[petsc-users] Neumann BC with non-symmetric matrix
Tue Mar 1 13:50:02 CST 2016
On Tue, Mar 1, 2016 at 1:48 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>
wrote:
> On Tue, Mar 1, 2016 at 1:15 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Mohammad Mirzadeh <mirzadeh at gmail.com> writes:
>> > I am not familiar with the terminology used here. What does the
>> refluxing
>> > mean?
>> The Chombo/BoxLib family of methods evaluate fluxes between coarse grid
>> cells overlaying refined grids, then later visit the fine grids and
>> reevaluate those fluxes.  The correction needs to be propagated back to
>> the adjoining coarse grid cell to maintain conservation.  It's an
>> implementation detail that they call refluxing.
> Thanks for clarification.
>> > Right. I think if the discretization is conservative, i.e. discretizing
>> div
>> > of grad, and is compact, i.e. only involves neighboring cells sharing a
>> > common face, then it is possible to construct symmetric discretization.
>> An
>> > example, that I have used before in other contexts, is described here:
>> > http://physbam.stanford.edu/~fedkiw/papers/stanford2004-02.pdf
>> It's unfortunate that this paper repeats some unfounded multigrid
>> slander and then basically claims to have uniform convergence using
>> incomplete Cholesky with CG.  In reality, incomplete Cholesky is
>> asymptotically no better than Jacobi.
>> > An interesting observation is although the fluxes are only first order
>> > accurate, the final solution to the linear system exhibits super
>> > convergence, i.e. second-order accurate, even in L_inf.
>> Perhaps for aligned coefficients; definitely not for unaligned
>> coefficients.
> Could you elaborate what you mean by aligned/unaligned coefficients? Do
> you mean anisotropic diffusion coefficient?
Jed (I think) means coefficients where the variation is aligned to the
grid. For example, where coefficient jumps or large variation
happens on cell boundaries.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160301/fbeaf90d/attachment-0001.html>
