSP preconditioned resid norm 4.755664235407e-04 true resid norm 7.622821355203e-06 ||r(i)||/||b|| 1.045159969092e-03
 35 KSP preconditioned resid norm 3.952174168403e-04 true resid norm 6.392397459573e-06 ||r(i)||/||b|| 8.764573666299e-04
Linear solve converged due to CONVERGED_RTOL iterations 35
iter =   7, Function value: -4.33756,  Residual: 0.0064391
  0 KSP preconditioned resid norm 3.365752074078e-01 true resid norm 5.647078421727e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.531642344643e-01 true resid norm 2.630845721377e-03 ||r(i)||/||b|| 4.658773129935e-01
  2 KSP preconditioned resid norm 1.226734750047e-01 true resid norm 2.022703176663e-03 ||r(i)||/||b|| 3.581857777787e-01
  3 KSP preconditioned resid norm 9.465944065661e-02 true resid norm 1.579710784144e-03 ||r(i)||/||b|| 2.797394805190e-01
  4 KSP preconditioned resid norm 8.232256940227e-02 true resid norm 1.342572239495e-03 ||r(i)||/||b|| 2.377463423085e-01
  5 KSP preconditioned resid norm 7.087246258195e-02 true resid norm 1.145327339449e-03 ||r(i)||/||b|| 2.028176791458e-01
  6 KSP preconditioned resid norm 6.130862137303e-02 true resid norm 9.752429627532e-04 ||r(i)||/||b|| 1.726986753010e-01
  7 KSP preconditioned resid norm 5.622445479685e-02 true resid norm 8.849249757586e-04 ||r(i)||/||b|| 1.567049206106e-01
  8 KSP preconditioned resid norm 5.263301324622e-02 true resid norm 7.962847091016e-04 ||r(i)||/||b|| 1.410082611989e-01
  9 KSP preconditioned resid norm 4.996806693692e-02 true resid norm 7.552014719124e-04 ||r(i)||/||b|| 1.337331298618e-01
 10 KSP preconditioned resid norm 4.504564691304e-02 true resid norm 6.740779374940e-04 ||r(i)||/||b|| 1.193675538311e-01
 11 KSP preconditioned resid norm 3.966453623321e-02 true resid norm 6.156797768173e-04 ||r(i)||/||b|| 1.090262487676e-01
 12 KSP preconditioned resid norm 3.355022162175e-02 true resid norm 5.176362863067e-04 ||r(i)||/||b|| 9.166444091075e-02
 13 KSP preconditioned resid norm 2.884353093299e-02 true resid norm 4.607489762404e-04 ||r(i)||/||b|| 8.159068138096e-02
 14 KSP preconditioned resid norm 2.443868728436e-02 true resid norm 3.810431618572e-04 ||r(i)||/||b|| 6.747615906859e-02
 15 KSP preconditioned resid norm 2.061181916384e-02 true resid norm 3.247698475475e-04 ||r(i)||/||b|| 5.751112757670e-02
 16 KSP preconditioned resid norm 1.694095875304e-02 true resid norm 2.658160255366e-04 ||r(i)||/||b|| 4.707142449339e-02
 17 KSP preconditioned resid norm 1.389239974916e-02 true resid norm 2.194435760846e-04 ||r(i)||/||b|| 3.885966506863e-02
 18 KSP preconditioned resid norm 1.150349869543e-02 true resid norm 1.826230849511e-04 ||r(i)||/||b|| 3.233939239244e-02
 19 KSP preconditioned resid norm 9.671536105962e-03 true resid norm 1.541210513702e-04 ||r(i)||/||b|| 2.729217479559e-02
 20 KSP preconditioned resid norm 8.389750981227e-03 true resid norm 1.315923210092e-04 ||r(i)||/||b|| 2.330272597294e-02
 21 KSP preconditioned resid norm 7.264631759910e-03 true resid norm 1.147613630894e-04 ||r(i)||/||b|| 2.032225418509e-02
 22 KSP preconditioned resid norm 6.178394019600e-03 true resid norm 9.763089243448e-05 ||r(i)||/||b|| 1.728874386778e-02
 23 KSP preconditioned resid norm 5.064980032463e-03 true resid norm 8.009828537702e-05 ||r(i)||/||b|| 1.418402214300e-02
 24 KSP preconditioned resid norm 4.171966914338e-03 true resid norm 6.581770418918e-05 ||r(i)||/||b|| 1.165517800071e-02
 25 KSP preconditioned resid norm 3.258142197063e-03 true resid norm 5.195216663286e-05 ||r(i)||/||b|| 9.199830913094e-03
 26 KSP preconditioned resid norm 2.543723506121e-03 true resid norm 4.046905232261e-05 ||r(i)||/||b|| 7.166369811141e-03
 27 KSP preconditioned resid norm 1.940877080259e-03 true resid norm 3.091509745004e-05 ||r(i)||/||b|| 5.474529507346e-03
 28 KSP preconditioned resid norm 1.516132620211e-03 true resid norm 2.455801701616e-05 ||r(i)||/||b|| 4.348800420705e-03
 29 KSP preconditioned resid norm 1.166994431020e-03 true resid norm 1.908250238100e-05 ||r(i)||/||b|| 3.379181402472e-03
 30 KSP preconditioned resid norm 9.374169781151e-04 true resid norm 1.520042632601e-05 ||r(i)||/||b|| 2.691732820202e-03
 31 KSP preconditioned resid norm 7.814603353036e-04 true resid norm 1.272050038155e-05 ||r(i)||/||b|| 2.252580791620e-03
 32 KSP preconditioned resid norm 6.790814550455e-04 true resid norm 1.097124865285e-05 ||r(i)||/||b|| 1.942818539697e-03
 33 KSP preconditioned resid norm 5.931655433780e-04 true resid norm 9.705766902663e-06 ||r(i)||/||b|| 1.718723590826e-03
 34 KSP preconditioned resid norm 5.094285876152e-04 true resid norm 8.295218778434e-06 ||r(i)||/||b|| 1.468939894038e-03
 35 KSP preconditioned resid norm 4.430171198913e-04 true resid norm 7.137730967573e-06 ||r(i)||/||b|| 1.263968805553e-03
 36 KSP preconditioned resid norm 3.798047602441e-04 true resid norm 6.081142846114e-06 ||r(i)||/||b|| 1.076865308390e-03
 37 KSP preconditioned resid norm 3.237513670801e-04 true resid norm 5.336678318234e-06 ||r(i)||/||b|| 9.450335057686e-04
Linear solve converged due to CONVERGED_RTOL iterations 37
iter =   8, Function value: -4.3394,  Residual: 0.00516987
  0 KSP preconditioned resid norm 2.579822664129e-01 true resid norm 4.535827584469e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.121169065460e-01 true resid norm 2.000030160469e-03 ||r(i)||/||b|| 4.409405170772e-01
  2 KSP preconditioned resid norm 8.875000413114e-02 true resid norm 1.571915348368e-03 ||r(i)||/||b|| 3.465553571194e-01
  3 KSP preconditioned resid norm 6.890568111092e-02 true resid norm 1.205003080660e-03 ||r(i)||/||b|| 2.656633344677e-01
  4 KSP preconditioned resid norm 5.989079351266e-02 true resid norm 1.011752326731e-03 ||r(i)||/||b|| 2.230579332856e-01
  5 KSP preconditioned resid norm 5.140645098381e-02 true resid norm 8.796805593396e-04 ||r(i)||/||b|| 1.939404756812e-01
  6 KSP preconditioned resid norm 4.582133364180e-02 true resid norm 7.668573161782e-04 ||r(i)||/||b|| 1.690666811948e-01
  7 KSP preconditioned resid norm 4.110024568133e-02 true resid norm 6.875780926670e-04 ||r(i)||/||b|| 1.515882338697e-01
  8 KSP preconditioned resid norm 3.675683962476e-02 true resid norm 5.965852203625e-04 ||r(i)||/||b|| 1.315273143109e-01
  9 KSP preconditioned resid norm 3.528737473146e-02 true resid norm 5.572414164908e-04 ||r(i)||/||b|| 1.228533065055e-01
 10 KSP preconditioned resid norm 3.308429905976e-02 true resid norm 5.137181186160e-04 ||r(i)||/||b|| 1.132578584722e-01
 11 KSP preconditioned resid norm 3.183638179864e-02 true resid norm 4.998432782211e-04 ||r(i)||/||b|| 1.101989149527e-01
 12 KSP preconditioned resid norm 2.900378553500e-02 true resid norm 4.605248585555e-04 ||r(i)||/||b|| 1.015305035254e-01
 13 KSP preconditioned resid norm 2.560602673425e-02 true resid norm 4.089497208156e-04 ||r(i)||/||b|| 9.015989104520e-02
 14 KSP preconditioned resid norm 2.172631779311e-02 true resid norm 3.435671032488e-04 ||r(i)||/||b|| 7.574518582347e-02
 15 KSP preconditioned resid norm 1.856238751993e-02 true resid norm 2.986154564276e-04 ||r(i)||/||b|| 6.583483407748e-02
 16 KSP preconditioned resid norm 1.552283696451e-02 true resid norm 2.486848270077e-04 ||r(i)||/||b|| 5.482678130430e-02
 17 KSP preconditioned resid norm 1.276388861151e-02 true resid norm 2.058816816931e-04 ||r(i)||/||b|| 4.539010309785e-02
 18 KSP preconditioned resid norm 1.061340188175e-02 true resid norm 1.683325449254e-04 ||r(i)||/||b|| 3.711176004613e-02
 19 KSP preconditioned resid norm 8.807746392307e-03 true resid norm 1.433985388140e-04 ||r(i)||/||b|| 3.161463617025e-02
 20 KSP preconditioned resid norm 7.384480483432e-03 true resid norm 1.180900991800e-04 ||r(i)||/||b|| 2.603496208374e-02
 21 KSP preconditioned resid norm 6.165993491753e-03 true resid norm 9.823905730110e-05 ||r(i)||/||b|| 2.165846374705e-02
 22 KSP preconditioned resid norm 5.390652069428e-03 true resid norm 8.757572639614e-05 ||r(i)||/||b|| 1.930755187785e-02
 23 KSP preconditioned resid norm 4.646336294101e-03 true resid norm 7.506049999161e-05 ||r(i)||/||b|| 1.654835828607e-02
 24 KSP preconditioned resid norm 4.019795043433e-03 true resid norm 6.611110498376e-05 ||r(i)||/||b|| 1.457531260891e-02
 25 KSP preconditioned resid norm 3.320956834943e-03 true resid norm 5.457508110541e-05 ||r(i)||/||b|| 1.203200079568e-02
 26 KSP preconditioned resid norm 2.709096312797e-03 true resid norm 4.476122687918e-05 ||r(i)||/||b|| 9.868370445217e-03
 27 KSP preconditioned resid norm 2.107803676616e-03 true resid norm 3.540727729604e-05 ||r(i)||/||b|| 7.806133861278e-03
 28 KSP preconditioned resid norm 1.691881451509e-03 true resid norm 2.756681403714e-05 ||r(i)||/||b|| 6.077570966658e-03
 29 KSP preconditioned resid norm 1.334628184064e-03 true resid norm 2.229796155957e-05 ||r(i)||/||b|| 4.915963216044e-03
 30 KSP preconditioned resid norm 1.079058365509e-03 true resid norm 1.800092925819e-05 ||r(i)||/||b|| 3.968609679925e-03
 31 KSP preconditioned resid norm 8.938550090028e-04 true resid norm 1.470331497514e-05 ||r(i)||/||b|| 3.241594769934e-03
 32 KSP preconditioned resid norm 7.585148340860e-04 true resid norm 1.260277041889e-05 ||r(i)||/||b|| 2.778494152213e-03
 33 KSP preconditioned resid norm 6.753225209717e-04 true resid norm 1.115728794747e-05 ||r(i)||/||b|| 2.459813063811e-03
 34 KSP preconditioned resid norm 5.915224853963e-04 true resid norm 9.725116108455e-06 ||r(i)||/||b|| 2.144066529723e-03
 35 KSP preconditioned resid norm 5.267672403241e-04 true resid norm 8.702267065332e-06 ||r(i)||/||b|| 1.918562137399e-03
 36 KSP preconditioned resid norm 4.544078869487e-04 true resid norm 7.489186416668e-06 ||r(i)||/||b|| 1.651117966281e-03
 37 KSP preconditioned resid norm 4.053787350824e-04 true resid norm 6.547856619253e-06 ||r(i)||/||b|| 1.443585872107e-03
 38 KSP preconditioned resid norm 3.566577067080e-04 true resid norm 5.893352338599e-06 ||r(i)||/||b|| 1.299289320163e-03
 39 KSP preconditioned resid norm 3.075832792784e-04 true resid norm 5.126232656792e-06 ||r(i)||/||b|| 1.130164796022e-03
 40 KSP preconditioned resid norm 2.514006833538e-04 true resid norm 4.102750449524e-06 ||r(i)||/||b|| 9.045208119400e-04
Linear solve converged due to CONVERGED_RTOL iterations 40
iter =   9, Function value: -4.34051,  Residual: 0.00411428
  0 KSP preconditioned resid norm 1.833039581210e-01 true resid norm 3.554527501002e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 8.879425844837e-02 true resid norm 1.589678744969e-03 ||r(i)||/||b|| 4.472264582342e-01
  2 KSP preconditioned resid norm 6.744331047980e-02 true resid norm 1.250288961979e-03 ||r(i)||/||b|| 3.517454743637e-01
  3 KSP preconditioned resid norm 5.076655139940e-02 true resid norm 9.317217176885e-04 ||r(i)||/||b|| 2.621225232962e-01
  4 KSP preconditioned resid norm 4.268624539738e-02 true resid norm 7.673129645816e-04 ||r(i)||/||b|| 2.158691877796e-01
  5 KSP preconditioned resid norm 3.675425616122e-02 true resid norm 6.627844536611e-04 ||r(i)||/||b|| 1.864620412908e-01
  6 KSP preconditioned resid norm 3.264888429126e-02 true resid norm 5.750294707113e-04 ||r(i)||/||b|| 1.617738139736e-01
  7 KSP preconditioned resid norm 2.938683806963e-02 true resid norm 5.189918474182e-04 ||r(i)||/||b|| 1.460086740845e-01
  8 KSP preconditioned resid norm 2.591483167169e-02 true resid norm 4.526142272403e-04 ||r(i)||/||b|| 1.273345689723e-01
  9 KSP preconditioned resid norm 2.398179250353e-02 true resid norm 4.012635115053e-04 ||r(i)||/||b|| 1.128880030868e-01
 10 KSP preconditioned resid norm 2.190806300749e-02 true resid norm 3.666991806483e-04 ||r(i)||/||b|| 1.031639734240e-01
 11 KSP preconditioned resid norm 2.138070086376e-02 true resid norm 3.418997966547e-04 ||r(i)||/||b|| 9.618712938873e-02
 12 KSP preconditioned resid norm 2.046278803230e-02 true resid norm 3.258822767504e-04 ||r(i)||/||b|| 9.168089898265e-02
 13 KSP preconditioned resid norm 1.902760737693e-02 true resid norm 3.094631955219e-04 ||r(i)||/||b|| 8.706169678942e-02
 14 KSP preconditioned resid norm 1.657474384314e-02 true resid norm 2.686344692801e-04 ||r(i)||/||b|| 7.557529635216e-02
 15 KSP preconditioned resid norm 1.436826862556e-02 true resid norm 2.340245997034e-04 ||r(i)||/||b|| 6.583845522011e-02
 16 KSP preconditioned resid norm 1.239020745933e-02 true resid norm 2.043306878958e-04 ||r(i)||/||b|| 5.748462709551e-02
 17 KSP preconditioned resid norm 1.062911795441e-02 true resid norm 1.766593783541e-04 ||r(i)||/||b|| 4.969982038521e-02
 18 KSP preconditioned resid norm 8.878952061488e-03 true resid norm 1.483095825529e-04 ||r(i)||/||b|| 4.172413422348e-02
 19 KSP preconditioned resid norm 7.460327150062e-03 true resid norm 1.227674316610e-04 ||r(i)||/||b|| 3.453832657825e-02
 20 KSP preconditioned resid norm 6.148364822331e-03 true resid norm 1.032712793961e-04 ||r(i)||/||b|| 2.905344785404e-02
 21 KSP preconditioned resid norm 5.194243108305e-03 true resid norm 8.522588715271e-05 ||r(i)||/||b|| 2.397671339684e-02
 22 KSP preconditioned resid norm 4.523621154593e-03 true resid norm 7.284344833090e-05 ||r(i)||/||b|| 2.049314523811e-02
 23 KSP preconditioned resid norm 3.920907681455e-03 true resid norm 6.413926502911e-05 ||r(i)||/||b|| 1.804438564930e-02
 24 KSP preconditioned resid norm 3.491419448943e-03 true resid norm 5.755834691931e-05 ||r(i)||/||b|| 1.619296711112e-02
 25 KSP preconditioned resid norm 2.996127446382e-03 true resid norm 5.016877571631e-05 ||r(i)||/||b|| 1.411404911122e-02
 26 KSP preconditioned resid norm 2.582373074783e-03 true resid norm 4.334681073825e-05 ||r(i)||/||b|| 1.219481653357e-02
 27 KSP preconditioned resid norm 2.149445960971e-03 true resid norm 3.646036383815e-05 ||r(i)||/||b|| 1.025744317012e-02
 28 KSP preconditioned resid norm 1.779882954843e-03 true resid norm 3.042160969776e-05 ||r(i)||/||b|| 8.558552350260e-03
 29 KSP preconditioned resid norm 1.434978879237e-03 true resid norm 2.460696179076e-05 ||r(i)||/||b|| 6.922709638291e-03
 30 KSP preconditioned resid norm 1.161834179649e-03 true resid norm 1.994990043985e-05 ||r(i)||/||b|| 5.612532308225e-03
 31 KSP preconditioned resid norm 9.591045801937e-04 true resid norm 1.649800230840e-05 ||r(i)||/||b|| 4.641405166719e-03
 32 KSP preconditioned resid norm 8.349627410909e-04 true resid norm 1.389434173803e-05 ||r(i)||/||b|| 3.908913838510e-03
 33 KSP preconditioned resid norm 7.451066133756e-04 true resid norm 1.252123319435e-05 ||r(i)||/||b|| 3.522615366127e-03
 34 KSP preconditioned resid norm 6.554433879995e-04 true resid norm 1.105269281989e-05 ||r(i)||/||b|| 3.109468928508e-03
 35 KSP preconditioned resid norm 5.813404412631e-04 true resid norm 9.942805922060e-06 ||r(i)||/||b|| 2.797222955585e-03
 36 KSP preconditioned resid norm 5.059758616976e-04 true resid norm 8.572359779432e-06 ||r(i)||/||b|| 2.411673500069e-03
 37 KSP preconditioned resid norm 4.462905228749e-04 true resid norm 7.501400824829e-06 ||r(i)||/||b|| 2.110379177743e-03
 38 KSP preconditioned resid norm 3.934664628627e-04 true resid norm 6.490357855655e-06 ||r(i)||/||b|| 1.825941100139e-03
 39 KSP preconditioned resid norm 3.396466705822e-04 true resid norm 5.732168274411e-06 ||r(i)||/||b|| 1.612638606058e-03
 40 KSP preconditioned resid norm 2.866064092110e-04 true resid norm 4.796976387692e-06 ||r(i)||/||b|| 1.349539815444e-03
 41 KSP preconditioned resid norm 2.360390847727e-04 true resid norm 4.020520754430e-06 ||r(i)||/||b|| 1.131098508394e-03
 42 KSP preconditioned resid norm 1.910885139084e-04 true resid norm 3.206412742634e-06 ||r(i)||/||b|| 9.020644070780e-04
 43 KSP preconditioned resid norm 1.579551639226e-04 true resid norm 2.673893225665e-06 ||r(i)||/||b|| 7.522499755343e-04
Linear solve converged due to CONVERGED_RTOL iterations 43
iter =  10, Function value: -4.34113,  Residual: 0.00298855
  0 KSP preconditioned resid norm 1.355014589832e-01 true resid norm 2.588223194387e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.012446726422e-02 true resid norm 1.185069120093e-03 ||r(i)||/||b|| 4.578697550748e-01
  2 KSP preconditioned resid norm 4.731899881235e-02 true resid norm 8.977931228669e-04 ||r(i)||/||b|| 3.468762372634e-01
  3 KSP preconditioned resid norm 3.606079042143e-02 true resid norm 7.008147838552e-04 ||r(i)||/||b|| 2.707706141321e-01
  4 KSP preconditioned resid norm 2.969142059466e-02 true resid norm 5.644621681368e-04 ||r(i)||/||b|| 2.180886754129e-01
  5 KSP preconditioned resid norm 2.522151861445e-02 true resid norm 4.693515049702e-04 ||r(i)||/||b|| 1.813412019443e-01
  6 KSP preconditioned resid norm 2.239765975149e-02 true resid norm 4.043289484193e-04 ||r(i)||/||b|| 1.562187331047e-01
  7 KSP preconditioned resid norm 2.042044702367e-02 true resid norm 3.687606253574e-04 ||r(i)||/||b|| 1.424763622230e-01
  8 KSP preconditioned resid norm 1.793609142814e-02 true resid norm 3.197767042271e-04 ||r(i)||/||b|| 1.235506678561e-01
  9 KSP preconditioned resid norm 1.636631443158e-02 true resid norm 2.977039840275e-04 ||r(i)||/||b|| 1.150225315472e-01
 10 KSP preconditioned resid norm 1.463158356454e-02 true resid norm 2.527668957506e-04 ||r(i)||/||b|| 9.766039354672e-02
 11 KSP preconditioned resid norm 1.359310576102e-02 true resid norm 2.363040576682e-04 ||r(i)||/||b|| 9.129972182486e-02
 12 KSP preconditioned resid norm 1.286224536085e-02 true resid norm 2.112872641904e-04 ||r(i)||/||b|| 8.163409734085e-02
 13 KSP preconditioned resid norm 1.259279399902e-02 true resid norm 2.112246905553e-04 ||r(i)||/||b|| 8.160992105062e-02
 14 KSP preconditioned resid norm 1.195160247692e-02 true resid norm 1.992313019942e-04 ||r(i)||/||b|| 7.697609017116e-02
 15 KSP preconditioned resid norm 1.090168247084e-02 true resid norm 1.848003831448e-04 ||r(i)||/||b|| 7.140048182303e-02
 16 KSP preconditioned resid norm 9.623490590758e-03 true resid norm 1.621835826501e-04 ||r(i)||/||b|| 6.266213169010e-02
 17 KSP preconditioned resid norm 8.379685259433e-03 true resid norm 1.389316983124e-04 ||r(i)||/||b|| 5.367840710711e-02
 18 KSP preconditioned resid norm 7.257510958402e-03 true resid norm 1.201722648553e-04 ||r(i)||/||b|| 4.643041029690e-02
 19 KSP preconditioned resid norm 6.091792690922e-03 true resid norm 1.026968778306e-04 ||r(i)||/||b|| 3.967852465480e-02
 20 KSP preconditioned resid norm 5.034040531644e-03 true resid norm 8.493946364578e-05 ||r(i)||/||b|| 3.281767346417e-02
 21 KSP preconditioned resid norm 4.054874404469e-03 true resid norm 7.028344407248e-05 ||r(i)||/||b|| 2.715509397524e-02
 22 KSP preconditioned resid norm 3.381469789440e-03 true resid norm 5.853532176524e-05 ||r(i)||/||b|| 2.261602550050e-02
 23 KSP preconditioned resid norm 2.895777112221e-03 true resid norm 5.039461915632e-05 ||r(i)||/||b|| 1.947073933408e-02
 24 KSP preconditioned resid norm 2.557453608211e-03 true resid norm 4.459005024131e-05 ||r(i)||/||b|| 1.722805449623e-02
 25 KSP preconditioned resid norm 2.199291578139e-03 true resid norm 3.894087540815e-05 ||r(i)||/||b|| 1.504540856160e-02
 26 KSP preconditioned resid norm 1.917724735237e-03 true resid norm 3.380611069985e-05 ||r(i)||/||b|| 1.306151292252e-02
 27 KSP preconditioned resid norm 1.643916347925e-03 true resid norm 2.893782290733e-05 ||r(i)||/||b|| 1.118057475494e-02
 28 KSP preconditioned resid norm 1.395505924678e-03 true resid norm 2.444692255239e-05 ||r(i)||/||b|| 9.445446051718e-03
 29 KSP preconditioned resid norm 1.184960913935e-03 true resid norm 2.048240192598e-05 ||r(i)||/||b|| 7.913692285269e-03
 30 KSP preconditioned resid norm 9.906203557454e-04 true resid norm 1.732828297856e-05 ||r(i)||/||b|| 6.695049722194e-03
 31 KSP preconditioned resid norm 8.020149598787e-04 true resid norm 1.430148845691e-05 ||r(i)||/||b|| 5.525600917233e-03
 32 KSP preconditioned resid norm 6.668165062323e-04 true resid norm 1.169868474700e-05 ||r(i)||/||b|| 4.519967509902e-03
 33 KSP preconditioned resid norm 5.708870454613e-04 true resid norm 1.004488020556e-05 ||r(i)||/||b|| 3.880994586301e-03
 34 KSP preconditioned resid norm 5.011561459315e-04 true resid norm 8.745360819835e-06 ||r(i)||/||b|| 3.378905203694e-03
 35 KSP preconditioned resid norm 4.538996590237e-04 true resid norm 8.083021967301e-06 ||r(i)||/||b|| 3.123000359795e-03
 36 KSP preconditioned resid norm 4.052298291182e-04 true resid norm 7.247052739467e-06 ||r(i)||/||b|| 2.800010739098e-03
 37 KSP preconditioned resid norm 3.654320848330e-04 true resid norm 6.610483296785e-06 ||r(i)||/||b|| 2.554062304642e-03
 38 KSP preconditioned resid norm 3.287952541535e-04 true resid norm 5.949959230776e-06 ||r(i)||/||b|| 2.298858631543e-03
 39 KSP preconditioned resid norm 2.925502372200e-04 true resid norm 5.193052836614e-06 ||r(i)||/||b|| 2.006416157569e-03
 40 KSP preconditioned resid norm 2.567116543052e-04 true resid norm 4.505880439325e-06 ||r(i)||/||b|| 1.740916490161e-03
 41 KSP preconditioned resid norm 2.241839110101e-04 true resid norm 3.964562676466e-06 ||r(i)||/||b|| 1.531770013136e-03
 42 KSP preconditioned resid norm 1.917980758634e-04 true resid norm 3.272694059385e-06 ||r(i)||/||b|| 1.264455888689e-03
 43 KSP preconditioned resid norm 1.579157331175e-04 true resid norm 2.726086700967e-06 ||r(i)||/||b|| 1.053265694736e-03
 44 KSP preconditioned resid norm 1.333939443028e-04 true resid norm 2.342338560644e-06 ||r(i)||/||b|| 9.049986746596e-04
Linear solve converged due to CONVERGED_RTOL iterations 44
iter =  11, Function value: -4.34146,  Residual: 0.00215526
  0 KSP preconditioned resid norm 9.767510809572e-02 true resid norm 1.871873166738e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.447912449374e-02 true resid norm 8.597916860474e-04 ||r(i)||/||b|| 4.593215509070e-01
  2 KSP preconditioned resid norm 3.391126026814e-02 true resid norm 6.790517732531e-04 ||r(i)||/||b|| 3.627659102760e-01
  3 KSP preconditioned resid norm 2.551660470840e-02 true resid norm 4.969266544986e-04 ||r(i)||/||b|| 2.654702590585e-01
  4 KSP preconditioned resid norm 2.138869351108e-02 true resid norm 4.301255956870e-04 ||r(i)||/||b|| 2.297835148930e-01
  5 KSP preconditioned resid norm 1.797333352373e-02 true resid norm 3.569151843760e-04 ||r(i)||/||b|| 1.906727393277e-01
  6 KSP preconditioned resid norm 1.589721247293e-02 true resid norm 3.096163398104e-04 ||r(i)||/||b|| 1.654045505390e-01
  7 KSP preconditioned resid norm 1.402668952356e-02 true resid norm 2.683332065331e-04 ||r(i)||/||b|| 1.433501004775e-01
  8 KSP preconditioned resid norm 1.264232814535e-02 true resid norm 2.386820221617e-04 ||r(i)||/||b|| 1.275097193564e-01
  9 KSP preconditioned resid norm 1.153515844579e-02 true resid norm 2.192127559343e-04 ||r(i)||/||b|| 1.171087656095e-01
 10 KSP preconditioned resid norm 1.027149964569e-02 true resid norm 1.889140606114e-04 ||r(i)||/||b|| 1.009224684494e-01
 11 KSP preconditioned resid norm 9.295029114594e-03 true resid norm 1.720318578229e-04 ||r(i)||/||b|| 9.190358667442e-02
 12 KSP preconditioned resid norm 8.514863726230e-03 true resid norm 1.485924981201e-04 ||r(i)||/||b|| 7.938171280004e-02
 13 KSP preconditioned resid norm 8.134321600176e-03 true resid norm 1.407953596122e-04 ||r(i)||/||b|| 7.521629248926e-02
 14 KSP preconditioned resid norm 7.836499445723e-03 true resid norm 1.308447336611e-04 ||r(i)||/||b|| 6.990042700867e-02
 15 KSP preconditioned resid norm 7.679285374892e-03 true resid norm 1.286029244689e-04 ||r(i)||/||b|| 6.870279822056e-02
 16 KSP preconditioned resid norm 7.315842126898e-03 true resid norm 1.215655713215e-04 ||r(i)||/||b|| 6.494327365853e-02
 17 KSP preconditioned resid norm 6.716935624831e-03 true resid norm 1.134903453501e-04 ||r(i)||/||b|| 6.062929228684e-02
 18 KSP preconditioned resid norm 5.950989705366e-03 true resid norm 1.003725240006e-04 ||r(i)||/||b|| 5.362143428528e-02
 19 KSP preconditioned resid norm 5.072521582935e-03 true resid norm 8.548190168077e-05 ||r(i)||/||b|| 4.566650305145e-02
 20 KSP preconditioned resid norm 4.294912918507e-03 true resid norm 7.329123405880e-05 ||r(i)||/||b|| 3.915395303546e-02
 21 KSP preconditioned resid norm 3.496779207965e-03 true resid norm 6.121748118575e-05 ||r(i)||/||b|| 3.270386171111e-02
 22 KSP preconditioned resid norm 2.806901318342e-03 true resid norm 5.053505591344e-05 ||r(i)||/||b|| 2.699705130209e-02
 23 KSP preconditioned resid norm 2.245942433781e-03 true resid norm 3.906191453189e-05 ||r(i)||/||b|| 2.086782118895e-02
 24 KSP preconditioned resid norm 1.908384165432e-03 true resid norm 3.455934107146e-05 ||r(i)||/||b|| 1.846243735182e-02
 25 KSP preconditioned resid norm 1.655990273586e-03 true resid norm 2.994399229443e-05 ||r(i)||/||b|| 1.599680620809e-02
 26 KSP preconditioned resid norm 1.485171068062e-03 true resid norm 2.636287711030e-05 ||r(i)||/||b|| 1.408368770852e-02
 27 KSP preconditioned resid norm 1.305810567640e-03 true resid norm 2.349856017283e-05 ||r(i)||/||b|| 1.255350019989e-02
 28 KSP preconditioned resid norm 1.127576789964e-03 true resid norm 2.034496874086e-05 ||r(i)||/||b|| 1.086877524737e-02
 29 KSP preconditioned resid norm 9.427755064193e-04 true resid norm 1.652882375750e-05 ||r(i)||/||b|| 8.830098134428e-03
 30 KSP preconditioned resid norm 7.942150154752e-04 true resid norm 1.400701976490e-05 ||r(i)||/||b|| 7.482889339832e-03
 31 KSP preconditioned resid norm 6.768023028294e-04 true resid norm 1.179320581633e-05 ||r(i)||/||b|| 6.300216289162e-03
 32 KSP preconditioned resid norm 5.485715993737e-04 true resid norm 9.723296036885e-06 ||r(i)||/||b|| 5.194420332350e-03
 33 KSP preconditioned resid norm 4.525499428935e-04 true resid norm 7.994024543963e-06 ||r(i)||/||b|| 4.270601601653e-03
 34 KSP preconditioned resid norm 3.784462248637e-04 true resid norm 6.555432133635e-06 ||r(i)||/||b|| 3.502070679851e-03
 35 KSP preconditioned resid norm 3.334912485972e-04 true resid norm 5.775082421396e-06 ||r(i)||/||b|| 3.085188956183e-03
 36 KSP preconditioned resid norm 3.039367900330e-04 true resid norm 5.318695306417e-06 ||r(i)||/||b|| 2.841375901384e-03
 37 KSP preconditioned resid norm 2.806058246862e-04 true resid norm 4.995317445387e-06 ||r(i)||/||b|| 2.668619612776e-03
 38 KSP preconditioned resid norm 2.537053603600e-04 true resid norm 4.576686973120e-06 ||r(i)||/||b|| 2.444977071334e-03
 39 KSP preconditioned resid norm 2.357952324330e-04 true resid norm 4.236244236811e-06 ||r(i)||/||b|| 2.263104312881e-03
 40 KSP preconditioned resid norm 2.127143973842e-04 true resid norm 3.954017992327e-06 ||r(i)||/||b|| 2.112332214910e-03
 41 KSP preconditioned resid norm 1.917592314648e-04 true resid norm 3.532027434661e-06 ||r(i)||/||b|| 1.886894634435e-03
 42 KSP preconditioned resid norm 1.663338272883e-04 true resid norm 2.977883429240e-06 ||r(i)||/||b|| 1.590857480173e-03
 43 KSP preconditioned resid norm 1.394729597535e-04 true resid norm 2.507820943865e-06 ||r(i)||/||b|| 1.339738711162e-03
 44 KSP preconditioned resid norm 1.171556138355e-04 true resid norm 2.102800608327e-06 ||r(i)||/||b|| 1.123367034526e-03
 45 KSP preconditioned resid norm 9.983998718950e-05 true resid norm 1.768369525693e-06 ||r(i)||/||b|| 9.447058471246e-04
 46 KSP preconditioned resid norm 8.720480360193e-05 true resid norm 1.548023800029e-06 ||r(i)||/||b|| 8.269918216344e-04
Linear solve converged due to CONVERGED_RTOL iterations 46
iter =  12, Function value: -4.34164,  Residual: 0.00146073
  0 KSP preconditioned resid norm 6.455740207494e-02 true resid norm 1.261393601962e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.717693121053e-02 true resid norm 5.430111708023e-04 ||r(i)||/||b|| 4.304851157940e-01
  2 KSP preconditioned resid norm 2.009335255709e-02 true resid norm 4.281987600836e-04 ||r(i)||/||b|| 3.394648263774e-01
  3 KSP preconditioned resid norm 1.489901087553e-02 true resid norm 3.004970000154e-04 ||r(i)||/||b|| 2.382261964449e-01
  4 KSP preconditioned resid norm 1.264022354170e-02 true resid norm 2.509717065536e-04 ||r(i)||/||b|| 1.989638334642e-01
  5 KSP preconditioned resid norm 1.074400315485e-02 true resid norm 2.118740912466e-04 ||r(i)||/||b|| 1.679682621800e-01
  6 KSP preconditioned resid norm 9.355384800220e-03 true resid norm 1.839730026950e-04 ||r(i)||/||b|| 1.458490057416e-01
  7 KSP preconditioned resid norm 8.246310678715e-03 true resid norm 1.598524745544e-04 ||r(i)||/||b|| 1.267268791484e-01
  8 KSP preconditioned resid norm 7.143299925729e-03 true resid norm 1.371378929509e-04 ||r(i)||/||b|| 1.087193503579e-01
  9 KSP preconditioned resid norm 6.575941837735e-03 true resid norm 1.257787178532e-04 ||r(i)||/||b|| 9.971409214187e-02
 10 KSP preconditioned resid norm 5.995211903527e-03 true resid norm 1.114112423766e-04 ||r(i)||/||b|| 8.832393172385e-02
 11 KSP preconditioned resid norm 5.455608691473e-03 true resid norm 1.034840083271e-04 ||r(i)||/||b|| 8.203942700056e-02
 12 KSP preconditioned resid norm 4.846115483961e-03 true resid norm 8.783734201343e-05 ||r(i)||/||b|| 6.963515739799e-02
 13 KSP preconditioned resid norm 4.442227094113e-03 true resid norm 8.017344044220e-05 ||r(i)||/||b|| 6.355941580606e-02
 14 KSP preconditioned resid norm 4.068728434642e-03 true resid norm 7.023299594577e-05 ||r(i)||/||b|| 5.567889026592e-02
 15 KSP preconditioned resid norm 3.931727186105e-03 true resid norm 6.762200293258e-05 ||r(i)||/||b|| 5.360896299728e-02
 16 KSP preconditioned resid norm 3.877404688477e-03 true resid norm 6.557143021900e-05 ||r(i)||/||b|| 5.198332234840e-02
 17 KSP preconditioned resid norm 3.757860433998e-03 true resid norm 6.538020782720e-05 ||r(i)||/||b|| 5.183172621576e-02
 18 KSP preconditioned resid norm 3.491143843725e-03 true resid norm 6.011104574090e-05 ||r(i)||/||b|| 4.765447172667e-02
 19 KSP preconditioned resid norm 3.131239458112e-03 true resid norm 5.324700711622e-05 ||r(i)||/||b|| 4.221284064974e-02
 20 KSP preconditioned resid norm 2.725586708230e-03 true resid norm 4.776207817929e-05 ||r(i)||/||b|| 3.786453182021e-02
 21 KSP preconditioned resid norm 2.297721629622e-03 true resid norm 4.043822848795e-05 ||r(i)||/||b|| 3.205837450345e-02
 22 KSP preconditioned resid norm 1.934630935658e-03 true resid norm 3.421841377981e-05 ||r(i)||/||b|| 2.712746737147e-02
 23 KSP preconditioned resid norm 1.570857267959e-03 true resid norm 2.825731046973e-05 ||r(i)||/||b|| 2.240165989885e-02
 24 KSP preconditioned resid norm 1.296059639247e-03 true resid norm 2.333899334784e-05 ||r(i)||/||b|| 1.850254616128e-02
 25 KSP preconditioned resid norm 1.082244744923e-03 true resid norm 1.969109171808e-05 ||r(i)||/||b|| 1.561058474329e-02
 26 KSP preconditioned resid norm 9.410615628634e-04 true resid norm 1.761685011599e-05 ||r(i)||/||b|| 1.396618001597e-02
 27 KSP preconditioned resid norm 8.407826162447e-04 true resid norm 1.565606047533e-05 ||r(i)||/||b|| 1.241171704928e-02
 28 KSP preconditioned resid norm 7.336206018538e-04 true resid norm 1.390455953873e-05 ||r(i)||/||b|| 1.102317271715e-02
 29 KSP preconditioned resid norm 6.158076043400e-04 true resid norm 1.153058899468e-05 ||r(i)||/||b|| 9.141150689795e-03
 30 KSP preconditioned resid norm 5.158032084613e-04 true resid norm 9.575942688494e-06 ||r(i)||/||b|| 7.591557998709e-03
 31 KSP preconditioned resid norm 4.360941254513e-04 true resid norm 7.906191601281e-06 ||r(i)||/||b|| 6.267822818337e-03
 32 KSP preconditioned resid norm 3.693846355875e-04 true resid norm 6.763994379291e-06 ||r(i)||/||b|| 5.362318604416e-03
 33 KSP preconditioned resid norm 3.037706193016e-04 true resid norm 5.582361804382e-06 ||r(i)||/||b|| 4.425551069626e-03
 34 KSP preconditioned resid norm 2.467756109857e-04 true resid norm 4.503043366032e-06 ||r(i)||/||b|| 3.569895517963e-03
 35 KSP preconditioned resid norm 2.056480131895e-04 true resid norm 3.719079000113e-06 ||r(i)||/||b|| 2.948388983683e-03
 36 KSP preconditioned resid norm 1.739542866337e-04 true resid norm 3.193927490558e-06 ||r(i)||/||b|| 2.532062542247e-03
 37 KSP preconditioned resid norm 1.541731994926e-04 true resid norm 2.837028684289e-06 ||r(i)||/||b|| 2.249122462550e-03
 38 KSP preconditioned resid norm 1.382493420293e-04 true resid norm 2.563795333716e-06 ||r(i)||/||b|| 2.032510177417e-03
 39 KSP preconditioned resid norm 1.270546963222e-04 true resid norm 2.380284716257e-06 ||r(i)||/||b|| 1.887027738649e-03
 40 KSP preconditioned resid norm 1.201117220012e-04 true resid norm 2.223154210367e-06 ||r(i)||/||b|| 1.762458765376e-03
 41 KSP preconditioned resid norm 1.143084003052e-04 true resid norm 2.116918081367e-06 ||r(i)||/||b|| 1.678237528773e-03
 42 KSP preconditioned resid norm 1.059480531597e-04 true resid norm 1.964934677518e-06 ||r(i)||/||b|| 1.557749043964e-03
 43 KSP preconditioned resid norm 9.310980550027e-05 true resid norm 1.728760891765e-06 ||r(i)||/||b|| 1.370516616761e-03
 44 KSP preconditioned resid norm 7.961074494863e-05 true resid norm 1.457674857826e-06 ||r(i)||/||b|| 1.155606668338e-03
 45 KSP preconditioned resid norm 6.755577354014e-05 true resid norm 1.236310714170e-06 ||r(i)||/||b|| 9.801149397359e-04
 46 KSP preconditioned resid norm 5.763709063664e-05 true resid norm 1.055904052875e-06 ||r(i)||/||b|| 8.370932365858e-04
iter =  13, Function value: -4.34171,  Residual: 0.00103052
  0 KSP preconditioned resid norm 4.305778440717e-02 true resid norm 8.882832839077e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.866733254678e-02 true resid norm 3.806870755500e-04 ||r(i)||/||b|| 4.285649436915e-01
  2 KSP preconditioned resid norm 1.387485870514e-02 true resid norm 2.899670414103e-04 ||r(i)||/||b|| 3.264353238020e-01
  3 KSP preconditioned resid norm 1.054706664774e-02 true resid norm 2.182515176046e-04 ||r(i)||/||b|| 2.457003543334e-01
  4 KSP preconditioned resid norm 8.829774255510e-03 true resid norm 1.808023563680e-04 ||r(i)||/||b|| 2.035413247592e-01
  5 KSP preconditioned resid norm 7.227238511185e-03 true resid norm 1.482027307450e-04 ||r(i)||/||b|| 1.668417423021e-01
  6 KSP preconditioned resid norm 6.274614013672e-03 true resid norm 1.286551934101e-04 ||r(i)||/||b|| 1.448357700081e-01
  7 KSP preconditioned resid norm 5.563167791389e-03 true resid norm 1.096548415837e-04 ||r(i)||/||b|| 1.234458010977e-01
  8 KSP preconditioned resid norm 4.927369567783e-03 true resid norm 9.688685117595e-05 ||r(i)||/||b|| 1.090720189507e-01
  9 KSP preconditioned resid norm 4.509100936677e-03 true resid norm 8.611529414250e-05 ||r(i)||/||b|| 9.694575559687e-02
 10 KSP preconditioned resid norm 3.986093329875e-03 true resid norm 7.478018535613e-05 ||r(i)||/||b|| 8.418506428170e-02
 11 KSP preconditioned resid norm 3.629519790101e-03 true resid norm 6.935757419514e-05 ||r(i)||/||b|| 7.808046762969e-02
 12 KSP preconditioned resid norm 3.320360502980e-03 true resid norm 6.098241566708e-05 ||r(i)||/||b|| 6.865199061138e-02
 13 KSP preconditioned resid norm 3.022372079745e-03 true resid norm 5.409334890054e-05 ||r(i)||/||b|| 6.089650664434e-02
 14 KSP preconditioned resid norm 2.682989027395e-03 true resid norm 4.639992155210e-05 ||r(i)||/||b|| 5.223550008504e-02
 15 KSP preconditioned resid norm 2.468089977432e-03 true resid norm 4.277543013990e-05 ||r(i)||/||b|| 4.815516729272e-02
 16 KSP preconditioned resid norm 2.368370671189e-03 true resid norm 3.949742486699e-05 ||r(i)||/||b|| 4.446489715898e-02
 17 KSP preconditioned resid norm 2.344832635754e-03 true resid norm 3.910624687143e-05 ||r(i)||/||b|| 4.402452188383e-02
 18 KSP preconditioned resid norm 2.285912627720e-03 true resid norm 3.891576064630e-05 ||r(i)||/||b|| 4.381007877926e-02
 19 KSP preconditioned resid norm 2.156732567947e-03 true resid norm 3.626329568410e-05 ||r(i)||/||b|| 4.082402127909e-02
 20 KSP preconditioned resid norm 1.958894185824e-03 true resid norm 3.348550568186e-05 ||r(i)||/||b|| 3.769687698563e-02
 21 KSP preconditioned resid norm 1.717245991115e-03 true resid norm 2.971442397052e-05 ||r(i)||/||b|| 3.345151767328e-02
 22 KSP preconditioned resid norm 1.511091496934e-03 true resid norm 2.655182115970e-05 ||r(i)||/||b|| 2.989116382208e-02
 23 KSP preconditioned resid norm 1.293388578849e-03 true resid norm 2.286998288137e-05 ||r(i)||/||b|| 2.574627182081e-02
 24 KSP preconditioned resid norm 1.056132747084e-03 true resid norm 1.884334345898e-05 ||r(i)||/||b|| 2.121321407298e-02
 25 KSP preconditioned resid norm 8.562228867453e-04 true resid norm 1.558879005274e-05 ||r(i)||/||b|| 1.754934527661e-02
 26 KSP preconditioned resid norm 7.195012507283e-04 true resid norm 1.304229533415e-05 ||r(i)||/||b|| 1.468258557876e-02
 27 KSP preconditioned resid norm 6.204484474287e-04 true resid norm 1.121758585536e-05 ||r(i)||/||b|| 1.262838787871e-02
 28 KSP preconditioned resid norm 5.561380128987e-04 true resid norm 1.024856361205e-05 ||r(i)||/||b|| 1.153749462329e-02
 29 KSP preconditioned resid norm 4.854856028322e-04 true resid norm 9.024684791925e-06 ||r(i)||/||b|| 1.015969224618e-02
 30 KSP preconditioned resid norm 4.094208527779e-04 true resid norm 7.668260305111e-06 ||r(i)||/||b|| 8.632674332649e-03
 31 KSP preconditioned resid norm 3.454541047504e-04 true resid norm 6.348967346901e-06 ||r(i)||/||b|| 7.147457868363e-03
 32 KSP preconditioned resid norm 2.883309471338e-04 true resid norm 5.268097897053e-06 ||r(i)||/||b|| 5.930650719754e-03
 33 KSP preconditioned resid norm 2.439044408736e-04 true resid norm 4.456091079734e-06 ||r(i)||/||b|| 5.016520248058e-03
 34 KSP preconditioned resid norm 1.979913220066e-04 true resid norm 3.578419114364e-06 ||r(i)||/||b|| 4.028466120203e-03
 35 KSP preconditioned resid norm 1.606742109242e-04 true resid norm 2.980515576477e-06 ||r(i)||/||b|| 3.355366053231e-03
 36 KSP preconditioned resid norm 1.306813537739e-04 true resid norm 2.428865938742e-06 ||r(i)||/||b|| 2.734337100274e-03
 37 KSP preconditioned resid norm 1.093838545574e-04 true resid norm 2.013581574616e-06 ||r(i)||/||b|| 2.266823671114e-03
 38 KSP preconditioned resid norm 9.145505812450e-05 true resid norm 1.683619309346e-06 ||r(i)||/||b|| 1.895363044477e-03
 39 KSP preconditioned resid norm 7.894914294029e-05 true resid norm 1.493274213360e-06 ||r(i)||/||b|| 1.681078818450e-03
 40 KSP preconditioned resid norm 7.090839260285e-05 true resid norm 1.320203835816e-06 ||r(i)||/||b|| 1.486241900229e-03
 41 KSP preconditioned resid norm 6.635249422512e-05 true resid norm 1.239589657233e-06 ||r(i)||/||b|| 1.395489118944e-03
 42 KSP preconditioned resid norm 6.288731607602e-05 true resid norm 1.175979760628e-06 ||r(i)||/||b|| 1.323879197023e-03
 43 KSP preconditioned resid norm 5.905177059529e-05 true resid norm 1.120464566624e-06 ||r(i)||/||b|| 1.261382024094e-03
 44 KSP preconditioned resid norm 5.449605296760e-05 true resid norm 1.011912663492e-06 ||r(i)||/||b|| 1.139177874699e-03
 45 KSP preconditioned resid norm 4.838624685786e-05 true resid norm 8.862532380221e-07 ||r(i)||/||b|| 9.977146413511e-04
 46 KSP preconditioned resid norm 4.191730284728e-05 true resid norm 7.688530028500e-07 ||r(i)||/||b|| 8.655493318164e-04
iter =  14, Function value: -4.34174,  Residual: 0.000620684
  0 KSP preconditioned resid norm 2.402035244627e-02 true resid norm 5.339168201708e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.005169555035e-02 true resid norm 2.139104501739e-04 ||r(i)||/||b|| 4.006437746341e-01
  2 KSP preconditioned resid norm 7.363602420795e-03 true resid norm 1.589007495974e-04 ||r(i)||/||b|| 2.976133052834e-01
  3 KSP preconditioned resid norm 5.615333235684e-03 true resid norm 1.189712983314e-04 ||r(i)||/||b|| 2.228274027653e-01
  4 KSP preconditioned resid norm 4.569319499047e-03 true resid norm 9.546511590363e-05 ||r(i)||/||b|| 1.788014767414e-01
  5 KSP preconditioned resid norm 3.843614652573e-03 true resid norm 8.030064747427e-05 ||r(i)||/||b|| 1.503991716323e-01
  6 KSP preconditioned resid norm 3.286931866635e-03 true resid norm 6.851087142543e-05 ||r(i)||/||b|| 1.283174997250e-01
  7 KSP preconditioned resid norm 2.909764575702e-03 true resid norm 5.969740322140e-05 ||r(i)||/||b|| 1.118103063363e-01
  8 KSP preconditioned resid norm 2.560108247941e-03 true resid norm 5.226781684000e-05 ||r(i)||/||b|| 9.789505568167e-02
  9 KSP preconditioned resid norm 2.361791406234e-03 true resid norm 4.682578677847e-05 ||r(i)||/||b|| 8.770240046658e-02
 10 KSP preconditioned resid norm 2.030964277877e-03 true resid norm 3.975533367409e-05 ||r(i)||/||b|| 7.445978881386e-02
 11 KSP preconditioned resid norm 1.876696481237e-03 true resid norm 3.646196218185e-05 ||r(i)||/||b|| 6.829146564475e-02
 12 KSP preconditioned resid norm 1.737092693866e-03 true resid norm 3.296989362510e-05 ||r(i)||/||b|| 6.175099262569e-02
 13 KSP preconditioned resid norm 1.590909324106e-03 true resid norm 3.021238295063e-05 ||r(i)||/||b|| 5.658631046866e-02
 14 KSP preconditioned resid norm 1.378549779595e-03 true resid norm 2.550058971026e-05 ||r(i)||/||b|| 4.776135298023e-02
 15 KSP preconditioned resid norm 1.218147458692e-03 true resid norm 2.239303572678e-05 ||r(i)||/||b|| 4.194105688526e-02
 16 KSP preconditioned resid norm 1.105855363960e-03 true resid norm 1.996214424593e-05 ||r(i)||/||b|| 3.738811644770e-02
 17 KSP preconditioned resid norm 1.067246776560e-03 true resid norm 1.892812596241e-05 ||r(i)||/||b|| 3.545145095139e-02
 18 KSP preconditioned resid norm 1.049832452344e-03 true resid norm 1.878030765664e-05 ||r(i)||/||b|| 3.517459451947e-02
 19 KSP preconditioned resid norm 1.016713350745e-03 true resid norm 1.811420320167e-05 ||r(i)||/||b|| 3.392701356715e-02
 20 KSP preconditioned resid norm 9.631374866222e-04 true resid norm 1.754812965838e-05 ||r(i)||/||b|| 3.286678560299e-02
 21 KSP preconditioned resid norm 8.690392146218e-04 true resid norm 1.598229846049e-05 ||r(i)||/||b|| 2.993406061899e-02
 22 KSP preconditioned resid norm 7.646752572079e-04 true resid norm 1.397800194111e-05 ||r(i)||/||b|| 2.618011160735e-02
 23 KSP preconditioned resid norm 6.619477960943e-04 true resid norm 1.208731092475e-05 ||r(i)||/||b|| 2.263894012719e-02
 24 KSP preconditioned resid norm 5.772340446918e-04 true resid norm 1.078484427565e-05 ||r(i)||/||b|| 2.019948401738e-02
 25 KSP preconditioned resid norm 4.824611134121e-04 true resid norm 8.988524018777e-06 ||r(i)||/||b|| 1.683506433811e-02
