[petsc-users] Strange GAMG performance for mixed FE formulation
Mark Adams mfadams at lbl.gov
Thu Mar 3 14:19:11 CST 2016
On Wed, Mar 2, 2016 at 5:28 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Dear all,
> Using the firedrake project, I am solving this simple mixed poisson
> problem:
> mesh = UnitCubeMesh(40,40,40)
> V = FunctionSpace(mesh,"RT",1)
> Q = FunctionSpace(mesh,"DG",0)
> W = V*Q
> v, p = TrialFunctions(W)
> w, q = TestFunctions(W)
> f = Function(Q)
> f.interpolate(Expression("12*pi*pi*sin(pi*x[0]*2)*sin(pi*x[1]*2)*sin(2*pi*x[2])"))
> a = dot(v,w)*dx - p*div(w)*dx + div(v)*q*dx
> L = f*q*dx
> u = Function(W)
> solve(a==L,u,solver_parameters={...})
> This problem has 1161600 degrees of freedom. The solver_parameters are:
> -ksp_type gmres
> -pc_type fieldsplit
> -pc_fieldsplit_type schur
> -pc_fieldsplit_schur_fact_type: upper
> -pc_fieldsplit_schur_precondition selfp
> -fieldsplit_0_ksp_type preonly
> -fieldsplit_0_pc_type bjacobi
> -fieldsplit_1_ksp_type preonly
> -fieldsplit_1_pc_type hypre/ml/gamg
> for the last option, I compared the wall-clock timings for hypre, ml,and
> gamg. Here are the strong-scaling results (across 64 cores, 8 cores per
> Intel Xeon E5-2670 node) for hypre, ml, and gamg:
> hypre:
> 1 core: 47.5 s, 12 solver iters
> 2 cores: 34.1 s, 15 solver iters
> 4 cores: 21.5 s, 15 solver iters
> 8 cores: 16.6 s, 15 solver iters
> 16 cores: 10.2 s, 15 solver iters
> 24 cores: 7.66 s, 15 solver iters
> 32 cores: 6.31 s, 15 solver iters
> 40 cores: 5.68 s, 15 solver iters
> 48 cores: 5.36 s, 16 solver iters
> 56 cores: 5.12 s, 16 solver iters
> 64 cores: 4.99 s, 16 solver iters
> ml:
> 1 core: 4.44 s, 14 solver iters
> 2 cores: 2.85 s, 16 solver iters
> 4 cores: 1.6 s, 17 solver iters
> 8 cores: 0.966 s, 17 solver iters
> 16 cores: 0.585 s, 18 solver iters
> 24 cores: 0.440 s, 18 solver iters
> 32 cores: 0.375 s, 18 solver iters
> 40 cores: 0.332 s, 18 solver iters
> 48 cores: 0.307 s, 17 solver iters
> 56 cores: 0.290 s, 18 solver iters
> 64 cores: 0.281 s, 18 solver items
> gamg:
> 1 core: 613 s, 12 solver iters
> 2 cores: 204 s, 15 solver iters
> 4 cores: 77.1 s, 15 solver iters
> 8 cores: 38.1 s, 15 solver iters
> 16 cores: 15.9 s, 16 solver iters
> 24 cores: 9.24 s, 16 solver iters
> 32 cores: 5.92 s, 16 solver iters
> 40 cores: 4.72 s, 16 solver iters
> 48 cores: 3.89 s, 16 solver iters
> 56 cores: 3.65 s, 16 solver iters
> 64 cores: 3.46 s, 16 solver iters
> The performance difference between ML and HYPRE makes sense to me, but
> what I am really confused about is GAMG. It seems GAMG is really slow on a
> single core but something internally is causing it to speed up
> super-linearly as I increase the number of MPI processes. Shouldn't ML and
> GAMG have the same performance? I am not sure what log outputs to give you
> guys, but for starters, below is -ksp_view for the single core case with
> GAMG
> KSP Object:(solver_) 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object:(solver_) 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization UPPER
>     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses (lumped, if requested) A00's diagonal's
> inverse
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object:      (solver_fieldsplit_0_)       1 MPI processes
>         type: preonly
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>         using NONE norm type for convergence test
>       PC Object:      (solver_fieldsplit_0_)       1 MPI processes
>         type: bjacobi
>           block Jacobi: number of blocks = 1
>           Local solve is same for all blocks, in the following KSP and PC
> objects:
>           KSP Object:          (solver_fieldsplit_0_sub_)           1 MPI
> processes
>             type: preonly
>           PC Object:          (solver_fieldsplit_0_sub_)           1 MPI
> processes
>             type: ilu
>               ILU: out-of-place factorization
>               0 levels of fill
>               tolerance for zero pivot 2.22045e-14
>               matrix ordering: natural
>               factor fill ratio given 1., needed 1.
