[petsc-users] handling multi physics applications on multiple MPI_Comm
Manav Bhatia bhatiamanav at gmail.com
Mon Jul 25 15:13:10 CDT 2016
    I have a multi physics application with discipline1 defined on comm1 and discipline2 on comm2.
    My intent is to use the nested matrix for the KSP solver where each diagonal block is provided by the disciplines, and the off-diagonal blocks are defined as shell-matrices with matrix vector products.
    I am a bit unclear about how to deal with the case of different set of processors on comm1 and comm2. I have the following questions and would appreciate some guidance:
— Would it make sense to define a comm_global as a union of comm1 and comm2 for the MatCreateNest?
— The diagonal blocks are available on comm1 and comm2 only. Should MatAssemblyBegin/End for these diagonal blocks be called on comm1 and comm2 separately?
— What comm should be used for the off-diagonal shell matrices?
— Likewise, when calling VecGetSubVector and VecRestoreSubVector to get sub-vectors corresponding to discipline1 (or 2), what comm should these function calls be made?
Manav