 26 KSP preconditioned resid norm 4.065140645115e-04 true resid norm 7.622302355070e-06 ||r(i)||/||b|| 1.427619821498e-02
 27 KSP preconditioned resid norm 3.451085886825e-04 true resid norm 6.593436198134e-06 ||r(i)||/||b|| 1.234918239891e-02
 28 KSP preconditioned resid norm 3.014214577278e-04 true resid norm 5.793960868658e-06 ||r(i)||/||b|| 1.085180434436e-02
 29 KSP preconditioned resid norm 2.662875361109e-04 true resid norm 5.154969201310e-06 ||r(i)||/||b|| 9.655004312582e-03
 30 KSP preconditioned resid norm 2.301038932806e-04 true resid norm 4.472793599721e-06 ||r(i)||/||b|| 8.377322891400e-03
 31 KSP preconditioned resid norm 1.972764393458e-04 true resid norm 3.786728345361e-06 ||r(i)||/||b|| 7.092356341480e-03
 32 KSP preconditioned resid norm 1.672312259828e-04 true resid norm 3.217524714976e-06 ||r(i)||/||b|| 6.026265877795e-03
 33 KSP preconditioned resid norm 1.436479925554e-04 true resid norm 2.709069124722e-06 ||r(i)||/||b|| 5.073953511814e-03
 34 KSP preconditioned resid norm 1.218532747452e-04 true resid norm 2.284889524896e-06 ||r(i)||/||b|| 4.279485939710e-03
 35 KSP preconditioned resid norm 1.032066259022e-04 true resid norm 1.966043176416e-06 ||r(i)||/||b|| 3.682302377713e-03
 36 KSP preconditioned resid norm 8.523820576686e-05 true resid norm 1.619993311847e-06 ||r(i)||/||b|| 3.034167965206e-03
 37 KSP preconditioned resid norm 7.169430493900e-05 true resid norm 1.377594134746e-06 ||r(i)||/||b|| 2.580166203240e-03
 38 KSP preconditioned resid norm 6.032491407240e-05 true resid norm 1.142523352317e-06 ||r(i)||/||b|| 2.139890164822e-03
 39 KSP preconditioned resid norm 5.154017530069e-05 true resid norm 9.776557093166e-07 ||r(i)||/||b|| 1.831101161046e-03
 40 KSP preconditioned resid norm 4.480232878254e-05 true resid norm 8.471161728846e-07 ||r(i)||/||b|| 1.586607016077e-03
 41 KSP preconditioned resid norm 3.957567682810e-05 true resid norm 7.587499400200e-07 ||r(i)||/||b|| 1.421101398861e-03
 42 KSP preconditioned resid norm 3.685474014314e-05 true resid norm 7.021556056847e-07 ||r(i)||/||b|| 1.315102988252e-03
 43 KSP preconditioned resid norm 3.519210350291e-05 true resid norm 6.746854316690e-07 ||r(i)||/||b|| 1.263652700533e-03
 44 KSP preconditioned resid norm 3.390331473089e-05 true resid norm 6.551911891888e-07 ||r(i)||/||b|| 1.227140941128e-03
 45 KSP preconditioned resid norm 3.073212207656e-05 true resid norm 6.055564785563e-07 ||r(i)||/||b|| 1.134177564143e-03
 46 KSP preconditioned resid norm 2.707091965923e-05 true resid norm 5.242855612490e-07 ||r(i)||/||b|| 9.819611247334e-04
 47 KSP preconditioned resid norm 2.333701818418e-05 true resid norm 4.413986325229e-07 ||r(i)||/||b|| 8.267179752488e-04
Linear solve converged due to CONVERGED_RTOL iterations 47
iter =  15, Function value: -4.34175,  Residual: 0.000372228
  0 KSP preconditioned resid norm 1.468915558432e-02 true resid norm 3.188464339552e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.943738246377e-03 true resid norm 1.275880478697e-04 ||r(i)||/||b|| 4.001551665077e-01
  2 KSP preconditioned resid norm 4.309035745184e-03 true resid norm 9.371732602572e-05 ||r(i)||/||b|| 2.939262166529e-01
  3 KSP preconditioned resid norm 3.141224930749e-03 true resid norm 6.694644422830e-05 ||r(i)||/||b|| 2.099645380939e-01
  4 KSP preconditioned resid norm 2.571099685655e-03 true resid norm 5.537940750719e-05 ||r(i)||/||b|| 1.736867708390e-01
  5 KSP preconditioned resid norm 2.156168519818e-03 true resid norm 4.485205775213e-05 ||r(i)||/||b|| 1.406697801062e-01
  6 KSP preconditioned resid norm 1.813483042259e-03 true resid norm 3.799038487326e-05 ||r(i)||/||b|| 1.191494739396e-01
  7 KSP preconditioned resid norm 1.575959129263e-03 true resid norm 3.352546447886e-05 ||r(i)||/||b|| 1.051461170915e-01
  8 KSP preconditioned resid norm 1.372976650767e-03 true resid norm 2.752667934342e-05 ||r(i)||/||b|| 8.633209097546e-02
  9 KSP preconditioned resid norm 1.247681568701e-03 true resid norm 2.597832137766e-05 ||r(i)||/||b|| 8.147596651908e-02
 10 KSP preconditioned resid norm 1.100660177018e-03 true resid norm 2.228613482898e-05 ||r(i)||/||b|| 6.989613950682e-02
 11 KSP preconditioned resid norm 9.849405795635e-04 true resid norm 1.953766099398e-05 ||r(i)||/||b|| 6.127608438841e-02
 12 KSP preconditioned resid norm 8.783945830029e-04 true resid norm 1.704306238606e-05 ||r(i)||/||b|| 5.345225968079e-02
 13 KSP preconditioned resid norm 8.313440720431e-04 true resid norm 1.589187781057e-05 ||r(i)||/||b|| 4.984179253139e-02
 14 KSP preconditioned resid norm 7.541589433437e-04 true resid norm 1.431939982132e-05 ||r(i)||/||b|| 4.491002029939e-02
 15 KSP preconditioned resid norm 6.691364128828e-04 true resid norm 1.260611929153e-05 ||r(i)||/||b|| 3.953664820759e-02
 16 KSP preconditioned resid norm 5.835909018861e-04 true resid norm 1.074985294405e-05 ||r(i)||/||b|| 3.371482883060e-02
 17 KSP preconditioned resid norm 5.255990068954e-04 true resid norm 9.505653102788e-06 ||r(i)||/||b|| 2.981263734041e-02
 18 KSP preconditioned resid norm 5.092664233644e-04 true resid norm 8.841128681868e-06 ||r(i)||/||b|| 2.772848537836e-02
 19 KSP preconditioned resid norm 5.130021094982e-04 true resid norm 9.134086804730e-06 ||r(i)||/||b|| 2.864729171164e-02
 20 KSP preconditioned resid norm 5.052421836366e-04 true resid norm 8.924335429458e-06 ||r(i)||/||b|| 2.798944720427e-02
 21 KSP preconditioned resid norm 4.796021102806e-04 true resid norm 8.586508957222e-06 ||r(i)||/||b|| 2.692991999537e-02
 22 KSP preconditioned resid norm 4.378361332832e-04 true resid norm 8.040489199914e-06 ||r(i)||/||b|| 2.521743492682e-02
 23 KSP preconditioned resid norm 3.770006087237e-04 true resid norm 6.909474941827e-06 ||r(i)||/||b|| 2.167022806596e-02
 24 KSP preconditioned resid norm 3.167088592155e-04 true resid norm 5.800262669738e-06 ||r(i)||/||b|| 1.819139890570e-02
 25 KSP preconditioned resid norm 2.605101620314e-04 true resid norm 4.790474066123e-06 ||r(i)||/||b|| 1.502439279844e-02
 26 KSP preconditioned resid norm 2.144849190954e-04 true resid norm 4.076417877755e-06 ||r(i)||/||b|| 1.278489405445e-02
 27 KSP preconditioned resid norm 1.793307174561e-04 true resid norm 3.407174237512e-06 ||r(i)||/||b|| 1.068594117628e-02
 28 KSP preconditioned resid norm 1.567420077410e-04 true resid norm 3.018617895553e-06 ||r(i)||/||b|| 9.467309570029e-03
 29 KSP preconditioned resid norm 1.402555648749e-04 true resid norm 2.681541035494e-06 ||r(i)||/||b|| 8.410133374333e-03
 30 KSP preconditioned resid norm 1.276877270938e-04 true resid norm 2.488061260038e-06 ||r(i)||/||b|| 7.803321583918e-03
 31 KSP preconditioned resid norm 1.134078423370e-04 true resid norm 2.172074405323e-06 ||r(i)||/||b|| 6.812290099593e-03
 32 KSP preconditioned resid norm 9.832752555978e-05 true resid norm 1.894547971770e-06 ||r(i)||/||b|| 5.941882266862e-03
 33 KSP preconditioned resid norm 8.509918954377e-05 true resid norm 1.637123465087e-06 ||r(i)||/||b|| 5.134520228998e-03
 34 KSP preconditioned resid norm 7.196261075978e-05 true resid norm 1.378858631241e-06 ||r(i)||/||b|| 4.324522667972e-03
 35 KSP preconditioned resid norm 6.161040834711e-05 true resid norm 1.181774564199e-06 ||r(i)||/||b|| 3.706406716046e-03
 36 KSP preconditioned resid norm 5.286467547792e-05 true resid norm 1.010441421616e-06 ||r(i)||/||b|| 3.169053544308e-03
 37 KSP preconditioned resid norm 4.509528243967e-05 true resid norm 8.742939726873e-07 ||r(i)||/||b|| 2.742053476471e-03
 38 KSP preconditioned resid norm 3.836510806573e-05 true resid norm 7.372425762934e-07 ||r(i)||/||b|| 2.312218352729e-03
 39 KSP preconditioned resid norm 3.335350649020e-05 true resid norm 6.395009145553e-07 ||r(i)||/||b|| 2.005670587632e-03
 40 KSP preconditioned resid norm 2.921686595740e-05 true resid norm 5.753503065472e-07 ||r(i)||/||b|| 1.804474647592e-03
 41 KSP preconditioned resid norm 2.569134258521e-05 true resid norm 5.092718836569e-07 ||r(i)||/||b|| 1.597232490072e-03
 42 KSP preconditioned resid norm 2.305837518475e-05 true resid norm 4.500567830554e-07 ||r(i)||/||b|| 1.411515811774e-03
 43 KSP preconditioned resid norm 2.143806569419e-05 true resid norm 4.161453842421e-07 ||r(i)||/||b|| 1.305159286494e-03
 44 KSP preconditioned resid norm 2.021907568701e-05 true resid norm 3.920545293521e-07 ||r(i)||/||b|| 1.229602992540e-03
 45 KSP preconditioned resid norm 1.867451599218e-05 true resid norm 3.655614378422e-07 ||r(i)||/||b|| 1.146512549341e-03
 46 KSP preconditioned resid norm 1.714365324148e-05 true resid norm 3.357138403388e-07 ||r(i)||/||b|| 1.052901348697e-03
 47 KSP preconditioned resid norm 1.490044315100e-05 true resid norm 2.915059776699e-07 ||r(i)||/||b|| 9.142519615285e-04
 48 KSP preconditioned resid norm 1.289209906621e-05 true resid norm 2.487088051613e-07 ||r(i)||/||b|| 7.800269304448e-04
Linear solve converged due to CONVERGED_RTOL iterations 48
iter =  16, Function value: -4.34176,  Residual: 0.000189954
  0 KSP preconditioned resid norm 6.919740996378e-03 true resid norm 1.630810478291e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.803515963097e-03 true resid norm 6.186347483212e-05 ||r(i)||/||b|| 3.793419018067e-01
  2 KSP preconditioned resid norm 1.984696462777e-03 true resid norm 4.329951389104e-05 ||r(i)||/||b|| 2.655091714668e-01
  3 KSP preconditioned resid norm 1.407306227400e-03 true resid norm 3.096472987678e-05 ||r(i)||/||b|| 1.898732580455e-01
  4 KSP preconditioned resid norm 1.108594852034e-03 true resid norm 2.432673325965e-05 ||r(i)||/||b|| 1.491695913380e-01
  5 KSP preconditioned resid norm 9.085488141096e-04 true resid norm 1.970117667878e-05 ||r(i)||/||b|| 1.208060466930e-01
  6 KSP preconditioned resid norm 7.532365821783e-04 true resid norm 1.594852487577e-05 ||r(i)||/||b|| 9.779508464090e-02
  7 KSP preconditioned resid norm 6.596324747605e-04 true resid norm 1.368277164478e-05 ||r(i)||/||b|| 8.390166623848e-02
  8 KSP preconditioned resid norm 5.641524188554e-04 true resid norm 1.164606292562e-05 ||r(i)||/||b|| 7.141273054501e-02
  9 KSP preconditioned resid norm 5.154852992353e-04 true resid norm 1.025274700879e-05 ||r(i)||/||b|| 6.286902828545e-02
 10 KSP preconditioned resid norm 4.629824482631e-04 true resid norm 9.193473737474e-06 ||r(i)||/||b|| 5.637364893012e-02
 11 KSP preconditioned resid norm 4.125716405477e-04 true resid norm 8.227853791804e-06 ||r(i)||/||b|| 5.045254431052e-02
 12 KSP preconditioned resid norm 3.606802772222e-04 true resid norm 7.001757374962e-06 ||r(i)||/||b|| 4.293421871007e-02
 13 KSP preconditioned resid norm 3.253190971582e-04 true resid norm 6.301372551030e-06 ||r(i)||/||b|| 3.863951473769e-02
 14 KSP preconditioned resid norm 2.989090722505e-04 true resid norm 5.639422961564e-06 ||r(i)||/||b|| 3.458049256266e-02
 15 KSP preconditioned resid norm 2.736056759370e-04 true resid norm 5.257585999221e-06 ||r(i)||/||b|| 3.223909871324e-02
 16 KSP preconditioned resid norm 2.421272203655e-04 true resid norm 4.516397565448e-06 ||r(i)||/||b|| 2.769419025429e-02
 17 KSP preconditioned resid norm 2.099550925843e-04 true resid norm 3.899266373154e-06 ||r(i)||/||b|| 2.390999092206e-02
 18 KSP preconditioned resid norm 1.922161002573e-04 true resid norm 3.446635682806e-06 ||r(i)||/||b|| 2.113449556946e-02
 19 KSP preconditioned resid norm 1.838270219830e-04 true resid norm 3.253501555804e-06 ||r(i)||/||b|| 1.995021248093e-02
 20 KSP preconditioned resid norm 1.782437673081e-04 true resid norm 3.177269557424e-06 ||r(i)||/||b|| 1.948276393682e-02
 21 KSP preconditioned resid norm 1.756538097674e-04 true resid norm 3.153268094814e-06 ||r(i)||/||b|| 1.933558887921e-02
 22 KSP preconditioned resid norm 1.690760491498e-04 true resid norm 3.070104762396e-06 ||r(i)||/||b|| 1.882563794668e-02
 23 KSP preconditioned resid norm 1.554672356028e-04 true resid norm 2.812152600567e-06 ||r(i)||/||b|| 1.724389582972e-02
 24 KSP preconditioned resid norm 1.404078018036e-04 true resid norm 2.535393217112e-06 ||r(i)||/||b|| 1.554682932727e-02
 25 KSP preconditioned resid norm 1.204750023360e-04 true resid norm 2.164270477978e-06 ||r(i)||/||b|| 1.327113424146e-02
 26 KSP preconditioned resid norm 1.003149824142e-04 true resid norm 1.815432802409e-06 ||r(i)||/||b|| 1.113208939098e-02
 27 KSP preconditioned resid norm 8.155920077114e-05 true resid norm 1.534824880234e-06 ||r(i)||/||b|| 9.411423955543e-03
 28 KSP preconditioned resid norm 6.626153053525e-05 true resid norm 1.255192674416e-06 ||r(i)||/||b|| 7.696741535114e-03
 29 KSP preconditioned resid norm 5.623625524811e-05 true resid norm 1.072533466794e-06 ||r(i)||/||b|| 6.576689818170e-03
 30 KSP preconditioned resid norm 4.973052168679e-05 true resid norm 9.500685144794e-07 ||r(i)||/||b|| 5.825744481818e-03
 31 KSP preconditioned resid norm 4.437933230173e-05 true resid norm 8.719169684246e-07 ||r(i)||/||b|| 5.346525424207e-03
 32 KSP preconditioned resid norm 3.887376092832e-05 true resid norm 7.678036519720e-07 ||r(i)||/||b|| 4.708110857717e-03
 33 KSP preconditioned resid norm 3.453255523384e-05 true resid norm 6.671965364472e-07 ||r(i)||/||b|| 4.091196036135e-03
 34 KSP preconditioned resid norm 3.045065573385e-05 true resid norm 6.028807137866e-07 ||r(i)||/||b|| 3.696816532712e-03
 35 KSP preconditioned resid norm 2.670729920315e-05 true resid norm 5.182932887600e-07 ||r(i)||/||b|| 3.178133177701e-03
 36 KSP preconditioned resid norm 2.279843241434e-05 true resid norm 4.430091552089e-07 ||r(i)||/||b|| 2.716496865247e-03
 37 KSP preconditioned resid norm 1.937658552771e-05 true resid norm 3.798128200233e-07 ||r(i)||/||b|| 2.328981969881e-03
 38 KSP preconditioned resid norm 1.664886533804e-05 true resid norm 3.244124192427e-07 ||r(i)||/||b|| 1.989271123538e-03
 39 KSP preconditioned resid norm 1.428012688544e-05 true resid norm 2.736645091414e-07 ||r(i)||/||b|| 1.678088979586e-03
 40 KSP preconditioned resid norm 1.234392712323e-05 true resid norm 2.349020105995e-07 ||r(i)||/||b|| 1.440400424981e-03
 41 KSP preconditioned resid norm 1.108807017227e-05 true resid norm 2.103602761406e-07 ||r(i)||/||b|| 1.289912463409e-03
 42 KSP preconditioned resid norm 9.993602831274e-06 true resid norm 1.889642601597e-07 ||r(i)||/||b|| 1.158713797067e-03
 43 KSP preconditioned resid norm 8.999627355325e-06 true resid norm 1.698567571409e-07 ||r(i)||/||b|| 1.041548109986e-03
 44 KSP preconditioned resid norm 8.339819751772e-06 true resid norm 1.543197862083e-07 ||r(i)||/||b|| 9.462766413544e-04
 45 KSP preconditioned resid norm 7.591352710794e-06 true resid norm 1.462123980322e-07 ||r(i)||/||b|| 8.965627826074e-04
 46 KSP preconditioned resid norm 7.001351730062e-06 true resid norm 1.351755116981e-07 ||r(i)||/||b|| 8.288854744159e-04
 47 KSP preconditioned resid norm 6.342580178837e-06 true resid norm 1.252934122255e-07 ||r(i)||/||b|| 7.682892273098e-04
iter =  17, Function value: -4.34176,  Residual: 8.97185e-05
  0 KSP preconditioned resid norm 3.131772628445e-03 true resid norm 7.696726079340e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.163429013178e-03 true resid norm 2.620162816276e-05 ||r(i)||/||b|| 3.404256289319e-01
  2 KSP preconditioned resid norm 8.088443460012e-04 true resid norm 1.752784606246e-05 ||r(i)||/||b|| 2.277311922210e-01
  3 KSP preconditioned resid norm 5.745171861712e-04 true resid norm 1.190522274243e-05 ||r(i)||/||b|| 1.546790495038e-01
  4 KSP preconditioned resid norm 4.291150669288e-04 true resid norm 9.211156621784e-06 ||r(i)||/||b|| 1.196762951784e-01
  5 KSP preconditioned resid norm 3.451045621632e-04 true resid norm 7.188254701153e-06 ||r(i)||/||b|| 9.339366669742e-02
  6 KSP preconditioned resid norm 2.822266596850e-04 true resid norm 5.934421625190e-06 ||r(i)||/||b|| 7.710319379976e-02
  7 KSP preconditioned resid norm 2.371591700380e-04 true resid norm 5.030008802482e-06 ||r(i)||/||b|| 6.535257654528e-02
  8 KSP preconditioned resid norm 1.993562336331e-04 true resid norm 4.136406859804e-06 ||r(i)||/||b|| 5.374242005191e-02
  9 KSP preconditioned resid norm 1.770995169354e-04 true resid norm 3.683964710565e-06 ||r(i)||/||b|| 4.786404859143e-02
 10 KSP preconditioned resid norm 1.549953692279e-04 true resid norm 3.132373873775e-06 ||r(i)||/||b|| 4.069748411838e-02
 11 KSP preconditioned resid norm 1.434404536618e-04 true resid norm 2.892575466940e-06 ||r(i)||/||b|| 3.758189439409e-02
 12 KSP preconditioned resid norm 1.255664309355e-04 true resid norm 2.502509071404e-06 ||r(i)||/||b|| 3.251394223476e-02
 13 KSP preconditioned resid norm 1.121491379797e-04 true resid norm 2.201035733254e-06 ||r(i)||/||b|| 2.859703867028e-02
 14 KSP preconditioned resid norm 1.013439521543e-04 true resid norm 1.944569718653e-06 ||r(i)||/||b|| 2.526489443183e-02
 15 KSP preconditioned resid norm 9.420811629406e-05 true resid norm 1.804097719569e-06 ||r(i)||/||b|| 2.343980675642e-02
 16 KSP preconditioned resid norm 8.609868808571e-05 true resid norm 1.627104313104e-06 ||r(i)||/||b|| 2.114021333657e-02
 17 KSP preconditioned resid norm 7.389516847297e-05 true resid norm 1.395061731419e-06 ||r(i)||/||b|| 1.812539145915e-02
 18 KSP preconditioned resid norm 6.566263869315e-05 true resid norm 1.190597915189e-06 ||r(i)||/||b|| 1.546888771818e-02
 19 KSP preconditioned resid norm 6.010141556509e-05 true resid norm 1.086442580368e-06 ||r(i)||/||b|| 1.411564565465e-02
 20 KSP preconditioned resid norm 5.746872701493e-05 true resid norm 1.016774149756e-06 ||r(i)||/||b|| 1.321047597738e-02
 21 KSP preconditioned resid norm 5.504608160174e-05 true resid norm 9.784184887438e-07 ||r(i)||/||b|| 1.271213862437e-02
 22 KSP preconditioned resid norm 5.485725842319e-05 true resid norm 9.827616768284e-07 ||r(i)||/||b|| 1.276856765718e-02
 23 KSP preconditioned resid norm 5.267180223119e-05 true resid norm 9.574046568511e-07 ||r(i)||/||b|| 1.243911563153e-02
 24 KSP preconditioned resid norm 4.915420209843e-05 true resid norm 9.171520446587e-07 ||r(i)||/||b|| 1.191613206972e-02
 25 KSP preconditioned resid norm 4.292723498315e-05 true resid norm 8.125278078257e-07 ||r(i)||/||b|| 1.055679777934e-02
 26 KSP preconditioned resid norm 3.623045786492e-05 true resid norm 6.829936848732e-07 ||r(i)||/||b|| 8.873820866595e-03
 27 KSP preconditioned resid norm 3.015115522346e-05 true resid norm 5.649206297596e-07 ||r(i)||/||b|| 7.339752304242e-03
 28 KSP preconditioned resid norm 2.480151501291e-05 true resid norm 4.755141948648e-07 ||r(i)||/||b|| 6.178135871837e-03
 29 KSP preconditioned resid norm 2.070247124736e-05 true resid norm 3.967120153093e-07 ||r(i)||/||b|| 5.154295621540e-03
 30 KSP preconditioned resid norm 1.761036053456e-05 true resid norm 3.451675954707e-07 ||r(i)||/||b|| 4.484602828691e-03
 31 KSP preconditioned resid norm 1.517375677054e-05 true resid norm 2.980672554824e-07 ||r(i)||/||b|| 3.872649908673e-03
 32 KSP preconditioned resid norm 1.311092989513e-05 true resid norm 2.523513117361e-07 ||r(i)||/||b|| 3.278683808347e-03
 33 KSP preconditioned resid norm 1.149466598329e-05 true resid norm 2.275801848775e-07 ||r(i)||/||b|| 2.956844020841e-03
 34 KSP preconditioned resid norm 1.030809642601e-05 true resid norm 1.934620086580e-07 ||r(i)||/||b|| 2.513562346688e-03
 35 KSP preconditioned resid norm 9.287424934906e-06 true resid norm 1.759852981316e-07 ||r(i)||/||b|| 2.286495534822e-03
 36 KSP preconditioned resid norm 8.093773273962e-06 true resid norm 1.523592548412e-07 ||r(i)||/||b|| 1.979533288188e-03
 37 KSP preconditioned resid norm 6.925754654006e-06 true resid norm 1.315557916168e-07 ||r(i)||/||b|| 1.709243518097e-03
 38 KSP preconditioned resid norm 5.824519845048e-06 true resid norm 1.116692041707e-07 ||r(i)||/||b|| 1.450866290674e-03
 39 KSP preconditioned resid norm 5.073056512929e-06 true resid norm 9.719495681394e-08 ||r(i)||/||b|| 1.262809093269e-03
 40 KSP preconditioned resid norm 4.433635326764e-06 true resid norm 8.543104801357e-08 ||r(i)||/||b|| 1.109966070416e-03
 41 KSP preconditioned resid norm 3.909169310328e-06 true resid norm 7.642591459337e-08 ||r(i)||/||b|| 9.929665393513e-04
 42 KSP preconditioned resid norm 3.412826037230e-06 true resid norm 6.627368136190e-08 ||r(i)||/||b|| 8.610632713017e-04
 43 KSP preconditioned resid norm 3.032814740983e-06 true resid norm 6.028305311359e-08 ||r(i)||/||b|| 7.832298108595e-04
iter =  18, Function value: -4.34176,  Residual: 4.01693e-05
  0 KSP preconditioned resid norm 1.322225781123e-03 true resid norm 3.405593205026e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.995673850832e-04 true resid norm 1.060841001212e-05 ||r(i)||/||b|| 3.114996235154e-01
  2 KSP preconditioned resid norm 3.162026656298e-04 true resid norm 6.910740673871e-06 ||r(i)||/||b|| 2.029232576478e-01
  3 KSP preconditioned resid norm 2.129561435015e-04 true resid norm 4.635163402885e-06 ||r(i)||/||b|| 1.361044353754e-01
  4 KSP preconditioned resid norm 1.610534251657e-04 true resid norm 3.312701793243e-06 ||r(i)||/||b|| 9.727238674173e-02
  5 KSP preconditioned resid norm 1.309528557120e-04 true resid norm 2.794327705930e-06 ||r(i)||/||b|| 8.205112994135e-02
  6 KSP preconditioned resid norm 1.044505009707e-04 true resid norm 2.095444991044e-06 ||r(i)||/||b|| 6.152951526776e-02
  7 KSP preconditioned resid norm 8.588794457239e-05 true resid norm 1.808518531288e-06 ||r(i)||/||b|| 5.310436163131e-02
  8 KSP preconditioned resid norm 7.030760304464e-05 true resid norm 1.462630443304e-06 ||r(i)||/||b|| 4.294789058028e-02
  9 KSP preconditioned resid norm 6.258769223182e-05 true resid norm 1.314565916865e-06 ||r(i)||/||b|| 3.860020377434e-02
 10 KSP preconditioned resid norm 5.300370609825e-05 true resid norm 1.066492584710e-06 ||r(i)||/||b|| 3.131591239774e-02
 11 KSP preconditioned resid norm 4.922604245698e-05 true resid norm 9.609670821258e-07 ||r(i)||/||b|| 2.821731851906e-02
 12 KSP preconditioned resid norm 4.507403751059e-05 true resid norm 9.159920373701e-07 ||r(i)||/||b|| 2.689669558943e-02
 13 KSP preconditioned resid norm 3.913868778349e-05 true resid norm 7.502449369458e-07 ||r(i)||/||b|| 2.202978722880e-02
 14 KSP preconditioned resid norm 3.490106002883e-05 true resid norm 6.425028839991e-07 ||r(i)||/||b|| 1.886610776210e-02
 15 KSP preconditioned resid norm 3.160147421659e-05 true resid norm 5.815979895599e-07 ||r(i)||/||b|| 1.707772932779e-02
 16 KSP preconditioned resid norm 2.959889142849e-05 true resid norm 5.404933949910e-07 ||r(i)||/||b|| 1.587075620756e-02
 17 KSP preconditioned resid norm 2.699438752944e-05 true resid norm 4.971558251790e-07 ||r(i)||/||b|| 1.459821520801e-02
 18 KSP preconditioned resid norm 2.294637139104e-05 true resid norm 4.044317033311e-07 ||r(i)||/||b|| 1.187551416106e-02
 19 KSP preconditioned resid norm 2.002634881316e-05 true resid norm 3.487632986598e-07 ||r(i)||/||b|| 1.024089718482e-02
 20 KSP preconditioned resid norm 1.828337149709e-05 true resid norm 3.147138017230e-07 ||r(i)||/||b|| 9.241086142012e-03
 21 KSP preconditioned resid norm 1.773287841403e-05 true resid norm 3.009517265025e-07 ||r(i)||/||b|| 8.836983996159e-03
 22 KSP preconditioned resid norm 1.764858498352e-05 true resid norm 3.111846525294e-07 ||r(i)||/||b|| 9.137458110680e-03
 23 KSP preconditioned resid norm 1.735748058077e-05 true resid norm 3.079339485030e-07 ||r(i)||/||b|| 9.042006192887e-03
 24 KSP preconditioned resid norm 1.663649073026e-05 true resid norm 2.973049704471e-07 ||r(i)||/||b|| 8.729902620439e-03
 25 KSP preconditioned resid norm 1.485159156222e-05 true resid norm 2.701425508723e-07 ||r(i)||/||b|| 7.932319998573e-03
 26 KSP preconditioned resid norm 1.285076393590e-05 true resid norm 2.335778072460e-07 ||r(i)||/||b|| 6.858652610102e-03
 27 KSP preconditioned resid norm 1.104078002446e-05 true resid norm 2.044735202517e-07 ||r(i)||/||b|| 6.004050041851e-03
 28 KSP preconditioned resid norm 9.054699209809e-06 true resid norm 1.668979996869e-07 ||r(i)||/||b|| 4.900702745138e-03
 29 KSP preconditioned resid norm 7.358742030042e-06 true resid norm 1.348383757127e-07 ||r(i)||/||b|| 3.959321257563e-03
 30 KSP preconditioned resid norm 6.128829660537e-06 true resid norm 1.171988042733e-07 ||r(i)||/||b|| 3.441362406419e-03
 31 KSP preconditioned resid norm 5.215485372403e-06 true resid norm 9.952403620577e-08 ||r(i)||/||b|| 2.922370060490e-03
 32 KSP preconditioned resid norm 4.554934587007e-06 true resid norm 8.587417602799e-08 ||r(i)||/||b|| 2.521562936561e-03
 33 KSP preconditioned resid norm 4.051318747373e-06 true resid norm 7.558466847871e-08 ||r(i)||/||b|| 2.219427392771e-03
 34 KSP preconditioned resid norm 3.616897295405e-06 true resid norm 6.902005905012e-08 ||r(i)||/||b|| 2.026667746114e-03
 35 KSP preconditioned resid norm 3.172663661273e-06 true resid norm 5.924641615290e-08 ||r(i)||/||b|| 1.739679773423e-03
 36 KSP preconditioned resid norm 2.746270981842e-06 true resid norm 5.117596250623e-08 ||r(i)||/||b|| 1.502703330236e-03
 37 KSP preconditioned resid norm 2.408251147421e-06 true resid norm 4.488283146484e-08 ||r(i)||/||b|| 1.317915228354e-03
 38 KSP preconditioned resid norm 2.087743431004e-06 true resid norm 3.953602156157e-08 ||r(i)||/||b|| 1.160914389400e-03
 39 KSP preconditioned resid norm 1.798364630482e-06 true resid norm 3.399967529470e-08 ||r(i)||/||b|| 9.983481070060e-04
 40 KSP preconditioned resid norm 1.588946507534e-06 true resid norm 3.044228998646e-08 ||r(i)||/||b|| 8.938909656482e-04
 41 KSP preconditioned resid norm 1.413610303844e-06 true resid norm 2.704334203503e-08 ||r(i)||/||b|| 7.940860932866e-04
 42 KSP preconditioned resid norm 1.261029310369e-06 true resid norm 2.450891486848e-08 ||r(i)||/||b|| 7.196665424486e-04
Linear solve converged due to CONVERGED_RTOL iterations 42
iter =  19, Function value: -4.34176,  Residual: 1.0966e-05
  0 KSP preconditioned resid norm 2.834753235122e-04 true resid norm 9.199725805332e-06 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.671850238398e-05 true resid norm 1.828666484869e-06 ||r(i)||/||b|| 1.987740203962e-01
  2 KSP preconditioned resid norm 4.552217792547e-05 true resid norm 9.245248909205e-07 ||r(i)||/||b|| 1.004948310943e-01
  3 KSP preconditioned resid norm 2.943186668756e-05 true resid norm 6.427287078450e-07 ||r(i)||/||b|| 6.986389827754e-02
  4 KSP preconditioned resid norm 2.190845581341e-05 true resid norm 4.365062950096e-07 ||r(i)||/||b|| 4.744775053585e-02
  5 KSP preconditioned resid norm 1.677936249249e-05 true resid norm 3.471852509163e-07 ||r(i)||/||b|| 3.773865202755e-02
  6 KSP preconditioned resid norm 1.325124592687e-05 true resid norm 2.686324299984e-07 ||r(i)||/||b|| 2.920004744518e-02
  7 KSP preconditioned resid norm 1.053115442053e-05 true resid norm 2.125718099648e-07 ||r(i)||/||b|| 2.310632017332e-02
  8 KSP preconditioned resid norm 8.838476394611e-06 true resid norm 1.769783142370e-07 ||r(i)||/||b|| 1.923734663206e-02
  9 KSP preconditioned resid norm 7.544263449240e-06 true resid norm 1.509494740757e-07 ||r(i)||/||b|| 1.640804055140e-02
 10 KSP preconditioned resid norm 6.414518722724e-06 true resid norm 1.297628240184e-07 ||r(i)||/||b|| 1.410507516900e-02
 11 KSP preconditioned resid norm 5.782150395405e-06 true resid norm 1.150707779723e-07 ||r(i)||/||b|| 1.250806604536e-02
 12 KSP preconditioned resid norm 5.123523977312e-06 true resid norm 1.031619039872e-07 ||r(i)||/||b|| 1.121358464047e-02
 13 KSP preconditioned resid norm 4.443616980016e-06 true resid norm 9.182113562299e-08 ||r(i)||/||b|| 9.980855687000e-03
 14 KSP preconditioned resid norm 3.885051189303e-06 true resid norm 7.610485010864e-08 ||r(i)||/||b|| 8.272512868212e-03
 15 KSP preconditioned resid norm 3.416383814036e-06 true resid norm 6.726229292368e-08 ||r(i)||/||b|| 7.311336701436e-03
 16 KSP preconditioned resid norm 3.189219080477e-06 true resid norm 6.107952452345e-08 ||r(i)||/||b|| 6.639276628011e-03
 17 KSP preconditioned resid norm 2.951968041422e-06 true resid norm 5.647533479336e-08 ||r(i)||/||b|| 6.138806306665e-03
 18 KSP preconditioned resid norm 2.696324595003e-06 true resid norm 5.174146472721e-08 ||r(i)||/||b|| 5.624239876499e-03
 19 KSP preconditioned resid norm 2.261351223372e-06 true resid norm 4.123407995435e-08 ||r(i)||/||b|| 4.482098795863e-03
 20 KSP preconditioned resid norm 1.991584144236e-06 true resid norm 3.585961065524e-08 ||r(i)||/||b|| 3.897899938980e-03
 21 KSP preconditioned resid norm 1.853328343141e-06 true resid norm 3.450293486182e-08 ||r(i)||/||b|| 3.750430783689e-03
 22 KSP preconditioned resid norm 1.790348845217e-06 true resid norm 3.258485242794e-08 ||r(i)||/||b|| 3.541937348725e-03
 23 KSP preconditioned resid norm 1.738362162705e-06 true resid norm 3.232265380528e-08 ||r(i)||/||b|| 3.513436649008e-03
 24 KSP preconditioned resid norm 1.701662498152e-06 true resid norm 3.165686953835e-08 ||r(i)||/||b|| 3.441066637008e-03
 25 KSP preconditioned resid norm 1.585531732168e-06 true resid norm 2.958153732956e-08 ||r(i)||/||b|| 3.215480325774e-03
 26 KSP preconditioned resid norm 1.432953673649e-06 true resid norm 2.706558432705e-08 ||r(i)||/||b|| 2.941999022554e-03
 27 KSP preconditioned resid norm 1.255003533522e-06 true resid norm 2.424292985953e-08 ||r(i)||/||b|| 2.635179609970e-03
 28 KSP preconditioned resid norm 1.109305579838e-06 true resid norm 2.135413064960e-08 ||r(i)||/||b|| 2.321170337188e-03
 29 KSP preconditioned resid norm 9.359142577955e-07 true resid norm 1.796632287660e-08 ||r(i)||/||b|| 1.952919386596e-03
 30 KSP preconditioned resid norm 7.905013967673e-07 true resid norm 1.523325710354e-08 ||r(i)||/||b|| 1.655838165819e-03
 31 KSP preconditioned resid norm 6.871676730748e-07 true resid norm 1.321289950920e-08 ||r(i)||/||b|| 1.436227534253e-03
 32 KSP preconditioned resid norm 5.988365139967e-07 true resid norm 1.120803757866e-08 ||r(i)||/||b|| 1.218301264170e-03
 33 KSP preconditioned resid norm 5.262942321561e-07 true resid norm 9.983046569993e-09 ||r(i)||/||b|| 1.085146099051e-03
 34 KSP preconditioned resid norm 4.547511237936e-07 true resid norm 8.485648381441e-09 ||r(i)||/||b|| 9.223805753562e-04
 35 KSP preconditioned resid norm 3.908365301856e-07 true resid norm 7.485095789562e-09 ||r(i)||/||b|| 8.136216174207e-04
 36 KSP preconditioned resid norm 3.297970210831e-07 true resid norm 6.322608973062e-09 ||r(i)||/||b|| 6.872605887229e-04
 37 KSP preconditioned resid norm 2.820636651212e-07 true resid norm 5.549016352309e-09 ||r(i)||/||b|| 6.031719281343e-04
Linear solve converged due to CONVERGED_RTOL iterations 37
iter =  20, Function value: -4.34176,  Residual: 2.10862e-06
  0 KSP preconditioned resid norm 6.830677268940e-05 true resid norm 1.856951709240e-06 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.406384948778e-05 true resid norm 4.208735026516e-07 ||r(i)||/||b|| 2.266475216116e-01
  2 KSP preconditioned resid norm 6.835283181980e-06 true resid norm 1.645598208924e-07 ||r(i)||/||b|| 8.861825543100e-02
  3 KSP preconditioned resid norm 3.863310923639e-06 true resid norm 8.958437165489e-08 ||r(i)||/||b|| 4.824270400202e-02
  4 KSP preconditioned resid norm 2.411011793283e-06 true resid norm 4.893091319464e-08 ||r(i)||/||b|| 2.635012690485e-02
  5 KSP preconditioned resid norm 1.603763839015e-06 true resid norm 3.390054202581e-08 ||r(i)||/||b|| 1.825601702895e-02
  6 KSP preconditioned resid norm 1.271001343991e-06 true resid norm 2.612804387178e-08 ||r(i)||/||b|| 1.407039490676e-02
  7 KSP preconditioned resid norm 9.878244657498e-07 true resid norm 1.965266376892e-08 ||r(i)||/||b|| 1.058329286170e-02
  8 KSP preconditioned resid norm 7.719522165424e-07 true resid norm 1.528157234949e-08 ||r(i)||/||b|| 8.229385973502e-03
  9 KSP preconditioned resid norm 6.467074169403e-07 true resid norm 1.225663278399e-08 ||r(i)||/||b|| 6.600404697121e-03
 10 KSP preconditioned resid norm 5.414522730748e-07 true resid norm 1.015543143439e-08 ||r(i)||/||b|| 5.468872121906e-03
 11 KSP preconditioned resid norm 4.572854991498e-07 true resid norm 9.054897049528e-09 ||r(i)||/||b|| 4.876215684271e-03
 12 KSP preconditioned resid norm 3.821672457141e-07 true resid norm 7.315935548453e-09 ||r(i)||/||b|| 3.939755413160e-03
 13 KSP preconditioned resid norm 3.410203695470e-07 true resid norm 6.847446322548e-09 ||r(i)||/||b|| 3.687466016740e-03
 14 KSP preconditioned resid norm 2.979121924760e-07 true resid norm 5.960620275353e-09 ||r(i)||/||b|| 3.209895144658e-03
 15 KSP preconditioned resid norm 2.563777646275e-07 true resid norm 4.986383366849e-09 ||r(i)||/||b|| 2.685252040771e-03
 16 KSP preconditioned resid norm 2.253899930178e-07 true resid norm 4.334537331741e-09 ||r(i)||/||b|| 2.334221891810e-03
 17 KSP preconditioned resid norm 2.068360116853e-07 true resid norm 3.828015372857e-09 ||r(i)||/||b|| 2.061451223427e-03
 18 KSP preconditioned resid norm 1.923736253277e-07 true resid norm 3.689957572078e-09 ||r(i)||/||b|| 1.987104755454e-03
 19 KSP preconditioned resid norm 1.755342218892e-07 true resid norm 3.271054896781e-09 ||r(i)||/||b|| 1.761518557809e-03
 20 KSP preconditioned resid norm 1.561672957859e-07 true resid norm 2.796085708462e-09 ||r(i)||/||b|| 1.505739591692e-03
 21 KSP preconditioned resid norm 1.403465702139e-07 true resid norm 2.460272490878e-09 ||r(i)||/||b|| 1.324898476701e-03
 22 KSP preconditioned resid norm 1.359217556860e-07 true resid norm 2.386682689115e-09 ||r(i)||/||b|| 1.285269119945e-03
 23 KSP preconditioned resid norm 1.308433962007e-07 true resid norm 2.256087388359e-09 ||r(i)||/||b|| 1.214941334841e-03
 24 KSP preconditioned resid norm 1.311836867253e-07 true resid norm 2.302005923558e-09 ||r(i)||/||b|| 1.239669245088e-03
 25 KSP preconditioned resid norm 1.263097518328e-07 true resid norm 2.189126164598e-09 ||r(i)||/||b|| 1.178881579799e-03
 26 KSP preconditioned resid norm 1.155902039051e-07 true resid norm 2.148430753134e-09 ||r(i)||/||b|| 1.156966410297e-03
 27 KSP preconditioned resid norm 1.027944710442e-07 true resid norm 1.865927709926e-09 ||r(i)||/||b|| 1.004833728654e-03
 28 KSP preconditioned resid norm 9.298615403849e-08 true resid norm 1.804679271278e-09 ||r(i)||/||b|| 9.718504053168e-04
 29 KSP preconditioned resid norm 8.133107372584e-08 true resid norm 1.526532984069e-09 ||r(i)||/||b|| 8.220639106948e-04
 30 KSP preconditioned resid norm 6.718433072463e-08 true resid norm 1.300909235523e-09 ||r(i)||/||b|| 7.005616942272e-04
Linear solve converged due to CONVERGED_RTOL iterations 30
iter =  21, Function value: -4.34176,  Residual: 2.38301e-07
Tao Object: 1 MPI processes
  type: tron
      Total PG its: 63,      PG tolerance: 0.001
  TaoLineSearch Object:   1 MPI processes
    type: more-thuente
  KSP Object:   1 MPI processes
    type: cg
  total KSP iterations: 797
  Active Set subset type: subvec
  convergence tolerances: gatol=1e-12,   steptol=1e-12,   gttol=0.
  Residual in Function/Gradient:=2.38301e-07
  Objective value=-4.34176
  total number of iterations=21,                          (max: 50)
  total number of function/gradient evaluations=85,      (max: 10000)
  total number of Hessian evaluations=21
  Solution converged:    ||g(X)||/|f(X)| <= grtol
TAO solve converged due to CONVERGED_GRTOL iterations 21
it: 1	1.199163e+01	797	6.802495e+08
  Time summary:
Creating DMPlex: 	0.533826
Distributing DMPlex: 	2.31266e-05
Refining DMPlex: 	2.10193
Setting up problem: 	3.03744
Overall analysis time: 	12.1315
Overall FLOPS/s: 	5.47522e+08
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main on a arch-darwin-c-opt named Justins-MacBook-Pro-2.local with 1 processor, by justin Tue Mar  8 00:53:22 2016
Using Petsc Development GIT revision: pre-tsfc-438-gf0bfc80  GIT Date: 2016-03-01 11:52:01 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           1.785e+01      1.00000   1.785e+01
Objects:              2.415e+03      1.00000   2.415e+03
Flops:                8.229e+09      1.00000   8.229e+09  8.229e+09
Flops/sec:            4.610e+08      1.00000   4.610e+08  4.610e+08
MPI Messages:         5.500e+00      1.00000   5.500e+00  5.500e+00
MPI Message Lengths:  4.494e+06      1.00000   8.170e+05  4.494e+06
MPI Reductions:       1.000e+00      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.7852e+01 100.0%  8.2291e+09 100.0%  5.500e+00 100.0%  8.170e+05      100.0%  1.000e+00 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
CreateMesh            86 1.0 2.9466e+00 1.0 3.61e+08 1.0 0.0e+00 0.0e+00 0.0e+00 17  4  0  0  0  17  4  0  0  0   122
BuildTwoSided          5 1.0 5.4789e-04 1.0 0.00e+00 0.0 5.0e-01 4.0e+00 0.0e+00  0  0  9  0  0   0  0  9  0  0     0
VecView                1 1.0 1.3087e-02 1.0 4.02e+05 1.0 1.0e+00 1.0e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0    31
VecDot               464 1.0 6.1516e-02 1.0 1.16e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1883
VecTDot             1594 1.0 1.8452e-01 1.0 3.28e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  1775
VecNorm             1700 1.0 1.7410e-01 1.0 3.51e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  2018
VecScale             252 1.0 1.7918e-02 1.0 3.10e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1730
VecCopy             1280 1.0 1.1792e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecSet              2693 1.0 2.1445e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY             1784 1.0 1.8100e-01 1.0 3.75e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0  2072
VecAYPX             1615 1.0 1.6647e-01 1.0 2.49e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  1494
VecWAXPY               1 1.0 2.0790e-04 1.0 1.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   600
VecScatterBegin       42 1.0 4.9083e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult             1722 1.0 4.3076e+00 1.0 4.35e+09 1.0 0.0e+00 0.0e+00 0.0e+00 24 53  0  0  0  24 53  0  0  0  1010
MatSolve             818 1.0 2.3631e+00 1.0 2.01e+09 1.0 0.0e+00 0.0e+00 0.0e+00 13 24  0  0  0  13 24  0  0  0   852
MatLUFactorNum        21 1.0 5.9143e-01 1.0 2.22e+08 1.0 0.0e+00 0.0e+00 0.0e+00  3  3  0  0  0   3  3  0  0  0   376
MatILUFactorSym       21 1.0 1.3571e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatAssemblyBegin      23 1.0 1.8835e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        23 1.0 6.8571e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           21 1.0 9.0599e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      21 1.0 5.2455e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatGetOrdering        21 1.0 6.6700e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 9.4509e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           3 1.0 4.8164e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
DMPlexStratify        11 1.0 6.3346e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
DMPlexPrealloc         1 1.0 1.0882e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
DMPlexResidualFE       1 1.0 6.3628e-01 1.0 4.01e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0    63
DMPlexJacobianFE       1 1.0 1.9361e+00 1.0 8.14e+07 1.0 0.0e+00 0.0e+00 0.0e+00 11  1  0  0  0  11  1  0  0  0    42
SFSetGraph             6 1.0 2.0554e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin           9 1.0 2.5361e-03 1.0 0.00e+00 0.0 4.5e+00 7.8e+05 0.0e+00  0  0 82 78  0   0  0 82 78  0     0
SFBcastEnd             9 1.0 6.9499e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          1 1.0 3.6287e-04 1.0 0.00e+00 0.0 1.0e+00 1.0e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0     0
SFReduceEnd            1 1.0 3.8218e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       1 1.0 6.4115e-01 1.0 4.01e+07 1.0 2.0e+00 1.0e+06 0.0e+00  4  0 36 44  0   4  0 36 44  0    63
SNESJacobianEval       1 1.0 1.9377e+00 1.0 8.14e+07 1.0 2.5e+00 6.0e+05 0.0e+00 11  1 45 33  0  11  1 45 33  0    42
KSPSetUp              42 1.0 5.8956e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              21 1.0 8.0150e+00 1.0 7.45e+09 1.0 0.0e+00 0.0e+00 0.0e+00 45 91  0  0  0  45 91  0  0  0   930
PCSetUp               42 1.0 7.3451e-01 1.0 2.22e+08 1.0 0.0e+00 0.0e+00 0.0e+00  4  3  0  0  0   4  3  0  0  0   303
PCSetUpOnBlocks       21 1.0 7.3436e-01 1.0 2.22e+08 1.0 0.0e+00 0.0e+00 0.0e+00  4  3  0  0  0   4  3  0  0  0   303
PCApply              818 1.0 2.4092e+00 1.0 2.01e+09 1.0 0.0e+00 0.0e+00 0.0e+00 13 24  0  0  0  13 24  0  0  0   836
TaoSolve               1 1.0 9.4062e+00 1.0 8.03e+09 1.0 0.0e+00 0.0e+00 0.0e+00 53 98  0  0  0  53 98  0  0  0   854
TaoHessianEval        21 1.0 5.2452e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
TaoLineSearchApply      84 1.0 5.7770e-01 1.0 4.61e+08 1.0 0.0e+00 0.0e+00 0.0e+00  3  6  0  0  0   3  6  0  0  0   798
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     4              3         2432     0.
              Object     7              7         4088     0.
           Container    15             15         8640     0.
              Vector  1850           1850   1684755112     0.
      Vector Scatter    42             42        27888     0.
              Matrix    43             43    742422776     0.
    Distributed Mesh    29             29       135576     0.
    GraphPartitioner    11             11         6732     0.
Star Forest Bipartite Graph    62             62        50488     0.
     Discrete System    29             29        25056     0.
           Index Set   249            249     35249872     0.
   IS L to G Mapping     1              1       561392     0.
             Section    56             54        36288     0.
                SNES     1              1         1340     0.
      SNESLineSearch     1              1         1000     0.
              DMSNES     1              1          672     0.
       Krylov Solver     3              3         3680     0.
      Preconditioner     3              3         2824     0.
        Linear Space     2              2         1296     0.
          Dual Space     2              2         1328     0.
            FE Space     2              2         1512     0.
                 Tao     1              1         1944     0.
       TaoLineSearch     1              1          888     0.
Average time to get PetscTime(): 0.