>                 Factored matrix follows:
>                   Mat Object:                   1 MPI processes
>                     type: seqaij
>                     rows=777600, cols=777600
>                     package used to perform factorization: petsc
>                     total: nonzeros=5385600, allocated nonzeros=5385600
>                     total number of mallocs used during MatSetValues calls
> =0
>                       not using I-node routines
>             linear system matrix = precond matrix:
>             Mat Object:            (solver_fieldsplit_0_)             1
> MPI processes
>               type: seqaij
>               total number of mallocs used during MatSetValues calls =0
>         Mat Object:        (solver_fieldsplit_0_)         1 MPI processes
>           type: seqaij
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (solver_fieldsplit_1_)       1 MPI processes
>         type: preonly
>       PC Object:      (solver_fieldsplit_1_)       1 MPI processes
>         type: gamg
>           MG: type is MULTIPLICATIVE, levels=5 cycles=v
>             Cycles per PCApply=1
>             Using Galerkin computed coarse grid matrices
>             GAMG specific options
>               Threshold for dropping small values from graph 0.
>               AGG specific options
>                 Symmetric graph false
>         Coarse grid solver -- level -------------------------------
>           KSP Object:          (solver_fieldsplit_1_mg_coarse_)
> 1 MPI processes
>             type: preonly
>             maximum iterations=1, initial guess is zero
>           PC Object:          (solver_fieldsplit_1_mg_coarse_)           1
> MPI processes
>             type: bjacobi
> PC objects:
>               KSP Object:
> (solver_fieldsplit_1_mg_coarse_sub_)               1 MPI processes
>                 type: preonly
> divergence=10000.
>               PC Object:              (solver_fieldsplit_1_mg_coarse_sub_)
>               1 MPI processes
>                 type: lu
>                   using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
>                   matrix ordering: nd
>                   factor fill ratio given 5., needed 1.
>                         type: seqaij
>                         rows=9, cols=9
>                         total: nonzeros=81, allocated nonzeros=81
> calls =0
>                           using I-node routines: found 2 nodes, limit used
> is 5
>                   type: seqaij
>                   rows=9, cols=9
>                     using I-node routines: found 2 nodes, limit used is 5
>               type: seqaij
>               rows=9, cols=9
>         Down solver (pre-smoother) on level 1
>           KSP Object:          (solver_fieldsplit_1_mg_levels_1_)
>   1 MPI processes
>             type: chebyshev
>               Chebyshev: eigenvalue estimates:  min = 0.0999525, max =
> 1.09948
>               Chebyshev: eigenvalues estimated using gmres with
> translations  [0. 0.1; 0. 1.1]
>               KSP Object:
> (solver_fieldsplit_1_mg_levels_1_esteig_)               1 MPI processes
>                 type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
>                 maximum iterations=10, initial guess is zero
>                 tolerances:  relative=1e-12, absolute=1e-50,
> divergence=10000.
>             maximum iterations=2
>             using nonzero initial guess
>           PC Object:          (solver_fieldsplit_1_mg_levels_1_)
> 1 MPI processes
>             type: sor
>               SOR: type = local_symmetric, iterations = 1, local
> iterations = 1, omega = 1.
>               type: seqaij
>               rows=207, cols=207
>               total: nonzeros=42849, allocated nonzeros=42849
>                 using I-node routines: found 42 nodes, limit used is 5
>         Up solver (post-smoother) same as down solver (pre-smoother)
>         Down solver (pre-smoother) on level 2
>           KSP Object:          (solver_fieldsplit_1_mg_levels_2_)
>   1 MPI processes
>             type: chebyshev
>               Chebyshev: eigenvalue estimates:  min = 0.0996628, max =
> 1.09629
>               KSP Object:
> (solver_fieldsplit_1_mg_levels_2_esteig_)               1 MPI processes
>                 type: gmres
> divergence=10000.