#PETSc Option Table entries:
-al 1
-am 0
-at 0.001
-bcloc 0,1,0,1,0,0,0,1,0,1,1,1,0,0,0,1,0,1,1,1,0,1,0,1,0,1,0,0,0,1,0,1,1,1,0,1,0.45,0.55,0.45,0.55,0.45,0.55
-bcnum 7
-bcval 0,0,0,0,0,0,1
-dim 3
-dm_refine 1
-dt 0.001
-edges 3,3
-floc 0.25,0.75,0.25,0.75,0.25,0.75
-fnum 0
-ftime 0,99
-fval 1
-ksp_atol 1.0e-12
-ksp_converged_reason
-ksp_monitor_true_residual
-ksp_rtol 1.0e-3
-ksp_type cg
-log_view
-lower 0,0
-mat_petscspace_order 0
-mesh datafiles/cube_with_hole2_mesh.dat
-mu 1
-nonneg 1
-numsteps 0
-options_left 0
-pc_type bjacobi
-petscpartitioner_type parmetis
-progress 0
-simplex 1
-solution_petscspace_order 1
-tao_converged_reason
-tao_gatol 1e-12
-tao_grtol 1e-7
-tao_monitor
-tao_type tron
-tao_view
-trans datafiles/cube_with_hole2_trans.dat
-upper 1,1
-vtuname figures/cube_with_hole_2
-vtuprint 1
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco --download-ctetgen --download-exodusii --download-fblaslapack --download-hdf5 --download-hypre --download-metis --download-ml --download-mumps --download-netcdf --download-parmetis --download-scalapack --download-superlu_dist --download-triangle --with-debugging=0 --with-mpi-dir=/usr/local/opt/open-mpi --with-shared-libraries=1 COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 PETSC_ARCH=arch-darwin-c-opt
Libraries compiled on Tue Mar  1 13:44:59 2016 on Justins-MacBook-Pro-2.local
Machine characteristics: Darwin-15.3.0-x86_64-i386-64bit
Using PETSc directory: /Users/justin/Software/petsc
Using PETSc arch: arch-darwin-c-opt
Using C compiler: /usr/local/opt/open-mpi/bin/mpicc    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -O2  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /usr/local/opt/open-mpi/bin/mpif90   -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O2   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/Users/justin/Software/petsc/arch-darwin-c-opt/include -I/Users/justin/Software/petsc/include -I/Users/justin/Software/petsc/include -I/Users/justin/Software/petsc/arch-darwin-c-opt/include -I/opt/X11/include -I/usr/local/opt/open-mpi/include -I/usr/local/Cellar/open-mpi/1.10.2/include
Using C linker: /usr/local/opt/open-mpi/bin/mpicc
Using Fortran linker: /usr/local/opt/open-mpi/bin/mpif90
Using libraries: -Wl,-rpath,/Users/justin/Software/petsc/arch-darwin-c-opt/lib -L/Users/justin/Software/petsc/arch-darwin-c-opt/lib -lpetsc -Wl,-rpath,/Users/justin/Software/petsc/arch-darwin-c-opt/lib -L/Users/justin/Software/petsc/arch-darwin-c-opt/lib -lsuperlu_dist -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lHYPRE -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.2/lib -L/usr/local/Cellar/open-mpi/1.10.2/lib -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/7.0.2/lib/darwin -lclang_rt.osx -lmpi_cxx -lc++ -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -lclang_rt.osx -lscalapack -lml -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -lflapack -lfblas -ltriangle -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11 -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lchaco -lctetgen -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -Wl,-rpath,/usr/local/Cellar/gcc/5.3.0/lib/gcc/5/gcc/x86_64-apple-darwin15.0.0/5.3.0 -L/usr/local/Cellar/gcc/5.3.0/lib/gcc/5/gcc/x86_64-apple-darwin15.0.0/5.3.0 -Wl,-rpath,/usr/local/Cellar/gcc/5.3.0/lib/gcc/5 -L/usr/local/Cellar/gcc/5.3.0/lib/gcc/5 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.2/lib -L/usr/local/Cellar/open-mpi/1.10.2/lib -ldl -lmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -lclang_rt.osx -ldl
TSTEP	ANALYSIS TIME	ITER	FLOPS/s
iter =   0, Function value: -8.83019e-08,  Residual: 0.214312
  0 KSP preconditioned resid norm 2.721099185886e+01 true resid norm 2.014138134175e-01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.869407744459e+00 true resid norm 5.822300398427e-02 ||r(i)||/||b|| 2.890715537151e-01
  2 KSP preconditioned resid norm 2.242110432761e+00 true resid norm 2.437887036293e-02 ||r(i)||/||b|| 1.210387209759e-01
  3 KSP preconditioned resid norm 1.159188546876e+00 true resid norm 1.299762353990e-02 ||r(i)||/||b|| 6.453193710683e-02
  4 KSP preconditioned resid norm 7.177070910360e-01 true resid norm 8.470337152644e-03 ||r(i)||/||b|| 4.205440038558e-02
  5 KSP preconditioned resid norm 5.036877443493e-01 true resid norm 6.119771032345e-03 ||r(i)||/||b|| 3.038406814562e-02
  6 KSP preconditioned resid norm 3.607350191643e-01 true resid norm 4.645502549467e-03 ||r(i)||/||b|| 2.306446847237e-02
  7 KSP preconditioned resid norm 2.882809204229e-01 true resid norm 3.925653521457e-03 ||r(i)||/||b|| 1.949048803977e-02
  8 KSP preconditioned resid norm 2.316382761182e-01 true resid norm 3.297365650418e-03 ||r(i)||/||b|| 1.637109984896e-02
  9 KSP preconditioned resid norm 1.988660674034e-01 true resid norm 2.872013000564e-03 ||r(i)||/||b|| 1.425926529980e-02
 10 KSP preconditioned resid norm 1.647703203546e-01 true resid norm 2.407596118385e-03 ||r(i)||/||b|| 1.195348063539e-02
 11 KSP preconditioned resid norm 1.392203719999e-01 true resid norm 2.011397078071e-03 ||r(i)||/||b|| 9.986390922959e-03
 12 KSP preconditioned resid norm 1.194926809320e-01 true resid norm 1.735371271678e-03 ||r(i)||/||b|| 8.615949632416e-03
 13 KSP preconditioned resid norm 1.021184952736e-01 true resid norm 1.495155793005e-03 ||r(i)||/||b|| 7.423303137139e-03
 14 KSP preconditioned resid norm 8.644061423831e-02 true resid norm 1.263475286700e-03 ||r(i)||/||b|| 6.273031949807e-03
 15 KSP preconditioned resid norm 6.765317790725e-02 true resid norm 9.953412375312e-04 ||r(i)||/||b|| 4.941772466559e-03
 16 KSP preconditioned resid norm 4.917452989312e-02 true resid norm 7.233557843802e-04 ||r(i)||/||b|| 3.591391137016e-03
 17 KSP preconditioned resid norm 3.423977253678e-02 true resid norm 4.971749871193e-04 ||r(i)||/||b|| 2.468425470347e-03
 18 KSP preconditioned resid norm 2.631060560074e-02 true resid norm 3.738334338599e-04 ||r(i)||/||b|| 1.856046651006e-03
 19 KSP preconditioned resid norm 2.150018400123e-02 true resid norm 3.066976855480e-04 ||r(i)||/||b|| 1.522724188297e-03
 20 KSP preconditioned resid norm 1.862939289182e-02 true resid norm 2.683025907357e-04 ||r(i)||/||b|| 1.332096275738e-03
 21 KSP preconditioned resid norm 1.658811781560e-02 true resid norm 2.364991565965e-04 ||r(i)||/||b|| 1.174195317509e-03
 22 KSP preconditioned resid norm 1.519476952113e-02 true resid norm 2.152496728220e-04 ||r(i)||/||b|| 1.068693696673e-03
 23 KSP preconditioned resid norm 1.324677805794e-02 true resid norm 1.908271209032e-04 ||r(i)||/||b|| 9.474381010186e-04
 24 KSP preconditioned resid norm 1.100601436745e-02 true resid norm 1.594847078641e-04 ||r(i)||/||b|| 7.918260677264e-04
 25 KSP preconditioned resid norm 8.984870418657e-03 true resid norm 1.346950418144e-04 ||r(i)||/||b|| 6.687477861072e-04
 26 KSP preconditioned resid norm 7.748887814752e-03 true resid norm 1.165325740675e-04 ||r(i)||/||b|| 5.785728996947e-04
 27 KSP preconditioned resid norm 6.576319020263e-03 true resid norm 9.791184587025e-05 ||r(i)||/||b|| 4.861227947028e-04
 28 KSP preconditioned resid norm 5.389117734804e-03 true resid norm 7.955305562044e-05 ||r(i)||/||b|| 3.949731861516e-04
 29 KSP preconditioned resid norm 4.519456717206e-03 true resid norm 6.698616740437e-05 ||r(i)||/||b|| 3.325798080468e-04
 30 KSP preconditioned resid norm 3.932240847963e-03 true resid norm 5.810472455106e-05 ||r(i)||/||b|| 2.884843078296e-04
 31 KSP preconditioned resid norm 3.507422820066e-03 true resid norm 5.184611521829e-05 ||r(i)||/||b|| 2.574109210217e-04
 32 KSP preconditioned resid norm 3.163649589191e-03 true resid norm 4.617289029310e-05 ||r(i)||/||b|| 2.292439108801e-04
 33 KSP preconditioned resid norm 2.899170705334e-03 true resid norm 4.222325544314e-05 ||r(i)||/||b|| 2.096343578760e-04
 34 KSP preconditioned resid norm 2.630786210763e-03 true resid norm 3.849978293468e-05 ||r(i)||/||b|| 1.911476789076e-04
 35 KSP preconditioned resid norm 2.335319526879e-03 true resid norm 3.486349939426e-05 ||r(i)||/||b|| 1.730938846880e-04
 36 KSP preconditioned resid norm 2.004563524318e-03 true resid norm 3.004754039312e-05 ||r(i)||/||b|| 1.491831165067e-04
 37 KSP preconditioned resid norm 1.763532111737e-03 true resid norm 2.598370699528e-05 ||r(i)||/||b|| 1.290065788160e-04
 38 KSP preconditioned resid norm 1.525341167053e-03 true resid norm 2.271971812894e-05 ||r(i)||/||b|| 1.128011914548e-04
 39 KSP preconditioned resid norm 1.350753831797e-03 true resid norm 2.038984224621e-05 ||r(i)||/||b|| 1.012335842326e-04
 40 KSP preconditioned resid norm 1.190975949540e-03 true resid norm 1.852980047591e-05 ||r(i)||/||b|| 9.199865769637e-05
 41 KSP preconditioned resid norm 1.101875226346e-03 true resid norm 1.698851660538e-05 ||r(i)||/||b|| 8.434633313935e-05
 42 KSP preconditioned resid norm 1.015609984078e-03 true resid norm 1.600315260378e-05 ||r(i)||/||b|| 7.945409667912e-05
 43 KSP preconditioned resid norm 9.099467858429e-04 true resid norm 1.445158769249e-05 ||r(i)||/||b|| 7.175072775440e-05
 44 KSP preconditioned resid norm 7.874717640691e-04 true resid norm 1.269696798266e-05 ||r(i)||/||b|| 6.303921149811e-05
 45 KSP preconditioned resid norm 6.950984299784e-04 true resid norm 1.119490884077e-05 ||r(i)||/||b|| 5.558163390493e-05
 46 KSP preconditioned resid norm 6.280641234357e-04 true resid norm 1.023401417248e-05 ||r(i)||/||b|| 5.081088530542e-05
 47 KSP preconditioned resid norm 5.648091928453e-04 true resid norm 9.147793382121e-06 ||r(i)||/||b|| 4.541790469535e-05
 48 KSP preconditioned resid norm 5.059139546744e-04 true resid norm 8.199545371755e-06 ||r(i)||/||b|| 4.070994552275e-05
 49 KSP preconditioned resid norm 4.534691667629e-04 true resid norm 7.329873767891e-06 ||r(i)||/||b|| 3.639211056840e-05
 50 KSP preconditioned resid norm 4.032773047833e-04 true resid norm 6.578158700790e-06 ||r(i)||/||b|| 3.265991835007e-05
 51 KSP preconditioned resid norm 3.667455182101e-04 true resid norm 5.853198666589e-06 ||r(i)||/||b|| 2.906056226867e-05
 52 KSP preconditioned resid norm 3.422077910799e-04 true resid norm 5.394434941801e-06 ||r(i)||/||b|| 2.678284498105e-05
 53 KSP preconditioned resid norm 3.078427368049e-04 true resid norm 4.864002462256e-06 ||r(i)||/||b|| 2.414929929445e-05
 54 KSP preconditioned resid norm 2.725837707914e-04 true resid norm 4.311024232678e-06 ||r(i)||/||b|| 2.140381615109e-05
 55 KSP preconditioned resid norm 2.440537398852e-04 true resid norm 3.886549581636e-06 ||r(i)||/||b|| 1.929634078066e-05
 56 KSP preconditioned resid norm 2.205886873990e-04 true resid norm 3.534900723394e-06 ||r(i)||/||b|| 1.755043839057e-05
 57 KSP preconditioned resid norm 1.981433998614e-04 true resid norm 3.211010253165e-06 ||r(i)||/||b|| 1.594235369800e-05
 58 KSP preconditioned resid norm 1.725710081850e-04 true resid norm 2.800409797826e-06 ||r(i)||/||b|| 1.390376236024e-05
 59 KSP preconditioned resid norm 1.493637198409e-04 true resid norm 2.458055450818e-06 ||r(i)||/||b|| 1.220400631471e-05
 60 KSP preconditioned resid norm 1.326613587650e-04 true resid norm 2.188541658623e-06 ||r(i)||/||b|| 1.086589654150e-05
 61 KSP preconditioned resid norm 1.196363811822e-04 true resid norm 1.990902324237e-06 ||r(i)||/||b|| 9.884636462895e-06
 62 KSP preconditioned resid norm 1.064700269885e-04 true resid norm 1.766171143006e-06 ||r(i)||/||b|| 8.768867998866e-06
 63 KSP preconditioned resid norm 9.503194275123e-05 true resid norm 1.580134784957e-06 ||r(i)||/||b|| 7.845215569610e-06
 64 KSP preconditioned resid norm 8.321673701272e-05 true resid norm 1.395227470305e-06 ||r(i)||/||b|| 6.927168731040e-06
 65 KSP preconditioned resid norm 7.331502089643e-05 true resid norm 1.218974554137e-06 ||r(i)||/||b|| 6.052090139472e-06
 66 KSP preconditioned resid norm 6.338376782962e-05 true resid norm 1.079912228121e-06 ||r(i)||/||b|| 5.361659211936e-06
 67 KSP preconditioned resid norm 5.761773416199e-05 true resid norm 9.657506114892e-07 ||r(i)||/||b|| 4.794857885380e-06
 68 KSP preconditioned resid norm 5.115597006225e-05 true resid norm 8.564973454081e-07 ||r(i)||/||b|| 4.252426042065e-06
 69 KSP preconditioned resid norm 4.433976778029e-05 true resid norm 7.420093170735e-07 ||r(i)||/||b|| 3.684004113141e-06
 70 KSP preconditioned resid norm 3.880717701108e-05 true resid norm 6.520731532060e-07 ||r(i)||/||b|| 3.237479804101e-06
 71 KSP preconditioned resid norm 3.419142599030e-05 true resid norm 5.729215582166e-07 ||r(i)||/||b|| 2.844499830948e-06
 72 KSP preconditioned resid norm 3.089262210794e-05 true resid norm 5.149748252731e-07 ||r(i)||/||b|| 2.556799936088e-06
 73 KSP preconditioned resid norm 2.755749580300e-05 true resid norm 4.521312348244e-07 ||r(i)||/||b|| 2.244787619840e-06
 74 KSP preconditioned resid norm 2.385938395277e-05 true resid norm 3.977069530736e-07 ||r(i)||/||b|| 1.974576352662e-06
 75 KSP preconditioned resid norm 2.041122887719e-05 true resid norm 3.385889170726e-07 ||r(i)||/||b|| 1.681061052008e-06
 76 KSP preconditioned resid norm 1.703797060566e-05 true resid norm 2.854222974065e-07 ||r(i)||/||b|| 1.417093954797e-06
 77 KSP preconditioned resid norm 1.461212664703e-05 true resid norm 2.449915749041e-07 ||r(i)||/||b|| 1.216359348682e-06
 78 KSP preconditioned resid norm 1.269211829393e-05 true resid norm 2.133870457446e-07 ||r(i)||/||b|| 1.059445934337e-06
 79 KSP preconditioned resid norm 1.099216493157e-05 true resid norm 1.859835924467e-07 ||r(i)||/||b|| 9.233904531720e-07
 80 KSP preconditioned resid norm 9.683032618557e-06 true resid norm 1.616844376470e-07 ||r(i)||/||b|| 8.027475122167e-07
 81 KSP preconditioned resid norm 8.543548059128e-06 true resid norm 1.443513810480e-07 ||r(i)||/||b|| 7.166905715091e-07
 82 KSP preconditioned resid norm 7.618003884106e-06 true resid norm 1.276243557946e-07 ||r(i)||/||b|| 6.336425175071e-07
 83 KSP preconditioned resid norm 6.768566118849e-06 true resid norm 1.124324635935e-07 ||r(i)||/||b|| 5.582162498482e-07
 84 KSP preconditioned resid norm 6.048915101349e-06 true resid norm 1.027715482282e-07 ||r(i)||/||b|| 5.102507443975e-07
 85 KSP preconditioned resid norm 5.586006560959e-06 true resid norm 9.482762097940e-08 ||r(i)||/||b|| 4.708099180012e-07
 86 KSP preconditioned resid norm 5.142843344087e-06 true resid norm 8.829385301824e-08 ||r(i)||/||b|| 4.383703953573e-07
 87 KSP preconditioned resid norm 4.752648373166e-06 true resid norm 8.206782775325e-08 ||r(i)||/||b|| 4.074587852778e-07
 88 KSP preconditioned resid norm 4.298372318090e-06 true resid norm 7.573438983970e-08 ||r(i)||/||b|| 3.760138818420e-07
 89 KSP preconditioned resid norm 3.921677884713e-06 true resid norm 6.921783634092e-08 ||r(i)||/||b|| 3.436598273300e-07
 90 KSP preconditioned resid norm 3.512316935593e-06 true resid norm 6.235807478991e-08 ||r(i)||/||b|| 3.096017782090e-07
 91 KSP preconditioned resid norm 3.155049198093e-06 true resid norm 5.494023287162e-08 ||r(i)||/||b|| 2.727729143271e-07
 92 KSP preconditioned resid norm 2.761124951607e-06 true resid norm 4.784100607496e-08 ||r(i)||/||b|| 2.375259435449e-07
 93 KSP preconditioned resid norm 2.370740074494e-06 true resid norm 4.098097607653e-08 ||r(i)||/||b|| 2.034665616086e-07
Linear solve converged due to CONVERGED_RTOL iterations 93
iter =   1, Function value: -3.07176,  Residual: 0.109561
  0 KSP preconditioned resid norm 1.208291666398e+01 true resid norm 8.128226097570e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.920561139500e+00 true resid norm 5.609725181947e-02 ||r(i)||/||b|| 6.901536835478e-01
  2 KSP preconditioned resid norm 3.881129456473e+00 true resid norm 3.955141467913e-02 ||r(i)||/||b|| 4.865934363091e-01
  3 KSP preconditioned resid norm 2.757565946849e+00 true resid norm 2.864602877081e-02 ||r(i)||/||b|| 3.524265741006e-01
  4 KSP preconditioned resid norm 2.068896536909e+00 true resid norm 2.281479796426e-02 ||r(i)||/||b|| 2.806860647132e-01
  5 KSP preconditioned resid norm 1.596871189340e+00 true resid norm 1.846530063458e-02 ||r(i)||/||b|| 2.271750368767e-01
  6 KSP preconditioned resid norm 1.256941337146e+00 true resid norm 1.525471217664e-02 ||r(i)||/||b|| 1.876757855099e-01
  7 KSP preconditioned resid norm 1.016165013076e+00 true resid norm 1.293071073526e-02 ||r(i)||/||b|| 1.590840434314e-01
  8 KSP preconditioned resid norm 8.533059398924e-01 true resid norm 1.104682985351e-02 ||r(i)||/||b|| 1.359070198209e-01
  9 KSP preconditioned resid norm 7.286296401476e-01 true resid norm 9.563452051797e-03 ||r(i)||/||b|| 1.176573084582e-01
 10 KSP preconditioned resid norm 6.007667725327e-01 true resid norm 7.925251418712e-03 ||r(i)||/||b|| 9.750284162348e-02
 11 KSP preconditioned resid norm 5.163497460926e-01 true resid norm 6.864695260761e-03 ||r(i)||/||b|| 8.445502349907e-02
 12 KSP preconditioned resid norm 4.428793542312e-01 true resid norm 5.978663663418e-03 ||r(i)||/||b|| 7.355434742650e-02
 13 KSP preconditioned resid norm 3.926551780564e-01 true resid norm 5.275518463473e-03 ||r(i)||/||b|| 6.490368747309e-02
 14 KSP preconditioned resid norm 3.155183977396e-01 true resid norm 4.275507793382e-03 ||r(i)||/||b|| 5.260074882341e-02
 15 KSP preconditioned resid norm 2.391629838386e-01 true resid norm 3.265859795081e-03 ||r(i)||/||b|| 4.017924398113e-02
 16 KSP preconditioned resid norm 1.661697353991e-01 true resid norm 2.259765224053e-03 ||r(i)||/||b|| 2.780145627013e-02
 17 KSP preconditioned resid norm 1.144139739063e-01 true resid norm 1.550139838624e-03 ||r(i)||/||b|| 1.907107184293e-02
 18 KSP preconditioned resid norm 8.348950562746e-02 true resid norm 1.121080906166e-03 ||r(i)||/||b|| 1.379244244327e-02
 19 KSP preconditioned resid norm 6.796993588659e-02 true resid norm 9.306815063392e-04 ||r(i)||/||b|| 1.144999530239e-02
 20 KSP preconditioned resid norm 5.797834544499e-02 true resid norm 7.869293093676e-04 ||r(i)||/||b|| 9.681439712939e-03
 21 KSP preconditioned resid norm 4.787642608640e-02 true resid norm 6.470524074053e-04 ||r(i)||/||b|| 7.960561131521e-03
 22 KSP preconditioned resid norm 3.955050761623e-02 true resid norm 5.419489180796e-04 ||r(i)||/||b|| 6.667493147633e-03
 23 KSP preconditioned resid norm 3.305605629354e-02 true resid norm 4.528439372683e-04 ||r(i)||/||b|| 5.571251732327e-03
 24 KSP preconditioned resid norm 2.811994621626e-02 true resid norm 3.804568665420e-04 ||r(i)||/||b|| 4.680687544552e-03
 25 KSP preconditioned resid norm 2.355696282960e-02 true resid norm 3.109624943633e-04 ||r(i)||/||b|| 3.825711669810e-03
 26 KSP preconditioned resid norm 1.914266933202e-02 true resid norm 2.553048324748e-04 ||r(i)||/||b|| 3.140966176508e-03
 27 KSP preconditioned resid norm 1.583081811760e-02 true resid norm 2.075586000815e-04 ||r(i)||/||b|| 2.553553476368e-03
 28 KSP preconditioned resid norm 1.317866353210e-02 true resid norm 1.720422793006e-04 ||r(i)||/||b|| 2.116603023039e-03
 29 KSP preconditioned resid norm 1.067926656285e-02 true resid norm 1.381683430730e-04 ||r(i)||/||b|| 1.699858510510e-03
 30 KSP preconditioned resid norm 8.682040728304e-03 true resid norm 1.119238160352e-04 ||r(i)||/||b|| 1.376977149647e-03
 31 KSP preconditioned resid norm 6.725934979352e-03 true resid norm 8.674091202708e-05 ||r(i)||/||b|| 1.067156732427e-03
 32 KSP preconditioned resid norm 5.074764386642e-03 true resid norm 6.519413336353e-05 ||r(i)||/||b|| 8.020708649212e-04
 33 KSP preconditioned resid norm 3.768589509007e-03 true resid norm 4.860932707548e-05 ||r(i)||/||b|| 5.980311877644e-04
 34 KSP preconditioned resid norm 2.910754652928e-03 true resid norm 3.678639744402e-05 ||r(i)||/||b|| 4.525759618697e-04
 35 KSP preconditioned resid norm 2.234075981015e-03 true resid norm 2.837270847521e-05 ||r(i)||/||b|| 3.490639671513e-04
 36 KSP preconditioned resid norm 1.753951250034e-03 true resid norm 2.207862424724e-05 ||r(i)||/||b|| 2.716290612762e-04
 37 KSP preconditioned resid norm 1.395909468657e-03 true resid norm 1.792904467113e-05 ||r(i)||/||b|| 2.205775830533e-04
 38 KSP preconditioned resid norm 1.095264422250e-03 true resid norm 1.403649128430e-05 ||r(i)||/||b|| 1.726882485281e-04
 39 KSP preconditioned resid norm 8.712685777796e-04 true resid norm 1.136279521341e-05 ||r(i)||/||b|| 1.397942807818e-04
 40 KSP preconditioned resid norm 7.106986415358e-04 true resid norm 9.433215720325e-06 ||r(i)||/||b|| 1.160550359585e-04
 41 KSP preconditioned resid norm 5.697793610436e-04 true resid norm 7.692817543641e-06 ||r(i)||/||b|| 9.464325243045e-05
 42 KSP preconditioned resid norm 4.580041191758e-04 true resid norm 6.258753959481e-06 ||r(i)||/||b|| 7.700024438730e-05
 43 KSP preconditioned resid norm 3.594688842143e-04 true resid norm 4.879253644562e-06 ||r(i)||/||b|| 6.002851773551e-05
 44 KSP preconditioned resid norm 2.800577180978e-04 true resid norm 3.734724942400e-06 ||r(i)||/||b|| 4.594760157467e-05
 45 KSP preconditioned resid norm 2.148410229076e-04 true resid norm 2.905266556978e-06 ||r(i)||/||b|| 3.574293483110e-05
 46 KSP preconditioned resid norm 1.679639949761e-04 true resid norm 2.263091608951e-06 ||r(i)||/||b|| 2.784238014279e-05
 47 KSP preconditioned resid norm 1.279392911580e-04 true resid norm 1.748768860236e-06 ||r(i)||/||b|| 2.151476643543e-05
 48 KSP preconditioned resid norm 9.914824374873e-05 true resid norm 1.369998842372e-06 ||r(i)||/||b|| 1.685483186525e-05
 49 KSP preconditioned resid norm 7.412614188098e-05 true resid norm 1.043438599818e-06 ||r(i)||/||b|| 1.283722410391e-05
 50 KSP preconditioned resid norm 5.466636524574e-05 true resid norm 8.055297834906e-07 ||r(i)||/||b|| 9.910277763206e-06
 51 KSP preconditioned resid norm 4.048843624713e-05 true resid norm 6.105397741503e-07 ||r(i)||/||b|| 7.511353237736e-06
 52 KSP preconditioned resid norm 3.086671147154e-05 true resid norm 4.537397693310e-07 ||r(i)||/||b|| 5.582272981636e-06
 53 KSP preconditioned resid norm 2.414074192235e-05 true resid norm 3.476290856641e-07 ||r(i)||/||b|| 4.276813679777e-06
 54 KSP preconditioned resid norm 1.841120613120e-05 true resid norm 2.601358598092e-07 ||r(i)||/||b|| 3.200401375239e-06
 55 KSP preconditioned resid norm 1.455825281038e-05 true resid norm 2.026301857839e-07 ||r(i)||/||b|| 2.492920144587e-06
 56 KSP preconditioned resid norm 1.192512021181e-05 true resid norm 1.678124203370e-07 ||r(i)||/||b|| 2.064563882975e-06
 57 KSP preconditioned resid norm 9.844805773649e-06 true resid norm 1.414896322458e-07 ||r(i)||/||b|| 1.740719691448e-06
 58 KSP preconditioned resid norm 7.906325721612e-06 true resid norm 1.173899736895e-07 ||r(i)||/||b|| 1.444226234363e-06
 59 KSP preconditioned resid norm 6.349183928891e-06 true resid norm 9.661097610855e-08 ||r(i)||/||b|| 1.188586229626e-06
 60 KSP preconditioned resid norm 5.062040589769e-06 true resid norm 7.851498529922e-08 ||r(i)||/||b|| 9.659547403915e-07
 61 KSP preconditioned resid norm 4.137770205574e-06 true resid norm 6.283776478010e-08 ||r(i)||/||b|| 7.730809161286e-07
 62 KSP preconditioned resid norm 3.384291454629e-06 true resid norm 5.007798463595e-08 ||r(i)||/||b|| 6.160997988346e-07
 63 KSP preconditioned resid norm 2.769028058673e-06 true resid norm 4.054138672197e-08 ||r(i)||/||b|| 4.987728716613e-07
 64 KSP preconditioned resid norm 2.300822489770e-06 true resid norm 3.321511744749e-08 ||r(i)||/||b|| 4.086391919809e-07
 65 KSP preconditioned resid norm 1.843913416235e-06 true resid norm 2.659743212987e-08 ||r(i)||/||b|| 3.272230842326e-07
 66 KSP preconditioned resid norm 1.405538559721e-06 true resid norm 2.061683161503e-08 ||r(i)||/||b|| 2.536449080962e-07
 67 KSP preconditioned resid norm 1.077850813732e-06 true resid norm 1.579257148683e-08 ||r(i)||/||b|| 1.942929649994e-07
Linear solve converged due to CONVERGED_RTOL iterations 67
iter =   2, Function value: -4.2216,  Residual: 0.0358744
  0 KSP preconditioned resid norm 3.078712726327e+00 true resid norm 2.511830325565e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.436785516558e+00 true resid norm 1.497519704922e-02 ||r(i)||/||b|| 5.961866491062e-01
  2 KSP preconditioned resid norm 9.839748965512e-01 true resid norm 1.104748856015e-02 ||r(i)||/||b|| 4.398182650999e-01
  3 KSP preconditioned resid norm 6.118449977932e-01 true resid norm 6.926850737956e-03 ||r(i)||/||b|| 2.757690544404e-01
  4 KSP preconditioned resid norm 4.410561113681e-01 true resid norm 5.061094236589e-03 ||r(i)||/||b|| 2.014902911665e-01
  5 KSP preconditioned resid norm 3.281601397321e-01 true resid norm 3.808680782210e-03 ||r(i)||/||b|| 1.516296998028e-01
  6 KSP preconditioned resid norm 2.448606232589e-01 true resid norm 2.949881358170e-03 ||r(i)||/||b|| 1.174395152470e-01
  7 KSP preconditioned resid norm 2.017578857263e-01 true resid norm 2.454929084613e-03 ||r(i)||/||b|| 9.773467019757e-02
  8 KSP preconditioned resid norm 1.729452118718e-01 true resid norm 2.195908112798e-03 ||r(i)||/||b|| 8.742262924565e-02
  9 KSP preconditioned resid norm 1.488159996928e-01 true resid norm 1.919411709263e-03 ||r(i)||/||b|| 7.641486328625e-02
 10 KSP preconditioned resid norm 1.216676441514e-01 true resid norm 1.593978511646e-03 ||r(i)||/||b|| 6.345884494756e-02
 11 KSP preconditioned resid norm 1.042776759019e-01 true resid norm 1.383079630114e-03 ||r(i)||/||b|| 5.506262170806e-02
 12 KSP preconditioned resid norm 8.418920977526e-02 true resid norm 1.122799371342e-03 ||r(i)||/||b|| 4.470044651960e-02
 13 KSP preconditioned resid norm 7.241350600183e-02 true resid norm 9.490161375700e-04 ||r(i)||/||b|| 3.778185683607e-02
 14 KSP preconditioned resid norm 6.016619175834e-02 true resid norm 7.909259663239e-04 ||r(i)||/||b|| 3.148803317940e-02
 15 KSP preconditioned resid norm 5.125981907456e-02 true resid norm 6.661005205745e-04 ||r(i)||/||b|| 2.651853167768e-02
 16 KSP preconditioned resid norm 4.057011389800e-02 true resid norm 5.278135981331e-04 ||r(i)||/||b|| 2.101310716577e-02
 17 KSP preconditioned resid norm 3.109972722989e-02 true resid norm 3.990281117194e-04 ||r(i)||/||b|| 1.588595008421e-02
 18 KSP preconditioned resid norm 2.284614241356e-02 true resid norm 2.969350117079e-04 ||r(i)||/||b|| 1.182145978117e-02
 19 KSP preconditioned resid norm 1.764483420584e-02 true resid norm 2.302438310211e-04 ||r(i)||/||b|| 9.166376752353e-03
 20 KSP preconditioned resid norm 1.420015549423e-02 true resid norm 1.899378160332e-04 ||r(i)||/||b|| 7.561729552354e-03
 21 KSP preconditioned resid norm 1.165478028029e-02 true resid norm 1.561867860434e-04 ||r(i)||/||b|| 6.218046834363e-03
 22 KSP preconditioned resid norm 1.004130667954e-02 true resid norm 1.313954171822e-04 ||r(i)||/||b|| 5.231062617759e-03
 23 KSP preconditioned resid norm 8.296092363320e-03 true resid norm 1.090794952456e-04 ||r(i)||/||b|| 4.342629919523e-03
 24 KSP preconditioned resid norm 6.786577654956e-03 true resid norm 8.958840577842e-05 ||r(i)||/||b|| 3.566658339404e-03
 25 KSP preconditioned resid norm 5.252814483069e-03 true resid norm 7.125683254750e-05 ||r(i)||/||b|| 2.836848963175e-03
 26 KSP preconditioned resid norm 4.243930114293e-03 true resid norm 5.713783394789e-05 ||r(i)||/||b|| 2.274748949655e-03
 27 KSP preconditioned resid norm 3.451657540901e-03 true resid norm 4.615164349915e-05 ||r(i)||/||b|| 1.837371060833e-03
 28 KSP preconditioned resid norm 2.801350948249e-03 true resid norm 3.782739272360e-05 ||r(i)||/||b|| 1.505969266260e-03
 29 KSP preconditioned resid norm 2.214358577188e-03 true resid norm 2.972786105478e-05 ||r(i)||/||b|| 1.183513900291e-03
 30 KSP preconditioned resid norm 1.817748371141e-03 true resid norm 2.452255191279e-05 ||r(i)||/||b|| 9.762821820887e-04
 31 KSP preconditioned resid norm 1.542430997111e-03 true resid norm 2.085501528754e-05 ||r(i)||/||b|| 8.302716578936e-04
 32 KSP preconditioned resid norm 1.320573543129e-03 true resid norm 1.786098055136e-05 ||r(i)||/||b|| 7.110743257448e-04
 33 KSP preconditioned resid norm 1.069123938664e-03 true resid norm 1.458332864504e-05 ||r(i)||/||b|| 5.805857384798e-04
 34 KSP preconditioned resid norm 8.278294539422e-04 true resid norm 1.135711952312e-05 ||r(i)||/||b|| 4.521451710943e-04
 35 KSP preconditioned resid norm 6.473427500034e-04 true resid norm 8.790182120684e-06 ||r(i)||/||b|| 3.499512698457e-04
 36 KSP preconditioned resid norm 4.950078157097e-04 true resid norm 6.837510025034e-06 ||r(i)||/||b|| 2.722122571514e-04
 37 KSP preconditioned resid norm 3.835822744757e-04 true resid norm 5.366537858790e-06 ||r(i)||/||b|| 2.136504923988e-04
 38 KSP preconditioned resid norm 2.956450814610e-04 true resid norm 4.142299798591e-06 ||r(i)||/||b|| 1.649116087353e-04
 39 KSP preconditioned resid norm 2.335051478651e-04 true resid norm 3.355387777810e-06 ||r(i)||/||b|| 1.335833771756e-04
 40 KSP preconditioned resid norm 1.840176017421e-04 true resid norm 2.675401008746e-06 ||r(i)||/||b|| 1.065120116401e-04
 41 KSP preconditioned resid norm 1.524320388282e-04 true resid norm 2.193486758137e-06 ||r(i)||/||b|| 8.732623122717e-05
 42 KSP preconditioned resid norm 1.222919376875e-04 true resid norm 1.728883461112e-06 ||r(i)||/||b|| 6.882962768288e-05
 43 KSP preconditioned resid norm 9.599565080538e-05 true resid norm 1.367007014872e-06 ||r(i)||/||b|| 5.442274507793e-05
 44 KSP preconditioned resid norm 7.661562076065e-05 true resid norm 1.105137541011e-06 ||r(i)||/||b|| 4.399730068401e-05
 45 KSP preconditioned resid norm 6.250406393055e-05 true resid norm 8.957073911718e-07 ||r(i)||/||b|| 3.565955001242e-05
 46 KSP preconditioned resid norm 5.145354949991e-05 true resid norm 7.063338136268e-07 ||r(i)||/||b|| 2.812028370061e-05
 47 KSP preconditioned resid norm 4.153440553245e-05 true resid norm 5.761498076209e-07 ||r(i)||/||b|| 2.293744930766e-05
 48 KSP preconditioned resid norm 3.419464595370e-05 true resid norm 4.702601363512e-07 ||r(i)||/||b|| 1.872181140442e-05
 49 KSP preconditioned resid norm 2.760201489298e-05 true resid norm 3.784962933248e-07 ||r(i)||/||b|| 1.506854541378e-05
 50 KSP preconditioned resid norm 2.199152517729e-05 true resid norm 3.078726722516e-07 ||r(i)||/||b|| 1.225690561652e-05
 51 KSP preconditioned resid norm 1.746370511231e-05 true resid norm 2.413117988859e-07 ||r(i)||/||b|| 9.607010331467e-06
 52 KSP preconditioned resid norm 1.418239019363e-05 true resid norm 1.954928901118e-07 ||r(i)||/||b|| 7.782885974507e-06
 53 KSP preconditioned resid norm 1.099712801869e-05 true resid norm 1.514891134122e-07 ||r(i)||/||b|| 6.031024941069e-06
 54 KSP preconditioned resid norm 8.441120743302e-06 true resid norm 1.159390409680e-07 ||r(i)||/||b|| 4.615719453182e-06
 55 KSP preconditioned resid norm 6.255938530880e-06 true resid norm 8.758832595523e-08 ||r(i)||/||b|| 3.487031948925e-06
 56 KSP preconditioned resid norm 4.606004914203e-06 true resid norm 6.379221987129e-08 ||r(i)||/||b|| 2.539670742169e-06
 57 KSP preconditioned resid norm 3.432709573112e-06 true resid norm 4.860654070950e-08 ||r(i)||/||b|| 1.935104462065e-06
 58 KSP preconditioned resid norm 2.639944912676e-06 true resid norm 3.784335158361e-08 ||r(i)||/||b|| 1.506604614112e-06
 59 KSP preconditioned resid norm 2.075012954065e-06 true resid norm 2.956848327713e-08 ||r(i)||/||b|| 1.177168814955e-06
 60 KSP preconditioned resid norm 1.590198859164e-06 true resid norm 2.257854817249e-08 ||r(i)||/||b|| 8.988882705448e-07
 61 KSP preconditioned resid norm 1.228443552904e-06 true resid norm 1.776903300082e-08 ||r(i)||/||b|| 7.074137460627e-07
 62 KSP preconditioned resid norm 9.758189757346e-07 true resid norm 1.432398473765e-08 ||r(i)||/||b|| 5.702608409441e-07
 63 KSP preconditioned resid norm 7.998041759359e-07 true resid norm 1.175896254407e-08 ||r(i)||/||b|| 4.681431872365e-07
 64 KSP preconditioned resid norm 6.692356604741e-07 true resid norm 9.725658337724e-09 ||r(i)||/||b|| 3.871940806964e-07
 65 KSP preconditioned resid norm 5.473721917974e-07 true resid norm 7.962042992050e-09 ||r(i)||/||b|| 3.169817208995e-07
 66 KSP preconditioned resid norm 4.457349347894e-07 true resid norm 6.456213457789e-09 ||r(i)||/||b|| 2.570322283348e-07
 67 KSP preconditioned resid norm 3.634186843581e-07 true resid norm 5.388520624502e-09 ||r(i)||/||b|| 2.145256616125e-07
 68 KSP preconditioned resid norm 3.002175112928e-07 true resid norm 4.343848652894e-09 ||r(i)||/||b|| 1.729355923719e-07
Linear solve converged due to CONVERGED_RTOL iterations 68
iter =   3, Function value: -4.30152,  Residual: 0.0171005
  0 KSP preconditioned resid norm 1.319159362845e+00 true resid norm 1.183488520040e-02 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 6.514138475320e-01 true resid norm 7.892484295511e-03 ||r(i)||/||b|| 6.668830463387e-01
  2 KSP preconditioned resid norm 5.282231230075e-01 true resid norm 6.540292465120e-03 ||r(i)||/||b|| 5.526282979829e-01
  3 KSP preconditioned resid norm 4.063192316002e-01 true resid norm 5.175775732114e-03 ||r(i)||/||b|| 4.373321451347e-01
  4 KSP preconditioned resid norm 3.130861851176e-01 true resid norm 3.899975461451e-03 ||r(i)||/||b|| 3.295321750412e-01
  5 KSP preconditioned resid norm 2.463984401133e-01 true resid norm 3.185989418482e-03 ||r(i)||/||b|| 2.692032380994e-01
  6 KSP preconditioned resid norm 1.980125928647e-01 true resid norm 2.545811460686e-03 ||r(i)||/||b|| 2.151107862542e-01
  7 KSP preconditioned resid norm 1.622464235995e-01 true resid norm 2.174720631219e-03 ||r(i)||/||b|| 1.837551099478e-01
  8 KSP preconditioned resid norm 1.330735287123e-01 true resid norm 1.813144130295e-03 ||r(i)||/||b|| 1.532033559763e-01
  9 KSP preconditioned resid norm 1.137966185611e-01 true resid norm 1.568927345671e-03 ||r(i)||/||b|| 1.325680240327e-01
 10 KSP preconditioned resid norm 9.405509160505e-02 true resid norm 1.298916291879e-03 ||r(i)||/||b|| 1.097531805239e-01
 11 KSP preconditioned resid norm 7.945645440114e-02 true resid norm 1.123739708851e-03 ||r(i)||/||b|| 9.495146677158e-02
 12 KSP preconditioned resid norm 6.573669085128e-02 true resid norm 9.226307522234e-04 ||r(i)||/||b|| 7.795857218727e-02
 13 KSP preconditioned resid norm 5.653185279397e-02 true resid norm 7.799404380735e-04 ||r(i)||/||b|| 6.590181694768e-02
 14 KSP preconditioned resid norm 4.569747543150e-02 true resid norm 6.263070868686e-04 ||r(i)||/||b|| 5.292041927432e-02
 15 KSP preconditioned resid norm 3.744441561071e-02 true resid norm 5.070359966992e-04 ||r(i)||/||b|| 4.284249387414e-02
 16 KSP preconditioned resid norm 3.035528717192e-02 true resid norm 4.175506502479e-04 ||r(i)||/||b|| 3.528134351770e-02
 17 KSP preconditioned resid norm 2.479764869002e-02 true resid norm 3.341761443657e-04 ||r(i)||/||b|| 2.823653450854e-02
 18 KSP preconditioned resid norm 1.963408065179e-02 true resid norm 2.724426047914e-04 ||r(i)||/||b|| 2.302029974758e-02
 19 KSP preconditioned resid norm 1.610937948671e-02 true resid norm 2.197476260379e-04 ||r(i)||/||b|| 1.856778687050e-02
 20 KSP preconditioned resid norm 1.373140776591e-02 true resid norm 1.905474815130e-04 ||r(i)||/||b|| 1.610049259342e-02
 21 KSP preconditioned resid norm 1.142190412378e-02 true resid norm 1.623013826004e-04 ||r(i)||/||b|| 1.371381131731e-02
 22 KSP preconditioned resid norm 9.075259152653e-03 true resid norm 1.295684097434e-04 ||r(i)||/||b|| 1.094800731477e-02
 23 KSP preconditioned resid norm 6.961620886742e-03 true resid norm 9.850472550573e-05 ||r(i)||/||b|| 8.323251458528e-03
 24 KSP preconditioned resid norm 5.280712373373e-03 true resid norm 7.539993600800e-05 ||r(i)||/||b|| 6.370990062958e-03
 25 KSP preconditioned resid norm 4.019447413973e-03 true resid norm 5.668561339935e-05 ||r(i)||/||b|| 4.789705387040e-03
 26 KSP preconditioned resid norm 3.100674051153e-03 true resid norm 4.388073055531e-05 ||r(i)||/||b|| 3.707744503836e-03
 27 KSP preconditioned resid norm 2.404289818837e-03 true resid norm 3.388570958937e-05 ||r(i)||/||b|| 2.863205600695e-03
 28 KSP preconditioned resid norm 1.963370194805e-03 true resid norm 2.831465399283e-05 ||r(i)||/||b|| 2.392473903497e-03
 29 KSP preconditioned resid norm 1.657212289849e-03 true resid norm 2.348881079581e-05 ||r(i)||/||b|| 1.984709644249e-03
 30 KSP preconditioned resid norm 1.408984269678e-03 true resid norm 1.997109783296e-05 ||r(i)||/||b|| 1.687477106435e-03
 31 KSP preconditioned resid norm 1.184952270711e-03 true resid norm 1.669200873332e-05 ||r(i)||/||b|| 1.410407321294e-03
 32 KSP preconditioned resid norm 9.955740309112e-04 true resid norm 1.409585267556e-05 ||r(i)||/||b|| 1.191042619922e-03
 33 KSP preconditioned resid norm 8.010772703545e-04 true resid norm 1.146129488172e-05 ||r(i)||/||b|| 9.684331269501e-04
 34 KSP preconditioned resid norm 6.571004710871e-04 true resid norm 9.274027085601e-06 ||r(i)||/||b|| 7.836178322446e-04
 35 KSP preconditioned resid norm 5.457596691859e-04 true resid norm 7.719885711333e-06 ||r(i)||/||b|| 6.522991630770e-04
 36 KSP preconditioned resid norm 4.424577045973e-04 true resid norm 6.334457661890e-06 ||r(i)||/||b|| 5.352360884478e-04
 37 KSP preconditioned resid norm 3.547158795991e-04 true resid norm 5.132558751496e-06 ||r(i)||/||b|| 4.336804848198e-04
 38 KSP preconditioned resid norm 2.776384857414e-04 true resid norm 4.029571043015e-06 ||r(i)||/||b|| 3.404824782651e-04
 39 KSP preconditioned resid norm 2.242160215654e-04 true resid norm 3.239872148598e-06 ||r(i)||/||b|| 2.737561111694e-04
 40 KSP preconditioned resid norm 1.821914020833e-04 true resid norm 2.639786697609e-06 ||r(i)||/||b|| 2.230513142214e-04
 41 KSP preconditioned resid norm 1.493010091960e-04 true resid norm 2.158224275163e-06 ||r(i)||/||b|| 1.823612344876e-04
 42 KSP preconditioned resid norm 1.187594113186e-04 true resid norm 1.712192142730e-06 ||r(i)||/||b|| 1.446733207578e-04
 43 KSP preconditioned resid norm 9.397295222777e-05 true resid norm 1.370897338981e-06 ||r(i)||/||b|| 1.158352882827e-04
 44 KSP preconditioned resid norm 7.358206485516e-05 true resid norm 1.097675946634e-06 ||r(i)||/||b|| 9.274918413210e-05
 45 KSP preconditioned resid norm 5.882058863425e-05 true resid norm 8.689029449935e-07 ||r(i)||/||b|| 7.341878947539e-05
 46 KSP preconditioned resid norm 4.685478354048e-05 true resid norm 6.993294964093e-07 ||r(i)||/||b|| 5.909051795329e-05
 47 KSP preconditioned resid norm 3.673844874942e-05 true resid norm 5.407211758978e-07 ||r(i)||/||b|| 4.568875546673e-05
 48 KSP preconditioned resid norm 2.957177102988e-05 true resid norm 4.300034119448e-07 ||r(i)||/||b|| 3.633355158614e-05
 49 KSP preconditioned resid norm 2.367745467249e-05 true resid norm 3.504211062746e-07 ||r(i)||/||b|| 2.960916817873e-05
 50 KSP preconditioned resid norm 1.925644647411e-05 true resid norm 2.851183607579e-07 ||r(i)||/||b|| 2.409134993116e-05
 51 KSP preconditioned resid norm 1.556912872089e-05 true resid norm 2.301064672081e-07 ||r(i)||/||b|| 1.944306711148e-05
 52 KSP preconditioned resid norm 1.275554806204e-05 true resid norm 1.902090952981e-07 ||r(i)||/||b|| 1.607190032495e-05
 53 KSP preconditioned resid norm 1.079695120256e-05 true resid norm 1.626571536353e-07 ||r(i)||/||b|| 1.374387253286e-05
 54 KSP preconditioned resid norm 9.169302418572e-06 true resid norm 1.374527463931e-07 ||r(i)||/||b|| 1.161420191794e-05
 55 KSP preconditioned resid norm 7.734363665135e-06 true resid norm 1.157756053301e-07 ||r(i)||/||b|| 9.782571049036e-06
 56 KSP preconditioned resid norm 6.412346887180e-06 true resid norm 9.508928829817e-08 ||r(i)||/||b|| 8.034660808958e-06
 57 KSP preconditioned resid norm 5.201601050280e-06 true resid norm 7.795914925251e-08 ||r(i)||/||b|| 6.587233245818e-06
 58 KSP preconditioned resid norm 4.207592687478e-06 true resid norm 6.201308598100e-08 ||r(i)||/||b|| 5.239855303278e-06
 59 KSP preconditioned resid norm 3.361615715837e-06 true resid norm 4.977498135501e-08 ||r(i)||/||b|| 4.205784890362e-06
 60 KSP preconditioned resid norm 2.644819873761e-06 true resid norm 3.974320482898e-08 ||r(i)||/||b|| 3.358140290844e-06
 61 KSP preconditioned resid norm 2.069478800455e-06 true resid norm 3.165162630840e-08 ||r(i)||/||b|| 2.674434586601e-06
 62 KSP preconditioned resid norm 1.607732490097e-06 true resid norm 2.428765462838e-08 ||r(i)||/||b|| 2.052208721683e-06
 63 KSP preconditioned resid norm 1.236234589205e-06 true resid norm 1.866591929698e-08 ||r(i)||/||b|| 1.577194791577e-06
 64 KSP preconditioned resid norm 9.482626657129e-07 true resid norm 1.425411657557e-08 ||r(i)||/||b|| 1.204415280267e-06
 65 KSP preconditioned resid norm 7.301471738651e-07 true resid norm 1.106664275922e-08 ||r(i)||/||b|| 9.350866165436e-07
 66 KSP preconditioned resid norm 5.604900760609e-07 true resid norm 8.463436362522e-09 ||r(i)||/||b|| 7.151261900061e-07
 67 KSP preconditioned resid norm 4.240448021014e-07 true resid norm 6.490057824452e-09 ||r(i)||/||b|| 5.483836737371e-07
 68 KSP preconditioned resid norm 3.321470511043e-07 true resid norm 5.088792971299e-09 ||r(i)||/||b|| 4.299824531570e-07
 69 KSP preconditioned resid norm 2.620915884870e-07 true resid norm 4.047590336629e-09 ||r(i)||/||b|| 3.420050357981e-07
 70 KSP preconditioned resid norm 2.119517793704e-07 true resid norm 3.262121220019e-09 ||r(i)||/||b|| 2.756360678437e-07
 71 KSP preconditioned resid norm 1.730393081521e-07 true resid norm 2.600379407906e-09 ||r(i)||/||b|| 2.197215574020e-07
 72 KSP preconditioned resid norm 1.423004777798e-07 true resid norm 2.134841301621e-09 ||r(i)||/||b|| 1.803854676637e-07
 73 KSP preconditioned resid norm 1.174690852278e-07 true resid norm 1.732300323811e-09 ||r(i)||/||b|| 1.463723808451e-07
Linear solve converged due to CONVERGED_RTOL iterations 73
iter =   4, Function value: -4.32312,  Residual: 0.0125018
  0 KSP preconditioned resid norm 7.709622512815e-01 true resid norm 7.928781623310e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.868155790035e-01 true resid norm 5.222403296788e-03 ||r(i)||/||b|| 6.586640350183e-01
  2 KSP preconditioned resid norm 3.007215979876e-01 true resid norm 4.069354370316e-03 ||r(i)||/||b|| 5.132382960773e-01
  3 KSP preconditioned resid norm 2.467162568911e-01 true resid norm 3.314673931707e-03 ||r(i)||/||b|| 4.180558992774e-01
  4 KSP preconditioned resid norm 2.139158321559e-01 true resid norm 2.888968849177e-03 ||r(i)||/||b|| 3.643647897533e-01
  5 KSP preconditioned resid norm 1.801774908774e-01 true resid norm 2.538770371212e-03 ||r(i)||/||b|| 3.201967832924e-01
  6 KSP preconditioned resid norm 1.523252608706e-01 true resid norm 2.111805222248e-03 ||r(i)||/||b|| 2.663467506835e-01
  7 KSP preconditioned resid norm 1.271850316560e-01 true resid norm 1.791383014721e-03 ||r(i)||/||b|| 2.259342103021e-01
  8 KSP preconditioned resid norm 1.068570399306e-01 true resid norm 1.472385780399e-03 ||r(i)||/||b|| 1.857013915063e-01
  9 KSP preconditioned resid norm 9.098020309241e-02 true resid norm 1.295156100566e-03 ||r(i)||/||b|| 1.633486911480e-01
 10 KSP preconditioned resid norm 7.634262887695e-02 true resid norm 1.064863801450e-03 ||r(i)||/||b|| 1.343035856000e-01
 11 KSP preconditioned resid norm 6.517309124223e-02 true resid norm 9.374080053428e-04 ||r(i)||/||b|| 1.182285059519e-01
 12 KSP preconditioned resid norm 5.357026307018e-02 true resid norm 7.641667526497e-04 ||r(i)||/||b|| 9.637883712210e-02
 13 KSP preconditioned resid norm 4.472183390369e-02 true resid norm 6.625726319158e-04 ||r(i)||/||b|| 8.356550393164e-02
 14 KSP preconditioned resid norm 3.668430630223e-02 true resid norm 5.317367290624e-04 ||r(i)||/||b|| 6.706411581562e-02
 15 KSP preconditioned resid norm 3.031382549937e-02 true resid norm 4.390550484943e-04 ||r(i)||/||b|| 5.537484437755e-02
 16 KSP preconditioned resid norm 2.494909278502e-02 true resid norm 3.582328132280e-04 ||r(i)||/||b|| 4.518131917958e-02
 17 KSP preconditioned resid norm 2.126516174579e-02 true resid norm 3.054595407649e-04 ||r(i)||/||b|| 3.852540721602e-02
 18 KSP preconditioned resid norm 1.761386078976e-02 true resid norm 2.576717960010e-04 ||r(i)||/||b|| 3.249828387801e-02
 19 KSP preconditioned resid norm 1.428915254056e-02 true resid norm 2.087003015117e-04 ||r(i)||/||b|| 2.632186273085e-02
 20 KSP preconditioned resid norm 1.149226186765e-02 true resid norm 1.692332453822e-04 ||r(i)||/||b|| 2.134416779555e-02
 21 KSP preconditioned resid norm 9.606351087692e-03 true resid norm 1.391666927645e-04 ||r(i)||/||b|| 1.755209051985e-02
 22 KSP preconditioned resid norm 8.138961870621e-03 true resid norm 1.197252337242e-04 ||r(i)||/||b|| 1.510007961024e-02
 23 KSP preconditioned resid norm 6.601693821087e-03 true resid norm 9.641926065813e-05 ||r(i)||/||b|| 1.216066543877e-02
 24 KSP preconditioned resid norm 5.135125242485e-03 true resid norm 7.560918870159e-05 ||r(i)||/||b|| 9.536041260023e-03
 25 KSP preconditioned resid norm 3.862523889699e-03 true resid norm 5.722676889872e-05 ||r(i)||/||b|| 7.217599325787e-03
 26 KSP preconditioned resid norm 3.050385434947e-03 true resid norm 4.533388720455e-05 ||r(i)||/||b|| 5.717635994826e-03
 27 KSP preconditioned resid norm 2.295504988717e-03 true resid norm 3.443897377922e-05 ||r(i)||/||b|| 4.343539198756e-03
 28 KSP preconditioned resid norm 1.826591765407e-03 true resid norm 2.711481381846e-05 ||r(i)||/||b|| 3.419795765184e-03
 29 KSP preconditioned resid norm 1.484742685428e-03 true resid norm 2.244463678780e-05 ||r(i)||/||b|| 2.830780043408e-03
 30 KSP preconditioned resid norm 1.250876934752e-03 true resid norm 1.873596933527e-05 ||r(i)||/||b|| 2.363032585005e-03
 31 KSP preconditioned resid norm 1.032962485683e-03 true resid norm 1.560473524447e-05 ||r(i)||/||b|| 1.968112628881e-03
 32 KSP preconditioned resid norm 8.894040124145e-04 true resid norm 1.309766609622e-05 ||r(i)||/||b|| 1.651914092035e-03
 33 KSP preconditioned resid norm 7.608612815522e-04 true resid norm 1.114927897527e-05 ||r(i)||/||b|| 1.406178086995e-03
 34 KSP preconditioned resid norm 6.300411545423e-04 true resid norm 9.272872418054e-06 ||r(i)||/||b|| 1.169520470938e-03
 35 KSP preconditioned resid norm 5.186229512144e-04 true resid norm 7.589535105842e-06 ||r(i)||/||b|| 9.572132852707e-04
 36 KSP preconditioned resid norm 4.177517723941e-04 true resid norm 6.120504847987e-06 ||r(i)||/||b|| 7.719351016043e-04
 37 KSP preconditioned resid norm 3.383661191525e-04 true resid norm 4.981170149298e-06 ||r(i)||/||b|| 6.282390392307e-04
 38 KSP preconditioned resid norm 2.786910672159e-04 true resid norm 4.095733310453e-06 ||r(i)||/||b|| 5.165652814062e-04
 39 KSP preconditioned resid norm 2.234724191416e-04 true resid norm 3.282704710025e-06 ||r(i)||/||b|| 4.140238520853e-04
 40 KSP preconditioned resid norm 1.771887908598e-04 true resid norm 2.631346060313e-06 ||r(i)||/||b|| 3.318726867917e-04
 41 KSP preconditioned resid norm 1.448364754336e-04 true resid norm 2.137803862729e-06 ||r(i)||/||b|| 2.696257715617e-04
 42 KSP preconditioned resid norm 1.173057791815e-04 true resid norm 1.749200058130e-06 ||r(i)||/||b|| 2.206139784438e-04
 43 KSP preconditioned resid norm 9.136391611972e-05 true resid norm 1.371716375931e-06 ||r(i)||/||b|| 1.730046861044e-04
 44 KSP preconditioned resid norm 6.988362222953e-05 true resid norm 1.052858769385e-06 ||r(i)||/||b|| 1.327894775523e-04
 45 KSP preconditioned resid norm 5.397526544397e-05 true resid norm 8.117735692941e-07 ||r(i)||/||b|| 1.023831413023e-04
 46 KSP preconditioned resid norm 4.275705913272e-05 true resid norm 6.490413162402e-07 ||r(i)||/||b|| 8.185889674803e-05
 47 KSP preconditioned resid norm 3.420852324177e-05 true resid norm 5.224381885425e-07 ||r(i)||/||b|| 6.589135801226e-05
 48 KSP preconditioned resid norm 2.727158398477e-05 true resid norm 4.195916155157e-07 ||r(i)||/||b|| 5.292006205369e-05
 49 KSP preconditioned resid norm 2.195560301124e-05 true resid norm 3.322469375010e-07 ||r(i)||/||b|| 4.190390822775e-05
 50 KSP preconditioned resid norm 1.784285373496e-05 true resid norm 2.735801719570e-07 ||r(i)||/||b|| 3.450469251829e-05
 51 KSP preconditioned resid norm 1.429971513510e-05 true resid norm 2.196630075085e-07 ||r(i)||/||b|| 2.770450971468e-05
 52 KSP preconditioned resid norm 1.197607383692e-05 true resid norm 1.843615346208e-07 ||r(i)||/||b|| 2.325218972847e-05
 53 KSP preconditioned resid norm 1.002312681434e-05 true resid norm 1.558529279530e-07 ||r(i)||/||b|| 1.965660493093e-05
 54 KSP preconditioned resid norm 8.489406201593e-06 true resid norm 1.335014904381e-07 ||r(i)||/||b|| 1.683757943915e-05
 55 KSP preconditioned resid norm 7.198586674778e-06 true resid norm 1.113500046787e-07 ||r(i)||/||b|| 1.404377241912e-05
 56 KSP preconditioned resid norm 6.011165514260e-06 true resid norm 9.338430284201e-08 ||r(i)||/||b|| 1.177788811429e-05
 57 KSP preconditioned resid norm 5.024838735304e-06 true resid norm 7.886406151033e-08 ||r(i)||/||b|| 9.946554875276e-06
 58 KSP preconditioned resid norm 4.122144046193e-06 true resid norm 6.383182503092e-08 ||r(i)||/||b|| 8.050647383611e-06
 59 KSP preconditioned resid norm 3.255476877261e-06 true resid norm 5.067810669811e-08 ||r(i)||/||b|| 6.391663827532e-06
 60 KSP preconditioned resid norm 2.547102630180e-06 true resid norm 3.918002013874e-08 ||r(i)||/||b|| 4.941493157481e-06
 61 KSP preconditioned resid norm 2.047599683181e-06 true resid norm 3.190856475230e-08 ||r(i)||/||b|| 4.024396971471e-06
 62 KSP preconditioned resid norm 1.631539133662e-06 true resid norm 2.571493735843e-08 ||r(i)||/||b|| 3.243239450918e-06
 63 KSP preconditioned resid norm 1.261302419970e-06 true resid norm 2.000358336127e-08 ||r(i)||/||b|| 2.522907593073e-06
 64 KSP preconditioned resid norm 9.838126058447e-07 true resid norm 1.548369379132e-08 ||r(i)||/||b|| 1.952846544013e-06
 65 KSP preconditioned resid norm 8.200700468068e-07 true resid norm 1.267690752501e-08 ||r(i)||/||b|| 1.598846850283e-06
 66 KSP preconditioned resid norm 6.743656138529e-07 true resid norm 1.054747497037e-08 ||r(i)||/||b|| 1.330276891391e-06
 67 KSP preconditioned resid norm 5.416191897012e-07 true resid norm 8.553548547030e-09 ||r(i)||/||b|| 1.078797342821e-06
 68 KSP preconditioned resid norm 4.267199659132e-07 true resid norm 6.635797645204e-09 ||r(i)||/||b|| 8.369252629806e-07
 69 KSP preconditioned resid norm 3.391095640834e-07 true resid norm 5.187682071427e-09 ||r(i)||/||b|| 6.542848974646e-07
 70 KSP preconditioned resid norm 2.712984065467e-07 true resid norm 4.227479017140e-09 ||r(i)||/||b|| 5.331814165132e-07
 71 KSP preconditioned resid norm 2.196306116474e-07 true resid norm 3.373713083816e-09 ||r(i)||/||b|| 4.255020814166e-07
 72 KSP preconditioned resid norm 1.826204483932e-07 true resid norm 2.834832303986e-09 ||r(i)||/||b|| 3.575369380400e-07
 73 KSP preconditioned resid norm 1.547957220154e-07 true resid norm 2.398174892013e-09 ||r(i)||/||b|| 3.024644902519e-07
 74 KSP preconditioned resid norm 1.297186572995e-07 true resid norm 2.012637005794e-09 ||r(i)||/||b|| 2.538393792909e-07
 75 KSP preconditioned resid norm 1.045606367621e-07 true resid norm 1.616988650277e-09 ||r(i)||/||b|| 2.039391078099e-07
 76 KSP preconditioned resid norm 8.282351720412e-08 true resid norm 1.285928628967e-09 ||r(i)||/||b|| 1.621848967547e-07
 77 KSP preconditioned resid norm 6.403069302509e-08 true resid norm 1.012303943116e-09 ||r(i)||/||b|| 1.276745900202e-07
Linear solve converged due to CONVERGED_RTOL iterations 77
iter =   5, Function value: -4.33214,  Residual: 0.00947882
  0 KSP preconditioned resid norm 5.329136712372e-01 true resid norm 5.927453203187e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.664093052616e-01 true resid norm 4.065588115303e-03 ||r(i)||/||b|| 6.858912210588e-01
  2 KSP preconditioned resid norm 2.151473001343e-01 true resid norm 3.177958116214e-03 ||r(i)||/||b|| 5.361422532202e-01
  3 KSP preconditioned resid norm 1.694601062455e-01 true resid norm 2.550533948058e-03 ||r(i)||/||b|| 4.302917054979e-01
  4 KSP preconditioned resid norm 1.490935605013e-01 true resid norm 2.128826532466e-03 ||r(i)||/||b|| 3.591469151239e-01
  5 KSP preconditioned resid norm 1.307585700081e-01 true resid norm 1.931498902237e-03 ||r(i)||/||b|| 3.258564574072e-01
  6 KSP preconditioned resid norm 1.201544554759e-01 true resid norm 1.671023961826e-03 ||r(i)||/||b|| 2.819126367674e-01
  7 KSP preconditioned resid norm 1.116244994383e-01 true resid norm 1.577516302907e-03 ||r(i)||/||b|| 2.661372850753e-01
  8 KSP preconditioned resid norm 9.495490236895e-02 true resid norm 1.361468244749e-03 ||r(i)||/||b|| 2.296885691172e-01
  9 KSP preconditioned resid norm 8.118422785956e-02 true resid norm 1.209410879861e-03 ||r(i)||/||b|| 2.040355003074e-01
 10 KSP preconditioned resid norm 6.709535676765e-02 true resid norm 9.980029944157e-04 ||r(i)||/||b|| 1.683696117380e-01
 11 KSP preconditioned resid norm 5.919171655500e-02 true resid norm 8.920529672100e-04 ||r(i)||/||b|| 1.504951513966e-01
 12 KSP preconditioned resid norm 5.067138041274e-02 true resid norm 7.601006840020e-04 ||r(i)||/||b|| 1.282339409434e-01
 13 KSP preconditioned resid norm 4.416001891393e-02 true resid norm 6.756683010601e-04 ||r(i)||/||b|| 1.139896474757e-01
 14 KSP preconditioned resid norm 3.647454065183e-02 true resid norm 5.531003314108e-04 ||r(i)||/||b|| 9.331163190177e-02
 15 KSP preconditioned resid norm 2.986371608486e-02 true resid norm 4.479365473114e-04 ||r(i)||/||b|| 7.556981589842e-02
 16 KSP preconditioned resid norm 2.405962889876e-02 true resid norm 3.642092201297e-04 ||r(i)||/||b|| 6.144446993421e-02
 17 KSP preconditioned resid norm 1.966721103217e-02 true resid norm 3.022774028686e-04 ||r(i)||/||b|| 5.099616859161e-02
 18 KSP preconditioned resid norm 1.662061553107e-02 true resid norm 2.516612765823e-04 ||r(i)||/||b|| 4.245689809023e-02
 19 KSP preconditioned resid norm 1.398844565797e-02 true resid norm 2.111530131261e-04 ||r(i)||/||b|| 3.562288994750e-02
 20 KSP preconditioned resid norm 1.181033334376e-02 true resid norm 1.794877915672e-04 ||r(i)||/||b|| 3.028076062594e-02
 21 KSP preconditioned resid norm 9.640934439034e-03 true resid norm 1.474825846225e-04 ||r(i)||/||b|| 2.488127355324e-02
 22 KSP preconditioned resid norm 8.156007324220e-03 true resid norm 1.258066352815e-04 ||r(i)||/||b|| 2.122439958090e-02
 23 KSP preconditioned resid norm 6.637989351340e-03 true resid norm 1.008526654973e-04 ||r(i)||/||b|| 1.701450218840e-02
 24 KSP preconditioned resid norm 5.476945032608e-03 true resid norm 8.395519862224e-05 ||r(i)||/||b|| 1.416378936186e-02
 25 KSP preconditioned resid norm 4.322504107675e-03 true resid norm 6.616893612549e-05 ||r(i)||/||b|| 1.116313091935e-02
 26 KSP preconditioned resid norm 3.461079910913e-03 true resid norm 5.347371060896e-05 ||r(i)||/||b|| 9.021363606921e-03
 27 KSP preconditioned resid norm 2.772679072192e-03 true resid norm 4.238410209063e-05 ||r(i)||/||b|| 7.150474350069e-03
 28 KSP preconditioned resid norm 2.223172474694e-03 true resid norm 3.423967659879e-05 ||r(i)||/||b|| 5.776456671202e-03
 29 KSP preconditioned resid norm 1.823564665075e-03 true resid norm 2.808015905473e-05 ||r(i)||/||b|| 4.737305903930e-03
 30 KSP preconditioned resid norm 1.568714926950e-03 true resid norm 2.405937268973e-05 ||r(i)||/||b|| 4.058973030238e-03
 31 KSP preconditioned resid norm 1.330951220115e-03 true resid norm 2.050232337301e-05 ||r(i)||/||b|| 3.458875619969e-03
 32 KSP preconditioned resid norm 1.112445380693e-03 true resid norm 1.712991499703e-05 ||r(i)||/||b|| 2.889928340188e-03
 33 KSP preconditioned resid norm 9.563483445891e-04 true resid norm 1.503181056583e-05 ||r(i)||/||b|| 2.535964443843e-03
 34 KSP preconditioned resid norm 8.050833361618e-04 true resid norm 1.247054349296e-05 ||r(i)||/||b|| 2.103861990215e-03
 35 KSP preconditioned resid norm 6.691621997592e-04 true resid norm 1.048761682431e-05 ||r(i)||/||b|| 1.769329333325e-03
 36 KSP preconditioned resid norm 5.616827971815e-04 true resid norm 8.696097029531e-06 ||r(i)||/||b|| 1.467088263954e-03
 37 KSP preconditioned resid norm 4.644596069741e-04 true resid norm 7.111056878819e-06 ||r(i)||/||b|| 1.199681656701e-03
 38 KSP preconditioned resid norm 3.797383619251e-04 true resid norm 5.800312293723e-06 ||r(i)||/||b|| 9.785504996656e-04
 39 KSP preconditioned resid norm 3.140877180449e-04 true resid norm 4.881383224291e-06 ||r(i)||/||b|| 8.235211746026e-04
 40 KSP preconditioned resid norm 2.620714588908e-04 true resid norm 4.145223034537e-06 ||r(i)||/||b|| 6.993261511214e-04
 41 KSP preconditioned resid norm 2.207767033161e-04 true resid norm 3.526818155252e-06 ||r(i)||/||b|| 5.949972162336e-04
 42 KSP preconditioned resid norm 1.866103035841e-04 true resid norm 2.915123525249e-06 ||r(i)||/||b|| 4.918003441481e-04
 43 KSP preconditioned resid norm 1.584957350172e-04 true resid norm 2.555374739511e-06 ||r(i)||/||b|| 4.311083785760e-04
 44 KSP preconditioned resid norm 1.375895017144e-04 true resid norm 2.222469481167e-06 ||r(i)||/||b|| 3.749450910842e-04
 45 KSP preconditioned resid norm 1.157547186203e-04 true resid norm 1.863218425765e-06 ||r(i)||/||b|| 3.143370958649e-04
 46 KSP preconditioned resid norm 9.415239922608e-05 true resid norm 1.514217348913e-06 ||r(i)||/||b|| 2.554583388527e-04
 47 KSP preconditioned resid norm 7.725611584946e-05 true resid norm 1.241595324784e-06 ||r(i)||/||b|| 2.094652259957e-04
 48 KSP preconditioned resid norm 6.781705852316e-05 true resid norm 1.099284519571e-06 ||r(i)||/||b|| 1.854564653467e-04
 49 KSP preconditioned resid norm 5.923195829130e-05 true resid norm 9.691441107602e-07 ||r(i)||/||b|| 1.635009299169e-04
 50 KSP preconditioned resid norm 5.182397514281e-05 true resid norm 8.331364930504e-07 ||r(i)||/||b|| 1.405555580941e-04
 51 KSP preconditioned resid norm 4.397998700492e-05 true resid norm 7.092893285835e-07 ||r(i)||/||b|| 1.196617340146e-04
 52 KSP preconditioned resid norm 3.761635024544e-05 true resid norm 6.078477562331e-07 ||r(i)||/||b|| 1.025478794006e-04
 53 KSP preconditioned resid norm 3.152684368196e-05 true resid norm 5.059022395950e-07 ||r(i)||/||b|| 8.534900609978e-05
 54 KSP preconditioned resid norm 2.577740905240e-05 true resid norm 4.161979041119e-07 ||r(i)||/||b|| 7.021529986742e-05
 55 KSP preconditioned resid norm 2.145915909493e-05 true resid norm 3.460469446994e-07 ||r(i)||/||b|| 5.838037565836e-05
 56 KSP preconditioned resid norm 1.757927671844e-05 true resid norm 2.834225953553e-07 ||r(i)||/||b|| 4.781523963831e-05
 57 KSP preconditioned resid norm 1.439118538326e-05 true resid norm 2.327344418164e-07 ||r(i)||/||b|| 3.926381766983e-05
 58 KSP preconditioned resid norm 1.169740799247e-05 true resid norm 1.865988357324e-07 ||r(i)||/||b|| 3.148044013777e-05
 59 KSP preconditioned resid norm 9.305161536024e-06 true resid norm 1.485317220345e-07 ||r(i)||/||b|| 2.505826987459e-05
 60 KSP preconditioned resid norm 7.340392997175e-06 true resid norm 1.169870113782e-07 ||r(i)||/||b|| 1.973647152798e-05
 61 KSP preconditioned resid norm 5.948184830516e-06 true resid norm 9.498101240174e-08 ||r(i)||/||b|| 1.602391603036e-05
 62 KSP preconditioned resid norm 4.856045883121e-06 true resid norm 7.665203902884e-08 ||r(i)||/||b|| 1.293169872478e-05
 63 KSP preconditioned resid norm 4.003374563206e-06 true resid norm 6.412161229166e-08 ||r(i)||/||b|| 1.081773404085e-05
 64 KSP preconditioned resid norm 3.294000767888e-06 true resid norm 5.265548496789e-08 ||r(i)||/||b|| 8.883323606768e-06
 65 KSP preconditioned resid norm 2.618902827840e-06 true resid norm 4.194004801676e-08 ||r(i)||/||b|| 7.075559532753e-06
 66 KSP preconditioned resid norm 2.045372991215e-06 true resid norm 3.283504880375e-08 ||r(i)||/||b|| 5.539486804567e-06
 67 KSP preconditioned resid norm 1.614463359023e-06 true resid norm 2.526644905659e-08 ||r(i)||/||b|| 4.262614682981e-06
 68 KSP preconditioned resid norm 1.354701377277e-06 true resid norm 2.102179670960e-08 ||r(i)||/||b|| 3.546514158610e-06
 69 KSP preconditioned resid norm 1.163662438531e-06 true resid norm 1.840504650815e-08 ||r(i)||/||b|| 3.105051339461e-06
 70 KSP preconditioned resid norm 9.875758627213e-07 true resid norm 1.573128686295e-08 ||r(i)||/||b|| 2.653970655474e-06
 71 KSP preconditioned resid norm 8.173474958423e-07 true resid norm 1.281461932427e-08 ||r(i)||/||b|| 2.161909826192e-06
 72 KSP preconditioned resid norm 6.544147953464e-07 true resid norm 1.052638171516e-08 ||r(i)||/||b|| 1.775869223143e-06
 73 KSP preconditioned resid norm 5.322733883208e-07 true resid norm 8.489246895874e-09 ||r(i)||/||b|| 1.432191297826e-06
 74 KSP preconditioned resid norm 4.310003151637e-07 true resid norm 6.915921258683e-09 ||r(i)||/||b|| 1.166761005378e-06
 75 KSP preconditioned resid norm 3.468225555240e-07 true resid norm 5.566954772995e-09 ||r(i)||/||b|| 9.391815645210e-07
 76 KSP preconditioned resid norm 2.799050744056e-07 true resid norm 4.442411026782e-09 ||r(i)||/||b|| 7.494637029599e-07
 77 KSP preconditioned resid norm 2.261070613956e-07 true resid norm 3.545644602364e-09 ||r(i)||/||b|| 5.981733606024e-07
 78 KSP preconditioned resid norm 1.812855257508e-07 true resid norm 2.831041207041e-09 ||r(i)||/||b|| 4.776151088832e-07
 79 KSP preconditioned resid norm 1.438330554410e-07 true resid norm 2.223841575568e-09 ||r(i)||/||b|| 3.751765723553e-07
 80 KSP preconditioned resid norm 1.100582738876e-07 true resid norm 1.713411156369e-09 ||r(i)||/||b|| 2.890636328343e-07
 81 KSP preconditioned resid norm 8.720476127648e-08 true resid norm 1.353029064479e-09 ||r(i)||/||b|| 2.282648243854e-07
 82 KSP preconditioned resid norm 6.966553683318e-08 true resid norm 1.101422472758e-09 ||r(i)||/||b|| 1.858171519879e-07
 83 KSP preconditioned resid norm 5.817764905132e-08 true resid norm 8.990163519562e-10 ||r(i)||/||b|| 1.516699198018e-07
 84 KSP preconditioned resid norm 4.792502348292e-08 true resid norm 7.515752811570e-10 ||r(i)||/||b|| 1.267956499012e-07
Linear solve converged due to CONVERGED_RTOL iterations 84
iter =   6, Function value: -4.33719,  Residual: 0.0066053
  0 KSP preconditioned resid norm 3.474242904644e-01 true resid norm 3.961934578937e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.711581205688e-01 true resid norm 2.880817137667e-03 ||r(i)||/||b|| 7.271238533272e-01
  2 KSP preconditioned resid norm 1.418231439181e-01 true resid norm 2.235990655353e-03 ||r(i)||/||b|| 5.643683939762e-01
  3 KSP preconditioned resid norm 1.127043237665e-01 true resid norm 1.902671099409e-03 ||r(i)||/||b|| 4.802378892182e-01
  4 KSP preconditioned resid norm 9.741197813294e-02 true resid norm 1.485705758073e-03 ||r(i)||/||b|| 3.749950254030e-01
  5 KSP preconditioned resid norm 8.225949043715e-02 true resid norm 1.339669573870e-03 ||r(i)||/||b|| 3.381352082371e-01
  6 KSP preconditioned resid norm 7.428222259201e-02 true resid norm 1.159243387601e-03 ||r(i)||/||b|| 2.925952876063e-01
  7 KSP preconditioned resid norm 6.753369882308e-02 true resid norm 1.101790764376e-03 ||r(i)||/||b|| 2.780941336673e-01
  8 KSP preconditioned resid norm 6.390597621527e-02 true resid norm 1.019027163634e-03 ||r(i)||/||b|| 2.572044397330e-01
  9 KSP preconditioned resid norm 5.964499562612e-02 true resid norm 9.682973562020e-04 ||r(i)||/||b|| 2.444001375868e-01
 10 KSP preconditioned resid norm 5.259971621876e-02 true resid norm 8.285243794341e-04 ||r(i)||/||b|| 2.091211661694e-01
 11 KSP preconditioned resid norm 4.650789668926e-02 true resid norm 7.472133185795e-04 ||r(i)||/||b|| 1.885980961301e-01
 12 KSP preconditioned resid norm 4.036296170738e-02 true resid norm 6.225524707407e-04 ||r(i)||/||b|| 1.571334554716e-01
 13 KSP preconditioned resid norm 3.466786738847e-02 true resid norm 5.345919136867e-04 ||r(i)||/||b|| 1.349320396477e-01
 14 KSP preconditioned resid norm 2.956467242261e-02 true resid norm 4.494419922228e-04 ||r(i)||/||b|| 1.134400337179e-01
 15 KSP preconditioned resid norm 2.508446152309e-02 true resid norm 3.868398311138e-04 ||r(i)||/||b|| 9.763912639306e-02
 16 KSP preconditioned resid norm 2.120358648392e-02 true resid norm 3.260363448712e-04 ||r(i)||/||b|| 8.229220810574e-02
 17 KSP preconditioned resid norm 1.821392978794e-02 true resid norm 2.849694195055e-04 ||r(i)||/||b|| 7.192683620284e-02
 18 KSP preconditioned resid norm 1.508257940402e-02 true resid norm 2.344946234797e-04 ||r(i)||/||b|| 5.918689943199e-02
 19 KSP preconditioned resid norm 1.275741100495e-02 true resid norm 1.968038828670e-04 ||r(i)||/||b|| 4.967368313282e-02
 20 KSP preconditioned resid norm 1.105496755734e-02 true resid norm 1.720437605441e-04 ||r(i)||/||b|| 4.342418006060e-02
 21 KSP preconditioned resid norm 9.407757049979e-03 true resid norm 1.489926846925e-04 ||r(i)||/||b|| 3.760604364459e-02
 22 KSP preconditioned resid norm 7.949404961184e-03 true resid norm 1.257443423064e-04 ||r(i)||/||b|| 3.173811677127e-02
 23 KSP preconditioned resid norm 6.638161409345e-03 true resid norm 1.051120781328e-04 ||r(i)||/||b|| 2.653049313122e-02
 24 KSP preconditioned resid norm 5.505887585297e-03 true resid norm 8.726930384494e-05 ||r(i)||/||b|| 2.202694216833e-02
 25 KSP preconditioned resid norm 4.453481255837e-03 true resid norm 7.104772588582e-05 ||r(i)||/||b|| 1.793258431463e-02
 26 KSP preconditioned resid norm 3.659927082290e-03 true resid norm 5.828556955789e-05 ||r(i)||/||b|| 1.471139121473e-02
 27 KSP preconditioned resid norm 3.022802873924e-03 true resid norm 4.846200879961e-05 ||r(i)||/||b|| 1.223190535686e-02
 28 KSP preconditioned resid norm 2.512003968093e-03 true resid norm 4.042394057365e-05 ||r(i)||/||b|| 1.020308128977e-02
 29 KSP preconditioned resid norm 2.104820918184e-03 true resid norm 3.432319450940e-05 ||r(i)||/||b|| 8.663241107483e-03
 30 KSP preconditioned resid norm 1.806080704286e-03 true resid norm 2.912804366027e-05 ||r(i)||/||b|| 7.351974920316e-03
 31 KSP preconditioned resid norm 1.624745714602e-03 true resid norm 2.648506730262e-05 ||r(i)||/||b|| 6.684882542844e-03
 32 KSP preconditioned resid norm 1.420108267995e-03 true resid norm 2.320957758719e-05 ||r(i)||/||b|| 5.858142562623e-03
 33 KSP preconditioned resid norm 1.252744503163e-03 true resid norm 2.038034473742e-05 ||r(i)||/||b|| 5.144038683973e-03
 34 KSP preconditioned resid norm 1.081080028832e-03 true resid norm 1.759517304493e-05 ||r(i)||/||b|| 4.441055927191e-03
 35 KSP preconditioned resid norm 9.709745091152e-04 true resid norm 1.541385365060e-05 ||r(i)||/||b|| 3.890486665920e-03
 36 KSP preconditioned resid norm 8.703396579731e-04 true resid norm 1.392746318119e-05 ||r(i)||/||b|| 3.515318818043e-03
 37 KSP preconditioned resid norm 7.607332195048e-04 true resid norm 1.223676284304e-05 ||r(i)||/||b|| 3.088582761588e-03
 38 KSP preconditioned resid norm 6.237168732407e-04 true resid norm 1.005981441910e-05 ||r(i)||/||b|| 2.539116741750e-03
 39 KSP preconditioned resid norm 5.197262908567e-04 true resid norm 8.310419662042e-06 ||r(i)||/||b|| 2.097566099709e-03
 40 KSP preconditioned resid norm 4.425053497849e-04 true resid norm 7.119774202159e-06 ||r(i)||/||b|| 1.797044867932e-03
 41 KSP preconditioned resid norm 3.861043837958e-04 true resid norm 6.287354142416e-06 ||r(i)||/||b|| 1.586940424469e-03
 42 KSP preconditioned resid norm 3.337360926896e-04 true resid norm 5.525215170658e-06 ||r(i)||/||b|| 1.394575064423e-03
 43 KSP preconditioned resid norm 2.901746152663e-04 true resid norm 4.720830735591e-06 ||r(i)||/||b|| 1.191546867202e-03
 44 KSP preconditioned resid norm 2.574662881464e-04 true resid norm 4.120383675600e-06 ||r(i)||/||b|| 1.039992860434e-03
 45 KSP preconditioned resid norm 2.214469185508e-04 true resid norm 3.507298630253e-06 ||r(i)||/||b|| 8.852490015610e-04
 46 KSP preconditioned resid norm 1.875353947062e-04 true resid norm 3.004375403889e-06 ||r(i)||/||b|| 7.583102002395e-04
 47 KSP preconditioned resid norm 1.540875725788e-04 true resid norm 2.441434159676e-06 ||r(i)||/||b|| 6.162227343823e-04
 48 KSP preconditioned resid norm 1.298145537129e-04 true resid norm 2.082948051347e-06 ||r(i)||/||b|| 5.257401428133e-04
 49 KSP preconditioned resid norm 1.106637251370e-04 true resid norm 1.774951572776e-06 ||r(i)||/||b|| 4.480012320779e-04
 50 KSP preconditioned resid norm 9.695360634495e-05 true resid norm 1.576110756896e-06 ||r(i)||/||b|| 3.978134230875e-04
 51 KSP preconditioned resid norm 8.299759057479e-05 true resid norm 1.349801485228e-06 ||r(i)||/||b|| 3.406925223865e-04
 52 KSP preconditioned resid norm 6.999667985659e-05 true resid norm 1.147015029675e-06 ||r(i)||/||b|| 2.895088262619e-04
 53 KSP preconditioned resid norm 5.939989661658e-05 true resid norm 9.733357605049e-07 ||r(i)||/||b|| 2.456718406406e-04
 54 KSP preconditioned resid norm 5.011816072046e-05 true resid norm 8.329979314243e-07 ||r(i)||/||b|| 2.102502993999e-04
 55 KSP preconditioned resid norm 4.240737830147e-05 true resid norm 7.058725265191e-07 ||r(i)||/||b|| 1.781635997403e-04
 56 KSP preconditioned resid norm 3.559705420947e-05 true resid norm 6.020149532401e-07 ||r(i)||/||b|| 1.519497460762e-04
 57 KSP preconditioned resid norm 3.007965802532e-05 true resid norm 4.994266139406e-07 ||r(i)||/||b|| 1.260562495393e-04
 58 KSP preconditioned resid norm 2.475534870412e-05 true resid norm 4.097309511098e-07 ||r(i)||/||b|| 1.034168896397e-04
 59 KSP preconditioned resid norm 2.043564637907e-05 true resid norm 3.420386965339e-07 ||r(i)||/||b|| 8.633123281549e-05
 60 KSP preconditioned resid norm 1.656142621722e-05 true resid norm 2.734533807265e-07 ||r(i)||/||b|| 6.902016559795e-05
 61 KSP preconditioned resid norm 1.401633443807e-05 true resid norm 2.277324663823e-07 ||r(i)||/||b|| 5.748011781745e-05
 62 KSP preconditioned resid norm 1.195949616259e-05 true resid norm 1.956134783230e-07 ||r(i)||/||b|| 4.937322270866e-05
 63 KSP preconditioned resid norm 1.011491957601e-05 true resid norm 1.689421240417e-07 ||r(i)||/||b|| 4.264132096978e-05
 64 KSP preconditioned resid norm 8.727602388246e-06 true resid norm 1.448041471437e-07 ||r(i)||/||b|| 3.654884861390e-05
 65 KSP preconditioned resid norm 7.735117263729e-06 true resid norm 1.256026877535e-07 ||r(i)||/||b|| 3.170236288638e-05
 66 KSP preconditioned resid norm 6.756267827530e-06 true resid norm 1.102996903578e-07 ||r(i)||/||b|| 2.783985655499e-05
 67 KSP preconditioned resid norm 5.643058075763e-06 true resid norm 9.482529110440e-08 ||r(i)||/||b|| 2.393408806105e-05
 68 KSP preconditioned resid norm 4.616637281689e-06 true resid norm 7.759628345890e-08 ||r(i)||/||b|| 1.958545299345e-05
 69 KSP preconditioned resid norm 3.746133639040e-06 true resid norm 6.135950502325e-08 ||r(i)||/||b|| 1.548725850989e-05
 70 KSP preconditioned resid norm 3.063597550441e-06 true resid norm 5.001602889000e-08 ||r(i)||/||b|| 1.262414305272e-05
 71 KSP preconditioned resid norm 2.523754570469e-06 true resid norm 4.126380553334e-08 ||r(i)||/||b|| 1.041506484047e-05
 72 KSP preconditioned resid norm 2.039188787404e-06 true resid norm 3.302137658554e-08 ||r(i)||/||b|| 8.334659729390e-06
 73 KSP preconditioned resid norm 1.595664944021e-06 true resid norm 2.607645627141e-08 ||r(i)||/||b|| 6.581748323166e-06
 74 KSP preconditioned resid norm 1.263362826252e-06 true resid norm 2.094000499886e-08 ||r(i)||/||b|| 5.285298023391e-06
 75 KSP preconditioned resid norm 1.003885058459e-06 true resid norm 1.663093550128e-08 ||r(i)||/||b|| 4.197680494197e-06
 76 KSP preconditioned resid norm 7.979532670862e-07 true resid norm 1.347974301787e-08 ||r(i)||/||b|| 3.402313377292e-06
 77 KSP preconditioned resid norm 6.450856821257e-07 true resid norm 1.077717244727e-08 ||r(i)||/||b|| 2.720179304465e-06
 78 KSP preconditioned resid norm 5.388602093955e-07 true resid norm 9.008405077328e-09 ||r(i)||/||b|| 2.273738977221e-06
 79 KSP preconditioned resid norm 4.536966600695e-07 true resid norm 7.554603563040e-09 ||r(i)||/||b|| 1.906796645054e-06
 80 KSP preconditioned resid norm 3.778076094541e-07 true resid norm 6.338687380953e-09 ||r(i)||/||b|| 1.599897033801e-06
 81 KSP preconditioned resid norm 3.097009198498e-07 true resid norm 5.261103646847e-09 ||r(i)||/||b|| 1.327912801695e-06
 82 KSP preconditioned resid norm 2.586663678939e-07 true resid norm 4.404454681252e-09 ||r(i)||/||b|| 1.111692935231e-06
 83 KSP preconditioned resid norm 2.224946898937e-07 true resid norm 3.800029691501e-09 ||r(i)||/||b|| 9.591348912481e-07
 84 KSP preconditioned resid norm 1.881436511955e-07 true resid norm 3.199086896759e-09 ||r(i)||/||b|| 8.074557600641e-07
 85 KSP preconditioned resid norm 1.570450789636e-07 true resid norm 2.640669638632e-09 ||r(i)||/||b|| 6.665101571013e-07
 86 KSP preconditioned resid norm 1.305781174045e-07 true resid norm 2.172187389986e-09 ||r(i)||/||b|| 5.482643255984e-07
 87 KSP preconditioned resid norm 1.119038853979e-07 true resid norm 1.833628403124e-09 ||r(i)||/||b|| 4.628113782779e-07
 88 KSP preconditioned resid norm 9.509771492227e-08 true resid norm 1.546485079686e-09 ||r(i)||/||b|| 3.903358444907e-07
 89 KSP preconditioned resid norm 8.096687622075e-08 true resid norm 1.321235470378e-09 ||r(i)||/||b|| 3.334824046320e-07
 90 KSP preconditioned resid norm 6.851137194289e-08 true resid norm 1.130297805011e-09 ||r(i)||/||b|| 2.852893662153e-07
 91 KSP preconditioned resid norm 5.658021776650e-08 true resid norm 9.362235291973e-10 ||r(i)||/||b|| 2.363046412161e-07
 92 KSP preconditioned resid norm 4.571104453997e-08 true resid norm 7.487150085066e-10 ||r(i)||/||b|| 1.889771255909e-07
 93 KSP preconditioned resid norm 3.789901271190e-08 true resid norm 6.075196468897e-10 ||r(i)||/||b|| 1.533391414688e-07
 94 KSP preconditioned resid norm 3.280005901845e-08 true resid norm 5.349512202283e-10 ||r(i)||/||b|| 1.350227293182e-07
Linear solve converged due to CONVERGED_RTOL iterations 94
iter =   7, Function value: -4.33959,  Residual: 0.00499036
  0 KSP preconditioned resid norm 2.227135824297e-01 true resid norm 2.885649999271e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.117329976209e-01 true resid norm 1.976488530071e-03 ||r(i)||/||b|| 6.849370265176e-01
  2 KSP preconditioned resid norm 8.395782924997e-02 true resid norm 1.507238385971e-03 ||r(i)||/||b|| 5.223219677896e-01
  3 KSP preconditioned resid norm 6.723893428241e-02 true resid norm 1.178422091524e-03 ||r(i)||/||b|| 4.083731886479e-01
  4 KSP preconditioned resid norm 5.949033337171e-02 true resid norm 1.019949270842e-03 ||r(i)||/||b|| 3.534556412244e-01
  5 KSP preconditioned resid norm 5.103617038169e-02 true resid norm 8.635076643283e-04 ||r(i)||/||b|| 2.992419955803e-01
  6 KSP preconditioned resid norm 4.385744566872e-02 true resid norm 7.549423809662e-04 ||r(i)||/||b|| 2.616195245982e-01
  7 KSP preconditioned resid norm 4.058790001615e-02 true resid norm 6.727259966837e-04 ||r(i)||/||b|| 2.331280636438e-01
  8 KSP preconditioned resid norm 3.697052330890e-02 true resid norm 5.947015342644e-04 ||r(i)||/||b|| 2.060892812415e-01
  9 KSP preconditioned resid norm 3.555374138821e-02 true resid norm 5.488462780438e-04 ||r(i)||/||b|| 1.901984919108e-01
 10 KSP preconditioned resid norm 3.320637068068e-02 true resid norm 5.145096199418e-04 ||r(i)||/||b|| 1.782993849121e-01
 11 KSP preconditioned resid norm 3.148648645139e-02 true resid norm 4.914223746345e-04 ||r(i)||/||b|| 1.702986761245e-01
 12 KSP preconditioned resid norm 2.757435903590e-02 true resid norm 4.278993339338e-04 ||r(i)||/||b|| 1.482852508246e-01
 13 KSP preconditioned resid norm 2.387535647702e-02 true resid norm 3.787067110210e-04 ||r(i)||/||b|| 1.312379225189e-01
 14 KSP preconditioned resid norm 2.018708972566e-02 true resid norm 3.185324421095e-04 ||r(i)||/||b|| 1.103849885433e-01
 15 KSP preconditioned resid norm 1.716177336666e-02 true resid norm 2.735217322199e-04 ||r(i)||/||b|| 9.478687030270e-02
 16 KSP preconditioned resid norm 1.417279867737e-02 true resid norm 2.288780821359e-04 ||r(i)||/||b|| 7.931595383836e-02
 17 KSP preconditioned resid norm 1.188661837672e-02 true resid norm 1.933504026258e-04 ||r(i)||/||b|| 6.700410745400e-02
 18 KSP preconditioned resid norm 1.006999239673e-02 true resid norm 1.651740015026e-04 ||r(i)||/||b|| 5.723979053049e-02
 19 KSP preconditioned resid norm 8.458854449409e-03 true resid norm 1.389843086347e-04 ||r(i)||/||b|| 4.816395220136e-02
 20 KSP preconditioned resid norm 7.366150486832e-03 true resid norm 1.196917098180e-04 ||r(i)||/||b|| 4.147824921535e-02
 21 KSP preconditioned resid norm 6.497187986366e-03 true resid norm 1.063338341813e-04 ||r(i)||/||b|| 3.684917928652e-02
 22 KSP preconditioned resid norm 5.827165888069e-03 true resid norm 9.523847375892e-05 ||r(i)||/||b|| 3.300416675029e-02
 23 KSP preconditioned resid norm 4.931096810044e-03 true resid norm 8.074512380836e-05 ||r(i)||/||b|| 2.798160685764e-02
 24 KSP preconditioned resid norm 4.202613829020e-03 true resid norm 6.941393955966e-05 ||r(i)||/||b|| 2.405487137289e-02
 25 KSP preconditioned resid norm 3.465789364999e-03 true resid norm 5.702987179756e-05 ||r(i)||/||b|| 1.976326713633e-02
 26 KSP preconditioned resid norm 2.902762094140e-03 true resid norm 4.810274900340e-05 ||r(i)||/||b|| 1.666964081422e-02
 27 KSP preconditioned resid norm 2.380474750771e-03 true resid norm 3.950999784913e-05 ||r(i)||/||b|| 1.369188843384e-02
 28 KSP preconditioned resid norm 1.978893964352e-03 true resid norm 3.281412887435e-05 ||r(i)||/||b|| 1.137148610630e-02
 29 KSP preconditioned resid norm 1.645760099757e-03 true resid norm 2.751179724744e-05 ||r(i)||/||b|| 9.534003518925e-03
 30 KSP preconditioned resid norm 1.423066188994e-03 true resid norm 2.352995721189e-05 ||r(i)||/||b|| 8.154127221885e-03
 31 KSP preconditioned resid norm 1.268762472840e-03 true resid norm 2.102777144020e-05 ||r(i)||/||b|| 7.287013825484e-03
 32 KSP preconditioned resid norm 1.110006457706e-03 true resid norm 1.858137454395e-05 ||r(i)||/||b|| 6.439233638398e-03
 33 KSP preconditioned resid norm 9.960483048182e-04 true resid norm 1.674056259132e-05 ||r(i)||/||b|| 5.801314295061e-03
 34 KSP preconditioned resid norm 8.710070186926e-04 true resid norm 1.449004087785e-05 ||r(i)||/||b|| 5.021413158737e-03
 35 KSP preconditioned resid norm 7.585273169470e-04 true resid norm 1.274506206496e-05 ||r(i)||/||b|| 4.416704059114e-03
 36 KSP preconditioned resid norm 6.521486257904e-04 true resid norm 1.063065053081e-05 ||r(i)||/||b|| 3.683970867395e-03
 37 KSP preconditioned resid norm 5.767087228669e-04 true resid norm 9.365402872902e-06 ||r(i)||/||b|| 3.245508940886e-03
 38 KSP preconditioned resid norm 4.958538740952e-04 true resid norm 8.227376689908e-06 ||r(i)||/||b|| 2.851134646262e-03
 39 KSP preconditioned resid norm 4.190138425860e-04 true resid norm 6.799965137006e-06 ||r(i)||/||b|| 2.356476058678e-03
 40 KSP preconditioned resid norm 3.385523838861e-04 true resid norm 5.447955608655e-06 ||r(i)||/||b|| 1.887947467652e-03
 41 KSP preconditioned resid norm 2.812473404588e-04 true resid norm 4.502316638953e-06 ||r(i)||/||b|| 1.560243494565e-03
 42 KSP preconditioned resid norm 2.415772108871e-04 true resid norm 3.915573427365e-06 ||r(i)||/||b|| 1.356912109353e-03
 43 KSP preconditioned resid norm 2.167341688705e-04 true resid norm 3.578775570689e-06 ||r(i)||/||b|| 1.240197380692e-03
 44 KSP preconditioned resid norm 1.938775019971e-04 true resid norm 3.186094930185e-06 ||r(i)||/||b|| 1.104116899482e-03
 45 KSP preconditioned resid norm 1.673352118713e-04 true resid norm 2.742092493214e-06 ||r(i)||/||b|| 9.502512411092e-04
 46 KSP preconditioned resid norm 1.465545003838e-04 true resid norm 2.401731188726e-06 ||r(i)||/||b|| 8.323016267853e-04
 47 KSP preconditioned resid norm 1.278085571838e-04 true resid norm 2.156332602427e-06 ||r(i)||/||b|| 7.472606182219e-04
 48 KSP preconditioned resid norm 1.145395283644e-04 true resid norm 1.923618967772e-06 ||r(i)||/||b|| 6.666154829097e-04
 49 KSP preconditioned resid norm 1.001440697871e-04 true resid norm 1.659957668766e-06 ||r(i)||/||b|| 5.752456705372e-04
 50 KSP preconditioned resid norm 8.677514762931e-05 true resid norm 1.476287312102e-06 ||r(i)||/||b|| 5.115961091868e-04
 51 KSP preconditioned resid norm 7.591574862560e-05 true resid norm 1.299260321326e-06 ||r(i)||/||b|| 4.502487556198e-04
 52 KSP preconditioned resid norm 6.640132611549e-05 true resid norm 1.142088339713e-06 ||r(i)||/||b|| 3.957820040550e-04
 53 KSP preconditioned resid norm 5.748830895110e-05 true resid norm 9.875982789612e-07 ||r(i)||/||b|| 3.422446517113e-04
 54 KSP preconditioned resid norm 4.940245072152e-05 true resid norm 8.426470346471e-07 ||r(i)||/||b|| 2.920129034567e-04
 55 KSP preconditioned resid norm 4.263172313668e-05 true resid norm 7.338677809012e-07 ||r(i)||/||b|| 2.543162826700e-04
 56 KSP preconditioned resid norm 3.673068816357e-05 true resid norm 6.416127893384e-07 ||r(i)||/||b|| 2.223460189214e-04
 57 KSP preconditioned resid norm 3.264403753267e-05 true resid norm 5.685224179767e-07 ||r(i)||/||b|| 1.970171081456e-04
 58 KSP preconditioned resid norm 2.805906768969e-05 true resid norm 4.836249085245e-07 ||r(i)||/||b|| 1.675965237110e-04
 59 KSP preconditioned resid norm 2.394524372714e-05 true resid norm 4.096839696077e-07 ||r(i)||/||b|| 1.419728552358e-04
 60 KSP preconditioned resid norm 1.966271880533e-05 true resid norm 3.459186627132e-07 ||r(i)||/||b|| 1.198754744340e-04
 61 KSP preconditioned resid norm 1.633081889428e-05 true resid norm 2.834970606872e-07 ||r(i)||/||b|| 9.824374430677e-05
 62 KSP preconditioned resid norm 1.384613199798e-05 true resid norm 2.328715138572e-07 ||r(i)||/||b|| 8.069984714571e-05
 63 KSP preconditioned resid norm 1.199732665707e-05 true resid norm 2.068542038897e-07 ||r(i)||/||b|| 7.168374679602e-05
 64 KSP preconditioned resid norm 1.052713729472e-05 true resid norm 1.806385724770e-07 ||r(i)||/||b|| 6.259891966199e-05
 65 KSP preconditioned resid norm 9.195699405680e-06 true resid norm 1.577418743274e-07 ||r(i)||/||b|| 5.466424353864e-05
 66 KSP preconditioned resid norm 7.941874399883e-06 true resid norm 1.343367535892e-07 ||r(i)||/||b|| 4.655337744464e-05
 67 KSP preconditioned resid norm 6.760037690776e-06 true resid norm 1.150430592683e-07 ||r(i)||/||b|| 3.986729482001e-05
 68 KSP preconditioned resid norm 5.783154898670e-06 true resid norm 9.994491239218e-08 ||r(i)||/||b|| 3.463514716526e-05
 69 KSP preconditioned resid norm 4.904178405653e-06 true resid norm 8.412520188205e-08 ||r(i)||/||b|| 2.915294713610e-05
 70 KSP preconditioned resid norm 4.174275408684e-06 true resid norm 7.058544912990e-08 ||r(i)||/||b|| 2.446084908001e-05
 71 KSP preconditioned resid norm 3.506802725391e-06 true resid norm 6.017240561483e-08 ||r(i)||/||b|| 2.085228826435e-05
 72 KSP preconditioned resid norm 2.986707695018e-06 true resid norm 5.110420521590e-08 ||r(i)||/||b|| 1.770977257422e-05
 73 KSP preconditioned resid norm 2.495813341764e-06 true resid norm 4.249367177950e-08 ||r(i)||/||b|| 1.472585787959e-05
 74 KSP preconditioned resid norm 2.108541319177e-06 true resid norm 3.612860716922e-08 ||r(i)||/||b|| 1.252009328170e-05
 75 KSP preconditioned resid norm 1.758008764090e-06 true resid norm 3.006388307729e-08 ||r(i)||/||b|| 1.041840939992e-05
 76 KSP preconditioned resid norm 1.474087087893e-06 true resid norm 2.517284760668e-08 ||r(i)||/||b|| 8.723458358788e-06
 77 KSP preconditioned resid norm 1.256008159579e-06 true resid norm 2.153029469865e-08 ||r(i)||/||b|| 7.461159428237e-06
 78 KSP preconditioned resid norm 1.109890008983e-06 true resid norm 1.904836843952e-08 ||r(i)||/||b|| 6.601066811404e-06
 79 KSP preconditioned resid norm 1.004373742540e-06 true resid norm 1.728591642542e-08 ||r(i)||/||b|| 5.990302507161e-06
 80 KSP preconditioned resid norm 8.939016234631e-07 true resid norm 1.554312330527e-08 ||r(i)||/||b|| 5.386350842685e-06
 81 KSP preconditioned resid norm 7.837137763429e-07 true resid norm 1.373315671199e-08 ||r(i)||/||b|| 4.759120723393e-06
 82 KSP preconditioned resid norm 6.598813923488e-07 true resid norm 1.163193336350e-08 ||r(i)||/||b|| 4.030957796835e-06
 83 KSP preconditioned resid norm 5.499520915549e-07 true resid norm 9.772711918176e-09 ||r(i)||/||b|| 3.386658784206e-06
 84 KSP preconditioned resid norm 4.549642134890e-07 true resid norm 8.147467633825e-09 ||r(i)||/||b|| 2.823442772298e-06
 85 KSP preconditioned resid norm 3.656026410605e-07 true resid norm 6.447061640346e-09 ||r(i)||/||b|| 2.234180043309e-06
 86 KSP preconditioned resid norm 2.888743586297e-07 true resid norm 5.094527991959e-09 ||r(i)||/||b|| 1.765469822482e-06
 87 KSP preconditioned resid norm 2.342917985524e-07 true resid norm 4.151118296604e-09 ||r(i)||/||b|| 1.438538387418e-06
 88 KSP preconditioned resid norm 1.928230563493e-07 true resid norm 3.351130063095e-09 ||r(i)||/||b|| 1.161308566161e-06
 89 KSP preconditioned resid norm 1.588626070574e-07 true resid norm 2.721254426539e-09 ||r(i)||/||b|| 9.430299680233e-07
 90 KSP preconditioned resid norm 1.334758351805e-07 true resid norm 2.222272016972e-09 ||r(i)||/||b|| 7.701114194492e-07
 91 KSP preconditioned resid norm 1.128806917646e-07 true resid norm 1.890132315663e-09 ||r(i)||/||b|| 6.550109390051e-07
 92 KSP preconditioned resid norm 9.818618430104e-08 true resid norm 1.660605073594e-09 ||r(i)||/||b|| 5.754700237429e-07
 93 KSP preconditioned resid norm 8.545787727719e-08 true resid norm 1.457979708551e-09 ||r(i)||/||b|| 5.052517487981e-07