>           PC Object:          (solver_fieldsplit_1_mg_levels_2_)
> 1 MPI processes
>             type: sor
>               type: seqaij
>               rows=5373, cols=5373
>               total: nonzeros=28852043, allocated nonzeros=28852043
>                 using I-node routines: found 1481 nodes, limit used is 5
>         Down solver (pre-smoother) on level 3
>           KSP Object:          (solver_fieldsplit_1_mg_levels_3_)
>   1 MPI processes
>             type: chebyshev
>               Chebyshev: eigenvalue estimates:  min = 0.0994294, max =
> 1.09372
>               KSP Object:
> (solver_fieldsplit_1_mg_levels_3_esteig_)               1 MPI processes
>                 type: gmres
> divergence=10000.
>           PC Object:          (solver_fieldsplit_1_mg_levels_3_)
> 1 MPI processes
>             type: sor
>               type: seqaij
>               rows=52147, cols=52147
>               total: nonzeros=38604909, allocated nonzeros=38604909
>               total number of mallocs used during MatSetValues calls =2
>         Down solver (pre-smoother) on level 4
>           KSP Object:          (solver_fieldsplit_1_mg_levels_4_)
>   1 MPI processes
>             type: chebyshev
>               Chebyshev: eigenvalue estimates:  min = 0.158979, max =
> 1.74876
>               KSP Object:
> (solver_fieldsplit_1_mg_levels_4_esteig_)               1 MPI processes
>                 type: gmres
> divergence=10000.
>           PC Object:          (solver_fieldsplit_1_mg_levels_4_)
> 1 MPI processes
>             type: sor
>             linear system matrix followed by preconditioner matrix:
>             Mat Object:            (solver_fieldsplit_1_)             1
> MPI processes
>               type: schurcomplement
>               rows=384000, cols=384000
>                 Schur complement A11 - A10 inv(A00) A01
>                 A11
>               1 MPI processes
>                     type: seqaij
>                     total: nonzeros=384000, allocated nonzeros=384000
> =0
>                 A10
>                     type: seqaij
>                     rows=384000, cols=777600
>                     total: nonzeros=1919999, allocated nonzeros=1919999
> =0
>                 KSP of A00
>               1 MPI processes
>                     type: preonly
> divergence=10000.
>             1 MPI processes
>                     type: bjacobi
> KSP and PC objects:
>                       KSP Object:
> (solver_fieldsplit_0_sub_)                       1 MPI processes
>                         type: preonly
> divergence=10000.
>                       PC Object:
>                         type: ilu
>                           0 levels of fill
>                               Mat Object:                               1
> MPI processes
>                                 type: seqaij
> petsc
> nonzeros=5385600
>                         Mat Object:
>                           type: seqaij
> nonzeros=5385600
> calls =0
>                     1 MPI processes
>                       type: seqaij
> calls =0
>                 A01
>                     type: seqaij
>                     rows=777600, cols=384000
> =0
>               type: seqaij
>               total: nonzeros=3416452, allocated nonzeros=3416452
>         Mat Object:        (solver_fieldsplit_1_)         1 MPI processes
>             A11
>   1 MPI processes
>                 type: seqaij
>             A10
>                 type: seqaij
>             KSP of A00
>   1 MPI processes
>                 type: preonly
> divergence=10000.
> 1 MPI processes
>                 type: bjacobi
> and PC objects:
>                   1 MPI processes
>                     type: preonly
> divergence=10000.
>                 1 MPI processes
>                     type: ilu
>                       0 levels of fill
>                           Mat Object:                           1 MPI
> processes
>                             type: seqaij
> nonzeros=5385600
>                     1 MPI processes
>                       type: seqaij
> calls =0
>        1 MPI processes
>                   type: seqaij
>             A01
>                 type: seqaij
>           type: seqaij
>     type: nest
>     rows=1161600, cols=116160
>       Matrix object:
>         type=nest, rows=2, cols=2
>         MatNest structure:
>         (0,0) : prefix="solver_fieldsplit_0_", type=seqaij, rows=777600,
> cols=777600
>         (0,1) : type=seqaij, rows=777600, cols=384000
>         (1,0) : type=seqaij, rows=384000, cols=777600
>         (1,1) : prefix="solver_fieldsplit_1_", type=seqaij, rows=384000,
> cols=384000
> Any insight as to what's happening? Btw this firedrake/petsc-mapdes is
> from way back in october 2015 (yes much has
This should not be a problem.
> changed since but reinstalling/updating firedrake and petsc on LANL's
> firewall HPC machines is a big pain in the ass).
> Thanks,
> Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160303/35370d88/attachment-0001.html>