 94 KSP preconditioned resid norm 7.344124358177e-08 true resid norm 1.236325833164e-09 ||r(i)||/||b|| 4.284392887136e-07
 95 KSP preconditioned resid norm 6.199539193848e-08 true resid norm 1.039001967351e-09 ||r(i)||/||b|| 3.600582078956e-07
 96 KSP preconditioned resid norm 5.269750043691e-08 true resid norm 8.926079644187e-10 ||r(i)||/||b|| 3.093264826449e-07
 97 KSP preconditioned resid norm 4.579889093423e-08 true resid norm 7.600648357004e-10 ||r(i)||/||b|| 2.633946722203e-07
 98 KSP preconditioned resid norm 4.120038839958e-08 true resid norm 6.868713709193e-10 ||r(i)||/||b|| 2.380300352062e-07
 99 KSP preconditioned resid norm 3.732660316701e-08 true resid norm 6.213163136750e-10 ||r(i)||/||b|| 2.153124300702e-07
100 KSP preconditioned resid norm 3.327169042246e-08 true resid norm 5.546240223426e-10 ||r(i)||/||b|| 1.922007251339e-07
101 KSP preconditioned resid norm 2.968967801300e-08 true resid norm 4.802412088211e-10 ||r(i)||/||b|| 1.664239283844e-07
102 KSP preconditioned resid norm 2.627260749907e-08 true resid norm 4.286604038728e-10 ||r(i)||/||b|| 1.485489938077e-07
103 KSP preconditioned resid norm 2.296927279665e-08 true resid norm 3.757642817289e-10 ||r(i)||/||b|| 1.302182460880e-07
104 KSP preconditioned resid norm 1.972466663752e-08 true resid norm 3.239010639550e-10 ||r(i)||/||b|| 1.122454435004e-07
Linear solve converged due to CONVERGED_RTOL iterations 104
iter =   8, Function value: -4.34067,  Residual: 0.00380523
  0 KSP preconditioned resid norm 1.588507251562e-01 true resid norm 2.111728178921e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.953321562513e-02 true resid norm 1.509280088011e-03 ||r(i)||/||b|| 7.147132396474e-01
  2 KSP preconditioned resid norm 6.263787688589e-02 true resid norm 1.161509246828e-03 ||r(i)||/||b|| 5.500278200682e-01
  3 KSP preconditioned resid norm 4.797517613008e-02 true resid norm 9.091076526194e-04 ||r(i)||/||b|| 4.305041063969e-01
  4 KSP preconditioned resid norm 4.078133877680e-02 true resid norm 7.396301283272e-04 ||r(i)||/||b|| 3.502487373660e-01
  5 KSP preconditioned resid norm 3.569317547805e-02 true resid norm 6.635452203600e-04 ||r(i)||/||b|| 3.142190491104e-01
  6 KSP preconditioned resid norm 3.213182113700e-02 true resid norm 5.633779989808e-04 ||r(i)||/||b|| 2.667852825967e-01
  7 KSP preconditioned resid norm 2.893656657812e-02 true resid norm 5.128687192381e-04 ||r(i)||/||b|| 2.428668255496e-01
  8 KSP preconditioned resid norm 2.576657132492e-02 true resid norm 4.425822360097e-04 ||r(i)||/||b|| 2.095829569485e-01
  9 KSP preconditioned resid norm 2.410856748761e-02 true resid norm 4.019544016551e-04 ||r(i)||/||b|| 1.903438168167e-01
 10 KSP preconditioned resid norm 2.214366495393e-02 true resid norm 3.600785860315e-04 ||r(i)||/||b|| 1.705137004023e-01
 11 KSP preconditioned resid norm 2.162531124984e-02 true resid norm 3.447059031305e-04 ||r(i)||/||b|| 1.632340310516e-01
 12 KSP preconditioned resid norm 2.044832510799e-02 true resid norm 3.308571495015e-04 ||r(i)||/||b|| 1.566760120001e-01
 13 KSP preconditioned resid norm 1.922530650362e-02 true resid norm 3.098773544575e-04 ||r(i)||/||b|| 1.467411182702e-01
 14 KSP preconditioned resid norm 1.677824479507e-02 true resid norm 2.760250196613e-04 ||r(i)||/||b|| 1.307104874655e-01
 15 KSP preconditioned resid norm 1.469648964620e-02 true resid norm 2.394716682259e-04 ||r(i)||/||b|| 1.134008015882e-01
 16 KSP preconditioned resid norm 1.244840630131e-02 true resid norm 2.046752016176e-04 ||r(i)||/||b|| 9.692308113359e-02
 17 KSP preconditioned resid norm 1.045343398778e-02 true resid norm 1.703556071147e-04 ||r(i)||/||b|| 8.067118145941e-02
 18 KSP preconditioned resid norm 8.828707796998e-03 true resid norm 1.449101380420e-04 ||r(i)||/||b|| 6.862158656996e-02
 19 KSP preconditioned resid norm 7.479543899877e-03 true resid norm 1.223421323421e-04 ||r(i)||/||b|| 5.793460236183e-02
 20 KSP preconditioned resid norm 6.391026564485e-03 true resid norm 1.046063960570e-04 ||r(i)||/||b|| 4.953591901702e-02
 21 KSP preconditioned resid norm 5.349115329151e-03 true resid norm 8.462600840691e-05 ||r(i)||/||b|| 4.007429045634e-02
 22 KSP preconditioned resid norm 4.644050055069e-03 true resid norm 7.367557141609e-05 ||r(i)||/||b|| 3.488875706235e-02
 23 KSP preconditioned resid norm 4.022144285696e-03 true resid norm 6.646220009596e-05 ||r(i)||/||b|| 3.147289540358e-02
 24 KSP preconditioned resid norm 3.506284618016e-03 true resid norm 5.850752376116e-05 ||r(i)||/||b|| 2.770599187205e-02
 25 KSP preconditioned resid norm 2.988937562339e-03 true resid norm 4.973734144972e-05 ||r(i)||/||b|| 2.355290891422e-02
 26 KSP preconditioned resid norm 2.569704370228e-03 true resid norm 4.304630498516e-05 ||r(i)||/||b|| 2.038439673005e-02
 27 KSP preconditioned resid norm 2.145010783349e-03 true resid norm 3.677690988038e-05 ||r(i)||/||b|| 1.741555103895e-02
 28 KSP preconditioned resid norm 1.785528086714e-03 true resid norm 3.023375067673e-05 ||r(i)||/||b|| 1.431706550991e-02
 29 KSP preconditioned resid norm 1.512325184162e-03 true resid norm 2.572166934430e-05 ||r(i)||/||b|| 1.218038836677e-02
 30 KSP preconditioned resid norm 1.248958171594e-03 true resid norm 2.173514928823e-05 ||r(i)||/||b|| 1.029258855623e-02
 31 KSP preconditioned resid norm 1.069824444697e-03 true resid norm 1.857668170137e-05 ||r(i)||/||b|| 8.796909510800e-03
 32 KSP preconditioned resid norm 9.502019917694e-04 true resid norm 1.616879145518e-05 ||r(i)||/||b|| 7.656663209108e-03
 33 KSP preconditioned resid norm 8.621479612558e-04 true resid norm 1.461998630183e-05 ||r(i)||/||b|| 6.923233040962e-03
 34 KSP preconditioned resid norm 7.709955045496e-04 true resid norm 1.306213109817e-05 ||r(i)||/||b|| 6.185517259539e-03
 35 KSP preconditioned resid norm 7.021836605070e-04 true resid norm 1.200828372480e-05 ||r(i)||/||b|| 5.686472266967e-03
 36 KSP preconditioned resid norm 6.153077107959e-04 true resid norm 1.065053857757e-05 ||r(i)||/||b|| 5.043517761367e-03
 37 KSP preconditioned resid norm 5.484280564042e-04 true resid norm 9.311901688920e-06 ||r(i)||/||b|| 4.409611891280e-03
 38 KSP preconditioned resid norm 4.921351418618e-04 true resid norm 8.177974779226e-06 ||r(i)||/||b|| 3.872645570987e-03
 39 KSP preconditioned resid norm 4.338523874473e-04 true resid norm 7.293428348227e-06 ||r(i)||/||b|| 3.453772327817e-03
 40 KSP preconditioned resid norm 3.697803076066e-04 true resid norm 6.253974170283e-06 ||r(i)||/||b|| 2.961543172417e-03
 41 KSP preconditioned resid norm 2.997145770065e-04 true resid norm 5.139219246110e-06 ||r(i)||/||b|| 2.433655665256e-03
 42 KSP preconditioned resid norm 2.429069180563e-04 true resid norm 4.131388551469e-06 ||r(i)||/||b|| 1.956401677407e-03
 43 KSP preconditioned resid norm 2.047801571591e-04 true resid norm 3.505361341977e-06 ||r(i)||/||b|| 1.659949124593e-03
 44 KSP preconditioned resid norm 1.771704774526e-04 true resid norm 3.016093770584e-06 ||r(i)||/||b|| 1.428258523370e-03
 45 KSP preconditioned resid norm 1.512055860859e-04 true resid norm 2.624005665840e-06 ||r(i)||/||b|| 1.242586849971e-03
 46 KSP preconditioned resid norm 1.295883175578e-04 true resid norm 2.265946239562e-06 ||r(i)||/||b|| 1.073029314180e-03
 47 KSP preconditioned resid norm 1.112141885213e-04 true resid norm 1.892173706291e-06 ||r(i)||/||b|| 8.960309026413e-04
 48 KSP preconditioned resid norm 9.649490813502e-05 true resid norm 1.651517058477e-06 ||r(i)||/||b|| 7.820689589514e-04
 49 KSP preconditioned resid norm 8.381924122370e-05 true resid norm 1.461684078350e-06 ||r(i)||/||b|| 6.921743493983e-04
 50 KSP preconditioned resid norm 7.449214730418e-05 true resid norm 1.281845950237e-06 ||r(i)||/||b|| 6.070127599908e-04
 51 KSP preconditioned resid norm 6.690662664963e-05 true resid norm 1.151132125641e-06 ||r(i)||/||b|| 5.451137779621e-04
 52 KSP preconditioned resid norm 6.123200510976e-05 true resid norm 1.060727747638e-06 ||r(i)||/||b|| 5.023031648799e-04
 53 KSP preconditioned resid norm 5.514153429767e-05 true resid norm 9.627845603338e-07 ||r(i)||/||b|| 4.559225803512e-04
 54 KSP preconditioned resid norm 4.771748901183e-05 true resid norm 8.409450418229e-07 ||r(i)||/||b|| 3.982259886558e-04
 55 KSP preconditioned resid norm 4.050283573750e-05 true resid norm 7.125730455587e-07 ||r(i)||/||b|| 3.374359695872e-04
 56 KSP preconditioned resid norm 3.453616493048e-05 true resid norm 5.972918513561e-07 ||r(i)||/||b|| 2.828450447924e-04
 57 KSP preconditioned resid norm 3.063399957005e-05 true resid norm 5.334441359243e-07 ||r(i)||/||b|| 2.526102276084e-04
 58 KSP preconditioned resid norm 2.671501219222e-05 true resid norm 4.714875800874e-07 ||r(i)||/||b|| 2.232709610990e-04
 59 KSP preconditioned resid norm 2.379297875336e-05 true resid norm 4.174954334313e-07 ||r(i)||/||b|| 1.977032070693e-04
 60 KSP preconditioned resid norm 2.076644500548e-05 true resid norm 3.654820187065e-07 ||r(i)||/||b|| 1.730724732259e-04
 61 KSP preconditioned resid norm 1.800737091319e-05 true resid norm 3.228282302102e-07 ||r(i)||/||b|| 1.528739510287e-04
 62 KSP preconditioned resid norm 1.551100225282e-05 true resid norm 2.798303126243e-07 ||r(i)||/||b|| 1.325124679481e-04
 63 KSP preconditioned resid norm 1.345636889946e-05 true resid norm 2.363045607918e-07 ||r(i)||/||b|| 1.119010311794e-04
 64 KSP preconditioned resid norm 1.169909963508e-05 true resid norm 2.050181818912e-07 ||r(i)||/||b|| 9.708549800001e-05
 65 KSP preconditioned resid norm 1.034217686115e-05 true resid norm 1.824494061657e-07 ||r(i)||/||b|| 8.639814914956e-05
 66 KSP preconditioned resid norm 9.021773257524e-06 true resid norm 1.583818804439e-07 ||r(i)||/||b|| 7.500107354009e-05
 67 KSP preconditioned resid norm 7.734927322885e-06 true resid norm 1.341006807559e-07 ||r(i)||/||b|| 6.350281352236e-05
 68 KSP preconditioned resid norm 6.633012470652e-06 true resid norm 1.162919778510e-07 ||r(i)||/||b|| 5.506957714152e-05
 69 KSP preconditioned resid norm 5.513539642110e-06 true resid norm 9.566376091826e-08 ||r(i)||/||b|| 4.530117174794e-05
 70 KSP preconditioned resid norm 4.596598866565e-06 true resid norm 8.005912699390e-08 ||r(i)||/||b|| 3.791166296546e-05
 71 KSP preconditioned resid norm 3.870779671132e-06 true resid norm 6.711982173833e-08 ||r(i)||/||b|| 3.178430936724e-05
 72 KSP preconditioned resid norm 3.445215213827e-06 true resid norm 5.949393991083e-08 ||r(i)||/||b|| 2.817310509217e-05
 73 KSP preconditioned resid norm 3.127640301560e-06 true resid norm 5.365042394003e-08 ||r(i)||/||b|| 2.540593267428e-05
 74 KSP preconditioned resid norm 2.850002434094e-06 true resid norm 4.905466565130e-08 ||r(i)||/||b|| 2.322963066031e-05
 75 KSP preconditioned resid norm 2.529735201581e-06 true resid norm 4.429824170832e-08 ||r(i)||/||b|| 2.097724610132e-05
 76 KSP preconditioned resid norm 2.269085820293e-06 true resid norm 3.984449123100e-08 ||r(i)||/||b|| 1.886819128936e-05
 77 KSP preconditioned resid norm 1.980780237612e-06 true resid norm 3.499711230373e-08 ||r(i)||/||b|| 1.657273537999e-05
 78 KSP preconditioned resid norm 1.675477193048e-06 true resid norm 2.981088416611e-08 ||r(i)||/||b|| 1.411681885182e-05
 79 KSP preconditioned resid norm 1.425922466607e-06 true resid norm 2.508378870433e-08 ||r(i)||/||b|| 1.187832267179e-05
 80 KSP preconditioned resid norm 1.258667641268e-06 true resid norm 2.183907172141e-08 ||r(i)||/||b|| 1.034180058750e-05
 81 KSP preconditioned resid norm 1.130369036064e-06 true resid norm 1.979509163279e-08 ||r(i)||/||b|| 9.373882410808e-06
 82 KSP preconditioned resid norm 1.005496104308e-06 true resid norm 1.765174889043e-08 ||r(i)||/||b|| 8.358911467219e-06
 83 KSP preconditioned resid norm 8.838704225493e-07 true resid norm 1.538145008911e-08 ||r(i)||/||b|| 7.283821015718e-06
 84 KSP preconditioned resid norm 7.684695151055e-07 true resid norm 1.333409523241e-08 ||r(i)||/||b|| 6.314304731790e-06
 85 KSP preconditioned resid norm 6.777464803531e-07 true resid norm 1.175894469434e-08 ||r(i)||/||b|| 5.568398817478e-06
 86 KSP preconditioned resid norm 5.658383068941e-07 true resid norm 9.874887575618e-09 ||r(i)||/||b|| 4.676211490754e-06
 87 KSP preconditioned resid norm 4.569313887945e-07 true resid norm 7.949727247625e-09 ||r(i)||/||b|| 3.764559912104e-06
 88 KSP preconditioned resid norm 3.501576211721e-07 true resid norm 6.122302489929e-09 ||r(i)||/||b|| 2.899190601822e-06
 89 KSP preconditioned resid norm 2.715916520243e-07 true resid norm 4.698283006594e-09 ||r(i)||/||b|| 2.224852163026e-06
 90 KSP preconditioned resid norm 2.181564811465e-07 true resid norm 3.746364473294e-09 ||r(i)||/||b|| 1.774075144088e-06
 91 KSP preconditioned resid norm 1.790542677206e-07 true resid norm 3.052307341591e-09 ||r(i)||/||b|| 1.445407307654e-06
 92 KSP preconditioned resid norm 1.507096650456e-07 true resid norm 2.529245611205e-09 ||r(i)||/||b|| 1.197713624534e-06
 93 KSP preconditioned resid norm 1.314504687332e-07 true resid norm 2.207539157863e-09 ||r(i)||/||b|| 1.045370886224e-06
 94 KSP preconditioned resid norm 1.193297434357e-07 true resid norm 2.004281819945e-09 ||r(i)||/||b|| 9.491192284839e-07
 95 KSP preconditioned resid norm 1.070377720016e-07 true resid norm 1.773980996663e-09 ||r(i)||/||b|| 8.400612419587e-07
 96 KSP preconditioned resid norm 9.767336936506e-08 true resid norm 1.608407816132e-09 ||r(i)||/||b|| 7.616547584995e-07
 97 KSP preconditioned resid norm 8.582518964132e-08 true resid norm 1.404431974568e-09 ||r(i)||/||b|| 6.650628563785e-07
 98 KSP preconditioned resid norm 7.507408194135e-08 true resid norm 1.212440197703e-09 ||r(i)||/||b|| 5.741459577067e-07
 99 KSP preconditioned resid norm 6.561206695933e-08 true resid norm 1.071605228353e-09 ||r(i)||/||b|| 5.074541501363e-07
100 KSP preconditioned resid norm 5.866626124681e-08 true resid norm 9.762712731695e-10 ||r(i)||/||b|| 4.623091565073e-07
101 KSP preconditioned resid norm 5.168477931396e-08 true resid norm 8.833901788827e-10 ||r(i)||/||b|| 4.183257048425e-07
102 KSP preconditioned resid norm 4.512424946802e-08 true resid norm 7.900268191801e-10 ||r(i)||/||b|| 3.741138784177e-07
103 KSP preconditioned resid norm 3.929560567886e-08 true resid norm 6.791739204818e-10 ||r(i)||/||b|| 3.216199543395e-07
104 KSP preconditioned resid norm 3.389650408012e-08 true resid norm 5.901070254444e-10 ||r(i)||/||b|| 2.794427006917e-07
105 KSP preconditioned resid norm 2.984888775028e-08 true resid norm 5.242238362569e-10 ||r(i)||/||b|| 2.482439934693e-07
106 KSP preconditioned resid norm 2.549604905992e-08 true resid norm 4.580403697316e-10 ||r(i)||/||b|| 2.169030911761e-07
107 KSP preconditioned resid norm 2.160174543398e-08 true resid norm 3.811938720994e-10 ||r(i)||/||b|| 1.805127553369e-07
108 KSP preconditioned resid norm 1.844141666379e-08 true resid norm 3.255264385025e-10 ||r(i)||/||b|| 1.541516762204e-07
109 KSP preconditioned resid norm 1.591859631783e-08 true resid norm 2.797982293814e-10 ||r(i)||/||b|| 1.324972750633e-07
110 KSP preconditioned resid norm 1.357228851155e-08 true resid norm 2.415993129844e-10 ||r(i)||/||b|| 1.144083388175e-07
Linear solve converged due to CONVERGED_RTOL iterations 110
iter =   9, Function value: -4.34125,  Residual: 0.00267839
  0 KSP preconditioned resid norm 1.081543834783e-01 true resid norm 1.477972613198e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 5.158676419371e-02 true resid norm 1.041365232540e-03 ||r(i)||/||b|| 7.045903443955e-01
  2 KSP preconditioned resid norm 4.048407937564e-02 true resid norm 7.632550635179e-04 ||r(i)||/||b|| 5.164203021775e-01
  3 KSP preconditioned resid norm 3.150503631214e-02 true resid norm 6.236548295545e-04 ||r(i)||/||b|| 4.219664315734e-01
  4 KSP preconditioned resid norm 2.635487697911e-02 true resid norm 4.955439162996e-04 ||r(i)||/||b|| 3.352862643559e-01
  5 KSP preconditioned resid norm 2.268943095048e-02 true resid norm 4.296969003616e-04 ||r(i)||/||b|| 2.907340071964e-01
  6 KSP preconditioned resid norm 2.007928121645e-02 true resid norm 3.696014510484e-04 ||r(i)||/||b|| 2.500732745302e-01
  7 KSP preconditioned resid norm 1.832652876598e-02 true resid norm 3.429545737554e-04 ||r(i)||/||b|| 2.320439301059e-01
  8 KSP preconditioned resid norm 1.628271400443e-02 true resid norm 2.934187394538e-04 ||r(i)||/||b|| 1.985278596055e-01
  9 KSP preconditioned resid norm 1.483044705568e-02 true resid norm 2.716223074898e-04 ||r(i)||/||b|| 1.837803387317e-01
 10 KSP preconditioned resid norm 1.305239383933e-02 true resid norm 2.230237428877e-04 ||r(i)||/||b|| 1.508984272754e-01
 11 KSP preconditioned resid norm 1.231274809272e-02 true resid norm 2.106550806509e-04 ||r(i)||/||b|| 1.425297591916e-01
 12 KSP preconditioned resid norm 1.170068323625e-02 true resid norm 1.931431760451e-04 ||r(i)||/||b|| 1.306811603411e-01
 13 KSP preconditioned resid norm 1.136763209043e-02 true resid norm 1.865757376545e-04 ||r(i)||/||b|| 1.262376149520e-01
 14 KSP preconditioned resid norm 1.088192976918e-02 true resid norm 1.742464978768e-04 ||r(i)||/||b|| 1.178956202035e-01
 15 KSP preconditioned resid norm 9.994767525053e-03 true resid norm 1.636374241989e-04 ||r(i)||/||b|| 1.107174941793e-01
 16 KSP preconditioned resid norm 8.857575088935e-03 true resid norm 1.439452517996e-04 ||r(i)||/||b|| 9.739372063740e-02
 17 KSP preconditioned resid norm 7.794800913321e-03 true resid norm 1.269564929985e-04 ||r(i)||/||b|| 8.589908355861e-02
 18 KSP preconditioned resid norm 6.734215620401e-03 true resid norm 1.086981502019e-04 ||r(i)||/||b|| 7.354544274451e-02
 19 KSP preconditioned resid norm 5.574236175983e-03 true resid norm 9.216488479704e-05 ||r(i)||/||b|| 6.235899364711e-02
 20 KSP preconditioned resid norm 4.666091899591e-03 true resid norm 7.788668729950e-05 ||r(i)||/||b|| 5.269832918687e-02
 21 KSP preconditioned resid norm 3.797273912040e-03 true resid norm 6.501504679952e-05 ||r(i)||/||b|| 4.398934474085e-02
 22 KSP preconditioned resid norm 3.189234958478e-03 true resid norm 5.395905419811e-05 ||r(i)||/||b|| 3.650883224510e-02
 23 KSP preconditioned resid norm 2.736646935143e-03 true resid norm 4.723967969475e-05 ||r(i)||/||b|| 3.196248649866e-02
 24 KSP preconditioned resid norm 2.438173046572e-03 true resid norm 4.309696086602e-05 ||r(i)||/||b|| 2.915951248431e-02
 25 KSP preconditioned resid norm 2.139061276136e-03 true resid norm 3.781291280434e-05 ||r(i)||/||b|| 2.558431223060e-02
 26 KSP preconditioned resid norm 1.870156209729e-03 true resid norm 3.269555309291e-05 ||r(i)||/||b|| 2.212189373534e-02
 27 KSP preconditioned resid norm 1.598877552064e-03 true resid norm 2.789183834255e-05 ||r(i)||/||b|| 1.887168821227e-02
 28 KSP preconditioned resid norm 1.364921502857e-03 true resid norm 2.376398925051e-05 ||r(i)||/||b|| 1.607877509928e-02
 29 KSP preconditioned resid norm 1.183403555243e-03 true resid norm 2.043221156512e-05 ||r(i)||/||b|| 1.382448590905e-02
 30 KSP preconditioned resid norm 1.004543574347e-03 true resid norm 1.747397295440e-05 ||r(i)||/||b|| 1.182293419943e-02
 31 KSP preconditioned resid norm 8.404405674624e-04 true resid norm 1.488346633083e-05 ||r(i)||/||b|| 1.007019088034e-02
 32 KSP preconditioned resid norm 7.029647994169e-04 true resid norm 1.216739995201e-05 ||r(i)||/||b|| 8.232493513987e-03
 33 KSP preconditioned resid norm 6.145684797228e-04 true resid norm 1.076821570552e-05 ||r(i)||/||b|| 7.285801921743e-03
 34 KSP preconditioned resid norm 5.440586340289e-04 true resid norm 9.548572028889e-06 ||r(i)||/||b|| 6.460587932158e-03
 35 KSP preconditioned resid norm 5.017104780518e-04 true resid norm 8.926449214853e-06 ||r(i)||/||b|| 6.039658066150e-03
 36 KSP preconditioned resid norm 4.644988680483e-04 true resid norm 8.299453328532e-06 ||r(i)||/||b|| 5.615431067137e-03
 37 KSP preconditioned resid norm 4.236634606615e-04 true resid norm 7.747007850385e-06 ||r(i)||/||b|| 5.241645062435e-03
 38 KSP preconditioned resid norm 3.792999202756e-04 true resid norm 6.823766852937e-06 ||r(i)||/||b|| 4.616977873609e-03
 39 KSP preconditioned resid norm 3.334578769227e-04 true resid norm 6.085541623008e-06 ||r(i)||/||b|| 4.117492820005e-03
 40 KSP preconditioned resid norm 2.886588518905e-04 true resid norm 5.258660355506e-06 ||r(i)||/||b|| 3.558022867641e-03
 41 KSP preconditioned resid norm 2.480218972111e-04 true resid norm 4.496628933851e-06 ||r(i)||/||b|| 3.042430484635e-03
 42 KSP preconditioned resid norm 2.096378851115e-04 true resid norm 3.747274646876e-06 ||r(i)||/||b|| 2.535415482948e-03
 43 KSP preconditioned resid norm 1.714965196343e-04 true resid norm 3.058118088322e-06 ||r(i)||/||b|| 2.069130416229e-03
 44 KSP preconditioned resid norm 1.448132438149e-04 true resid norm 2.549682779469e-06 ||r(i)||/||b|| 1.725121803138e-03
 45 KSP preconditioned resid norm 1.238080426885e-04 true resid norm 2.192113918259e-06 ||r(i)||/||b|| 1.483189809259e-03
 46 KSP preconditioned resid norm 1.063858194887e-04 true resid norm 1.882557958529e-06 ||r(i)||/||b|| 1.273743465690e-03
 47 KSP preconditioned resid norm 9.201549772619e-05 true resid norm 1.618940446703e-06 ||r(i)||/||b|| 1.095379191905e-03
 48 KSP preconditioned resid norm 8.023716994284e-05 true resid norm 1.402171502794e-06 ||r(i)||/||b|| 9.487127774034e-04
 49 KSP preconditioned resid norm 6.823284586995e-05 true resid norm 1.176551430607e-06 ||r(i)||/||b|| 7.960576671718e-04
 50 KSP preconditioned resid norm 5.784494765483e-05 true resid norm 1.003818897603e-06 ||r(i)||/||b|| 6.791863994223e-04
 51 KSP preconditioned resid norm 4.901558190373e-05 true resid norm 8.633031151298e-07 ||r(i)||/||b|| 5.841130663860e-04
 52 KSP preconditioned resid norm 4.336664174647e-05 true resid norm 7.631570916703e-07 ||r(i)||/||b|| 5.163540141782e-04
 53 KSP preconditioned resid norm 3.913644406353e-05 true resid norm 6.884579008835e-07 ||r(i)||/||b|| 4.658123531760e-04
 54 KSP preconditioned resid norm 3.567370300610e-05 true resid norm 6.250236885752e-07 ||r(i)||/||b|| 4.228926050413e-04
 55 KSP preconditioned resid norm 3.264510131963e-05 true resid norm 5.691089952861e-07 ||r(i)||/||b|| 3.850605824519e-04
 56 KSP preconditioned resid norm 2.951667615693e-05 true resid norm 5.135990688242e-07 ||r(i)||/||b|| 3.475024261192e-04
 57 KSP preconditioned resid norm 2.662820877241e-05 true resid norm 4.634279580650e-07 ||r(i)||/||b|| 3.135565259644e-04
 58 KSP preconditioned resid norm 2.375834847224e-05 true resid norm 4.222177180146e-07 ||r(i)||/||b|| 2.856735735454e-04
 59 KSP preconditioned resid norm 2.079068048340e-05 true resid norm 3.746720424867e-07 ||r(i)||/||b|| 2.535040494938e-04
 60 KSP preconditioned resid norm 1.796300059473e-05 true resid norm 3.192204594145e-07 ||r(i)||/||b|| 2.159853684458e-04
 61 KSP preconditioned resid norm 1.581549509158e-05 true resid norm 2.827100230472e-07 ||r(i)||/||b|| 1.912823150595e-04
 62 KSP preconditioned resid norm 1.341762130452e-05 true resid norm 2.418104843897e-07 ||r(i)||/||b|| 1.636095839871e-04
 63 KSP preconditioned resid norm 1.118479118751e-05 true resid norm 2.037474255958e-07 ||r(i)||/||b|| 1.378560223487e-04
 64 KSP preconditioned resid norm 9.587749298800e-06 true resid norm 1.734559424939e-07 ||r(i)||/||b|| 1.173607284363e-04
 65 KSP preconditioned resid norm 8.433310696123e-06 true resid norm 1.523527933733e-07 ||r(i)||/||b|| 1.030822844840e-04
 66 KSP preconditioned resid norm 7.342661121942e-06 true resid norm 1.351702431508e-07 ||r(i)||/||b|| 9.145652764043e-05
 67 KSP preconditioned resid norm 6.359867858935e-06 true resid norm 1.165389319496e-07 ||r(i)||/||b|| 7.885053546250e-05
 68 KSP preconditioned resid norm 5.601874423412e-06 true resid norm 1.027838036651e-07 ||r(i)||/||b|| 6.954378095187e-05
 69 KSP preconditioned resid norm 4.923277660163e-06 true resid norm 8.954876250645e-08 ||r(i)||/||b|| 6.058891870308e-05
 70 KSP preconditioned resid norm 4.250408582634e-06 true resid norm 7.591520685666e-08 ||r(i)||/||b|| 5.136442054388e-05
 71 KSP preconditioned resid norm 3.546974381149e-06 true resid norm 6.284379761388e-08 ||r(i)||/||b|| 4.252027206234e-05
 72 KSP preconditioned resid norm 2.913555663022e-06 true resid norm 5.251641796314e-08 ||r(i)||/||b|| 3.553274092778e-05
 73 KSP preconditioned resid norm 2.381023743041e-06 true resid norm 4.194224620436e-08 ||r(i)||/||b|| 2.837822963011e-05
 74 KSP preconditioned resid norm 1.950803671217e-06 true resid norm 3.424426686208e-08 ||r(i)||/||b|| 2.316975738000e-05
 75 KSP preconditioned resid norm 1.668138493955e-06 true resid norm 2.991617170512e-08 ||r(i)||/||b|| 2.024135727412e-05
 76 KSP preconditioned resid norm 1.473361105516e-06 true resid norm 2.645237105088e-08 ||r(i)||/||b|| 1.789774100999e-05
 77 KSP preconditioned resid norm 1.340493255510e-06 true resid norm 2.357237673706e-08 ||r(i)||/||b|| 1.594912958911e-05
 78 KSP preconditioned resid norm 1.249479759684e-06 true resid norm 2.241891611866e-08 ||r(i)||/||b|| 1.516869522375e-05
 79 KSP preconditioned resid norm 1.169991337332e-06 true resid norm 2.120260652385e-08 ||r(i)||/||b|| 1.434573708235e-05
 80 KSP preconditioned resid norm 1.067245812041e-06 true resid norm 1.944819511683e-08 ||r(i)||/||b|| 1.315869789681e-05
 81 KSP preconditioned resid norm 9.792861372120e-07 true resid norm 1.782976182628e-08 ||r(i)||/||b|| 1.206366184803e-05
 82 KSP preconditioned resid norm 8.661918751873e-07 true resid norm 1.568240775251e-08 ||r(i)||/||b|| 1.061075666251e-05
 83 KSP preconditioned resid norm 7.599883189520e-07 true resid norm 1.379557876073e-08 ||r(i)||/||b|| 9.334123404948e-06
 84 KSP preconditioned resid norm 6.570580774931e-07 true resid norm 1.200661191232e-08 ||r(i)||/||b|| 8.123703920559e-06
 85 KSP preconditioned resid norm 5.773343245647e-07 true resid norm 1.052441444440e-08 ||r(i)||/||b|| 7.120845373197e-06
 86 KSP preconditioned resid norm 5.046170061675e-07 true resid norm 9.256657786196e-09 ||r(i)||/||b|| 6.263078018858e-06
 87 KSP preconditioned resid norm 4.486370048462e-07 true resid norm 8.158953390153e-09 ||r(i)||/||b|| 5.520368454255e-06
 88 KSP preconditioned resid norm 3.911602305186e-07 true resid norm 7.128137784774e-09 ||r(i)||/||b|| 4.822916014221e-06
 89 KSP preconditioned resid norm 3.356311296245e-07 true resid norm 6.059808469765e-09 ||r(i)||/||b|| 4.100081703579e-06
 90 KSP preconditioned resid norm 2.818751123447e-07 true resid norm 5.102233707991e-09 ||r(i)||/||b|| 3.452184203163e-06
 91 KSP preconditioned resid norm 2.310282350805e-07 true resid norm 4.200697644267e-09 ||r(i)||/||b|| 2.842202627271e-06
 92 KSP preconditioned resid norm 1.860945172934e-07 true resid norm 3.346207897968e-09 ||r(i)||/||b|| 2.264052708478e-06
 93 KSP preconditioned resid norm 1.510293674315e-07 true resid norm 2.707775495329e-09 ||r(i)||/||b|| 1.832087733662e-06
 94 KSP preconditioned resid norm 1.284508105354e-07 true resid norm 2.303378932188e-09 ||r(i)||/||b|| 1.558471998479e-06
 95 KSP preconditioned resid norm 1.090744029590e-07 true resid norm 1.937769834589e-09 ||r(i)||/||b|| 1.311099960367e-06
 96 KSP preconditioned resid norm 9.328826987918e-08 true resid norm 1.681401042116e-09 ||r(i)||/||b|| 1.137640188391e-06
 97 KSP preconditioned resid norm 8.119952416938e-08 true resid norm 1.435109635651e-09 ||r(i)||/||b|| 9.709988012193e-07
 98 KSP preconditioned resid norm 7.361210991420e-08 true resid norm 1.326186480808e-09 ||r(i)||/||b|| 8.973011197670e-07
 99 KSP preconditioned resid norm 6.715599053986e-08 true resid norm 1.222831297136e-09 ||r(i)||/||b|| 8.273707416605e-07
100 KSP preconditioned resid norm 5.985184721629e-08 true resid norm 1.080505108603e-09 ||r(i)||/||b|| 7.310724833154e-07
101 KSP preconditioned resid norm 5.368410437041e-08 true resid norm 9.563525961387e-10 ||r(i)||/||b|| 6.470705800625e-07
102 KSP preconditioned resid norm 4.742437366901e-08 true resid norm 8.499391888744e-10 ||r(i)||/||b|| 5.750710001555e-07
103 KSP preconditioned resid norm 4.145550886245e-08 true resid norm 7.596357303662e-10 ||r(i)||/||b|| 5.139714522330e-07
104 KSP preconditioned resid norm 3.669613473790e-08 true resid norm 6.621694173198e-10 ||r(i)||/||b|| 4.480254988534e-07
105 KSP preconditioned resid norm 3.280067707230e-08 true resid norm 5.970256353207e-10 ||r(i)||/||b|| 4.039490515516e-07
106 KSP preconditioned resid norm 2.851444743678e-08 true resid norm 5.299340186452e-10 ||r(i)||/||b|| 3.585546943921e-07
107 KSP preconditioned resid norm 2.416182353798e-08 true resid norm 4.549650485466e-10 ||r(i)||/||b|| 3.078305000267e-07
108 KSP preconditioned resid norm 2.042910554018e-08 true resid norm 3.784468209220e-10 ||r(i)||/||b|| 2.560580741094e-07
109 KSP preconditioned resid norm 1.791052663672e-08 true resid norm 3.277752869640e-10 ||r(i)||/||b|| 2.217735863554e-07
110 KSP preconditioned resid norm 1.586172489975e-08 true resid norm 2.915951650748e-10 ||r(i)||/||b|| 1.972940245786e-07
111 KSP preconditioned resid norm 1.394920090918e-08 true resid norm 2.563432756195e-10 ||r(i)||/||b|| 1.734425072091e-07
112 KSP preconditioned resid norm 1.219105526920e-08 true resid norm 2.256543661631e-10 ||r(i)||/||b|| 1.526783136223e-07
113 KSP preconditioned resid norm 1.082357865624e-08 true resid norm 1.996271642138e-10 ||r(i)||/||b|| 1.350682430994e-07
114 KSP preconditioned resid norm 9.695789377441e-09 true resid norm 1.763494226474e-10 ||r(i)||/||b|| 1.193184644104e-07
Linear solve converged due to CONVERGED_RTOL iterations 114
iter =  10, Function value: -4.34153,  Residual: 0.00197318
  0 KSP preconditioned resid norm 7.874946444818e-02 true resid norm 1.082620300776e-03 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 3.836353131299e-02 true resid norm 7.708347834842e-04 ||r(i)||/||b|| 7.120084326256e-01
  2 KSP preconditioned resid norm 2.925512260523e-02 true resid norm 5.462276926541e-04 ||r(i)||/||b|| 5.045422594261e-01
  3 KSP preconditioned resid norm 2.216266797424e-02 true resid norm 4.384191751652e-04 ||r(i)||/||b|| 4.049611621461e-01
  4 KSP preconditioned resid norm 1.828595571705e-02 true resid norm 3.545445624006e-04 ||r(i)||/||b|| 3.274874507216e-01
  5 KSP preconditioned resid norm 1.606075745459e-02 true resid norm 3.154605412604e-04 ||r(i)||/||b|| 2.913861314389e-01
  6 KSP preconditioned resid norm 1.394247281936e-02 true resid norm 2.702632926002e-04 ||r(i)||/||b|| 2.496381163428e-01
  7 KSP preconditioned resid norm 1.238790928160e-02 true resid norm 2.421611195195e-04 ||r(i)||/||b|| 2.236805640408e-01
  8 KSP preconditioned resid norm 1.120028770745e-02 true resid norm 2.133434753622e-04 ||r(i)||/||b|| 1.970621419248e-01
  9 KSP preconditioned resid norm 1.037248624705e-02 true resid norm 1.963182715206e-04 ||r(i)||/||b|| 1.813362185984e-01
 10 KSP preconditioned resid norm 9.077324835431e-03 true resid norm 1.701233851393e-04 ||r(i)||/||b|| 1.571403981778e-01
 11 KSP preconditioned resid norm 8.194327444024e-03 true resid norm 1.509038749059e-04 ||r(i)||/||b|| 1.393876272205e-01
 12 KSP preconditioned resid norm 7.556248789941e-03 true resid norm 1.307276199214e-04 ||r(i)||/||b|| 1.207511256049e-01
 13 KSP preconditioned resid norm 7.198978398180e-03 true resid norm 1.274934851720e-04 ||r(i)||/||b|| 1.177638042448e-01
 14 KSP preconditioned resid norm 6.824533850872e-03 true resid norm 1.184239920364e-04 ||r(i)||/||b|| 1.093864505880e-01
 15 KSP preconditioned resid norm 6.600080133600e-03 true resid norm 1.130973415655e-04 ||r(i)||/||b|| 1.044663040998e-01
 16 KSP preconditioned resid norm 6.194840453839e-03 true resid norm 1.077747735316e-04 ||r(i)||/||b|| 9.954992849697e-02
 17 KSP preconditioned resid norm 5.626075339249e-03 true resid norm 9.656765780304e-05 ||r(i)||/||b|| 8.919808517707e-02
 18 KSP preconditioned resid norm 4.962412342328e-03 true resid norm 8.657122589981e-05 ||r(i)||/||b|| 7.996453219818e-02
 19 KSP preconditioned resid norm 4.154643084069e-03 true resid norm 7.036031170831e-05 ||r(i)||/||b|| 6.499075590756e-02
 20 KSP preconditioned resid norm 3.512093674440e-03 true resid norm 6.086383217609e-05 ||r(i)||/||b|| 5.621900137330e-02
 21 KSP preconditioned resid norm 2.887445360588e-03 true resid norm 5.072587664814e-05 ||r(i)||/||b|| 4.685472516244e-02
 22 KSP preconditioned resid norm 2.388742850091e-03 true resid norm 4.209626936694e-05 ||r(i)||/||b|| 3.888368741725e-02
 23 KSP preconditioned resid norm 1.988224576340e-03 true resid norm 3.385733942714e-05 ||r(i)||/||b|| 3.127351242432e-02
 24 KSP preconditioned resid norm 1.754759810591e-03 true resid norm 3.172075237042e-05 ||r(i)||/||b|| 2.929997927037e-02
 25 KSP preconditioned resid norm 1.570412327127e-03 true resid norm 2.785991345847e-05 ||r(i)||/||b|| 2.573378075258e-02
 26 KSP preconditioned resid norm 1.403919698211e-03 true resid norm 2.565259599576e-05 ||r(i)||/||b|| 2.369491499224e-02
 27 KSP preconditioned resid norm 1.249092796661e-03 true resid norm 2.231536105669e-05 ||r(i)||/||b|| 2.061236154606e-02
 28 KSP preconditioned resid norm 1.090184495624e-03 true resid norm 2.009518478067e-05 ||r(i)||/||b|| 1.856161829431e-02
 29 KSP preconditioned resid norm 9.335830400615e-04 true resid norm 1.639390327873e-05 ||r(i)||/||b|| 1.514280054325e-02
 30 KSP preconditioned resid norm 7.901454629134e-04 true resid norm 1.417038488214e-05 ||r(i)||/||b|| 1.308897022528e-02
 31 KSP preconditioned resid norm 6.822899097573e-04 true resid norm 1.205980907217e-05 ||r(i)||/||b|| 1.113946326660e-02
 32 KSP preconditioned resid norm 5.864194111593e-04 true resid norm 1.048352636813e-05 ||r(i)||/||b|| 9.683474770069e-03
 33 KSP preconditioned resid norm 5.151378472270e-04 true resid norm 9.112272821563e-06 ||r(i)||/||b|| 8.416868605763e-03
 34 KSP preconditioned resid norm 4.386078665161e-04 true resid norm 7.813187123103e-06 ||r(i)||/||b|| 7.216922791401e-03
 35 KSP preconditioned resid norm 3.819367626579e-04 true resid norm 6.980233635333e-06 ||r(i)||/||b|| 6.447536251010e-03
 36 KSP preconditioned resid norm 3.523176469009e-04 true resid norm 6.455919088468e-06 ||r(i)||/||b|| 5.963234832970e-03
 37 KSP preconditioned resid norm 3.379649462213e-04 true resid norm 6.300410520924e-06 ||r(i)||/||b|| 5.819593920794e-03
 38 KSP preconditioned resid norm 3.123205896593e-04 true resid norm 5.814859678071e-06 ||r(i)||/||b|| 5.371097949949e-03
 39 KSP preconditioned resid norm 2.845622568239e-04 true resid norm 5.253424287634e-06 ||r(i)||/||b|| 4.852508570057e-03
 40 KSP preconditioned resid norm 2.521829904781e-04 true resid norm 4.707978370119e-06 ||r(i)||/||b|| 4.348688424505e-03
 41 KSP preconditioned resid norm 2.190577359521e-04 true resid norm 4.120917707668e-06 ||r(i)||/||b|| 3.806429368370e-03
 42 KSP preconditioned resid norm 1.844924405192e-04 true resid norm 3.412388768950e-06 ||r(i)||/||b|| 3.151971902341e-03
 43 KSP preconditioned resid norm 1.524062972821e-04 true resid norm 2.795242781318e-06 ||r(i)||/||b|| 2.581923486299e-03
 44 KSP preconditioned resid norm 1.268616103452e-04 true resid norm 2.262934924141e-06 ||r(i)||/||b|| 2.090238768402e-03
 45 KSP preconditioned resid norm 1.046262147687e-04 true resid norm 1.931036194211e-06 ||r(i)||/||b|| 1.783668930674e-03
 46 KSP preconditioned resid norm 9.017884447022e-05 true resid norm 1.620843293909e-06 ||r(i)||/||b|| 1.497148439529e-03
 47 KSP preconditioned resid norm 7.675255209044e-05 true resid norm 1.402710706435e-06 ||r(i)||/||b|| 1.295662667169e-03
 48 KSP preconditioned resid norm 6.607843393014e-05 true resid norm 1.206346489630e-06 ||r(i)||/||b|| 1.114284009606e-03
 49 KSP preconditioned resid norm 5.655391949210e-05 true resid norm 1.034472543089e-06 ||r(i)||/||b|| 9.555266443351e-04
 50 KSP preconditioned resid norm 4.858819604751e-05 true resid norm 8.828327652702e-07 ||r(i)||/||b|| 8.154592747221e-04
 51 KSP preconditioned resid norm 4.215166220025e-05 true resid norm 7.639608052401e-07 ||r(i)||/||b|| 7.056590428726e-04
 52 KSP preconditioned resid norm 3.698153566707e-05 true resid norm 6.840243611038e-07 ||r(i)||/||b|| 6.318229582555e-04
 53 KSP preconditioned resid norm 3.240388180779e-05 true resid norm 6.109241289003e-07 ||r(i)||/||b|| 5.643013792207e-04
 54 KSP preconditioned resid norm 2.863162350542e-05 true resid norm 5.297406271420e-07 ||r(i)||/||b|| 4.893134063368e-04
 55 KSP preconditioned resid norm 2.589788007691e-05 true resid norm 4.759211400795e-07 ||r(i)||/||b|| 4.396011600174e-04
 56 KSP preconditioned resid norm 2.395588812796e-05 true resid norm 4.386072480715e-07 ||r(i)||/||b|| 4.051348822456e-04
 57 KSP preconditioned resid norm 2.248889680593e-05 true resid norm 4.184215944520e-07 ||r(i)||/||b|| 3.864896992529e-04
 58 KSP preconditioned resid norm 2.040252470747e-05 true resid norm 3.743778860796e-07 ||r(i)||/||b|| 3.458071918763e-04
 59 KSP preconditioned resid norm 1.851945700472e-05 true resid norm 3.437365387587e-07 ||r(i)||/||b|| 3.175042427270e-04
 60 KSP preconditioned resid norm 1.686023286533e-05 true resid norm 3.109039389114e-07 ||r(i)||/||b|| 2.871772667560e-04
 61 KSP preconditioned resid norm 1.524456296999e-05 true resid norm 2.847569788214e-07 ||r(i)||/||b|| 2.630257151259e-04
 62 KSP preconditioned resid norm 1.339277841691e-05 true resid norm 2.489208234734e-07 ||r(i)||/||b|| 2.299244003600e-04
 63 KSP preconditioned resid norm 1.140161671824e-05 true resid norm 2.139760177170e-07 ||r(i)||/||b|| 1.976464117324e-04
 64 KSP preconditioned resid norm 9.550513341507e-06 true resid norm 1.787851326623e-07 ||r(i)||/||b|| 1.651411233783e-04
 65 KSP preconditioned resid norm 8.033762776762e-06 true resid norm 1.497991432779e-07 ||r(i)||/||b|| 1.383672033219e-04
 66 KSP preconditioned resid norm 6.770973784587e-06 true resid norm 1.265124951315e-07 ||r(i)||/||b|| 1.168576785793e-04
 67 KSP preconditioned resid norm 5.675071155464e-06 true resid norm 1.051746391652e-07 ||r(i)||/||b|| 9.714822370299e-05
 68 KSP preconditioned resid norm 4.825907750340e-06 true resid norm 9.027136005182e-08 ||r(i)||/||b|| 8.338229015946e-05
 69 KSP preconditioned resid norm 4.141889105746e-06 true resid norm 7.734649795559e-08 ||r(i)||/||b|| 7.144379049622e-05
 70 KSP preconditioned resid norm 3.609246290733e-06 true resid norm 6.787992807774e-08 ||r(i)||/||b|| 6.269966305738e-05
 71 KSP preconditioned resid norm 3.088128956390e-06 true resid norm 5.783350333058e-08 ||r(i)||/||b|| 5.341993244457e-05
 72 KSP preconditioned resid norm 2.610628201375e-06 true resid norm 4.884499495613e-08 ||r(i)||/||b|| 4.511738318699e-05
 73 KSP preconditioned resid norm 2.222821218514e-06 true resid norm 4.163981244326e-08 ||r(i)||/||b|| 3.846206505957e-05
 74 KSP preconditioned resid norm 1.908097661100e-06 true resid norm 3.534683915296e-08 ||r(i)||/||b|| 3.264934079624e-05
 75 KSP preconditioned resid norm 1.607160927854e-06 true resid norm 2.898993354749e-08 ||r(i)||/||b|| 2.677756322019e-05
 76 KSP preconditioned resid norm 1.354284638600e-06 true resid norm 2.438171527172e-08 ||r(i)||/||b|| 2.252102168622e-05
 77 KSP preconditioned resid norm 1.149066858939e-06 true resid norm 2.093498218956e-08 ||r(i)||/||b|| 1.933732646114e-05
 78 KSP preconditioned resid norm 9.944646929550e-07 true resid norm 1.783142751715e-08 ||r(i)||/||b|| 1.647061994346e-05
 79 KSP preconditioned resid norm 8.905035576619e-07 true resid norm 1.612554125842e-08 ||r(i)||/||b|| 1.489491860338e-05
 80 KSP preconditioned resid norm 8.220035270642e-07 true resid norm 1.491905449795e-08 ||r(i)||/||b|| 1.378050502772e-05
 81 KSP preconditioned resid norm 7.540905258504e-07 true resid norm 1.376003070362e-08 ||r(i)||/||b|| 1.270993227613e-05
 82 KSP preconditioned resid norm 6.966198580725e-07 true resid norm 1.257441188587e-08 ||r(i)||/||b|| 1.161479410358e-05
 83 KSP preconditioned resid norm 6.511707808680e-07 true resid norm 1.178653469672e-08 ||r(i)||/||b|| 1.088704385857e-05
 84 KSP preconditioned resid norm 5.848708787756e-07 true resid norm 1.056803486322e-08 ||r(i)||/||b|| 9.761533989008e-06
 85 KSP preconditioned resid norm 5.196676227443e-07 true resid norm 9.445339945527e-09 ||r(i)||/||b|| 8.724517671391e-06
 86 KSP preconditioned resid norm 4.574229694637e-07 true resid norm 8.412999432063e-09 ||r(i)||/||b|| 7.770960350580e-06
 87 KSP preconditioned resid norm 4.061948061931e-07 true resid norm 7.354161087167e-09 ||r(i)||/||b|| 6.792927383586e-06
 88 KSP preconditioned resid norm 3.564985985913e-07 true resid norm 6.350291727630e-09 ||r(i)||/||b|| 5.865668437104e-06
 89 KSP preconditioned resid norm 3.140282171475e-07 true resid norm 5.656760105149e-09 ||r(i)||/||b|| 5.225063765287e-06
 90 KSP preconditioned resid norm 2.773920979455e-07 true resid norm 4.942272777220e-09 ||r(i)||/||b|| 4.565102625249e-06
 91 KSP preconditioned resid norm 2.366867302448e-07 true resid norm 4.193605757317e-09 ||r(i)||/||b|| 3.873570220613e-06
 92 KSP preconditioned resid norm 1.956188982003e-07 true resid norm 3.487847666677e-09 ||r(i)||/||b|| 3.221672145051e-06
 93 KSP preconditioned resid norm 1.591484577701e-07 true resid norm 2.788502623340e-09 ||r(i)||/||b|| 2.575697704303e-06
 94 KSP preconditioned resid norm 1.333988119803e-07 true resid norm 2.356149842725e-09 ||r(i)||/||b|| 2.176339979064e-06
 95 KSP preconditioned resid norm 1.154240184317e-07 true resid norm 2.036406775312e-09 ||r(i)||/||b|| 1.880998142980e-06
 96 KSP preconditioned resid norm 1.019856999259e-07 true resid norm 1.803027192070e-09 ||r(i)||/||b|| 1.665428951201e-06
 97 KSP preconditioned resid norm 9.150506659395e-08 true resid norm 1.640918922009e-09 ||r(i)||/||b|| 1.515691993613e-06
 98 KSP preconditioned resid norm 8.185775908050e-08 true resid norm 1.458367471407e-09 ||r(i)||/||b|| 1.347071979310e-06
 99 KSP preconditioned resid norm 7.209124970124e-08 true resid norm 1.273353750835e-09 ||r(i)||/||b|| 1.176177603470e-06
100 KSP preconditioned resid norm 6.458672913912e-08 true resid norm 1.176408664631e-09 ||r(i)||/||b|| 1.086630893387e-06
101 KSP preconditioned resid norm 5.733811833658e-08 true resid norm 1.044717390376e-09 ||r(i)||/||b|| 9.649896548465e-07
102 KSP preconditioned resid norm 4.933092886016e-08 true resid norm 8.869629250831e-10 ||r(i)||/||b|| 8.192742408833e-07
103 KSP preconditioned resid norm 4.243789287130e-08 true resid norm 7.579756261584e-10 ||r(i)||/||b|| 7.001306234652e-07
104 KSP preconditioned resid norm 3.609241101259e-08 true resid norm 6.519165378332e-10 ||r(i)||/||b|| 6.021654474481e-07
105 KSP preconditioned resid norm 3.108390895460e-08 true resid norm 5.626021086075e-10 ||r(i)||/||b|| 5.196670598216e-07
106 KSP preconditioned resid norm 2.693411804730e-08 true resid norm 4.816894925112e-10 ||r(i)||/||b|| 4.449292999272e-07
107 KSP preconditioned resid norm 2.383174442310e-08 true resid norm 4.271528495019e-10 ||r(i)||/||b|| 3.945546275049e-07
108 KSP preconditioned resid norm 2.151098027337e-08 true resid norm 3.906392383820e-10 ||r(i)||/||b|| 3.608275570872e-07
109 KSP preconditioned resid norm 1.902601106534e-08 true resid norm 3.434772069152e-10 ||r(i)||/||b|| 3.172647018248e-07
110 KSP preconditioned resid norm 1.656752388443e-08 true resid norm 2.954328393839e-10 ||r(i)||/||b|| 2.728868460827e-07
111 KSP preconditioned resid norm 1.456915915131e-08 true resid norm 2.603052158281e-10 ||r(i)||/||b|| 2.404399914186e-07
112 KSP preconditioned resid norm 1.286214115008e-08 true resid norm 2.268469220832e-10 ||r(i)||/||b|| 2.095350714563e-07
113 KSP preconditioned resid norm 1.126092630172e-08 true resid norm 1.995862567038e-10 ||r(i)||/||b|| 1.843548070923e-07
114 KSP preconditioned resid norm 9.918459604519e-09 true resid norm 1.770231640754e-10 ||r(i)||/||b|| 1.635136196397e-07
115 KSP preconditioned resid norm 8.870628641383e-09 true resid norm 1.584590304720e-10 ||r(i)||/||b|| 1.463662101647e-07
116 KSP preconditioned resid norm 7.864654208334e-09 true resid norm 1.404388194054e-10 ||r(i)||/||b|| 1.297212137116e-07
Linear solve converged due to CONVERGED_RTOL iterations 116
iter =  11, Function value: -4.34167,  Residual: 0.00126025
  0 KSP preconditioned resid norm 5.066591745231e-02 true resid norm 7.002088467130e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.342475175611e-02 true resid norm 4.859083359895e-04 ||r(i)||/||b|| 6.939477246975e-01
  2 KSP preconditioned resid norm 1.775043591174e-02 true resid norm 3.520087809380e-04 ||r(i)||/||b|| 5.027196994018e-01
  3 KSP preconditioned resid norm 1.379320515986e-02 true resid norm 2.811630471387e-04 ||r(i)||/||b|| 4.015416949651e-01
  4 KSP preconditioned resid norm 1.152920881799e-02 true resid norm 2.278825054309e-04 ||r(i)||/||b|| 3.254493377235e-01
  5 KSP preconditioned resid norm 9.502871942875e-03 true resid norm 1.971507440013e-04 ||r(i)||/||b|| 2.815599159119e-01
  6 KSP preconditioned resid norm 8.435049715766e-03 true resid norm 1.667876899749e-04 ||r(i)||/||b|| 2.381970618593e-01
  7 KSP preconditioned resid norm 7.471961032076e-03 true resid norm 1.484464441511e-04 ||r(i)||/||b|| 2.120030971445e-01
  8 KSP preconditioned resid norm 6.629116689134e-03 true resid norm 1.288277088997e-04 ||r(i)||/||b|| 1.839846918593e-01
  9 KSP preconditioned resid norm 6.148557051308e-03 true resid norm 1.173566243133e-04 ||r(i)||/||b|| 1.676023158865e-01
 10 KSP preconditioned resid norm 5.554693253429e-03 true resid norm 1.042913104594e-04 ||r(i)||/||b|| 1.489431488176e-01
 11 KSP preconditioned resid norm 5.048263839301e-03 true resid norm 9.660703478803e-05 ||r(i)||/||b|| 1.379688863423e-01
 12 KSP preconditioned resid norm 4.465204147332e-03 true resid norm 8.154440985046e-05 ||r(i)||/||b|| 1.164572687610e-01
 13 KSP preconditioned resid norm 4.078324311849e-03 true resid norm 7.289158504071e-05 ||r(i)||/||b|| 1.040997773491e-01
 14 KSP preconditioned resid norm 3.750460614491e-03 true resid norm 6.458316681740e-05 ||r(i)||/||b|| 9.223414859806e-02
 15 KSP preconditioned resid norm 3.624882012500e-03 true resid norm 6.332671092862e-05 ||r(i)||/||b|| 9.043974697821e-02
 16 KSP preconditioned resid norm 3.568245152338e-03 true resid norm 6.016269490561e-05 ||r(i)||/||b|| 8.592107224586e-02
 17 KSP preconditioned resid norm 3.432818643009e-03 true resid norm 5.957113427425e-05 ||r(i)||/||b|| 8.507623768808e-02
 18 KSP preconditioned resid norm 3.199612487326e-03 true resid norm 5.517898361788e-05 ||r(i)||/||b|| 7.880360820477e-02
 19 KSP preconditioned resid norm 2.822236424045e-03 true resid norm 4.873037634834e-05 ||r(i)||/||b|| 6.959405979673e-02
 20 KSP preconditioned resid norm 2.457039292679e-03 true resid norm 4.330452544436e-05 ||r(i)||/||b|| 6.184515612399e-02
 21 KSP preconditioned resid norm 2.066432397744e-03 true resid norm 3.565224617556e-05 ||r(i)||/||b|| 5.091658916183e-02
 22 KSP preconditioned resid norm 1.725368783235e-03 true resid norm 3.082481966758e-05 ||r(i)||/||b|| 4.402232250033e-02
 23 KSP preconditioned resid norm 1.423216218369e-03 true resid norm 2.488484488699e-05 ||r(i)||/||b|| 3.553917521009e-02
 24 KSP preconditioned resid norm 1.183921928765e-03 true resid norm 2.095500208176e-05 ||r(i)||/||b|| 2.992678852906e-02
 25 KSP preconditioned resid norm 1.004721394185e-03 true resid norm 1.807664844204e-05 ||r(i)||/||b|| 2.581608119763e-02
 26 KSP preconditioned resid norm 8.982961643006e-04 true resid norm 1.641713796620e-05 ||r(i)||/||b|| 2.344605904833e-02
 27 KSP preconditioned resid norm 8.075660176076e-04 true resid norm 1.463521227680e-05 ||r(i)||/||b|| 2.090121018251e-02
 28 KSP preconditioned resid norm 7.127769564136e-04 true resid norm 1.298710816477e-05 ||r(i)||/||b|| 1.854747797852e-02
 29 KSP preconditioned resid norm 6.115849101993e-04 true resid norm 1.119065138942e-05 ||r(i)||/||b|| 1.598187661004e-02
 30 KSP preconditioned resid norm 5.217005573094e-04 true resid norm 9.532959511605e-06 ||r(i)||/||b|| 1.361445168303e-02
 31 KSP preconditioned resid norm 4.500790983878e-04 true resid norm 8.008239779498e-06 ||r(i)||/||b|| 1.143693030600e-02
 32 KSP preconditioned resid norm 3.890751243413e-04 true resid norm 7.013179442009e-06 ||r(i)||/||b|| 1.001583952407e-02
 33 KSP preconditioned resid norm 3.276266173346e-04 true resid norm 5.924001702185e-06 ||r(i)||/||b|| 8.460335412776e-03
 34 KSP preconditioned resid norm 2.750228936892e-04 true resid norm 4.961057328019e-06 ||r(i)||/||b|| 7.085110894140e-03
 35 KSP preconditioned resid norm 2.332248137414e-04 true resid norm 4.341204938807e-06 ||r(i)||/||b|| 6.199871594290e-03
 36 KSP preconditioned resid norm 1.988926360286e-04 true resid norm 3.665817479611e-06 ||r(i)||/||b|| 5.235320143155e-03
 37 KSP preconditioned resid norm 1.771496961050e-04 true resid norm 3.306540455130e-06 ||r(i)||/||b|| 4.722220335621e-03
 38 KSP preconditioned resid norm 1.641557532122e-04 true resid norm 3.099551798206e-06 ||r(i)||/||b|| 4.426610450234e-03
 39 KSP preconditioned resid norm 1.563306597609e-04 true resid norm 2.960717504070e-06 ||r(i)||/||b|| 4.228334900321e-03
 40 KSP preconditioned resid norm 1.510382263745e-04 true resid norm 2.768075776785e-06 ||r(i)||/||b|| 3.953214515611e-03
 41 KSP preconditioned resid norm 1.423037183632e-04 true resid norm 2.648070793768e-06 ||r(i)||/||b|| 3.781829958589e-03
 42 KSP preconditioned resid norm 1.299647819718e-04 true resid norm 2.454010640244e-06 ||r(i)||/||b|| 3.504683855059e-03
 43 KSP preconditioned resid norm 1.144035725724e-04 true resid norm 2.101966404722e-06 ||r(i)||/||b|| 3.001913521357e-03
 44 KSP preconditioned resid norm 9.678543707060e-05 true resid norm 1.778028016335e-06 ||r(i)||/||b|| 2.539282422211e-03
 45 KSP preconditioned resid norm 8.031098007488e-05 true resid norm 1.453898374609e-06 ||r(i)||/||b|| 2.076378185500e-03
 46 KSP preconditioned resid norm 6.662143218109e-05 true resid norm 1.207090584541e-06 ||r(i)||/||b|| 1.723900790754e-03
 47 KSP preconditioned resid norm 5.533377126263e-05 true resid norm 1.019036592226e-06 ||r(i)||/||b|| 1.455332358353e-03
 48 KSP preconditioned resid norm 4.682938567759e-05 true resid norm 8.460921977478e-07 ||r(i)||/||b|| 1.208342627660e-03
 49 KSP preconditioned resid norm 4.026058625987e-05 true resid norm 7.394900131240e-07 ||r(i)||/||b|| 1.056099214678e-03
 50 KSP preconditioned resid norm 3.557546406415e-05 true resid norm 6.472290800539e-07 ||r(i)||/||b|| 9.243371932421e-04
 51 KSP preconditioned resid norm 3.011872058319e-05 true resid norm 5.496922611753e-07 ||r(i)||/||b|| 7.850404400855e-04
 52 KSP preconditioned resid norm 2.575133112606e-05 true resid norm 4.660019313025e-07 ||r(i)||/||b|| 6.655184856491e-04
 53 KSP preconditioned resid norm 2.203532786425e-05 true resid norm 4.067627921461e-07 ||r(i)||/||b|| 5.809163852408e-04
 54 KSP preconditioned resid norm 1.895837864673e-05 true resid norm 3.579914364229e-07 ||r(i)||/||b|| 5.112638009409e-04
 55 KSP preconditioned resid norm 1.658230242941e-05 true resid norm 3.141302822528e-07 ||r(i)||/||b|| 4.486236980973e-04
 56 KSP preconditioned resid norm 1.433102684068e-05 true resid norm 2.695472127328e-07 ||r(i)||/||b|| 3.849525952124e-04
 57 KSP preconditioned resid norm 1.275112674995e-05 true resid norm 2.358404013011e-07 ||r(i)||/||b|| 3.368143696103e-04
 58 KSP preconditioned resid norm 1.159984700749e-05 true resid norm 2.150145384715e-07 ||r(i)||/||b|| 3.070720107020e-04
 59 KSP preconditioned resid norm 1.086784224943e-05 true resid norm 1.963387235023e-07 ||r(i)||/||b|| 2.804002326220e-04
 60 KSP preconditioned resid norm 9.773354142316e-06 true resid norm 1.799371756381e-07 ||r(i)||/||b|| 2.569764385052e-04
 61 KSP preconditioned resid norm 9.101064097392e-06 true resid norm 1.651576088350e-07 ||r(i)||/||b|| 2.358690690788e-04
 62 KSP preconditioned resid norm 8.493129275533e-06 true resid norm 1.542149478541e-07 ||r(i)||/||b|| 2.202413588146e-04
 63 KSP preconditioned resid norm 7.909342920282e-06 true resid norm 1.436391340170e-07 ||r(i)||/||b|| 2.051375595885e-04
 64 KSP preconditioned resid norm 7.214136503631e-06 true resid norm 1.335240940709e-07 ||r(i)||/||b|| 1.906918124466e-04
 65 KSP preconditioned resid norm 6.403166974175e-06 true resid norm 1.190363462429e-07 ||r(i)||/||b|| 1.700012029293e-04
 66 KSP preconditioned resid norm 5.545790250842e-06 true resid norm 1.035992344935e-07 ||r(i)||/||b|| 1.479547637535e-04
 67 KSP preconditioned resid norm 4.778691537152e-06 true resid norm 8.925036352030e-08 ||r(i)||/||b|| 1.274624905687e-04
 68 KSP preconditioned resid norm 4.038280394073e-06 true resid norm 7.513989411213e-08 ||r(i)||/||b|| 1.073106894677e-04
 69 KSP preconditioned resid norm 3.410431298429e-06 true resid norm 6.325964698086e-08 ||r(i)||/||b|| 9.034396991387e-05
 70 KSP preconditioned resid norm 2.926775564316e-06 true resid norm 5.499068138670e-08 ||r(i)||/||b|| 7.853468525119e-05
 71 KSP preconditioned resid norm 2.498125684411e-06 true resid norm 4.727526939775e-08 ||r(i)||/||b|| 6.751595558908e-05
 72 KSP preconditioned resid norm 2.170071419566e-06 true resid norm 4.102540712809e-08 ||r(i)||/||b|| 5.859024392605e-05
 73 KSP preconditioned resid norm 1.831764612253e-06 true resid norm 3.490050684279e-08 ||r(i)||/||b|| 4.984299613840e-05
 74 KSP preconditioned resid norm 1.546790710999e-06 true resid norm 2.896313846199e-08 ||r(i)||/||b|| 4.136357116588e-05
 75 KSP preconditioned resid norm 1.303026369812e-06 true resid norm 2.400320964045e-08 ||r(i)||/||b|| 3.428007194301e-05
 76 KSP preconditioned resid norm 1.094920410522e-06 true resid norm 2.016237928086e-08 ||r(i)||/||b|| 2.879480797124e-05
 77 KSP preconditioned resid norm 8.972048943092e-07 true resid norm 1.623172655613e-08 ||r(i)||/||b|| 2.318126460746e-05
 78 KSP preconditioned resid norm 7.368706084779e-07 true resid norm 1.340975520702e-08 ||r(i)||/||b|| 1.915107938148e-05
 79 KSP preconditioned resid norm 6.132438460063e-07 true resid norm 1.112546282456e-08 ||r(i)||/||b|| 1.588877786505e-05
 80 KSP preconditioned resid norm 5.161134518848e-07 true resid norm 9.420431944230e-09 ||r(i)||/||b|| 1.345374596230e-05
 81 KSP preconditioned resid norm 4.405771007766e-07 true resid norm 8.046114081186e-09 ||r(i)||/||b|| 1.149102031338e-05
 82 KSP preconditioned resid norm 3.874375343695e-07 true resid norm 7.063977453169e-09 ||r(i)||/||b|| 1.008838646688e-05
 83 KSP preconditioned resid norm 3.496418807632e-07 true resid norm 6.424239897428e-09 ||r(i)||/||b|| 9.174748259159e-06
 84 KSP preconditioned resid norm 3.186826436047e-07 true resid norm 5.786168593267e-09 ||r(i)||/||b|| 8.263489700866e-06
 85 KSP preconditioned resid norm 2.936917057866e-07 true resid norm 5.366050827427e-09 ||r(i)||/||b|| 7.663500472205e-06
 86 KSP preconditioned resid norm 2.590529526460e-07 true resid norm 4.717277407083e-09 ||r(i)||/||b|| 6.736957736577e-06
 87 KSP preconditioned resid norm 2.333235475902e-07 true resid norm 4.248307122794e-09 ||r(i)||/||b|| 6.067200011449e-06
 88 KSP preconditioned resid norm 2.139376950936e-07 true resid norm 3.922183656401e-09 ||r(i)||/||b|| 5.601448303336e-06
 89 KSP preconditioned resid norm 1.960085837088e-07 true resid norm 3.606772644865e-09 ||r(i)||/||b|| 5.150995537684e-06
 90 KSP preconditioned resid norm 1.805044132002e-07 true resid norm 3.322840327786e-09 ||r(i)||/||b|| 4.745498922763e-06
 91 KSP preconditioned resid norm 1.654760732746e-07 true resid norm 3.086023034996e-09 ||r(i)||/||b|| 4.407289410128e-06
 92 KSP preconditioned resid norm 1.475566056138e-07 true resid norm 2.746533880067e-09 ||r(i)||/||b|| 3.922449556243e-06
 93 KSP preconditioned resid norm 1.275759819936e-07 true resid norm 2.373488455263e-09 ||r(i)||/||b|| 3.389686471980e-06
 94 KSP preconditioned resid norm 1.080347385532e-07 true resid norm 2.018100763084e-09 ||r(i)||/||b|| 2.882141196241e-06
 95 KSP preconditioned resid norm 8.892944411364e-08 true resid norm 1.664509653953e-09 ||r(i)||/||b|| 2.377161702208e-06
 96 KSP preconditioned resid norm 7.242519716029e-08 true resid norm 1.324033304272e-09 ||r(i)||/||b|| 1.890911990740e-06
 97 KSP preconditioned resid norm 5.978311191652e-08 true resid norm 1.086852839621e-09 ||r(i)||/||b|| 1.552183815904e-06
 98 KSP preconditioned resid norm 5.090674336577e-08 true resid norm 9.237647346721e-10 ||r(i)||/||b|| 1.319270299152e-06
 99 KSP preconditioned resid norm 4.459452702447e-08 true resid norm 8.085511211514e-10 ||r(i)||/||b|| 1.154728514138e-06
100 KSP preconditioned resid norm 3.972943102244e-08 true resid norm 7.215580515257e-10 ||r(i)||/||b|| 1.030489767322e-06
101 KSP preconditioned resid norm 3.540438044609e-08 true resid norm 6.405783782006e-10 ||r(i)||/||b|| 9.148390243965e-07
102 KSP preconditioned resid norm 3.170686489217e-08 true resid norm 5.705982997517e-10 ||r(i)||/||b|| 8.148973016127e-07
103 KSP preconditioned resid norm 2.837980201389e-08 true resid norm 5.049173616098e-10 ||r(i)||/||b|| 7.210953760155e-07
104 KSP preconditioned resid norm 2.480522238196e-08 true resid norm 4.430968897145e-10 ||r(i)||/||b|| 6.328067572904e-07
105 KSP preconditioned resid norm 2.194422481575e-08 true resid norm 3.885609008918e-10 ||r(i)||/||b|| 5.549214391047e-07
106 KSP preconditioned resid norm 1.900800915978e-08 true resid norm 3.310280832385e-10 ||r(i)||/||b|| 4.727562137960e-07
107 KSP preconditioned resid norm 1.638974818734e-08 true resid norm 2.880065534266e-10 ||r(i)||/||b|| 4.113152165652e-07
108 KSP preconditioned resid norm 1.414064986165e-08 true resid norm 2.492699049426e-10 ||r(i)||/||b|| 3.559936526263e-07
109 KSP preconditioned resid norm 1.232213243507e-08 true resid norm 2.163985227484e-10 ||r(i)||/||b|| 3.090485413949e-07
110 KSP preconditioned resid norm 1.080443583600e-08 true resid norm 1.936800893757e-10 ||r(i)||/||b|| 2.766033166889e-07
111 KSP preconditioned resid norm 9.296689415186e-09 true resid norm 1.676888286274e-10 ||r(i)||/||b|| 2.394840188247e-07
112 KSP preconditioned resid norm 7.896505700552e-09 true resid norm 1.414471395007e-10 ||r(i)||/||b|| 2.020070728394e-07
113 KSP preconditioned resid norm 6.661370463239e-09 true resid norm 1.181827178739e-10 ||r(i)||/||b|| 1.687820975538e-07
114 KSP preconditioned resid norm 5.692136778568e-09 true resid norm 1.025743903117e-10 ||r(i)||/||b|| 1.464911373132e-07
115 KSP preconditioned resid norm 4.822644293253e-09 true resid norm 8.717821451151e-11 ||r(i)||/||b|| 1.245031606224e-07
Linear solve converged due to CONVERGED_RTOL iterations 115
iter =  12, Function value: -4.34173,  Residual: 0.000838293
  0 KSP preconditioned resid norm 2.920028076044e-02 true resid norm 4.426564165080e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.415059321831e-02 true resid norm 2.997130801024e-04 ||r(i)||/||b|| 6.770783590279e-01
  2 KSP preconditioned resid norm 1.103050021990e-02 true resid norm 2.198099364934e-04 ||r(i)||/||b|| 4.965700897944e-01
  3 KSP preconditioned resid norm 8.286760775208e-03 true resid norm 1.804353530127e-04 ||r(i)||/||b|| 4.076194228385e-01
  4 KSP preconditioned resid norm 6.969471867495e-03 true resid norm 1.369041316474e-04 ||r(i)||/||b|| 3.092785432264e-01
  5 KSP preconditioned resid norm 5.791658163831e-03 true resid norm 1.197284332884e-04 ||r(i)||/||b|| 2.704771213595e-01
  6 KSP preconditioned resid norm 5.029930317125e-03 true resid norm 9.643233307088e-05 ||r(i)||/||b|| 2.178491703150e-01
  7 KSP preconditioned resid norm 4.463843284125e-03 true resid norm 8.806202807420e-05 ||r(i)||/||b|| 1.989399109334e-01
  8 KSP preconditioned resid norm 3.887091622810e-03 true resid norm 7.591695484607e-05 ||r(i)||/||b|| 1.715031162204e-01
  9 KSP preconditioned resid norm 3.558358970702e-03 true resid norm 7.020936684391e-05 ||r(i)||/||b|| 1.586091700596e-01
 10 KSP preconditioned resid norm 3.172542468176e-03 true resid norm 5.942108178901e-05 ||r(i)||/||b|| 1.342374798445e-01
 11 KSP preconditioned resid norm 2.936689449005e-03 true resid norm 5.684840339927e-05 ||r(i)||/||b|| 1.284255717961e-01
 12 KSP preconditioned resid norm 2.641644953734e-03 true resid norm 4.874007239201e-05 ||r(i)||/||b|| 1.101081348295e-01
 13 KSP preconditioned resid norm 2.355824912595e-03 true resid norm 4.292000691995e-05 ||r(i)||/||b|| 9.696009211510e-02
 14 KSP preconditioned resid norm 2.084347487335e-03 true resid norm 3.674207334884e-05 ||r(i)||/||b|| 8.300359370976e-02
 15 KSP preconditioned resid norm 1.920321995999e-03 true resid norm 3.451515502635e-05 ||r(i)||/||b|| 7.797278823751e-02
 16 KSP preconditioned resid norm 1.833212612858e-03 true resid norm 3.160823889953e-05 ||r(i)||/||b|| 7.140580757619e-02
 17 KSP preconditioned resid norm 1.787587223270e-03 true resid norm 3.108516938285e-05 ||r(i)||/||b|| 7.022414726996e-02
 18 KSP preconditioned resid norm 1.758736658043e-03 true resid norm 3.112258812547e-05 ||r(i)||/||b|| 7.030867951942e-02
 19 KSP preconditioned resid norm 1.662986099714e-03 true resid norm 2.845877195869e-05 ||r(i)||/||b|| 6.429088317119e-02
 20 KSP preconditioned resid norm 1.512674775988e-03 true resid norm 2.594797938654e-05 ||r(i)||/||b|| 5.861878065891e-02
 21 KSP preconditioned resid norm 1.329740382039e-03 true resid norm 2.289128044409e-05 ||r(i)||/||b|| 5.171342736806e-02
 22 KSP preconditioned resid norm 1.157682467990e-03 true resid norm 1.985473567453e-05 ||r(i)||/||b|| 4.485360413651e-02
 23 KSP preconditioned resid norm 9.621289501660e-04 true resid norm 1.701402025000e-05 ||r(i)||/||b|| 3.843617671743e-02
 24 KSP preconditioned resid norm 7.876719805710e-04 true resid norm 1.407967645193e-05 ||r(i)||/||b|| 3.180723452063e-02
 25 KSP preconditioned resid norm 6.381291701367e-04 true resid norm 1.150056534162e-05 ||r(i)||/||b|| 2.598079438755e-02
 26 KSP preconditioned resid norm 5.445418019507e-04 true resid norm 9.878047184694e-06 ||r(i)||/||b|| 2.231538235144e-02
 27 KSP preconditioned resid norm 4.732608477956e-04 true resid norm 8.725075104076e-06 ||r(i)||/||b|| 1.971071643535e-02
 28 KSP preconditioned resid norm 4.250167935197e-04 true resid norm 7.945115883029e-06 ||r(i)||/||b|| 1.794871956383e-02
 29 KSP preconditioned resid norm 3.758671739013e-04 true resid norm 7.081306060104e-06 ||r(i)||/||b|| 1.599729676567e-02
 30 KSP preconditioned resid norm 3.234156919391e-04 true resid norm 5.884875006392e-06 ||r(i)||/||b|| 1.329445318520e-02
 31 KSP preconditioned resid norm 2.797176515100e-04 true resid norm 5.174311985396e-06 ||r(i)||/||b|| 1.168922846802e-02
 32 KSP preconditioned resid norm 2.377518942529e-04 true resid norm 4.340721579681e-06 ||r(i)||/||b|| 9.806074006391e-03
 33 KSP preconditioned resid norm 2.055540830318e-04 true resid norm 3.757588158064e-06 ||r(i)||/||b|| 8.488724025977e-03
 34 KSP preconditioned resid norm 1.749487969405e-04 true resid norm 3.109765402566e-06 ||r(i)||/||b|| 7.025235118240e-03
 35 KSP preconditioned resid norm 1.514607363050e-04 true resid norm 2.701257005361e-06 ||r(i)||/||b|| 6.102378514403e-03
 36 KSP preconditioned resid norm 1.292399241270e-04 true resid norm 2.320942442747e-06 ||r(i)||/||b|| 5.243214276789e-03
 37 KSP preconditioned resid norm 1.113093655985e-04 true resid norm 2.012620032643e-06 ||r(i)||/||b|| 4.546686679750e-03
 38 KSP preconditioned resid norm 9.638370609107e-05 true resid norm 1.745852020030e-06 ||r(i)||/||b|| 3.944034142333e-03
 39 KSP preconditioned resid norm 8.513224656629e-05 true resid norm 1.567471611197e-06 ||r(i)||/||b|| 3.541057020165e-03
 40 KSP preconditioned resid norm 7.704949362208e-05 true resid norm 1.441870032586e-06 ||r(i)||/||b|| 3.257311944015e-03
 41 KSP preconditioned resid norm 7.416600969234e-05 true resid norm 1.387116363643e-06 ||r(i)||/||b|| 3.133618562644e-03
 42 KSP preconditioned resid norm 7.089738304852e-05 true resid norm 1.340002853411e-06 ||r(i)||/||b|| 3.027184975612e-03
 43 KSP preconditioned resid norm 6.581250801038e-05 true resid norm 1.249219785304e-06 ||r(i)||/||b|| 2.822097994555e-03
 44 KSP preconditioned resid norm 6.017536328335e-05 true resid norm 1.138318209892e-06 ||r(i)||/||b|| 2.571561525916e-03
 45 KSP preconditioned resid norm 5.291453805278e-05 true resid norm 9.879388097098e-07 ||r(i)||/||b|| 2.231841159117e-03
 46 KSP preconditioned resid norm 4.487340354867e-05 true resid norm 8.485532777055e-07 ||r(i)||/||b|| 1.916956912993e-03
 47 KSP preconditioned resid norm 3.739882357030e-05 true resid norm 7.003096353684e-07 ||r(i)||/||b|| 1.582061412083e-03
 48 KSP preconditioned resid norm 3.137542049643e-05 true resid norm 5.955225458651e-07 ||r(i)||/||b|| 1.345338107969e-03
 49 KSP preconditioned resid norm 2.602851465755e-05 true resid norm 4.947611952217e-07 ||r(i)||/||b|| 1.117709304035e-03
 50 KSP preconditioned resid norm 2.239648622827e-05 true resid norm 4.176334446981e-07 ||r(i)||/||b|| 9.434708932782e-04
 51 KSP preconditioned resid norm 1.943272403913e-05 true resid norm 3.617586189005e-07 ||r(i)||/||b|| 8.172447194018e-04
 52 KSP preconditioned resid norm 1.694651141780e-05 true resid norm 3.124113892535e-07 ||r(i)||/||b|| 7.057649626274e-04
 53 KSP preconditioned resid norm 1.437962880232e-05 true resid norm 2.673007067596e-07 ||r(i)||/||b|| 6.038559406148e-04
 54 KSP preconditioned resid norm 1.238515886214e-05 true resid norm 2.296627404421e-07 ||r(i)||/||b|| 5.188284454428e-04
 55 KSP preconditioned resid norm 1.066480833551e-05 true resid norm 2.011009805376e-07 ||r(i)||/||b|| 4.543049033923e-04
 56 KSP preconditioned resid norm 9.252762614443e-06 true resid norm 1.750957732474e-07 ||r(i)||/||b|| 3.955568398369e-04
 57 KSP preconditioned resid norm 8.156742519122e-06 true resid norm 1.543548242077e-07 ||r(i)||/||b|| 3.487012013185e-04
 58 KSP preconditioned resid norm 7.047446830436e-06 true resid norm 1.329697427176e-07 ||r(i)||/||b|| 3.003904106181e-04
 59 KSP preconditioned resid norm 6.272543501603e-06 true resid norm 1.173596968440e-07 ||r(i)||/||b|| 2.651259362053e-04
 60 KSP preconditioned resid norm 5.617850076658e-06 true resid norm 1.048872581175e-07 ||r(i)||/||b|| 2.369495938746e-04
 61 KSP preconditioned resid norm 5.088697078617e-06 true resid norm 9.338259193215e-08 ||r(i)||/||b|| 2.109595353182e-04
 62 KSP preconditioned resid norm 4.609889053145e-06 true resid norm 8.448514669193e-08 ||r(i)||/||b|| 1.908594194984e-04
 63 KSP preconditioned resid norm 4.348711544154e-06 true resid norm 7.896125674079e-08 ||r(i)||/||b|| 1.783804634839e-04
 64 KSP preconditioned resid norm 4.134741875454e-06 true resid norm 7.522427150948e-08 ||r(i)||/||b|| 1.699382832918e-04
 65 KSP preconditioned resid norm 3.890648765226e-06 true resid norm 7.140013752843e-08 ||r(i)||/||b|| 1.612992263654e-04
 66 KSP preconditioned resid norm 3.630637183476e-06 true resid norm 6.620414074232e-08 ||r(i)||/||b|| 1.495610100145e-04
 67 KSP preconditioned resid norm 3.351402191268e-06 true resid norm 6.142354083693e-08 ||r(i)||/||b|| 1.387612119609e-04
 68 KSP preconditioned resid norm 3.003069764131e-06 true resid norm 5.521174933891e-08 ||r(i)||/||b|| 1.247282255038e-04
 69 KSP preconditioned resid norm 2.553922397494e-06 true resid norm 4.752558914508e-08 ||r(i)||/||b|| 1.073645097478e-04
 70 KSP preconditioned resid norm 2.175897257712e-06 true resid norm 4.034864166737e-08 ||r(i)||/||b|| 9.115115055977e-05
 71 KSP preconditioned resid norm 1.819866210793e-06 true resid norm 3.431149032452e-08 ||r(i)||/||b|| 7.751269166095e-05
 72 KSP preconditioned resid norm 1.548242180926e-06 true resid norm 2.928994370346e-08 ||r(i)||/||b|| 6.616857366380e-05
 73 KSP preconditioned resid norm 1.310285862681e-06 true resid norm 2.457648929714e-08 ||r(i)||/||b|| 5.552046323200e-05
 74 KSP preconditioned resid norm 1.117760857018e-06 true resid norm 2.124356033291e-08 ||r(i)||/||b|| 4.799108188805e-05
 75 KSP preconditioned resid norm 9.400046718828e-07 true resid norm 1.801132753984e-08 ||r(i)||/||b|| 4.068918210183e-05
 76 KSP preconditioned resid norm 7.879724131876e-07 true resid norm 1.487185493020e-08 ||r(i)||/||b|| 3.359683577508e-05
 77 KSP preconditioned resid norm 6.501647223826e-07 true resid norm 1.238639168275e-08 ||r(i)||/||b|| 2.798195444779e-05
 78 KSP preconditioned resid norm 5.244102352647e-07 true resid norm 9.938643942450e-09 ||r(i)||/||b|| 2.245227578729e-05
 79 KSP preconditioned resid norm 4.252748195173e-07 true resid norm 8.086882864631e-09 ||r(i)||/||b|| 1.826898371524e-05
 80 KSP preconditioned resid norm 3.570931502725e-07 true resid norm 6.678020281780e-09 ||r(i)||/||b|| 1.508623851985e-05
 81 KSP preconditioned resid norm 3.065742074773e-07 true resid norm 5.781105865334e-09 ||r(i)||/||b|| 1.306002951666e-05
 82 KSP preconditioned resid norm 2.643367534957e-07 true resid norm 4.982866732987e-09 ||r(i)||/||b|| 1.125673670856e-05
 83 KSP preconditioned resid norm 2.280950542432e-07 true resid norm 4.327517506073e-09 ||r(i)||/||b|| 9.776244836147e-06
 84 KSP preconditioned resid norm 1.995403320679e-07 true resid norm 3.788717715943e-09 ||r(i)||/||b|| 8.559048450786e-06
 85 KSP preconditioned resid norm 1.801197754396e-07 true resid norm 3.391421449432e-09 ||r(i)||/||b|| 7.661521041955e-06
 86 KSP preconditioned resid norm 1.657011734354e-07 true resid norm 3.116913459728e-09 ||r(i)||/||b|| 7.041383211650e-06
 87 KSP preconditioned resid norm 1.543040611531e-07 true resid norm 2.878254030645e-09 ||r(i)||/||b|| 6.502230450765e-06
 88 KSP preconditioned resid norm 1.407455045236e-07 true resid norm 2.663937606316e-09 ||r(i)||/||b|| 6.018070690879e-06
 89 KSP preconditioned resid norm 1.274777598637e-07 true resid norm 2.419915125875e-09 ||r(i)||/||b|| 5.466802322591e-06
 90 KSP preconditioned resid norm 1.175684432017e-07 true resid norm 2.220924203193e-09 ||r(i)||/||b|| 5.017264226537e-06
 91 KSP preconditioned resid norm 1.075781206789e-07 true resid norm 1.993444802292e-09 ||r(i)||/||b|| 4.503368138245e-06
 92 KSP preconditioned resid norm 9.759578419791e-08 true resid norm 1.821314287582e-09 ||r(i)||/||b|| 4.114510079736e-06
 93 KSP preconditioned resid norm 8.925485244272e-08 true resid norm 1.674835427967e-09 ||r(i)||/||b|| 3.783601379100e-06
 94 KSP preconditioned resid norm 8.089788818430e-08 true resid norm 1.515996211883e-09 ||r(i)||/||b|| 3.424769539867e-06
 95 KSP preconditioned resid norm 7.289960311973e-08 true resid norm 1.368485652074e-09 ||r(i)||/||b|| 3.091530137232e-06
 96 KSP preconditioned resid norm 6.469530000382e-08 true resid norm 1.226036696280e-09 ||r(i)||/||b|| 2.769725345794e-06
 97 KSP preconditioned resid norm 5.424755061660e-08 true resid norm 1.031810853292e-09 ||r(i)||/||b|| 2.330951986265e-06
 98 KSP preconditioned resid norm 4.410372113577e-08 true resid norm 8.347415824027e-10 ||r(i)||/||b|| 1.885755071592e-06
 99 KSP preconditioned resid norm 3.626671465664e-08 true resid norm 6.760895394329e-10 ||r(i)||/||b|| 1.527346072980e-06
100 KSP preconditioned resid norm 3.009853212523e-08 true resid norm 5.671239345142e-10 ||r(i)||/||b|| 1.281183132932e-06
101 KSP preconditioned resid norm 2.466608372990e-08 true resid norm 4.710596536551e-10 ||r(i)||/||b|| 1.064165425120e-06
102 KSP preconditioned resid norm 2.046065106600e-08 true resid norm 3.883310134620e-10 ||r(i)||/||b|| 8.772741091736e-07
103 KSP preconditioned resid norm 1.744110409526e-08 true resid norm 3.265789399039e-10 ||r(i)||/||b|| 7.377707127353e-07
104 KSP preconditioned resid norm 1.491687421251e-08 true resid norm 2.810628271215e-10 ||r(i)||/||b|| 6.349457878387e-07
105 KSP preconditioned resid norm 1.255818686884e-08 true resid norm 2.373067242255e-10 ||r(i)||/||b|| 5.360968809569e-07
106 KSP preconditioned resid norm 1.048044151279e-08 true resid norm 1.942962727142e-10 ||r(i)||/||b|| 4.389324665097e-07
107 KSP preconditioned resid norm 8.811173613915e-09 true resid norm 1.601952795475e-10 ||r(i)||/||b|| 3.618953065478e-07
108 KSP preconditioned resid norm 7.580770590862e-09 true resid norm 1.356161927586e-10 ||r(i)||/||b|| 3.063689753522e-07
109 KSP preconditioned resid norm 6.667645657219e-09 true resid norm 1.184207170417e-10 ||r(i)||/||b|| 2.675228746843e-07
110 KSP preconditioned resid norm 5.786888011591e-09 true resid norm 1.032767550023e-10 ||r(i)||/||b|| 2.333113248803e-07
111 KSP preconditioned resid norm 5.105514156375e-09 true resid norm 9.072728069484e-11 ||r(i)||/||b|| 2.049609523580e-07
112 KSP preconditioned resid norm 4.598490784391e-09 true resid norm 8.132033496205e-11 ||r(i)||/||b|| 1.837098298576e-07
113 KSP preconditioned resid norm 4.289089905641e-09 true resid norm 7.522280292960e-11 ||r(i)||/||b|| 1.699349656400e-07
114 KSP preconditioned resid norm 3.931201484852e-09 true resid norm 6.933688891365e-11 ||r(i)||/||b|| 1.566381652403e-07
115 KSP preconditioned resid norm 3.615770085121e-09 true resid norm 6.449782831177e-11 ||r(i)||/||b|| 1.457062993023e-07
116 KSP preconditioned resid norm 3.343513105555e-09 true resid norm 5.983074039029e-11 ||r(i)||/||b|| 1.351629348610e-07
117 KSP preconditioned resid norm 2.979612262456e-09 true resid norm 5.432722174073e-11 ||r(i)||/||b|| 1.227299994188e-07
118 KSP preconditioned resid norm 2.618943928923e-09 true resid norm 4.837467850025e-11 ||r(i)||/||b|| 1.092826777072e-07
Linear solve converged due to CONVERGED_RTOL iterations 118
iter =  13, Function value: -4.34175,  Residual: 0.000473351
  0 KSP preconditioned resid norm 1.665406546128e-02 true resid norm 2.542389909048e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.762821677879e-03 true resid norm 1.723130360340e-04 ||r(i)||/||b|| 6.777600690625e-01
  2 KSP preconditioned resid norm 5.730360207287e-03 true resid norm 1.175034297243e-04 ||r(i)||/||b|| 4.621770614575e-01
  3 KSP preconditioned resid norm 4.158254684144e-03 true resid norm 9.233346809360e-05 ||r(i)||/||b|| 3.631758754430e-01
  4 KSP preconditioned resid norm 3.462269316449e-03 true resid norm 7.319286387970e-05 ||r(i)||/||b|| 2.878900030999e-01
  5 KSP preconditioned resid norm 2.947014730376e-03 true resid norm 6.231760845069e-05 ||r(i)||/||b|| 2.451142849054e-01
  6 KSP preconditioned resid norm 2.489751932136e-03 true resid norm 5.121995881800e-05 ||r(i)||/||b|| 2.014638220350e-01
  7 KSP preconditioned resid norm 2.187122046702e-03 true resid norm 4.438983484254e-05 ||r(i)||/||b|| 1.745988476613e-01
  8 KSP preconditioned resid norm 1.933326609914e-03 true resid norm 3.907945163153e-05 ||r(i)||/||b|| 1.537114802590e-01
  9 KSP preconditioned resid norm 1.770984446142e-03 true resid norm 3.616765436381e-05 ||r(i)||/||b|| 1.422584877130e-01
 10 KSP preconditioned resid norm 1.552274290148e-03 true resid norm 3.077428893596e-05 ||r(i)||/||b|| 1.210447257772e-01
 11 KSP preconditioned resid norm 1.420403944918e-03 true resid norm 2.771678069237e-05 ||r(i)||/||b|| 1.090186072315e-01
 12 KSP preconditioned resid norm 1.290086011974e-03 true resid norm 2.423194900580e-05 ||r(i)||/||b|| 9.531169440045e-02
 13 KSP preconditioned resid norm 1.176835496138e-03 true resid norm 2.279581957798e-05 ||r(i)||/||b|| 8.966295648379e-02
 14 KSP preconditioned resid norm 1.029531641046e-03 true resid norm 1.906420570115e-05 ||r(i)||/||b|| 7.498537353890e-02
 15 KSP preconditioned resid norm 9.051957508244e-04 true resid norm 1.651822339016e-05 ||r(i)||/||b|| 6.497124351924e-02
 16 KSP preconditioned resid norm 8.326573125341e-04 true resid norm 1.512108143206e-05 ||r(i)||/||b|| 5.947585528972e-02
 17 KSP preconditioned resid norm 7.947963753897e-04 true resid norm 1.433488854741e-05 ||r(i)||/||b|| 5.638351732123e-02
 18 KSP preconditioned resid norm 7.750505115026e-04 true resid norm 1.375763579889e-05 ||r(i)||/||b|| 5.411300505061e-02
 19 KSP preconditioned resid norm 7.515608274598e-04 true resid norm 1.356212679763e-05 ||r(i)||/||b|| 5.334400812939e-02
 20 KSP preconditioned resid norm 7.168397682319e-04 true resid norm 1.288201885123e-05 ||r(i)||/||b|| 5.066893478999e-02
 21 KSP preconditioned resid norm 6.571699209222e-04 true resid norm 1.198728836689e-05 ||r(i)||/||b|| 4.714968512195e-02
 22 KSP preconditioned resid norm 5.847535237162e-04 true resid norm 1.075832320564e-05 ||r(i)||/||b|| 4.231578786304e-02
 23 KSP preconditioned resid norm 5.040039697040e-04 true resid norm 9.218464930846e-06 ||r(i)||/||b|| 3.625905254752e-02
 24 KSP preconditioned resid norm 4.267511938192e-04 true resid norm 8.008254242835e-06 ||r(i)||/||b|| 3.149892238926e-02
 25 KSP preconditioned resid norm 3.514634470641e-04 true resid norm 6.497919814166e-06 ||r(i)||/||b|| 2.555831342408e-02
 26 KSP preconditioned resid norm 2.916096460573e-04 true resid norm 5.460677972310e-06 ||r(i)||/||b|| 2.147852283741e-02
 27 KSP preconditioned resid norm 2.484153941515e-04 true resid norm 4.723322757188e-06 ||r(i)||/||b|| 1.857827841582e-02
 28 KSP preconditioned resid norm 2.191777036887e-04 true resid norm 4.191375391372e-06 ||r(i)||/||b|| 1.648596612367e-02
 29 KSP preconditioned resid norm 1.951913502236e-04 true resid norm 3.770547041410e-06 ||r(i)||/||b|| 1.483071903326e-02
 30 KSP preconditioned resid norm 1.719469806897e-04 true resid norm 3.339161788619e-06 ||r(i)||/||b|| 1.313394840318e-02
 31 KSP preconditioned resid norm 1.516623276863e-04 true resid norm 2.918435521540e-06 ||r(i)||/||b|| 1.147910283609e-02
 32 KSP preconditioned resid norm 1.332909230881e-04 true resid norm 2.570137389514e-06 ||r(i)||/||b|| 1.010913935887e-02
 33 KSP preconditioned resid norm 1.166102561032e-04 true resid norm 2.239798146899e-06 ||r(i)||/||b|| 8.809813706890e-03
 34 KSP preconditioned resid norm 9.862102896104e-05 true resid norm 1.867740593429e-06 ||r(i)||/||b|| 7.346397131225e-03
 35 KSP preconditioned resid norm 8.345932858878e-05 true resid norm 1.594139752687e-06 ||r(i)||/||b|| 6.270241031926e-03
 36 KSP preconditioned resid norm 7.124244422748e-05 true resid norm 1.358179091408e-06 ||r(i)||/||b|| 5.342135313606e-03
 37 KSP preconditioned resid norm 6.080305219803e-05 true resid norm 1.183439247526e-06 ||r(i)||/||b|| 4.654829864272e-03
 38 KSP preconditioned resid norm 5.146086530179e-05 true resid norm 9.863020309344e-07 ||r(i)||/||b|| 3.879428672306e-03
 39 KSP preconditioned resid norm 4.528243684605e-05 true resid norm 8.672324661035e-07 ||r(i)||/||b|| 3.411091520687e-03
 40 KSP preconditioned resid norm 4.015530901780e-05 true resid norm 7.810501070816e-07 ||r(i)||/||b|| 3.072109845551e-03
 41 KSP preconditioned resid norm 3.601609891090e-05 true resid norm 6.965475410266e-07 ||r(i)||/||b|| 2.739735311832e-03
 42 KSP preconditioned resid norm 3.375820115143e-05 true resid norm 6.456503328774e-07 ||r(i)||/||b|| 2.539540967259e-03
 43 KSP preconditioned resid norm 3.238518318841e-05 true resid norm 6.292058277199e-07 ||r(i)||/||b|| 2.474859680180e-03
 44 KSP preconditioned resid norm 3.081908393977e-05 true resid norm 5.974807824183e-07 ||r(i)||/||b|| 2.350075337744e-03
 45 KSP preconditioned resid norm 2.833116548689e-05 true resid norm 5.570285287043e-07 ||r(i)||/||b|| 2.190964205459e-03
 46 KSP preconditioned resid norm 2.557534575364e-05 true resid norm 4.938717716617e-07 ||r(i)||/||b|| 1.942549291531e-03
 47 KSP preconditioned resid norm 2.200016307922e-05 true resid norm 4.309049518621e-07 ||r(i)||/||b|| 1.694881459089e-03
 48 KSP preconditioned resid norm 1.893145369922e-05 true resid norm 3.668739167400e-07 ||r(i)||/||b|| 1.443027741081e-03
 49 KSP preconditioned resid norm 1.597334300065e-05 true resid norm 3.071175098862e-07 ||r(i)||/||b|| 1.207987448319e-03
 50 KSP preconditioned resid norm 1.310136774183e-05 true resid norm 2.564578937007e-07 ||r(i)||/||b|| 1.008727625877e-03
 51 KSP preconditioned resid norm 1.084764737205e-05 true resid norm 2.049360568312e-07 ||r(i)||/||b|| 8.060764247917e-04
 52 KSP preconditioned resid norm 9.351073254127e-06 true resid norm 1.802829844611e-07 ||r(i)||/||b|| 7.091083229190e-04
 53 KSP preconditioned resid norm 8.036962182361e-06 true resid norm 1.565039884598e-07 ||r(i)||/||b|| 6.155782317370e-04
 54 KSP preconditioned resid norm 6.851814685728e-06 true resid norm 1.309663966713e-07 ||r(i)||/||b|| 5.151310434532e-04
 55 KSP preconditioned resid norm 5.883865692944e-06 true resid norm 1.112887538854e-07 ||r(i)||/||b|| 4.377328335410e-04
 56 KSP preconditioned resid norm 5.072708150447e-06 true resid norm 9.692464391766e-08 ||r(i)||/||b|| 3.812343794031e-04
 57 KSP preconditioned resid norm 4.460772452998e-06 true resid norm 8.439709311622e-08 ||r(i)||/||b|| 3.319596762710e-04
 58 KSP preconditioned resid norm 3.840182059036e-06 true resid norm 7.345567785883e-08 ||r(i)||/||b|| 2.889237311610e-04
 59 KSP preconditioned resid norm 3.336336514839e-06 true resid norm 6.430064814244e-08 ||r(i)||/||b|| 2.529141887859e-04
 60 KSP preconditioned resid norm 2.900267096427e-06 true resid norm 5.680968553960e-08 ||r(i)||/||b|| 2.234499332200e-04
 61 KSP preconditioned resid norm 2.622574784800e-06 true resid norm 5.117589550846e-08 ||r(i)||/||b|| 2.012905075116e-04
 62 KSP preconditioned resid norm 2.348923915177e-06 true resid norm 4.559088530578e-08 ||r(i)||/||b|| 1.793229478434e-04
 63 KSP preconditioned resid norm 2.135618976340e-06 true resid norm 4.109934908821e-08 ||r(i)||/||b|| 1.616563570440e-04
 64 KSP preconditioned resid norm 1.948652255387e-06 true resid norm 3.792162147274e-08 ||r(i)||/||b|| 1.491573788024e-04
 65 KSP preconditioned resid norm 1.772853480251e-06 true resid norm 3.404740806878e-08 ||r(i)||/||b|| 1.339189081408e-04
 66 KSP preconditioned resid norm 1.632419572311e-06 true resid norm 3.192205055143e-08 ||r(i)||/||b|| 1.255592245620e-04
 67 KSP preconditioned resid norm 1.537342676530e-06 true resid norm 2.933588200712e-08 ||r(i)||/||b|| 1.153870297499e-04
 68 KSP preconditioned resid norm 1.465519778017e-06 true resid norm 2.822501838826e-08 ||r(i)||/||b|| 1.110176621132e-04
 69 KSP preconditioned resid norm 1.337225700066e-06 true resid norm 2.582699048234e-08 ||r(i)||/||b|| 1.015854821891e-04
 70 KSP preconditioned resid norm 1.176472143456e-06 true resid norm 2.210340345603e-08 ||r(i)||/||b|| 8.693947131151e-05
 71 KSP preconditioned resid norm 1.007724709002e-06 true resid norm 1.880177249637e-08 ||r(i)||/||b|| 7.395314318020e-05
 72 KSP preconditioned resid norm 8.806895093453e-07 true resid norm 1.640579686125e-08 ||r(i)||/||b|| 6.452903546724e-05
 73 KSP preconditioned resid norm 7.645074064644e-07 true resid norm 1.455849027510e-08 ||r(i)||/||b|| 5.726301155967e-05
 74 KSP preconditioned resid norm 6.690568602477e-07 true resid norm 1.279302677709e-08 ||r(i)||/||b|| 5.031890164276e-05
 75 KSP preconditioned resid norm 5.847136611453e-07 true resid norm 1.123348464954e-08 ||r(i)||/||b|| 4.418474369161e-05
 76 KSP preconditioned resid norm 5.063952503599e-07 true resid norm 9.841336997405e-09 ||r(i)||/||b|| 3.870899960065e-05
 77 KSP preconditioned resid norm 4.499914848548e-07 true resid norm 8.491434535985e-09 ||r(i)||/||b|| 3.339941881363e-05
 78 KSP preconditioned resid norm 3.903526436765e-07 true resid norm 7.456808129350e-09 ||r(i)||/||b|| 2.932991553661e-05
 79 KSP preconditioned resid norm 3.315524318510e-07 true resid norm 6.388872412591e-09 ||r(i)||/||b|| 2.512939651725e-05
 80 KSP preconditioned resid norm 2.813356386563e-07 true resid norm 5.304011984782e-09 ||r(i)||/||b|| 2.086230741361e-05
 81 KSP preconditioned resid norm 2.434980744312e-07 true resid norm 4.621382142216e-09 ||r(i)||/||b|| 1.817731468241e-05
 82 KSP preconditioned resid norm 2.146039101655e-07 true resid norm 4.071459409762e-09 ||r(i)||/||b|| 1.601429975501e-05
 83 KSP preconditioned resid norm 1.906451692306e-07 true resid norm 3.605849643930e-09 ||r(i)||/||b|| 1.418291360856e-05
 84 KSP preconditioned resid norm 1.696949140319e-07 true resid norm 3.225946797325e-09 ||r(i)||/||b|| 1.268863908657e-05
 85 KSP preconditioned resid norm 1.510311127331e-07 true resid norm 2.873880025223e-09 ||r(i)||/||b|| 1.130385239099e-05
 86 KSP preconditioned resid norm 1.313985697057e-07 true resid norm 2.498109538074e-09 ||r(i)||/||b|| 9.825831707337e-06
 87 KSP preconditioned resid norm 1.162363605880e-07 true resid norm 2.153812725524e-09 ||r(i)||/||b|| 8.471606647977e-06
 88 KSP preconditioned resid norm 1.027351892078e-07 true resid norm 1.907041977042e-09 ||r(i)||/||b|| 7.500981538098e-06
 89 KSP preconditioned resid norm 9.006376613620e-08 true resid norm 1.675261777899e-09 ||r(i)||/||b|| 6.589318860719e-06
 90 KSP preconditioned resid norm 7.938070031619e-08 true resid norm 1.481537361672e-09 ||r(i)||/||b|| 5.827341260281e-06
 91 KSP preconditioned resid norm 7.045983067036e-08 true resid norm 1.333708610854e-09 ||r(i)||/||b|| 5.245885401398e-06
 92 KSP preconditioned resid norm 6.344583591785e-08 true resid norm 1.187609504833e-09 ||r(i)||/||b|| 4.671232766487e-06
 93 KSP preconditioned resid norm 5.488145237787e-08 true resid norm 1.039023079803e-09 ||r(i)||/||b|| 4.086796742332e-06
 94 KSP preconditioned resid norm 4.665102853183e-08 true resid norm 8.859316833387e-10 ||r(i)||/||b|| 3.484641282542e-06
 95 KSP preconditioned resid norm 3.918906865965e-08 true resid norm 7.462289012816e-10 ||r(i)||/||b|| 2.935147353385e-06
 96 KSP preconditioned resid norm 3.418329138079e-08 true resid norm 6.470736288472e-10 ||r(i)||/||b|| 2.545139227246e-06
 97 KSP preconditioned resid norm 2.958182063702e-08 true resid norm 5.668036922505e-10 ||r(i)||/||b|| 2.229412924561e-06
 98 KSP preconditioned resid norm 2.605801895302e-08 true resid norm 5.016897131464e-10 ||r(i)||/||b|| 1.973299655419e-06
 99 KSP preconditioned resid norm 2.297469741371e-08 true resid norm 4.404562612435e-10 ||r(i)||/||b|| 1.732449691041e-06
100 KSP preconditioned resid norm 2.028123585027e-08 true resid norm 3.953809065586e-10 ||r(i)||/||b|| 1.555154483392e-06
101 KSP preconditioned resid norm 1.821783809657e-08 true resid norm 3.508226051296e-10 ||r(i)||/||b|| 1.379893004928e-06
102 KSP preconditioned resid norm 1.668975071392e-08 true resid norm 3.221769138587e-10 ||r(i)||/||b|| 1.267220707226e-06
103 KSP preconditioned resid norm 1.546316021900e-08 true resid norm 3.033698969283e-10 ||r(i)||/||b|| 1.193246936076e-06
104 KSP preconditioned resid norm 1.435290425838e-08 true resid norm 2.771671469340e-10 ||r(i)||/||b|| 1.090183476372e-06
105 KSP preconditioned resid norm 1.327443549963e-08 true resid norm 2.609245531633e-10 ||r(i)||/||b|| 1.026296368762e-06
106 KSP preconditioned resid norm 1.220225779437e-08 true resid norm 2.386548866911e-10 ||r(i)||/||b|| 9.387029339667e-07
107 KSP preconditioned resid norm 1.096964523364e-08 true resid norm 2.144025306558e-10 ||r(i)||/||b|| 8.433109724545e-07
108 KSP preconditioned resid norm 9.607281795243e-09 true resid norm 1.850447180457e-10 ||r(i)||/||b|| 7.278376829105e-07
109 KSP preconditioned resid norm 8.249798087173e-09 true resid norm 1.588822791602e-10 ||r(i)||/||b|| 6.249327791727e-07
110 KSP preconditioned resid norm 7.098531926403e-09 true resid norm 1.367985030728e-10 ||r(i)||/||b|| 5.380705083273e-07
111 KSP preconditioned resid norm 6.187916604076e-09 true resid norm 1.198542566625e-10 ||r(i)||/||b|| 4.714235854854e-07
112 KSP preconditioned resid norm 5.274910109217e-09 true resid norm 1.033366212017e-10 ||r(i)||/||b|| 4.064546544725e-07
113 KSP preconditioned resid norm 4.461349389916e-09 true resid norm 8.735103877817e-11 ||r(i)||/||b|| 3.435784513906e-07
114 KSP preconditioned resid norm 3.763466701280e-09 true resid norm 7.355582001244e-11 ||r(i)||/||b|| 2.893176209938e-07
115 KSP preconditioned resid norm 3.180877156906e-09 true resid norm 6.207168940750e-11 ||r(i)||/||b|| 2.441470098139e-07
116 KSP preconditioned resid norm 2.699351210329e-09 true resid norm 5.223380269809e-11 ||r(i)||/||b|| 2.054515812551e-07
117 KSP preconditioned resid norm 2.231855875133e-09 true resid norm 4.320892913413e-11 ||r(i)||/||b|| 1.699539829841e-07
118 KSP preconditioned resid norm 1.844930804643e-09 true resid norm 3.610467103818e-11 ||r(i)||/||b|| 1.420107549581e-07
119 KSP preconditioned resid norm 1.545780195325e-09 true resid norm 2.988823067721e-11 ||r(i)||/||b|| 1.175595866348e-07
Linear solve converged due to CONVERGED_RTOL iterations 119
iter =  14, Function value: -4.34176,  Residual: 0.000272484
  0 KSP preconditioned resid norm 9.512781256679e-03 true resid norm 1.451643280572e-04 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 4.247935335848e-03 true resid norm 8.559814023996e-05 ||r(i)||/||b|| 5.896637375417e-01
  2 KSP preconditioned resid norm 3.048007251559e-03 true resid norm 6.106713057651e-05 ||r(i)||/||b|| 4.206758739822e-01
  3 KSP preconditioned resid norm 2.280558081061e-03 true resid norm 4.731567305671e-05 ||r(i)||/||b|| 3.259455934522e-01
  4 KSP preconditioned resid norm 1.782956153208e-03 true resid norm 3.604441930644e-05 ||r(i)||/||b|| 2.483008035709e-01
  5 KSP preconditioned resid norm 1.454433854062e-03 true resid norm 2.977300884449e-05 ||r(i)||/||b|| 2.050986577966e-01
  6 KSP preconditioned resid norm 1.245479739002e-03 true resid norm 2.500612362386e-05 ||r(i)||/||b|| 1.722608023508e-01
  7 KSP preconditioned resid norm 1.065986588615e-03 true resid norm 2.133476287121e-05 ||r(i)||/||b|| 1.469697353113e-01
  8 KSP preconditioned resid norm 9.191225715829e-04 true resid norm 1.807879070452e-05 ||r(i)||/||b|| 1.245401742045e-01
  9 KSP preconditioned resid norm 8.312159401608e-04 true resid norm 1.657189192811e-05 ||r(i)||/||b|| 1.141595331987e-01
 10 KSP preconditioned resid norm 7.361047509661e-04 true resid norm 1.476020208585e-05 ||r(i)||/||b|| 1.016792643440e-01
 11 KSP preconditioned resid norm 6.655336457854e-04 true resid norm 1.289834164826e-05 ||r(i)||/||b|| 8.885338306510e-02
 12 KSP preconditioned resid norm 5.938398806050e-04 true resid norm 1.126115668417e-05 ||r(i)||/||b|| 7.757523377048e-02
 13 KSP preconditioned resid norm 5.476388407658e-04 true resid norm 1.008223648285e-05 ||r(i)||/||b|| 6.945395344557e-02
 14 KSP preconditioned resid norm 4.998263892484e-04 true resid norm 9.194829099331e-06 ||r(i)||/||b|| 6.334083050834e-02
 15 KSP preconditioned resid norm 4.376679373662e-04 true resid norm 7.978324864436e-06 ||r(i)||/||b|| 5.496064337025e-02
 16 KSP preconditioned resid norm 3.839433433867e-04 true resid norm 6.679072172684e-06 ||r(i)||/||b|| 4.601042323601e-02
 17 KSP preconditioned resid norm 3.466763516145e-04 true resid norm 6.070502281893e-06 ||r(i)||/||b|| 4.181814060751e-02
 18 KSP preconditioned resid norm 3.415570839864e-04 true resid norm 5.882733626133e-06 ||r(i)||/||b|| 4.052465026955e-02
 19 KSP preconditioned resid norm 3.356182901931e-04 true resid norm 5.707552490361e-06 ||r(i)||/||b|| 3.931787214357e-02
 20 KSP preconditioned resid norm 3.234617963319e-04 true resid norm 5.649763671395e-06 ||r(i)||/||b|| 3.891977972142e-02
 21 KSP preconditioned resid norm 3.052262524881e-04 true resid norm 5.323510730924e-06 ||r(i)||/||b|| 3.667230649685e-02
 22 KSP preconditioned resid norm 2.793964844470e-04 true resid norm 5.025542873273e-06 ||r(i)||/||b|| 3.461968198751e-02
 23 KSP preconditioned resid norm 2.438471206299e-04 true resid norm 4.375295442107e-06 ||r(i)||/||b|| 3.014029342238e-02
 24 KSP preconditioned resid norm 2.075797620578e-04 true resid norm 3.763120001701e-06 ||r(i)||/||b|| 2.592317308297e-02
 25 KSP preconditioned resid norm 1.717271800505e-04 true resid norm 3.127921673267e-06 ||r(i)||/||b|| 2.154745394498e-02
 26 KSP preconditioned resid norm 1.409799139711e-04 true resid norm 2.557158767523e-06 ||r(i)||/||b|| 1.761561398551e-02
 27 KSP preconditioned resid norm 1.132592353157e-04 true resid norm 2.103070258973e-06 ||r(i)||/||b|| 1.448751416494e-02
 28 KSP preconditioned resid norm 9.409792491380e-05 true resid norm 1.778286352206e-06 ||r(i)||/||b|| 1.225016073856e-02
 29 KSP preconditioned resid norm 8.298812912571e-05 true resid norm 1.562597265463e-06 ||r(i)||/||b|| 1.076433367877e-02
 30 KSP preconditioned resid norm 7.516274621636e-05 true resid norm 1.411405325034e-06 ||r(i)||/||b|| 9.722810995805e-03
 31 KSP preconditioned resid norm 6.668806155590e-05 true resid norm 1.268209234974e-06 ||r(i)||/||b|| 8.736369684939e-03
 32 KSP preconditioned resid norm 5.983348325875e-05 true resid norm 1.134049306052e-06 ||r(i)||/||b|| 7.812176181496e-03
 33 KSP preconditioned resid norm 5.500090764363e-05 true resid norm 1.040122705665e-06 ||r(i)||/||b|| 7.165139808006e-03
 34 KSP preconditioned resid norm 4.846195374763e-05 true resid norm 9.285230995401e-07 ||r(i)||/||b|| 6.396358609355e-03
 35 KSP preconditioned resid norm 4.223946705512e-05 true resid norm 8.079300675425e-07 ||r(i)||/||b|| 5.565623995614e-03
 36 KSP preconditioned resid norm 3.714935379640e-05 true resid norm 6.949254811812e-07 ||r(i)||/||b|| 4.787164246764e-03
 37 KSP preconditioned resid norm 3.274041238901e-05 true resid norm 6.218688080125e-07 ||r(i)||/||b|| 4.283895474426e-03
 38 KSP preconditioned resid norm 2.861832059681e-05 true resid norm 5.516883601066e-07 ||r(i)||/||b|| 3.800440283711e-03
 39 KSP preconditioned resid norm 2.486535522020e-05 true resid norm 4.758309590275e-07 ||r(i)||/||b|| 3.277878011738e-03
 40 KSP preconditioned resid norm 2.166974338831e-05 true resid norm 4.096702188078e-07 ||r(i)||/||b|| 2.822113561166e-03
 41 KSP preconditioned resid norm 1.950257702500e-05 true resid norm 3.797284539713e-07 ||r(i)||/||b|| 2.615852386418e-03
 42 KSP preconditioned resid norm 1.805341459389e-05 true resid norm 3.413588237374e-07 ||r(i)||/||b|| 2.351533798323e-03
 43 KSP preconditioned resid norm 1.660018623069e-05 true resid norm 3.196333020606e-07 ||r(i)||/||b|| 2.201872225348e-03
 44 KSP preconditioned resid norm 1.507816215902e-05 true resid norm 2.854746118192e-07 ||r(i)||/||b|| 1.966561727938e-03
 45 KSP preconditioned resid norm 1.372245704602e-05 true resid norm 2.628857493497e-07 ||r(i)||/||b|| 1.810952820627e-03
 46 KSP preconditioned resid norm 1.267449038834e-05 true resid norm 2.416991920070e-07 ||r(i)||/||b|| 1.665004035369e-03
 47 KSP preconditioned resid norm 1.129080270679e-05 true resid norm 2.157335750295e-07 ||r(i)||/||b|| 1.486133528234e-03
 48 KSP preconditioned resid norm 9.901508564335e-06 true resid norm 1.899438729462e-07 ||r(i)||/||b|| 1.308474853900e-03
 49 KSP preconditioned resid norm 8.468209431232e-06 true resid norm 1.620225229717e-07 ||r(i)||/||b|| 1.116131801387e-03
 50 KSP preconditioned resid norm 7.067051738098e-06 true resid norm 1.368713775782e-07 ||r(i)||/||b|| 9.428719810850e-04
 51 KSP preconditioned resid norm 5.760968307639e-06 true resid norm 1.123216677002e-07 ||r(i)||/||b|| 7.737552965212e-04
 52 KSP preconditioned resid norm 4.767946425207e-06 true resid norm 9.140834629864e-08 ||r(i)||/||b|| 6.296887639131e-04
 53 KSP preconditioned resid norm 4.043611327868e-06 true resid norm 7.632893649213e-08 ||r(i)||/||b|| 5.258105590654e-04
 54 KSP preconditioned resid norm 3.409200956023e-06 true resid norm 6.608447405989e-08 ||r(i)||/||b|| 4.552390724658e-04
 55 KSP preconditioned resid norm 2.872688826482e-06 true resid norm 5.606627249858e-08 ||r(i)||/||b|| 3.862262392485e-04
 56 KSP preconditioned resid norm 2.386453155897e-06 true resid norm 4.677950405183e-08 ||r(i)||/||b|| 3.222520620450e-04
 57 KSP preconditioned resid norm 1.996293336952e-06 true resid norm 3.854654677596e-08 ||r(i)||/||b|| 2.655373209923e-04
 58 KSP preconditioned resid norm 1.669255234067e-06 true resid norm 3.261923537996e-08 ||r(i)||/||b|| 2.247055858454e-04
 59 KSP preconditioned resid norm 1.424343430628e-06 true resid norm 2.774524902984e-08 ||r(i)||/||b|| 1.911299380582e-04
 60 KSP preconditioned resid norm 1.215569160336e-06 true resid norm 2.363371653446e-08 ||r(i)||/||b|| 1.628066402453e-04
 61 KSP preconditioned resid norm 1.080355867943e-06 true resid norm 2.064951714295e-08 ||r(i)||/||b|| 1.422492524115e-04
 62 KSP preconditioned resid norm 9.642525615553e-07 true resid norm 1.852781244262e-08 ||r(i)||/||b|| 1.276333703368e-04
 63 KSP preconditioned resid norm 8.838967922883e-07 true resid norm 1.654081396652e-08 ||r(i)||/||b|| 1.139454450545e-04
 64 KSP preconditioned resid norm 8.114463039732e-07 true resid norm 1.542606010334e-08 ||r(i)||/||b|| 1.062661902534e-04
 65 KSP preconditioned resid norm 7.569157166540e-07 true resid norm 1.437211390620e-08 ||r(i)||/||b|| 9.900582394132e-05
 66 KSP preconditioned resid norm 6.934677085550e-07 true resid norm 1.313136486222e-08 ||r(i)||/||b|| 9.045862050246e-05
 67 KSP preconditioned resid norm 6.369982058575e-07 true resid norm 1.198373950697e-08 ||r(i)||/||b|| 8.255292238355e-05
 68 KSP preconditioned resid norm 5.920982388892e-07 true resid norm 1.125392590973e-08 ||r(i)||/||b|| 7.752542281111e-05
 69 KSP preconditioned resid norm 5.498249891308e-07 true resid norm 1.041112058224e-08 ||r(i)||/||b|| 7.171955205232e-05
 70 KSP preconditioned resid norm 5.095091075694e-07 true resid norm 9.730210921943e-09 ||r(i)||/||b|| 6.702893921781e-05
 71 KSP preconditioned resid norm 4.440774604911e-07 true resid norm 8.557690729922e-09 ||r(i)||/||b|| 5.895174692331e-05
 72 KSP preconditioned resid norm 3.858825705857e-07 true resid norm 7.384737522803e-09 ||r(i)||/||b|| 5.087157169832e-05
 73 KSP preconditioned resid norm 3.350888933055e-07 true resid norm 6.323926232115e-09 ||r(i)||/||b|| 4.356391350926e-05
 74 KSP preconditioned resid norm 2.939199021955e-07 true resid norm 5.508873929747e-09 ||r(i)||/||b|| 3.794922625602e-05
 75 KSP preconditioned resid norm 2.609814534518e-07 true resid norm 4.866523099332e-09 ||r(i)||/||b|| 3.352423535769e-05
 76 KSP preconditioned resid norm 2.344877877143e-07 true resid norm 4.398409996642e-09 ||r(i)||/||b|| 3.029952368813e-05
 77 KSP preconditioned resid norm 2.067507756677e-07 true resid norm 3.887704219130e-09 ||r(i)||/||b|| 2.678140195432e-05
 78 KSP preconditioned resid norm 1.798655063324e-07 true resid norm 3.350107550101e-09 ||r(i)||/||b|| 2.307803573327e-05
 79 KSP preconditioned resid norm 1.555139717897e-07 true resid norm 2.983671803119e-09 ||r(i)||/||b|| 2.055375341208e-05
 80 KSP preconditioned resid norm 1.305172041942e-07 true resid norm 2.478903207218e-09 ||r(i)||/||b|| 1.707653140681e-05
 81 KSP preconditioned resid norm 1.096471775176e-07 true resid norm 2.116354481708e-09 ||r(i)||/||b|| 1.457902578430e-05
 82 KSP preconditioned resid norm 9.569246891295e-08 true resid norm 1.828050970992e-09 ||r(i)||/||b|| 1.259297649400e-05
 83 KSP preconditioned resid norm 8.508083212076e-08 true resid norm 1.638150987541e-09 ||r(i)||/||b|| 1.128480398363e-05
 84 KSP preconditioned resid norm 7.497638762904e-08 true resid norm 1.425310982653e-09 ||r(i)||/||b|| 9.818603521457e-06
 85 KSP preconditioned resid norm 6.644409481813e-08 true resid norm 1.267232834567e-09 ||r(i)||/||b|| 8.729643511779e-06
 86 KSP preconditioned resid norm 5.845287051654e-08 true resid norm 1.126477398379e-09 ||r(i)||/||b|| 7.760015242412e-06
 87 KSP preconditioned resid norm 5.078242857944e-08 true resid norm 9.721939797321e-10 ||r(i)||/||b|| 6.697196155165e-06
 88 KSP preconditioned resid norm 4.410803642403e-08 true resid norm 8.434786972170e-10 ||r(i)||/||b|| 5.810509430970e-06
 89 KSP preconditioned resid norm 3.840716003571e-08 true resid norm 7.349328205815e-10 ||r(i)||/||b|| 5.062764595250e-06
 90 KSP preconditioned resid norm 3.315478145107e-08 true resid norm 6.322233419033e-10 ||r(i)||/||b|| 4.355225215206e-06
 91 KSP preconditioned resid norm 2.920722080312e-08 true resid norm 5.507152491118e-10 ||r(i)||/||b|| 3.793736770473e-06
 92 KSP preconditioned resid norm 2.661333380491e-08 true resid norm 5.011967648660e-10 ||r(i)||/||b|| 3.452616573050e-06
 93 KSP preconditioned resid norm 2.440634138181e-08 true resid norm 4.604517848671e-10 ||r(i)||/||b|| 3.171934806777e-06
 94 KSP preconditioned resid norm 2.204816044796e-08 true resid norm 4.149283447929e-10 ||r(i)||/||b|| 2.858335448839e-06
 95 KSP preconditioned resid norm 1.971585487393e-08 true resid norm 3.693266239522e-10 ||r(i)||/||b|| 2.544196834684e-06
 96 KSP preconditioned resid norm 1.732547653660e-08 true resid norm 3.229256880620e-10 ||r(i)||/||b|| 2.224552632068e-06
 97 KSP preconditioned resid norm 1.487158564563e-08 true resid norm 2.776722891061e-10 ||r(i)||/||b|| 1.912813518460e-06
 98 KSP preconditioned resid norm 1.298790162378e-08 true resid norm 2.438340445636e-10 ||r(i)||/||b|| 1.679710489670e-06
 99 KSP preconditioned resid norm 1.124975305383e-08 true resid norm 2.111337939943e-10 ||r(i)||/||b|| 1.454446810866e-06
100 KSP preconditioned resid norm 9.983351572406e-09 true resid norm 1.895300137236e-10 ||r(i)||/||b|| 1.305623883361e-06
101 KSP preconditioned resid norm 9.079623055690e-09 true resid norm 1.701663230664e-10 ||r(i)||/||b|| 1.172232361378e-06
102 KSP preconditioned resid norm 8.134129028763e-09 true resid norm 1.533708860681e-10 ||r(i)||/||b|| 1.056532883255e-06
103 KSP preconditioned resid norm 7.209228189314e-09 true resid norm 1.374610004440e-10 ||r(i)||/||b|| 9.469337424952e-07
104 KSP preconditioned resid norm 6.451814236276e-09 true resid norm 1.226717165142e-10 ||r(i)||/||b|| 8.450541407520e-07
105 KSP preconditioned resid norm 5.970764994512e-09 true resid norm 1.104355022221e-10 ||r(i)||/||b|| 7.607619840224e-07
106 KSP preconditioned resid norm 5.467718661820e-09 true resid norm 1.039408755359e-10 ||r(i)||/||b|| 7.160221586595e-07
107 KSP preconditioned resid norm 5.007798420131e-09 true resid norm 9.598805438838e-11 ||r(i)||/||b|| 6.612372038848e-07
108 KSP preconditioned resid norm 4.555048344232e-09 true resid norm 8.542883344042e-11 ||r(i)||/||b|| 5.884974262185e-07
109 KSP preconditioned resid norm 4.099284825149e-09 true resid norm 7.689076450753e-11 ||r(i)||/||b|| 5.296808488461e-07
110 KSP preconditioned resid norm 3.615702314960e-09 true resid norm 6.778750748526e-11 ||r(i)||/||b|| 4.669708350011e-07
111 KSP preconditioned resid norm 3.199383680271e-09 true resid norm 6.040136209062e-11 ||r(i)||/||b|| 4.160895648331e-07
112 KSP preconditioned resid norm 2.843128048355e-09 true resid norm 5.334187986598e-11 ||r(i)||/||b|| 3.674585938561e-07
113 KSP preconditioned resid norm 2.481571681153e-09 true resid norm 4.734372222782e-11 ||r(i)||/||b|| 3.261388170319e-07
114 KSP preconditioned resid norm 2.154178638363e-09 true resid norm 4.052168399609e-11 ||r(i)||/||b|| 2.791435371100e-07
115 KSP preconditioned resid norm 1.845229356536e-09 true resid norm 3.437430800692e-11 ||r(i)||/||b|| 2.367958331565e-07
116 KSP preconditioned resid norm 1.579340935429e-09 true resid norm 2.953099604151e-11 ||r(i)||/||b|| 2.034314933754e-07
117 KSP preconditioned resid norm 1.329184519435e-09 true resid norm 2.474847870647e-11 ||r(i)||/||b|| 1.704859522838e-07
118 KSP preconditioned resid norm 1.106492278970e-09 true resid norm 2.032516618157e-11 ||r(i)||/||b|| 1.400148814353e-07
119 KSP preconditioned resid norm 9.310945737255e-10 true resid norm 1.751690022046e-11 ||r(i)||/||b|| 1.206694540931e-07
iter =  15, Function value: -4.34176,  Residual: 0.000132906
  0 KSP preconditioned resid norm 4.184974371826e-03 true resid norm 6.803884023334e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.909035304799e-03 true resid norm 4.421910060409e-05 ||r(i)||/||b|| 6.499096758917e-01
  2 KSP preconditioned resid norm 1.410286720438e-03 true resid norm 2.770041945675e-05 ||r(i)||/||b|| 4.071265671454e-01
  3 KSP preconditioned resid norm 1.008004610115e-03 true resid norm 2.224280469591e-05 ||r(i)||/||b|| 3.269133427265e-01
  4 KSP preconditioned resid norm 7.938281142422e-04 true resid norm 1.629208423665e-05 ||r(i)||/||b|| 2.394527034966e-01
  5 KSP preconditioned resid norm 6.489401150198e-04 true resid norm 1.372908449974e-05 ||r(i)||/||b|| 2.017830470457e-01
  6 KSP preconditioned resid norm 5.236781096777e-04 true resid norm 1.100680935596e-05 ||r(i)||/||b|| 1.617724423023e-01
  7 KSP preconditioned resid norm 4.629183855892e-04 true resid norm 9.512571722139e-06 ||r(i)||/||b|| 1.398109034416e-01
  8 KSP preconditioned resid norm 3.901536265055e-04 true resid norm 7.791569923851e-06 ||r(i)||/||b|| 1.145165011210e-01
  9 KSP preconditioned resid norm 3.528646412086e-04 true resid norm 7.034996184748e-06 ||r(i)||/||b|| 1.033967680904e-01
 10 KSP preconditioned resid norm 3.150964219564e-04 true resid norm 6.194294701855e-06 ||r(i)||/||b|| 9.104056860187e-02
 11 KSP preconditioned resid norm 2.853773453948e-04 true resid norm 5.627815482687e-06 ||r(i)||/||b|| 8.271474739114e-02
 12 KSP preconditioned resid norm 2.499333377964e-04 true resid norm 4.699848644376e-06 ||r(i)||/||b|| 6.907596643708e-02
 13 KSP preconditioned resid norm 2.256272286909e-04 true resid norm 4.225838656812e-06 ||r(i)||/||b|| 6.210921059676e-02
 14 KSP preconditioned resid norm 2.060598855007e-04 true resid norm 3.863848741708e-06 ||r(i)||/||b|| 5.678886836484e-02
 15 KSP preconditioned resid norm 1.885875723485e-04 true resid norm 3.522314112040e-06 ||r(i)||/||b|| 5.176916743379e-02
 16 KSP preconditioned resid norm 1.655818267727e-04 true resid norm 3.065790916930e-06 ||r(i)||/||b|| 4.505942350599e-02
 17 KSP preconditioned resid norm 1.417619476339e-04 true resid norm 2.529870879701e-06 ||r(i)||/||b|| 3.718274548809e-02
 18 KSP preconditioned resid norm 1.317367351147e-04 true resid norm 2.341398436036e-06 ||r(i)||/||b|| 3.441267411387e-02
 19 KSP preconditioned resid norm 1.250171127939e-04 true resid norm 2.157229747952e-06 ||r(i)||/||b|| 3.170585713327e-02
 20 KSP preconditioned resid norm 1.244896994340e-04 true resid norm 2.172918599071e-06 ||r(i)||/||b|| 3.193644382559e-02
 21 KSP preconditioned resid norm 1.208592437155e-04 true resid norm 2.088406096862e-06 ||r(i)||/||b|| 3.069432238557e-02
 22 KSP preconditioned resid norm 1.164840982643e-04 true resid norm 2.084464196558e-06 ||r(i)||/||b|| 3.063638635534e-02
 23 KSP preconditioned resid norm 1.062000593035e-04 true resid norm 1.896098784878e-06 ||r(i)||/||b|| 2.786788808238e-02
 24 KSP preconditioned resid norm 9.387876516150e-05 true resid norm 1.750226909857e-06 ||r(i)||/||b|| 2.572393803091e-02
 25 KSP preconditioned resid norm 7.960756820736e-05 true resid norm 1.459699389267e-06 ||r(i)||/||b|| 2.145391344504e-02
 26 KSP preconditioned resid norm 6.676507565897e-05 true resid norm 1.213061564223e-06 ||r(i)||/||b|| 1.782895710837e-02
 27 KSP preconditioned resid norm 5.519538091414e-05 true resid norm 1.032303015773e-06 ||r(i)||/||b|| 1.517226061221e-02
 28 KSP preconditioned resid norm 4.477950037418e-05 true resid norm 8.477604156264e-07 ||r(i)||/||b|| 1.245994806377e-02
 29 KSP preconditioned resid norm 3.777479171437e-05 true resid norm 7.287554508874e-07 ||r(i)||/||b|| 1.071087408880e-02
 30 KSP preconditioned resid norm 3.288573818592e-05 true resid norm 6.286997561128e-07 ||r(i)||/||b|| 9.240306771201e-03
 31 KSP preconditioned resid norm 2.884987161402e-05 true resid norm 5.565523793358e-07 ||r(i)||/||b|| 8.179921606939e-03
 32 KSP preconditioned resid norm 2.487502497872e-05 true resid norm 4.752295913598e-07 ||r(i)||/||b|| 6.984680951792e-03
 33 KSP preconditioned resid norm 2.241282724515e-05 true resid norm 4.231177639454e-07 ||r(i)||/||b|| 6.218768022710e-03
 34 KSP preconditioned resid norm 1.989521041243e-05 true resid norm 3.721861038361e-07 ||r(i)||/||b|| 5.470200587778e-03
 35 KSP preconditioned resid norm 1.750966015249e-05 true resid norm 3.320144336208e-07 ||r(i)||/||b|| 4.879777969203e-03
 36 KSP preconditioned resid norm 1.495638574718e-05 true resid norm 2.857075118775e-07 ||r(i)||/||b|| 4.199182568335e-03
 37 KSP preconditioned resid norm 1.297573037965e-05 true resid norm 2.495752278564e-07 ||r(i)||/||b|| 3.668128777630e-03
 38 KSP preconditioned resid norm 1.147473705218e-05 true resid norm 2.136969489685e-07 ||r(i)||/||b|| 3.140808224180e-03
 39 KSP preconditioned resid norm 1.020642110610e-05 true resid norm 1.954746615151e-07 ||r(i)||/||b|| 2.872986383141e-03
 40 KSP preconditioned resid norm 9.118157290403e-06 true resid norm 1.737580773760e-07 ||r(i)||/||b|| 2.553807160441e-03
 41 KSP preconditioned resid norm 8.045943242362e-06 true resid norm 1.561082913863e-07 ||r(i)||/||b|| 2.294399652477e-03
 42 KSP preconditioned resid norm 7.260370430295e-06 true resid norm 1.413341016330e-07 ||r(i)||/||b|| 2.077256184090e-03
 43 KSP preconditioned resid norm 6.617138252750e-06 true resid norm 1.291520606641e-07 ||r(i)||/||b|| 1.898210789914e-03
 44 KSP preconditioned resid norm 6.035956559514e-06 true resid norm 1.161705582936e-07 ||r(i)||/||b|| 1.707415321824e-03
 45 KSP preconditioned resid norm 5.319598605023e-06 true resid norm 1.049006659833e-07 ||r(i)||/||b|| 1.541776221105e-03
 46 KSP preconditioned resid norm 4.769610802394e-06 true resid norm 9.361906760439e-08 ||r(i)||/||b|| 1.375965070588e-03
 47 KSP preconditioned resid norm 4.333070577183e-06 true resid norm 8.458629671312e-08 ||r(i)||/||b|| 1.243206033833e-03
 48 KSP preconditioned resid norm 4.030245411709e-06 true resid norm 7.828168401483e-08 ||r(i)||/||b|| 1.150544067864e-03
 49 KSP preconditioned resid norm 3.655050984968e-06 true resid norm 7.115523707764e-08 ||r(i)||/||b|| 1.045803203488e-03
 50 KSP preconditioned resid norm 3.154830867310e-06 true resid norm 6.162004549812e-08 ||r(i)||/||b|| 9.056598449767e-04
 51 KSP preconditioned resid norm 2.666362592644e-06 true resid norm 5.362426030166e-08 ||r(i)||/||b|| 7.881418924508e-04
 52 KSP preconditioned resid norm 2.215975990319e-06 true resid norm 4.334364872589e-08 ||r(i)||/||b|| 6.370427329044e-04
 53 KSP preconditioned resid norm 1.841960594553e-06 true resid norm 3.623976658411e-08 ||r(i)||/||b|| 5.326335143254e-04
 54 KSP preconditioned resid norm 1.545998283796e-06 true resid norm 2.993595801864e-08 ||r(i)||/||b|| 4.399833670881e-04
 55 KSP preconditioned resid norm 1.330945823688e-06 true resid norm 2.586309114755e-08 ||r(i)||/||b|| 3.801224573914e-04
 56 KSP preconditioned resid norm 1.124635573916e-06 true resid norm 2.177982200721e-08 ||r(i)||/||b|| 3.201086604727e-04
 57 KSP preconditioned resid norm 9.368296003785e-07 true resid norm 1.809097006799e-08 ||r(i)||/||b|| 2.658918054150e-04
 58 KSP preconditioned resid norm 7.819211276208e-07 true resid norm 1.494801748347e-08 ||r(i)||/||b|| 2.196982992686e-04
 59 KSP preconditioned resid norm 6.589852767022e-07 true resid norm 1.248690859789e-08 ||r(i)||/||b|| 1.835261823256e-04
 60 KSP preconditioned resid norm 5.493735641088e-07 true resid norm 1.048671854207e-08 ||r(i)||/||b|| 1.541284140957e-04
 61 KSP preconditioned resid norm 4.613027107581e-07 true resid norm 8.721128826355e-09 ||r(i)||/||b|| 1.281786814185e-04
 62 KSP preconditioned resid norm 3.981989460219e-07 true resid norm 7.432836170761e-09 ||r(i)||/||b|| 1.092440162894e-04
 63 KSP preconditioned resid norm 3.585632758135e-07 true resid norm 6.709387931420e-09 ||r(i)||/||b|| 9.861114487564e-05
 64 KSP preconditioned resid norm 3.277163893322e-07 true resid norm 6.078868463693e-09 ||r(i)||/||b|| 8.934409291584e-05
 65 KSP preconditioned resid norm 3.021216979753e-07 true resid norm 5.618874654401e-09 ||r(i)||/||b|| 8.258333967968e-05
 66 KSP preconditioned resid norm 2.819087317031e-07 true resid norm 5.346565407866e-09 ||r(i)||/||b|| 7.858107794798e-05
 67 KSP preconditioned resid norm 2.556586149718e-07 true resid norm 4.881284017489e-09 ||r(i)||/||b|| 7.174261055523e-05
 68 KSP preconditioned resid norm 2.359709791466e-07 true resid norm 4.436917491675e-09 ||r(i)||/||b|| 6.521153912175e-05
 69 KSP preconditioned resid norm 2.169660344514e-07 true resid norm 4.086449825210e-09 ||r(i)||/||b|| 6.006054499454e-05
 70 KSP preconditioned resid norm 2.028546042168e-07 true resid norm 3.851462023052e-09 ||r(i)||/||b|| 5.660681472294e-05
 71 KSP preconditioned resid norm 1.900273187442e-07 true resid norm 3.618086490662e-09 ||r(i)||/||b|| 5.317678076601e-05
 72 KSP preconditioned resid norm 1.698668076313e-07 true resid norm 3.253473206554e-09 ||r(i)||/||b|| 4.781788160109e-05
 73 KSP preconditioned resid norm 1.482619680639e-07 true resid norm 2.832266831450e-09 ||r(i)||/||b|| 4.162720619189e-05
 74 KSP preconditioned resid norm 1.284671242065e-07 true resid norm 2.458840395320e-09 ||r(i)||/||b|| 3.613877583580e-05
 75 KSP preconditioned resid norm 1.135319624760e-07 true resid norm 2.139101882873e-09 ||r(i)||/||b|| 3.143942306390e-05
 76 KSP preconditioned resid norm 9.867102804581e-08 true resid norm 1.857318221486e-09 ||r(i)||/||b|| 2.729791123887e-05
 77 KSP preconditioned resid norm 8.652081964705e-08 true resid norm 1.636466760076e-09 ||r(i)||/||b|| 2.405194965792e-05
 78 KSP preconditioned resid norm 7.519859727102e-08 true resid norm 1.401827234127e-09 ||r(i)||/||b|| 2.060333817154e-05
 79 KSP preconditioned resid norm 6.594544882648e-08 true resid norm 1.224311313954e-09 ||r(i)||/||b|| 1.799430016377e-05
 80 KSP preconditioned resid norm 5.688343999129e-08 true resid norm 1.087343970500e-09 ||r(i)||/||b|| 1.598122435320e-05
 81 KSP preconditioned resid norm 4.949192930707e-08 true resid norm 9.483991414969e-10 ||r(i)||/||b|| 1.393908447358e-05
 82 KSP preconditioned resid norm 4.145398902615e-08 true resid norm 7.881320226820e-10 ||r(i)||/||b|| 1.158356050719e-05
 83 KSP preconditioned resid norm 3.529729473579e-08 true resid norm 6.721775235085e-10 ||r(i)||/||b|| 9.879320711571e-06
 84 KSP preconditioned resid norm 3.066150334152e-08 true resid norm 5.853358143744e-10 ||r(i)||/||b|| 8.602965782000e-06
 85 KSP preconditioned resid norm 2.655724121203e-08 true resid norm 5.052377953892e-10 ||r(i)||/||b|| 7.425726153717e-06
 86 KSP preconditioned resid norm 2.275405968218e-08 true resid norm 4.323599111733e-10 ||r(i)||/||b|| 6.354604365544e-06
 87 KSP preconditioned resid norm 1.911684628647e-08 true resid norm 3.688573065257e-10 ||r(i)||/||b|| 5.421275631106e-06
 88 KSP preconditioned resid norm 1.591708011714e-08 true resid norm 3.110085392262e-10 ||r(i)||/||b|| 4.571044100100e-06
 89 KSP preconditioned resid norm 1.363734900317e-08 true resid norm 2.635078588594e-10 ||r(i)||/||b|| 3.872903446850e-06
 90 KSP preconditioned resid norm 1.169743685146e-08 true resid norm 2.282391964111e-10 ||r(i)||/||b|| 3.354542723367e-06
 91 KSP preconditioned resid norm 1.011738528389e-08 true resid norm 1.944406032839e-10 ||r(i)||/||b|| 2.857788325272e-06
 92 KSP preconditioned resid norm 9.045580777192e-09 true resid norm 1.742874143555e-10 ||r(i)||/||b|| 2.561587084050e-06
 93 KSP preconditioned resid norm 8.198456370824e-09 true resid norm 1.577567760410e-10 ||r(i)||/||b|| 2.318628234991e-06
 94 KSP preconditioned resid norm 7.534008324723e-09 true resid norm 1.447951392261e-10 ||r(i)||/||b|| 2.128124740655e-06
 95 KSP preconditioned resid norm 6.869722600689e-09 true resid norm 1.310553425049e-10 ||r(i)||/||b|| 1.926184250870e-06
 96 KSP preconditioned resid norm 6.298568401042e-09 true resid norm 1.193070242101e-10 ||r(i)||/||b|| 1.753513490250e-06
 97 KSP preconditioned resid norm 5.781741496868e-09 true resid norm 1.096127971253e-10 ||r(i)||/||b|| 1.611032709397e-06
 98 KSP preconditioned resid norm 5.264347910590e-09 true resid norm 1.001921664598e-10 ||r(i)||/||b|| 1.472573108481e-06
 99 KSP preconditioned resid norm 4.648653103156e-09 true resid norm 8.775901527616e-11 ||r(i)||/||b|| 1.289837025076e-06
100 KSP preconditioned resid norm 4.080375720692e-09 true resid norm 7.813818842892e-11 ||r(i)||/||b|| 1.148435043292e-06
101 KSP preconditioned resid norm 3.665075743628e-09 true resid norm 7.000076408058e-11 ||r(i)||/||b|| 1.028835351110e-06
102 KSP preconditioned resid norm 3.282174695000e-09 true resid norm 6.237321838018e-11 ||r(i)||/||b|| 9.167295939536e-07
103 KSP preconditioned resid norm 2.951790323535e-09 true resid norm 5.580253758952e-11 ||r(i)||/||b|| 8.201570955376e-07
104 KSP preconditioned resid norm 2.598806947428e-09 true resid norm 4.968129595019e-11 ||r(i)||/||b|| 7.301902234049e-07
105 KSP preconditioned resid norm 2.301744624784e-09 true resid norm 4.468414467404e-11 ||r(i)||/||b|| 6.567446552703e-07
106 KSP preconditioned resid norm 2.034807118272e-09 true resid norm 3.860788741149e-11 ||r(i)||/||b|| 5.674389404506e-07
107 KSP preconditioned resid norm 1.806296996779e-09 true resid norm 3.514719026996e-11 ||r(i)||/||b|| 5.165753876671e-07
108 KSP preconditioned resid norm 1.617423909628e-09 true resid norm 3.139376374909e-11 ||r(i)||/||b|| 4.614094485065e-07
109 KSP preconditioned resid norm 1.455184820634e-09 true resid norm 2.761762783653e-11 ||r(i)||/||b|| 4.059097383468e-07
110 KSP preconditioned resid norm 1.286527268944e-09 true resid norm 2.437798520957e-11 ||r(i)||/||b|| 3.582951315156e-07
111 KSP preconditioned resid norm 1.132013373913e-09 true resid norm 2.142324517339e-11 ||r(i)||/||b|| 3.148678769350e-07
112 KSP preconditioned resid norm 1.007120599718e-09 true resid norm 1.896640529911e-11 ||r(i)||/||b|| 2.787585037320e-07
113 KSP preconditioned resid norm 9.135548397455e-10 true resid norm 1.725682078768e-11 ||r(i)||/||b|| 2.536319068417e-07
114 KSP preconditioned resid norm 8.269925799269e-10 true resid norm 1.572475016337e-11 ||r(i)||/||b|| 2.311143180783e-07
115 KSP preconditioned resid norm 7.284793597065e-10 true resid norm 1.389669930514e-11 ||r(i)||/||b|| 2.042465635434e-07
116 KSP preconditioned resid norm 6.390792406440e-10 true resid norm 1.218201275469e-11 ||r(i)||/||b|| 1.790449794986e-07
117 KSP preconditioned resid norm 5.545720352670e-10 true resid norm 1.053567280188e-11 ||r(i)||/||b|| 1.548479187146e-07
118 KSP preconditioned resid norm 4.773577604600e-10 true resid norm 8.976298498111e-12 ||r(i)||/||b|| 1.319290344651e-07
119 KSP preconditioned resid norm 4.030796277093e-10 true resid norm 7.596402318624e-12 ||r(i)||/||b|| 1.116480276938e-07
iter =  16, Function value: -4.34176,  Residual: 5.34513e-05
  0 KSP preconditioned resid norm 1.561324840663e-03 true resid norm 2.660200780355e-05 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.048936387430e-04 true resid norm 1.578633615260e-05 ||r(i)||/||b|| 5.934264913074e-01
  2 KSP preconditioned resid norm 4.677813759892e-04 true resid norm 1.011607470460e-05 ||r(i)||/||b|| 3.802748566690e-01
  3 KSP preconditioned resid norm 3.349461302649e-04 true resid norm 6.860491799737e-06 ||r(i)||/||b|| 2.578937593884e-01
  4 KSP preconditioned resid norm 2.570561228012e-04 true resid norm 5.331776315216e-06 ||r(i)||/||b|| 2.004275900748e-01
  5 KSP preconditioned resid norm 2.075056982063e-04 true resid norm 4.227664774320e-06 ||r(i)||/||b|| 1.589227702488e-01
  6 KSP preconditioned resid norm 1.629225285298e-04 true resid norm 3.354157307710e-06 ||r(i)||/||b|| 1.260866222008e-01
  7 KSP preconditioned resid norm 1.352368640323e-04 true resid norm 2.772304738287e-06 ||r(i)||/||b|| 1.042141164216e-01
  8 KSP preconditioned resid norm 1.144760500728e-04 true resid norm 2.355059562259e-06 ||r(i)||/||b|| 8.852939145235e-02
  9 KSP preconditioned resid norm 9.959050251124e-05 true resid norm 1.983855992617e-06 ||r(i)||/||b|| 7.457542330139e-02
 10 KSP preconditioned resid norm 8.422927864444e-05 true resid norm 1.677204235283e-06 ||r(i)||/||b|| 6.304803185040e-02
 11 KSP preconditioned resid norm 7.693460290776e-05 true resid norm 1.534842973563e-06 ||r(i)||/||b|| 5.769650865820e-02
 12 KSP preconditioned resid norm 6.860440772165e-05 true resid norm 1.362647096948e-06 ||r(i)||/||b|| 5.122346805588e-02
 13 KSP preconditioned resid norm 6.088013236106e-05 true resid norm 1.180112977271e-06 ||r(i)||/||b|| 4.436180103341e-02
 14 KSP preconditioned resid norm 5.364467284846e-05 true resid norm 9.989759867468e-07 ||r(i)||/||b|| 3.755265369907e-02
 15 KSP preconditioned resid norm 4.945953066028e-05 true resid norm 9.318887690987e-07 ||r(i)||/||b|| 3.503076820293e-02
 16 KSP preconditioned resid norm 4.567053678537e-05 true resid norm 8.791485915380e-07 ||r(i)||/||b|| 3.304820440736e-02
 17 KSP preconditioned resid norm 3.992094719685e-05 true resid norm 7.451586872595e-07 ||r(i)||/||b|| 2.801137014778e-02
 18 KSP preconditioned resid norm 3.459848303995e-05 true resid norm 6.272385796372e-07 ||r(i)||/||b|| 2.357861798512e-02
 19 KSP preconditioned resid norm 3.101898135172e-05 true resid norm 5.580990563862e-07 ||r(i)||/||b|| 2.097958396628e-02
 20 KSP preconditioned resid norm 2.915580777117e-05 true resid norm 5.216283144212e-07 ||r(i)||/||b|| 1.960860692445e-02
 21 KSP preconditioned resid norm 2.808749492082e-05 true resid norm 4.981110962931e-07 ||r(i)||/||b|| 1.872456770825e-02
 22 KSP preconditioned resid norm 2.786680137401e-05 true resid norm 4.974295517257e-07 ||r(i)||/||b|| 1.869894766587e-02
 23 KSP preconditioned resid norm 2.710629487120e-05 true resid norm 4.825047168003e-07 ||r(i)||/||b|| 1.813790599429e-02
 24 KSP preconditioned resid norm 2.500581881107e-05 true resid norm 4.577422789854e-07 ||r(i)||/||b|| 1.720705754113e-02
 25 KSP preconditioned resid norm 2.260061487826e-05 true resid norm 4.188617987637e-07 ||r(i)||/||b|| 1.574549567299e-02
 26 KSP preconditioned resid norm 1.929612483226e-05 true resid norm 3.660432712260e-07 ||r(i)||/||b|| 1.375998661188e-02
 27 KSP preconditioned resid norm 1.623688448295e-05 true resid norm 3.021271958851e-07 ||r(i)||/||b|| 1.135730799405e-02
 28 KSP preconditioned resid norm 1.331585368613e-05 true resid norm 2.455544224915e-07 ||r(i)||/||b|| 9.230672523098e-03
 29 KSP preconditioned resid norm 1.114790248562e-05 true resid norm 2.098967231939e-07 ||r(i)||/||b|| 7.890258688136e-03
 30 KSP preconditioned resid norm 9.274970065062e-06 true resid norm 1.804862041474e-07 ||r(i)||/||b|| 6.784683527658e-03
 31 KSP preconditioned resid norm 7.968722635920e-06 true resid norm 1.560865358038e-07 ||r(i)||/||b|| 5.867471995214e-03
 32 KSP preconditioned resid norm 6.885370550083e-06 true resid norm 1.307595730573e-07 ||r(i)||/||b|| 4.915402402063e-03
 33 KSP preconditioned resid norm 6.086771528549e-06 true resid norm 1.191308381011e-07 ||r(i)||/||b|| 4.478264910711e-03
 34 KSP preconditioned resid norm 5.376234236609e-06 true resid norm 1.031073484130e-07 ||r(i)||/||b|| 3.875923545864e-03
 35 KSP preconditioned resid norm 4.774331381604e-06 true resid norm 9.187204916560e-08 ||r(i)||/||b|| 3.453575754283e-03
 36 KSP preconditioned resid norm 4.251652431386e-06 true resid norm 8.219615368990e-08 ||r(i)||/||b|| 3.089847739948e-03
 37 KSP preconditioned resid norm 3.754096032677e-06 true resid norm 7.327548509574e-08 ||r(i)||/||b|| 2.754509570738e-03
 38 KSP preconditioned resid norm 3.282845775393e-06 true resid norm 6.335411108754e-08 ||r(i)||/||b|| 2.381553736672e-03
 39 KSP preconditioned resid norm 2.901002406965e-06 true resid norm 5.510372185205e-08 ||r(i)||/||b|| 2.071412137722e-03
 40 KSP preconditioned resid norm 2.617593071896e-06 true resid norm 5.061361632971e-08 ||r(i)||/||b|| 1.902623918595e-03
 41 KSP preconditioned resid norm 2.320427489884e-06 true resid norm 4.538140258101e-08 ||r(i)||/||b|| 1.705938999647e-03
 42 KSP preconditioned resid norm 2.037595475665e-06 true resid norm 3.990817038247e-08 ||r(i)||/||b|| 1.500193920593e-03
 43 KSP preconditioned resid norm 1.817221564221e-06 true resid norm 3.529441746721e-08 ||r(i)||/||b|| 1.326757654078e-03
 44 KSP preconditioned resid norm 1.676309784598e-06 true resid norm 3.250249719393e-08 ||r(i)||/||b|| 1.221806167186e-03
 45 KSP preconditioned resid norm 1.529076531087e-06 true resid norm 2.877556305180e-08 ||r(i)||/||b|| 1.081706436006e-03
 46 KSP preconditioned resid norm 1.348931626786e-06 true resid norm 2.619489739647e-08 ||r(i)||/||b|| 9.846962526253e-04
 47 KSP preconditioned resid norm 1.207929026888e-06 true resid norm 2.319748597365e-08 ||r(i)||/||b|| 8.720201176148e-04
 48 KSP preconditioned resid norm 1.095664618689e-06 true resid norm 2.131510440594e-08 ||r(i)||/||b|| 8.012592343911e-04
 49 KSP preconditioned resid norm 1.008059783584e-06 true resid norm 1.960225181266e-08 ||r(i)||/||b|| 7.368711398560e-04
 50 KSP preconditioned resid norm 9.153990043497e-07 true resid norm 1.761810128985e-08 ||r(i)||/||b|| 6.622846448264e-04
 51 KSP preconditioned resid norm 8.149696059901e-07 true resid norm 1.585760838986e-08 ||r(i)||/||b|| 5.961056964934e-04
 52 KSP preconditioned resid norm 6.940691883657e-07 true resid norm 1.354810327414e-08 ||r(i)||/||b|| 5.092887489615e-04
 53 KSP preconditioned resid norm 5.773135403959e-07 true resid norm 1.138448834636e-08 ||r(i)||/||b|| 4.279559810084e-04
 54 KSP preconditioned resid norm 4.820444531341e-07 true resid norm 9.403999421223e-09 ||r(i)||/||b|| 3.535071296373e-04
 55 KSP preconditioned resid norm 4.086017702491e-07 true resid norm 8.032113070734e-09 ||r(i)||/||b|| 3.019363474384e-04
 56 KSP preconditioned resid norm 3.407046139996e-07 true resid norm 6.611662152781e-09 ||r(i)||/||b|| 2.485399674192e-04
 57 KSP preconditioned resid norm 2.906362091136e-07 true resid norm 5.720606082563e-09 ||r(i)||/||b|| 2.150441472241e-04
 58 KSP preconditioned resid norm 2.400667370506e-07 true resid norm 4.713077728873e-09 ||r(i)||/||b|| 1.771700002375e-04
 59 KSP preconditioned resid norm 1.964778230108e-07 true resid norm 3.852392636516e-09 ||r(i)||/||b|| 1.448158599518e-04
 60 KSP preconditioned resid norm 1.606375450174e-07 true resid norm 3.138680713902e-09 ||r(i)||/||b|| 1.179866097732e-04
 61 KSP preconditioned resid norm 1.335533303153e-07 true resid norm 2.585155854801e-09 ||r(i)||/||b|| 9.717897513193e-05
 62 KSP preconditioned resid norm 1.112340633920e-07 true resid norm 2.129307715445e-09 ||r(i)||/||b|| 8.004312047305e-05
 63 KSP preconditioned resid norm 9.506736723151e-08 true resid norm 1.821407434001e-09 ||r(i)||/||b|| 6.846879556805e-05
 64 KSP preconditioned resid norm 8.319583504788e-08 true resid norm 1.592684642946e-09 ||r(i)||/||b|| 5.987084338549e-05
 65 KSP preconditioned resid norm 7.465068579271e-08 true resid norm 1.448430692019e-09 ||r(i)||/||b|| 5.444817183405e-05
 66 KSP preconditioned resid norm 6.887948059819e-08 true resid norm 1.328161228112e-09 ||r(i)||/||b|| 4.992710467269e-05
 67 KSP preconditioned resid norm 6.423940855092e-08 true resid norm 1.248004241221e-09 ||r(i)||/||b|| 4.691391155272e-05
 68 KSP preconditioned resid norm 5.992744126375e-08 true resid norm 1.167343987062e-09 ||r(i)||/||b|| 4.388180003865e-05
 69 KSP preconditioned resid norm 5.501602840286e-08 true resid norm 1.064833594175e-09 ||r(i)||/||b|| 4.002831673604e-05
 70 KSP preconditioned resid norm 5.010711019057e-08 true resid norm 9.794548550182e-10 ||r(i)||/||b|| 3.681883195626e-05
 71 KSP preconditioned resid norm 4.776041396265e-08 true resid norm 9.227166682458e-10 ||r(i)||/||b|| 3.468597840658e-05
 72 KSP preconditioned resid norm 4.543991698804e-08 true resid norm 8.763428120478e-10 ||r(i)||/||b|| 3.294273193660e-05
 73 KSP preconditioned resid norm 4.120871041596e-08 true resid norm 8.028250538297e-10 ||r(i)||/||b|| 3.017911504118e-05
 74 KSP preconditioned resid norm 3.659843232363e-08 true resid norm 6.983227758128e-10 ||r(i)||/||b|| 2.625075449078e-05
 75 KSP preconditioned resid norm 3.167510868808e-08 true resid norm 6.136642776656e-10 ||r(i)||/||b|| 2.306834439706e-05
 76 KSP preconditioned resid norm 2.747465018866e-08 true resid norm 5.202686931948e-10 ||r(i)||/||b|| 1.955749720235e-05
 77 KSP preconditioned resid norm 2.386564352409e-08 true resid norm 4.503774477338e-10 ||r(i)||/||b|| 1.693020508300e-05
 78 KSP preconditioned resid norm 2.064672894856e-08 true resid norm 3.836468907700e-10 ||r(i)||/||b|| 1.442172687126e-05
 79 KSP preconditioned resid norm 1.827648663750e-08 true resid norm 3.398821677040e-10 ||r(i)||/||b|| 1.277656070977e-05
 80 KSP preconditioned resid norm 1.581634393217e-08 true resid norm 2.921916446312e-10 ||r(i)||/||b|| 1.098381922105e-05
 81 KSP preconditioned resid norm 1.354945335223e-08 true resid norm 2.596243816388e-10 ||r(i)||/||b|| 9.759578433178e-06
 82 KSP preconditioned resid norm 1.140214070690e-08 true resid norm 2.191406318159e-10 ||r(i)||/||b|| 8.237747820924e-06
 83 KSP preconditioned resid norm 9.543613931863e-09 true resid norm 1.855671427701e-10 ||r(i)||/||b|| 6.975681841026e-06
 84 KSP preconditioned resid norm 8.128878742046e-09 true resid norm 1.588745627828e-10 ||r(i)||/||b|| 5.972277128706e-06
 85 KSP preconditioned resid norm 7.014051844116e-09 true resid norm 1.381778737440e-10 ||r(i)||/||b|| 5.194264837618e-06
 86 KSP preconditioned resid norm 6.059328895169e-09 true resid norm 1.177300547679e-10 ||r(i)||/||b|| 4.425607857773e-06
 87 KSP preconditioned resid norm 5.166508285590e-09 true resid norm 1.005845420639e-10 ||r(i)||/||b|| 3.781088360197e-06
 88 KSP preconditioned resid norm 4.387690775020e-09 true resid norm 8.599449196959e-11 ||r(i)||/||b|| 3.232631634598e-06
 89 KSP preconditioned resid norm 3.655258457250e-09 true resid norm 7.253554846849e-11 ||r(i)||/||b|| 2.726694503819e-06
 90 KSP preconditioned resid norm 3.099633193826e-09 true resid norm 6.034227115756e-11 ||r(i)||/||b|| 2.268335217521e-06
 91 KSP preconditioned resid norm 2.610773865691e-09 true resid norm 5.110436626858e-11 ||r(i)||/||b|| 1.921071771949e-06
 92 KSP preconditioned resid norm 2.267634720276e-09 true resid norm 4.387203588802e-11 ||r(i)||/||b|| 1.649200173611e-06
 93 KSP preconditioned resid norm 1.956127287416e-09 true resid norm 3.785527103025e-11 ||r(i)||/||b|| 1.423023078175e-06
 94 KSP preconditioned resid norm 1.715093351412e-09 true resid norm 3.284424691407e-11 ||r(i)||/||b|| 1.234652931335e-06
 95 KSP preconditioned resid norm 1.531192450182e-09 true resid norm 2.975862820569e-11 ||r(i)||/||b|| 1.118660983240e-06
 96 KSP preconditioned resid norm 1.391641029732e-09 true resid norm 2.715114324938e-11 ||r(i)||/||b|| 1.020642631559e-06
 97 KSP preconditioned resid norm 1.272686827099e-09 true resid norm 2.472459620436e-11 ||r(i)||/||b|| 9.294259435958e-07
 98 KSP preconditioned resid norm 1.167740077625e-09 true resid norm 2.255914301058e-11 ||r(i)||/||b|| 8.480240731139e-07
 99 KSP preconditioned resid norm 1.098615998731e-09 true resid norm 2.105037633797e-11 ||r(i)||/||b|| 7.913078025319e-07
100 KSP preconditioned resid norm 1.022252639693e-09 true resid norm 1.949118784482e-11 ||r(i)||/||b|| 7.326961178554e-07
101 KSP preconditioned resid norm 9.330835672187e-10 true resid norm 1.797775372303e-11 ||r(i)||/||b|| 6.758043925025e-07
102 KSP preconditioned resid norm 8.405271305455e-10 true resid norm 1.602150742382e-11 ||r(i)||/||b|| 6.022668492594e-07
103 KSP preconditioned resid norm 7.693015606366e-10 true resid norm 1.481260570458e-11 ||r(i)||/||b|| 5.568228463793e-07
104 KSP preconditioned resid norm 7.089135349703e-10 true resid norm 1.360308068205e-11 ||r(i)||/||b|| 5.113554128133e-07
105 KSP preconditioned resid norm 6.369665039887e-10 true resid norm 1.231864451401e-11 ||r(i)||/||b|| 4.630719833245e-07
106 KSP preconditioned resid norm 5.625724507742e-10 true resid norm 1.075145623094e-11 ||r(i)||/||b|| 4.041595773649e-07
107 KSP preconditioned resid norm 4.966400051561e-10 true resid norm 9.565011941533e-12 ||r(i)||/||b|| 3.595597750428e-07
108 KSP preconditioned resid norm 4.253188430285e-10 true resid norm 8.344268178404e-12 ||r(i)||/||b|| 3.136706161438e-07
109 KSP preconditioned resid norm 3.629681099996e-10 true resid norm 7.179404213826e-12 ||r(i)||/||b|| 2.698820429963e-07
110 KSP preconditioned resid norm 3.129702631230e-10 true resid norm 6.200262401090e-12 ||r(i)||/||b|| 2.330749786586e-07
111 KSP preconditioned resid norm 2.691833359028e-10 true resid norm 5.301396390392e-12 ||r(i)||/||b|| 1.992855738387e-07
112 KSP preconditioned resid norm 2.307988274778e-10 true resid norm 4.508688022795e-12 ||r(i)||/||b|| 1.694867566422e-07
113 KSP preconditioned resid norm 1.980226754059e-10 true resid norm 3.881960091115e-12 ||r(i)||/||b|| 1.459273344998e-07
114 KSP preconditioned resid norm 1.749971597022e-10 true resid norm 3.411191729673e-12 ||r(i)||/||b|| 1.282306115712e-07
115 KSP preconditioned resid norm 1.561332641725e-10 true resid norm 3.067329156349e-12 ||r(i)||/||b|| 1.153044228466e-07
116 KSP preconditioned resid norm 1.412021310536e-10 true resid norm 2.774734164732e-12 ||r(i)||/||b|| 1.043054413495e-07
Linear solve converged due to CONVERGED_RTOL iterations 116
iter =  17, Function value: -4.34176,  Residual: 1.42828e-05
  0 KSP preconditioned resid norm 3.506421354743e-04 true resid norm 6.866903802372e-06 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.148453471671e-04 true resid norm 2.974227659087e-06 ||r(i)||/||b|| 4.331249926727e-01
  2 KSP preconditioned resid norm 7.740279764372e-05 true resid norm 1.569091650477e-06 ||r(i)||/||b|| 2.285006016737e-01
  3 KSP preconditioned resid norm 5.017379175425e-05 true resid norm 1.190764878678e-06 ||r(i)||/||b|| 1.734063725002e-01
  4 KSP preconditioned resid norm 3.946631334191e-05 true resid norm 7.901088194635e-07 ||r(i)||/||b|| 1.150604176500e-01
  5 KSP preconditioned resid norm 2.996754265342e-05 true resid norm 6.218835246865e-07 ||r(i)||/||b|| 9.056243433491e-02
  6 KSP preconditioned resid norm 2.402583892477e-05 true resid norm 5.028879805662e-07 ||r(i)||/||b|| 7.323358460220e-02
  7 KSP preconditioned resid norm 2.010542319539e-05 true resid norm 4.106621001309e-07 ||r(i)||/||b|| 5.980309495365e-02
  8 KSP preconditioned resid norm 1.607092351882e-05 true resid norm 3.346994281441e-07 ||r(i)||/||b|| 4.874095193070e-02
  9 KSP preconditioned resid norm 1.394459839076e-05 true resid norm 2.994883166534e-07 ||r(i)||/||b|| 4.361329724030e-02
 10 KSP preconditioned resid norm 1.189789758909e-05 true resid norm 2.423808523983e-07 ||r(i)||/||b|| 3.529696343125e-02
 11 KSP preconditioned resid norm 1.070270093520e-05 true resid norm 2.146177857799e-07 ||r(i)||/||b|| 3.125393801290e-02
 12 KSP preconditioned resid norm 9.679823126824e-06 true resid norm 1.968577010113e-07 ||r(i)||/||b|| 2.866760721815e-02
 13 KSP preconditioned resid norm 8.619730953303e-06 true resid norm 1.751690265659e-07 ||r(i)||/||b|| 2.550917147047e-02
 14 KSP preconditioned resid norm 7.544257093518e-06 true resid norm 1.420542616779e-07 ||r(i)||/||b|| 2.068679943191e-02
 15 KSP preconditioned resid norm 6.725951974399e-06 true resid norm 1.311804393651e-07 ||r(i)||/||b|| 1.910328776119e-02
 16 KSP preconditioned resid norm 6.216434849730e-06 true resid norm 1.145203305314e-07 ||r(i)||/||b|| 1.667714210469e-02
 17 KSP preconditioned resid norm 5.624323370535e-06 true resid norm 1.068332658698e-07 ||r(i)||/||b|| 1.555770532754e-02
 18 KSP preconditioned resid norm 4.900988330811e-06 true resid norm 9.253629477040e-08 ||r(i)||/||b|| 1.347569405857e-02
 19 KSP preconditioned resid norm 4.273589856202e-06 true resid norm 7.388110947532e-08 ||r(i)||/||b|| 1.075901331977e-02
 20 KSP preconditioned resid norm 3.886002205972e-06 true resid norm 6.864580353189e-08 ||r(i)||/||b|| 9.996616452990e-03
 21 KSP preconditioned resid norm 3.679075699028e-06 true resid norm 6.453103535462e-08 ||r(i)||/||b|| 9.397399062489e-03
 22 KSP preconditioned resid norm 3.617178136626e-06 true resid norm 6.416721242276e-08 ||r(i)||/||b|| 9.344416970075e-03
 23 KSP preconditioned resid norm 3.496519610076e-06 true resid norm 6.291510898136e-08 ||r(i)||/||b|| 9.162078105655e-03
 24 KSP preconditioned resid norm 3.345281133953e-06 true resid norm 6.188722171003e-08 ||r(i)||/||b|| 9.012390953934e-03
 25 KSP preconditioned resid norm 3.046253382855e-06 true resid norm 5.439128857245e-08 ||r(i)||/||b|| 7.920787903518e-03
 26 KSP preconditioned resid norm 2.702334306139e-06 true resid norm 4.957499609292e-08 ||r(i)||/||b|| 7.219410307712e-03
 27 KSP preconditioned resid norm 2.361537902551e-06 true resid norm 4.468527846082e-08 ||r(i)||/||b|| 6.507340097787e-03
 28 KSP preconditioned resid norm 2.003438894347e-06 true resid norm 3.688486181287e-08 ||r(i)||/||b|| 5.371396319856e-03
 29 KSP preconditioned resid norm 1.661301349571e-06 true resid norm 3.146571174066e-08 ||r(i)||/||b|| 4.582226960831e-03
 30 KSP preconditioned resid norm 1.379526632617e-06 true resid norm 2.664843800839e-08 ||r(i)||/||b|| 3.880706469076e-03
 31 KSP preconditioned resid norm 1.186806233711e-06 true resid norm 2.274055234170e-08 ||r(i)||/||b|| 3.311616559103e-03
 32 KSP preconditioned resid norm 1.022810145659e-06 true resid norm 1.954931692773e-08 ||r(i)||/||b|| 2.846889586683e-03
 33 KSP preconditioned resid norm 8.922936707517e-07 true resid norm 1.730978699270e-08 ||r(i)||/||b|| 2.520755713327e-03
 34 KSP preconditioned resid norm 7.797724917831e-07 true resid norm 1.479670859890e-08 ||r(i)||/||b|| 2.154786061484e-03
 35 KSP preconditioned resid norm 6.825303559638e-07 true resid norm 1.310713790278e-08 ||r(i)||/||b|| 1.908740573627e-03
 36 KSP preconditioned resid norm 5.851469468431e-07 true resid norm 1.112949840216e-08 ||r(i)||/||b|| 1.620744766850e-03
 37 KSP preconditioned resid norm 5.122135125008e-07 true resid norm 9.820958852439e-09 ||r(i)||/||b|| 1.430187335528e-03
 38 KSP preconditioned resid norm 4.478862947906e-07 true resid norm 8.663843341091e-09 ||r(i)||/||b|| 1.261681187102e-03
 39 KSP preconditioned resid norm 3.930900484540e-07 true resid norm 7.599691612469e-09 ||r(i)||/||b|| 1.106712986112e-03
 40 KSP preconditioned resid norm 3.467001015409e-07 true resid norm 6.629359149650e-09 ||r(i)||/||b|| 9.654073131708e-04
 41 KSP preconditioned resid norm 3.101302395094e-07 true resid norm 6.013234781554e-09 ||r(i)||/||b|| 8.756835619973e-04
 42 KSP preconditioned resid norm 2.825085809115e-07 true resid norm 5.559474403821e-09 ||r(i)||/||b|| 8.096042355945e-04
 43 KSP preconditioned resid norm 2.522834462687e-07 true resid norm 4.948410891306e-09 ||r(i)||/||b|| 7.206174767727e-04
 44 KSP preconditioned resid norm 2.274739360159e-07 true resid norm 4.497807586345e-09 ||r(i)||/||b|| 6.549979023721e-04
 45 KSP preconditioned resid norm 2.063492720153e-07 true resid norm 3.935715351826e-09 ||r(i)||/||b|| 5.731426367828e-04
 46 KSP preconditioned resid norm 1.849616593113e-07 true resid norm 3.589843093222e-09 ||r(i)||/||b|| 5.227746298094e-04
 47 KSP preconditioned resid norm 1.620298549053e-07 true resid norm 3.107284428181e-09 ||r(i)||/||b|| 4.525015229000e-04
 48 KSP preconditioned resid norm 1.432631476886e-07 true resid norm 2.782026323769e-09 ||r(i)||/||b|| 4.051354735461e-04
 49 KSP preconditioned resid norm 1.268737891052e-07 true resid norm 2.419065043674e-09 ||r(i)||/||b|| 3.522788600647e-04
 50 KSP preconditioned resid norm 1.125302459259e-07 true resid norm 2.206231992322e-09 ||r(i)||/||b|| 3.212848258570e-04
 51 KSP preconditioned resid norm 1.016708106543e-07 true resid norm 1.985632946068e-09 ||r(i)||/||b|| 2.891598605739e-04
 52 KSP preconditioned resid norm 9.072835164836e-08 true resid norm 1.813919638193e-09 ||r(i)||/||b|| 2.641539317278e-04
 53 KSP preconditioned resid norm 7.839459727391e-08 true resid norm 1.529073921421e-09 ||r(i)||/||b|| 2.226729783069e-04
 54 KSP preconditioned resid norm 6.601381028591e-08 true resid norm 1.287552859854e-09 ||r(i)||/||b|| 1.875012228086e-04
 55 KSP preconditioned resid norm 5.685480685634e-08 true resid norm 1.114093807824e-09 ||r(i)||/||b|| 1.622410681564e-04
 56 KSP preconditioned resid norm 4.800842533085e-08 true resid norm 9.507812100719e-10 ||r(i)||/||b|| 1.384585014491e-04
 57 KSP preconditioned resid norm 4.190158928552e-08 true resid norm 8.131929793017e-10 ||r(i)||/||b|| 1.184220724078e-04
 58 KSP preconditioned resid norm 3.560756796435e-08 true resid norm 7.009747940059e-10 ||r(i)||/||b|| 1.020801825946e-04
 59 KSP preconditioned resid norm 2.984048555207e-08 true resid norm 5.953346332861e-10 ||r(i)||/||b|| 8.669622444404e-05
 60 KSP preconditioned resid norm 2.494120959879e-08 true resid norm 4.903954213055e-10 ||r(i)||/||b|| 7.141434268179e-05
 61 KSP preconditioned resid norm 2.134788043904e-08 true resid norm 4.176570704622e-10 ||r(i)||/||b|| 6.082174477498e-05
 62 KSP preconditioned resid norm 1.851222016394e-08 true resid norm 3.616113215178e-10 ||r(i)||/||b|| 5.266002436104e-05
 63 KSP preconditioned resid norm 1.609839710515e-08 true resid norm 3.135835757558e-10 ||r(i)||/||b|| 4.566593399015e-05
 64 KSP preconditioned resid norm 1.447252133793e-08 true resid norm 2.761923213472e-10 ||r(i)||/||b|| 4.022079372246e-05
 65 KSP preconditioned resid norm 1.306766247453e-08 true resid norm 2.472413677732e-10 ||r(i)||/||b|| 3.600478103215e-05
 66 KSP preconditioned resid norm 1.181313051589e-08 true resid norm 2.203404703898e-10 ||r(i)||/||b|| 3.208730990432e-05
 67 KSP preconditioned resid norm 1.078588279393e-08 true resid norm 2.037242539109e-10 ||r(i)||/||b|| 2.966755611758e-05
 68 KSP preconditioned resid norm 1.016884166240e-08 true resid norm 1.924729805649e-10 ||r(i)||/||b|| 2.802907774802e-05
 69 KSP preconditioned resid norm 9.109991617990e-09 true resid norm 1.745364221068e-10 ||r(i)||/||b|| 2.541704778892e-05
 70 KSP preconditioned resid norm 8.114223072990e-09 true resid norm 1.518144931714e-10 ||r(i)||/||b|| 2.210814328270e-05
 71 KSP preconditioned resid norm 7.281620157406e-09 true resid norm 1.377442037481e-10 ||r(i)||/||b|| 2.005914276832e-05
 72 KSP preconditioned resid norm 6.653215203048e-09 true resid norm 1.270370139789e-10 ||r(i)||/||b|| 1.849989713486e-05
 73 KSP preconditioned resid norm 5.874545495878e-09 true resid norm 1.119615699193e-10 ||r(i)||/||b|| 1.630451993235e-05
 74 KSP preconditioned resid norm 4.977741499543e-09 true resid norm 9.548882079341e-11 ||r(i)||/||b|| 1.390565872794e-05
 75 KSP preconditioned resid norm 4.279143491153e-09 true resid norm 8.090536469081e-11 ||r(i)||/||b|| 1.178192778277e-05
 76 KSP preconditioned resid norm 3.677721856599e-09 true resid norm 7.037162927698e-11 ||r(i)||/||b|| 1.024794162002e-05
 77 KSP preconditioned resid norm 3.217314721593e-09 true resid norm 6.070725407907e-11 ||r(i)||/||b|| 8.840556941849e-06
 78 KSP preconditioned resid norm 2.801036133387e-09 true resid norm 5.215425647071e-11 ||r(i)||/||b|| 7.595017779730e-06
 79 KSP preconditioned resid norm 2.555512332058e-09 true resid norm 4.802360533696e-11 ||r(i)||/||b|| 6.993487417192e-06
 80 KSP preconditioned resid norm 2.317538043006e-09 true resid norm 4.386210071516e-11 ||r(i)||/||b|| 6.387463983405e-06
 81 KSP preconditioned resid norm 2.105665248868e-09 true resid norm 4.035362896160e-11 ||r(i)||/||b|| 5.876539139468e-06
 82 KSP preconditioned resid norm 1.886996607916e-09 true resid norm 3.625883378171e-11 ||r(i)||/||b|| 5.280230337461e-06
 83 KSP preconditioned resid norm 1.701604764324e-09 true resid norm 3.263979795870e-11 ||r(i)||/||b|| 4.753204486048e-06
 84 KSP preconditioned resid norm 1.531004109565e-09 true resid norm 2.891821875368e-11 ||r(i)||/||b|| 4.211245648103e-06
 85 KSP preconditioned resid norm 1.402921200739e-09 true resid norm 2.640928112158e-11 ||r(i)||/||b|| 3.845878998983e-06
 86 KSP preconditioned resid norm 1.300540578957e-09 true resid norm 2.457010439027e-11 ||r(i)||/||b|| 3.578046976831e-06
 87 KSP preconditioned resid norm 1.169216480698e-09 true resid norm 2.160125853189e-11 ||r(i)||/||b|| 3.145705714477e-06
 88 KSP preconditioned resid norm 1.025253545515e-09 true resid norm 1.915616025289e-11 ||r(i)||/||b|| 2.789635737473e-06
 89 KSP preconditioned resid norm 8.703002774169e-10 true resid norm 1.624103875352e-11 ||r(i)||/||b|| 2.365118140713e-06
 90 KSP preconditioned resid norm 7.414365312721e-10 true resid norm 1.377979625389e-11 ||r(i)||/||b|| 2.006697144808e-06
 91 KSP preconditioned resid norm 6.067907628716e-10 true resid norm 1.128640105671e-11 ||r(i)||/||b|| 1.643593878920e-06
 92 KSP preconditioned resid norm 5.265640442250e-10 true resid norm 9.804106873462e-12 ||r(i)||/||b|| 1.427733248582e-06
 93 KSP preconditioned resid norm 4.493098902254e-10 true resid norm 8.475253995624e-12 ||r(i)||/||b|| 1.234217667750e-06
 94 KSP preconditioned resid norm 3.859635925960e-10 true resid norm 7.312556023375e-12 ||r(i)||/||b|| 1.064898567656e-06
 95 KSP preconditioned resid norm 3.295352644910e-10 true resid norm 6.140175306245e-12 ||r(i)||/||b|| 8.941694077794e-07
 96 KSP preconditioned resid norm 2.800984335336e-10 true resid norm 5.312392798861e-12 ||r(i)||/||b|| 7.736227201881e-07
 97 KSP preconditioned resid norm 2.376762502526e-10 true resid norm 4.600938310438e-12 ||r(i)||/||b|| 6.700164212070e-07
 98 KSP preconditioned resid norm 2.001722319026e-10 true resid norm 3.909730209143e-12 ||r(i)||/||b|| 5.693585233847e-07
 99 KSP preconditioned resid norm 1.681704481239e-10 true resid norm 3.266901496994e-12 ||r(i)||/||b|| 4.757459243663e-07
100 KSP preconditioned resid norm 1.412854480766e-10 true resid norm 2.721515130117e-12 ||r(i)||/||b|| 3.963234681076e-07
101 KSP preconditioned resid norm 1.195995080034e-10 true resid norm 2.365139805283e-12 ||r(i)||/||b|| 3.444259412031e-07
102 KSP preconditioned resid norm 1.025386072253e-10 true resid norm 2.000363767666e-12 ||r(i)||/||b|| 2.913050517724e-07
103 KSP preconditioned resid norm 8.879174942592e-11 true resid norm 1.741125432604e-12 ||r(i)||/||b|| 2.535531999156e-07
104 KSP preconditioned resid norm 7.713887817627e-11 true resid norm 1.479997884682e-12 ||r(i)||/||b|| 2.155262294734e-07
105 KSP preconditioned resid norm 6.847651519322e-11 true resid norm 1.317894935459e-12 ||r(i)||/||b|| 1.919198190898e-07
106 KSP preconditioned resid norm 6.203905531932e-11 true resid norm 1.194271139214e-12 ||r(i)||/||b|| 1.739169753334e-07
107 KSP preconditioned resid norm 5.594839599801e-11 true resid norm 1.090203856383e-12 ||r(i)||/||b|| 1.587620691594e-07
108 KSP preconditioned resid norm 5.037334613468e-11 true resid norm 9.690174925613e-13 ||r(i)||/||b|| 1.411141790317e-07
109 KSP preconditioned resid norm 4.503126411310e-11 true resid norm 8.834186391084e-13 ||r(i)||/||b|| 1.286487570720e-07
110 KSP preconditioned resid norm 4.028080915007e-11 true resid norm 7.848357552337e-13 ||r(i)||/||b|| 1.142925221936e-07
111 KSP preconditioned resid norm 3.799844646046e-11 true resid norm 7.301397670085e-13 ||r(i)||/||b|| 1.063273620866e-07
112 KSP preconditioned resid norm 3.624871136275e-11 true resid norm 7.087010471957e-13 ||r(i)||/||b|| 1.032053262419e-07
113 KSP preconditioned resid norm 3.389723660711e-11 true resid norm 6.520789767051e-13 ||r(i)||/||b|| 9.495967840409e-08
Linear solve converged due to CONVERGED_RTOL iterations 113
iter =  18, Function value: -4.34176,  Residual: 1.93571e-06
  0 KSP preconditioned resid norm 4.508502261780e-05 true resid norm 1.071143234017e-06 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 1.069076165093e-05 true resid norm 3.089684572391e-07 ||r(i)||/||b|| 2.884473779294e-01
  2 KSP preconditioned resid norm 5.497023079267e-06 true resid norm 1.449735850853e-07 ||r(i)||/||b|| 1.353447237318e-01
  3 KSP preconditioned resid norm 3.205788707464e-06 true resid norm 7.443224954375e-08 ||r(i)||/||b|| 6.948860542637e-02
  4 KSP preconditioned resid norm 2.012004018387e-06 true resid norm 4.147254560650e-08 ||r(i)||/||b|| 3.871802041914e-02
  5 KSP preconditioned resid norm 1.370146586025e-06 true resid norm 2.847571217488e-08 ||r(i)||/||b|| 2.658441118849e-02
  6 KSP preconditioned resid norm 1.103918072549e-06 true resid norm 2.283957626182e-08 ||r(i)||/||b|| 2.132261637518e-02
  7 KSP preconditioned resid norm 8.423418496349e-07 true resid norm 1.642838763832e-08 ||r(i)||/||b|| 1.533724633325e-02
  8 KSP preconditioned resid norm 6.460765607550e-07 true resid norm 1.371129397637e-08 ||r(i)||/||b|| 1.280061670646e-02
  9 KSP preconditioned resid norm 5.104032388305e-07 true resid norm 1.026992142474e-08 ||r(i)||/||b|| 9.587813374151e-03
 10 KSP preconditioned resid norm 4.364583451738e-07 true resid norm 9.171420557624e-09 ||r(i)||/||b|| 8.562272781417e-03
 11 KSP preconditioned resid norm 3.639022967259e-07 true resid norm 7.624383911178e-09 ||r(i)||/||b|| 7.117987276626e-03
 12 KSP preconditioned resid norm 3.054320429023e-07 true resid norm 6.108076795150e-09 ||r(i)||/||b|| 5.702390307077e-03
 13 KSP preconditioned resid norm 2.720334214801e-07 true resid norm 5.461969871945e-09 ||r(i)||/||b|| 5.099196539253e-03
 14 KSP preconditioned resid norm 2.294694535830e-07 true resid norm 4.591959682475e-09 ||r(i)||/||b|| 4.286970721229e-03
 15 KSP preconditioned resid norm 2.003072158320e-07 true resid norm 3.827623819504e-09 ||r(i)||/||b|| 3.573400548075e-03
 16 KSP preconditioned resid norm 1.764850308967e-07 true resid norm 3.345473181437e-09 ||r(i)||/||b|| 3.123273410307e-03
 17 KSP preconditioned resid norm 1.624102863325e-07 true resid norm 2.986247918685e-09 ||r(i)||/||b|| 2.787907185377e-03
 18 KSP preconditioned resid norm 1.512289664610e-07 true resid norm 2.926414942528e-09 ||r(i)||/||b|| 2.732048198216e-03
 19 KSP preconditioned resid norm 1.304990287691e-07 true resid norm 2.401335782675e-09 ||r(i)||/||b|| 2.241843766934e-03
 20 KSP preconditioned resid norm 1.123327840984e-07 true resid norm 2.046673736526e-09 ||r(i)||/||b|| 1.910737678704e-03
 21 KSP preconditioned resid norm 9.871204336004e-08 true resid norm 1.746520697062e-09 ||r(i)||/||b|| 1.630520215781e-03
 22 KSP preconditioned resid norm 9.050642850270e-08 true resid norm 1.615821848890e-09 ||r(i)||/||b|| 1.508502128917e-03
 23 KSP preconditioned resid norm 8.253529795981e-08 true resid norm 1.474775485537e-09 ||r(i)||/||b|| 1.376823788548e-03
 24 KSP preconditioned resid norm 7.766901010769e-08 true resid norm 1.438482277688e-09 ||r(i)||/||b|| 1.342941104425e-03
 25 KSP preconditioned resid norm 7.383790753378e-08 true resid norm 1.350419162407e-09 ||r(i)||/||b|| 1.260726968645e-03
 26 KSP preconditioned resid norm 6.792424170787e-08 true resid norm 1.275048201039e-09 ||r(i)||/||b|| 1.190361998793e-03
 27 KSP preconditioned resid norm 6.283855135356e-08 true resid norm 1.164017041623e-09 ||r(i)||/||b|| 1.086705311350e-03
 28 KSP preconditioned resid norm 5.792741282609e-08 true resid norm 1.103086858381e-09 ||r(i)||/||b|| 1.029821991448e-03
 29 KSP preconditioned resid norm 5.156397921132e-08 true resid norm 9.664289780117e-10 ||r(i)||/||b|| 9.022406596242e-04
 30 KSP preconditioned resid norm 4.527404622723e-08 true resid norm 8.331839991615e-10 ||r(i)||/||b|| 7.778455510910e-04
 31 KSP preconditioned resid norm 3.859475127142e-08 true resid norm 7.301223842779e-10 ||r(i)||/||b|| 6.816290866532e-04
 32 KSP preconditioned resid norm 3.446748010393e-08 true resid norm 6.390767742056e-10 ||r(i)||/||b|| 5.966305475401e-04
 33 KSP preconditioned resid norm 2.990657825706e-08 true resid norm 5.845742031679e-10 ||r(i)||/||b|| 5.457479304383e-04
 34 KSP preconditioned resid norm 2.627687512902e-08 true resid norm 4.983627876452e-10 ||r(i)||/||b|| 4.652625081485e-04
 35 KSP preconditioned resid norm 2.297563962610e-08 true resid norm 4.475415161696e-10 ||r(i)||/||b|| 4.178166859077e-04
 36 KSP preconditioned resid norm 2.023593248562e-08 true resid norm 3.927293520099e-10 ||r(i)||/||b|| 3.666450382522e-04
 37 KSP preconditioned resid norm 1.763442730162e-08 true resid norm 3.428839297666e-10 ||r(i)||/||b|| 3.201102512506e-04
 38 KSP preconditioned resid norm 1.556013127375e-08 true resid norm 2.962767563452e-10 ||r(i)||/||b|| 2.765986349314e-04
 39 KSP preconditioned resid norm 1.357598956918e-08 true resid norm 2.594680253075e-10 ||r(i)||/||b|| 2.422346676592e-04
 40 KSP preconditioned resid norm 1.180073324344e-08 true resid norm 2.229475554566e-10 ||r(i)||/||b|| 2.081398158307e-04
 41 KSP preconditioned resid norm 1.030135397927e-08 true resid norm 1.927210980411e-10 ||r(i)||/||b|| 1.799209404687e-04
 42 KSP preconditioned resid norm 9.252148038335e-09 true resid norm 1.747396606405e-10 ||r(i)||/||b|| 1.631337948942e-04
 43 KSP preconditioned resid norm 8.223041863942e-09 true resid norm 1.565452449710e-10 ||r(i)||/||b|| 1.461478166500e-04
 44 KSP preconditioned resid norm 7.380942032235e-09 true resid norm 1.416503542115e-10 ||r(i)||/||b|| 1.322422153387e-04
 45 KSP preconditioned resid norm 6.453831650211e-09 true resid norm 1.241068825442e-10 ||r(i)||/||b|| 1.158639466720e-04
 46 KSP preconditioned resid norm 5.688126650324e-09 true resid norm 1.106855151342e-10 ||r(i)||/||b|| 1.033340001776e-04
 47 KSP preconditioned resid norm 5.057302464313e-09 true resid norm 9.820289452367e-11 ||r(i)||/||b|| 9.168045076041e-05
 48 KSP preconditioned resid norm 4.500799098525e-09 true resid norm 8.852961473294e-11 ||r(i)||/||b|| 8.264965125245e-05
 49 KSP preconditioned resid norm 3.983769407394e-09 true resid norm 7.789147315022e-11 ||r(i)||/||b|| 7.271807418145e-05
 50 KSP preconditioned resid norm 3.420304235712e-09 true resid norm 6.615770981665e-11 ||r(i)||/||b|| 6.176364440873e-05
 51 KSP preconditioned resid norm 2.969395787357e-09 true resid norm 5.775608928511e-11 ||r(i)||/||b|| 5.392004304457e-05
 52 KSP preconditioned resid norm 2.583265801170e-09 true resid norm 4.936215282441e-11 ||r(i)||/||b|| 4.608361539034e-05
 53 KSP preconditioned resid norm 2.303172156518e-09 true resid norm 4.555830632203e-11 ||r(i)||/||b|| 4.253241291659e-05
 54 KSP preconditioned resid norm 2.004038570012e-09 true resid norm 3.883153249403e-11 ||r(i)||/||b|| 3.625241822086e-05
 55 KSP preconditioned resid norm 1.758746167534e-09 true resid norm 3.394179710909e-11 ||r(i)||/||b|| 3.168744947563e-05
 56 KSP preconditioned resid norm 1.527568393189e-09 true resid norm 3.011417594376e-11 ||r(i)||/||b|| 2.811405140545e-05
 57 KSP preconditioned resid norm 1.351270602655e-09 true resid norm 2.646768367869e-11 ||r(i)||/||b|| 2.470975200900e-05
 58 KSP preconditioned resid norm 1.188580433509e-09 true resid norm 2.310607643585e-11 ||r(i)||/||b|| 2.157141613003e-05
 59 KSP preconditioned resid norm 1.049772725898e-09 true resid norm 2.055122733712e-11 ||r(i)||/||b|| 1.918625510059e-05
 60 KSP preconditioned resid norm 9.178135338494e-10 true resid norm 1.789537479201e-11 ||r(i)||/||b|| 1.670679907569e-05
 61 KSP preconditioned resid norm 8.172466131650e-10 true resid norm 1.584599056440e-11 ||r(i)||/||b|| 1.479353093141e-05
 62 KSP preconditioned resid norm 7.373368729936e-10 true resid norm 1.425470170182e-11 ||r(i)||/||b|| 1.330793235593e-05
 63 KSP preconditioned resid norm 6.449901730940e-10 true resid norm 1.230744306740e-11 ||r(i)||/||b|| 1.149000682313e-05
 64 KSP preconditioned resid norm 5.598483514662e-10 true resid norm 1.086956128883e-11 ||r(i)||/||b|| 1.014762633384e-05
 65 KSP preconditioned resid norm 4.963094200575e-10 true resid norm 9.397813144522e-12 ||r(i)||/||b|| 8.773628816453e-06
 66 KSP preconditioned resid norm 4.366969072145e-10 true resid norm 8.480411965936e-12 ||r(i)||/||b|| 7.917159625917e-06
 67 KSP preconditioned resid norm 3.778573793786e-10 true resid norm 7.258854529176e-12 ||r(i)||/||b|| 6.776735639689e-06
 68 KSP preconditioned resid norm 3.370904464953e-10 true resid norm 6.503542250737e-12 ||r(i)||/||b|| 6.071589722269e-06
 69 KSP preconditioned resid norm 2.982699444561e-10 true resid norm 5.688313388577e-12 ||r(i)||/||b|| 5.310506763174e-06
 70 KSP preconditioned resid norm 2.675651763666e-10 true resid norm 5.136077412575e-12 ||r(i)||/||b|| 4.794949218241e-06
 71 KSP preconditioned resid norm 2.393278506019e-10 true resid norm 4.498351645872e-12 ||r(i)||/||b|| 4.199579946933e-06
 72 KSP preconditioned resid norm 2.159108701621e-10 true resid norm 4.102354584836e-12 ||r(i)||/||b|| 3.829884234483e-06
 73 KSP preconditioned resid norm 1.976346514770e-10 true resid norm 3.794817346865e-12 ||r(i)||/||b|| 3.542773017044e-06
 74 KSP preconditioned resid norm 1.730082030043e-10 true resid norm 3.329374283677e-12 ||r(i)||/||b|| 3.108243769781e-06
 75 KSP preconditioned resid norm 1.475368383202e-10 true resid norm 2.822421740838e-12 ||r(i)||/||b|| 2.634962021142e-06
 76 KSP preconditioned resid norm 1.241796283012e-10 true resid norm 2.356348835514e-12 ||r(i)||/||b|| 2.199844764622e-06
 77 KSP preconditioned resid norm 1.051910287558e-10 true resid norm 2.018639880815e-12 ||r(i)||/||b|| 1.884565776740e-06
 78 KSP preconditioned resid norm 8.962988346101e-11 true resid norm 1.708872881925e-12 ||r(i)||/||b|| 1.595372894730e-06
 79 KSP preconditioned resid norm 7.570084976402e-11 true resid norm 1.429761782062e-12 ||r(i)||/||b|| 1.334799807025e-06
 80 KSP preconditioned resid norm 6.683347346922e-11 true resid norm 1.274890468348e-12 ||r(i)||/||b|| 1.190214742399e-06
 81 KSP preconditioned resid norm 5.997149607838e-11 true resid norm 1.154991045391e-12 ||r(i)||/||b|| 1.078278804096e-06
 82 KSP preconditioned resid norm 5.423985443710e-11 true resid norm 1.040041627308e-12 ||r(i)||/||b|| 9.709641010446e-07
 83 KSP preconditioned resid norm 4.894792603260e-11 true resid norm 9.522002485135e-13 ||r(i)||/||b|| 8.889569744491e-07
 84 KSP preconditioned resid norm 4.492690279298e-11 true resid norm 8.792462658391e-13 ||r(i)||/||b|| 8.208484523041e-07
 85 KSP preconditioned resid norm 4.061630539729e-11 true resid norm 8.018573862948e-13 ||r(i)||/||b|| 7.485995904465e-07
 86 KSP preconditioned resid norm 3.767320471887e-11 true resid norm 7.271396081286e-13 ||r(i)||/||b|| 6.788444206491e-07
 87 KSP preconditioned resid norm 3.530363419777e-11 true resid norm 6.782807966740e-13 ||r(i)||/||b|| 6.332307156814e-07
 88 KSP preconditioned resid norm 3.335188852670e-11 true resid norm 6.399306643496e-13 ||r(i)||/||b|| 5.974277239745e-07
 89 KSP preconditioned resid norm 3.101008041056e-11 true resid norm 6.004937283362e-13 ||r(i)||/||b|| 5.606101119494e-07
 90 KSP preconditioned resid norm 2.826503485799e-11 true resid norm 5.505976680085e-13 ||r(i)||/||b|| 5.140280501456e-07
 91 KSP preconditioned resid norm 2.451903803277e-11 true resid norm 4.785428397528e-13 ||r(i)||/||b|| 4.467589623454e-07
 92 KSP preconditioned resid norm 2.097479072432e-11 true resid norm 4.041277788586e-13 ||r(i)||/||b|| 3.772864039321e-07
 93 KSP preconditioned resid norm 1.767596735270e-11 true resid norm 3.470813024880e-13 ||r(i)||/||b|| 3.240288427033e-07
 94 KSP preconditioned resid norm 1.530390760261e-11 true resid norm 2.971278260534e-13 ||r(i)||/||b|| 2.773931782578e-07
 95 KSP preconditioned resid norm 1.305001317805e-11 true resid norm 2.540140788993e-13 ||r(i)||/||b|| 2.371429616809e-07
 96 KSP preconditioned resid norm 1.085438720889e-11 true resid norm 2.119323936237e-13 ||r(i)||/||b|| 1.978562594555e-07
 97 KSP preconditioned resid norm 9.141824794601e-12 true resid norm 1.787874371738e-13 ||r(i)||/||b|| 1.669127260444e-07
 98 KSP preconditioned resid norm 7.641790221189e-12 true resid norm 1.506813342331e-13 ||r(i)||/||b|| 1.406733753692e-07
 99 KSP preconditioned resid norm 6.453763919751e-12 true resid norm 1.252091856570e-13 ||r(i)||/||b|| 1.168930369726e-07
100 KSP preconditioned resid norm 5.352698890327e-12 true resid norm 1.034643039009e-13 ||r(i)||/||b|| 9.659240763987e-08
101 KSP preconditioned resid norm 4.468634575064e-12 true resid norm 8.698708890092e-14 ||r(i)||/||b|| 8.120957696263e-08
Linear solve converged due to CONVERGED_RTOL iterations 101
iter =  19, Function value: -4.34176,  Residual: 1.15202e-07
Tao Object: 1 MPI processes
  type: tron
      Total PG its: 57,      PG tolerance: 0.001
  TaoLineSearch Object:   1 MPI processes
    type: more-thuente
  KSP Object:   1 MPI processes
    type: cg
  total KSP iterations: 1920
  Active Set subset type: subvec
  convergence tolerances: gatol=1e-12,   steptol=1e-12,   gttol=0.
  Residual in Function/Gradient:=1.15202e-07
  Objective value=-4.34176
  total number of iterations=19,                          (max: 50)
  total number of function/gradient evaluations=78,      (max: 10000)
  total number of Hessian evaluations=19
  Solution converged:    ||g(X)||/|f(X)| <= grtol
TAO solve converged due to CONVERGED_GRTOL iterations 19
it: 1	2.245113e+01	1920	8.441264e+08
  Time summary:
Creating DMPlex: 	0.520237
Distributing DMPlex: 	1.97887e-05
Refining DMPlex: 	2.10413
Setting up problem: 	2.86735
Overall analysis time: 	22.5795
Overall FLOPS/s: 	7.5135e+08
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main on a arch-darwin-c-opt named Justins-MacBook-Pro-2.local with 1 processor, by justin Tue Mar  8 00:51:47 2016
Using Petsc Development GIT revision: pre-tsfc-438-gf0bfc80  GIT Date: 2016-03-01 11:52:01 -0600
                         Max       Max/Min        Avg      Total
Time (sec):           2.811e+01      1.00000   2.811e+01
Objects:              4.611e+03      1.00000   4.611e+03
Flops:                1.902e+10      1.00000   1.902e+10  1.902e+10
Flops/sec:            6.766e+08      1.00000   6.766e+08  6.766e+08
MPI Messages:         5.500e+00      1.00000   5.500e+00  5.500e+00
MPI Message Lengths:  4.494e+06      1.00000   8.170e+05  4.494e+06
MPI Reductions:       1.000e+00      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 2.8115e+01 100.0%  1.9023e+10 100.0%  5.500e+00 100.0%  8.170e+05      100.0%  1.000e+00 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
CreateMesh            79 1.0 2.9209e+00 1.0 3.31e+08 1.0 0.0e+00 0.0e+00 0.0e+00 10  2  0  0  0  10  2  0  0  0   113
BuildTwoSided          5 1.0 5.2476e-04 1.0 0.00e+00 0.0 5.0e-01 4.0e+00 0.0e+00  0  0  9  0  0   0  0  9  0  0     0
VecView                1 1.0 1.2794e-02 1.0 4.02e+05 1.0 1.0e+00 1.0e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0    31
VecDot               424 1.0 5.8249e-02 1.0 1.06e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  1817
VecTDot             3840 1.0 4.5666e-01 1.0 8.13e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  4  0  0  0   2  4  0  0  0  1779
VecNorm             3936 1.0 4.1154e-01 1.0 8.34e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  2027
VecScale             228 1.0 1.6403e-02 1.0 2.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1713
VecCopy             2358 1.0 2.1371e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecSet              6036 1.0 3.6855e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY             4014 1.0 4.1987e-01 1.0 8.56e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  2039
VecAYPX             3859 1.0 4.1066e-01 1.0 6.12e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  1491
VecWAXPY               1 1.0 2.1100e-04 1.0 1.25e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   592
VecScatterBegin       38 1.0 4.5440e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult             3957 1.0 1.0226e+01 1.0 1.03e+10 1.0 0.0e+00 0.0e+00 0.0e+00 36 54  0  0  0  36 54  0  0  0  1011
MatSolve            1939 1.0 5.8253e+00 1.0 5.02e+09 1.0 0.0e+00 0.0e+00 0.0e+00 21 26  0  0  0  21 26  0  0  0   863
MatLUFactorNum        19 1.0 5.6000e-01 1.0 2.13e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   2  1  0  0  0   380
MatILUFactorSym       19 1.0 1.2467e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin      21 1.0 9.0599e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        21 1.0 6.1831e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           19 1.0 5.9605e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      19 1.0 4.8048e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatGetOrdering        19 1.0 5.6238e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 9.4700e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           3 1.0 4.7024e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
DMPlexStratify        11 1.0 6.3541e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
DMPlexPrealloc         1 1.0 1.0536e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
DMPlexResidualFE       1 1.0 6.2948e-01 1.0 4.01e+07 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0    64
DMPlexJacobianFE       1 1.0 1.8430e+00 1.0 8.14e+07 1.0 0.0e+00 0.0e+00 0.0e+00  7  0  0  0  0   7  0  0  0  0    44
SFSetGraph             6 1.0 2.0661e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin           9 1.0 2.5048e-03 1.0 0.00e+00 0.0 4.5e+00 7.8e+05 0.0e+00  0  0 82 78  0   0  0 82 78  0     0
SFBcastEnd             9 1.0 7.1669e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          1 1.0 3.6120e-04 1.0 0.00e+00 0.0 1.0e+00 1.0e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0     0
SFReduceEnd            1 1.0 3.8004e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       1 1.0 6.3624e-01 1.0 4.01e+07 1.0 2.0e+00 1.0e+06 0.0e+00  2  0 36 44  0   2  0 36 44  0    63
SNESJacobianEval       1 1.0 1.8445e+00 1.0 8.14e+07 1.0 2.5e+00 6.0e+05 0.0e+00  7  0 45 33  0   7  0 45 33  0    44
KSPSetUp              38 1.0 4.6651e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              19 1.0 1.8689e+01 1.0 1.83e+10 1.0 0.0e+00 0.0e+00 0.0e+00 66 96  0  0  0  66 96  0  0  0   979
PCSetUp               38 1.0 6.9092e-01 1.0 2.13e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   2  1  0  0  0   308
PCSetUpOnBlocks       19 1.0 6.9078e-01 1.0 2.13e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0   2  1  0  0  0   308
PCApply             1939 1.0 5.9339e+00 1.0 5.02e+09 1.0 0.0e+00 0.0e+00 0.0e+00 21 26  0  0  0  21 26  0  0  0   847
TaoSolve               1 1.0 1.9964e+01 1.0 1.88e+10 1.0 0.0e+00 0.0e+00 0.0e+00 71 99  0  0  0  71 99  0  0  0   943
TaoHessianEval        19 1.0 4.5300e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
TaoLineSearchApply      76 1.0 5.3617e-01 1.0 4.22e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0   787
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     4              3         2432     0.
              Object     7              7         4088     0.
           Container    15             15         8640     0.
              Vector  4074           4074   3615142824     0.
      Vector Scatter    38             38        25232     0.
              Matrix    39             39    699796976     0.
    Distributed Mesh    29             29       135576     0.
    GraphPartitioner    11             11         6732     0.
Star Forest Bipartite Graph    62             62        50488     0.
     Discrete System    29             29        25056     0.
           Index Set   229            229     33961616     0.
   IS L to G Mapping     1              1       561392     0.
             Section    56             54        36288     0.
                SNES     1              1         1340     0.
      SNESLineSearch     1              1         1000     0.
              DMSNES     1              1          672     0.
       Krylov Solver     3              3         3680     0.
      Preconditioner     3              3         2824     0.
        Linear Space     2              2         1296     0.
          Dual Space     2              2         1328     0.
            FE Space     2              2         1512     0.
                 Tao     1              1         1944     0.
       TaoLineSearch     1              1          888     0.
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-al 1
-am 0
-at 0.001
-bcloc 0,1,0,1,0,0,0,1,0,1,1,1,0,0,0,1,0,1,1,1,0,1,0,1,0,1,0,0,0,1,0,1,1,1,0,1,0.45,0.55,0.45,0.55,0.45,0.55
-bcnum 7
-bcval 0,0,0,0,0,0,1
-dim 3
-dm_refine 1
-dt 0.001
-edges 3,3
-floc 0.25,0.75,0.25,0.75,0.25,0.75
-fnum 0
-ftime 0,99
-fval 1
-ksp_atol 1.0e-12
-ksp_converged_reason
-ksp_monitor_true_residual
-ksp_rtol 1.0e-7
-ksp_type cg
-log_view
-lower 0,0
-mat_petscspace_order 0
-mesh datafiles/cube_with_hole2_mesh.dat
-mu 1
-nonneg 1
-numsteps 0
-options_left 0
-pc_type bjacobi
-petscpartitioner_type parmetis
-progress 0
-simplex 1
-solution_petscspace_order 1
-tao_converged_reason
-tao_gatol 1e-12
-tao_grtol 1e-7
-tao_monitor
-tao_type tron
-tao_view
-trans datafiles/cube_with_hole2_trans.dat
-upper 1,1
-vtuname figures/cube_with_hole_2
-vtuprint 1
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco --download-ctetgen --download-exodusii --download-fblaslapack --download-hdf5 --download-hypre --download-metis --download-ml --download-mumps --download-netcdf --download-parmetis --download-scalapack --download-superlu_dist --download-triangle --with-debugging=0 --with-mpi-dir=/usr/local/opt/open-mpi --with-shared-libraries=1 COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 PETSC_ARCH=arch-darwin-c-opt
Libraries compiled on Tue Mar  1 13:44:59 2016 on Justins-MacBook-Pro-2.local
Machine characteristics: Darwin-15.3.0-x86_64-i386-64bit
Using PETSc directory: /Users/justin/Software/petsc
Using PETSc arch: arch-darwin-c-opt
Using C compiler: /usr/local/opt/open-mpi/bin/mpicc    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -O2  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /usr/local/opt/open-mpi/bin/mpif90   -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O2   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/Users/justin/Software/petsc/arch-darwin-c-opt/include -I/Users/justin/Software/petsc/include -I/Users/justin/Software/petsc/include -I/Users/justin/Software/petsc/arch-darwin-c-opt/include -I/opt/X11/include -I/usr/local/opt/open-mpi/include -I/usr/local/Cellar/open-mpi/1.10.2/include
Using C linker: /usr/local/opt/open-mpi/bin/mpicc
Using Fortran linker: /usr/local/opt/open-mpi/bin/mpif90
Using libraries: -Wl,-rpath,/Users/justin/Software/petsc/arch-darwin-c-opt/lib -L/Users/justin/Software/petsc/arch-darwin-c-opt/lib -lpetsc -Wl,-rpath,/Users/justin/Software/petsc/arch-darwin-c-opt/lib -L/Users/justin/Software/petsc/arch-darwin-c-opt/lib -lsuperlu_dist -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lHYPRE -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.2/lib -L/usr/local/Cellar/open-mpi/1.10.2/lib -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/7.0.2/lib/darwin -lclang_rt.osx -lmpi_cxx -lc++ -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -lclang_rt.osx -lscalapack -lml -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -lflapack -lfblas -ltriangle -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11 -lexoIIv2for -lexodus -lnetcdf -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lchaco -lctetgen -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -Wl,-rpath,/usr/local/Cellar/gcc/5.3.0/lib/gcc/5/gcc/x86_64-apple-darwin15.0.0/5.3.0 -L/usr/local/Cellar/gcc/5.3.0/lib/gcc/5/gcc/x86_64-apple-darwin15.0.0/5.3.0 -Wl,-rpath,/usr/local/Cellar/gcc/5.3.0/lib/gcc/5 -L/usr/local/Cellar/gcc/5.3.0/lib/gcc/5 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpi_cxx -lc++ -lclang_rt.osx -Wl,-rpath,/usr/local/opt/libevent/lib -L/usr/local/opt/libevent/lib -Wl,-rpath,/usr/local/Cellar/open-mpi/1.10.2/lib -L/usr/local/Cellar/open-mpi/1.10.2/lib -ldl -lmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/7.0.2/lib/darwin -lclang_rt.osx -ldl
