[petsc-users] OpenMPI 2.0 and Petsc 3.7.2
Mon Jul 25 14:53:32 CDT 2016
On Mon, Jul 25, 2016 at 12:44 PM, Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Ok,
> here is the 2 points answered:
> #1) got valgrind output... here is the fatal free operation:
Okay, this is not the MatMult scatter, this is for local representations of
ghosted vectors. However, to me
it looks like OpenMPI mistakenly frees its built-in type for MPI_DOUBLE.
> ==107156== Invalid free() / delete / delete[] / realloc()
> ==107156==    at 0x4C2A37C: free (in
> /usr/lib64/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==107156==    by 0x1E63CD5F: opal_free (malloc.c:184)
> ==107156==    by 0x27622627: mca_pml_ob1_recv_request_fini
> (pml_ob1_recvreq.h:133)
> ==107156==    by 0x27622C4F: mca_pml_ob1_recv_request_free
> (pml_ob1_recvreq.c:90)
> ==107156==    by 0x1D3EF9DC: ompi_request_free (request.h:362)
> ==107156==    by 0x1D3EFAD5: PMPI_Request_free (prequest_free.c:59)
> ==107156==    by 0x14AE3B9C: VecScatterDestroy_PtoP (vpscat.c:219)
> ==107156==    by 0x14ADEB74: VecScatterDestroy (vscat.c:1860)
> ==107156==    by 0x14A8D426: VecDestroy_MPI (pdvec.c:25)
> ==107156==    by 0x14A33809: VecDestroy (vector.c:432)
> ==107156==    by 0x10A2A5AB: GIREFVecDestroy(_p_Vec*&)
> (girefConfigurationPETSc.h:115)
> ==107156==    by 0x10BA9F14: VecteurPETSc::detruitObjetPETSc()
> (VecteurPETSc.cc:2292)
> ==107156==    by 0x10BA9D0D: VecteurPETSc::~VecteurPETSc()
> (VecteurPETSc.cc:287)
> ==107156==    by 0x10BA9F48: VecteurPETSc::~VecteurPETSc()
> (VecteurPETSc.cc:281)
> ==107156==    by 0x1135A57B: PPReactionsAppuiEL3D::~PPReactionsAppuiEL3D()
> (PPReactionsAppuiEL3D.cc:216)
> ==107156==    by 0xCD9A1EA: ProblemeGD::~ProblemeGD() (in
> /home/mefpp_ericc/depots_prepush/GIREF/lib/libgiref_dev_Formulation.so)
> ==107156==    by 0x435702: main (Test.ProblemeGD.icc:381)
> ==107156==  Address 0x1d6acbc0 is 0 bytes inside data symbol
> "ompi_mpi_double"
> --107156-- REDIR: 0x1dda2680 (libc.so.6:__GI_stpcpy) redirected to
> 0x4c2f330 (__GI_stpcpy)
> ==107156==
> ==107156== Process terminating with default action of signal 6 (SIGABRT):
> dumping core
> ==107156==    at 0x1DD520C7: raise (in /lib64/libc-2.19.so)
> ==107156==    by 0x1DD53534: abort (in /lib64/libc-2.19.so)
> ==107156==    by 0x1DD4B145: __assert_fail_base (in /lib64/libc-2.19.so)
> ==107156==    by 0x1DD4B1F1: __assert_fail (in /lib64/libc-2.19.so)
> ==107156==    by 0x27626D12: mca_pml_ob1_send_request_fini
> (pml_ob1_sendreq.h:221)
> ==107156==    by 0x276274C9: mca_pml_ob1_send_request_free
> (pml_ob1_sendreq.c:117)
> ==107156==    by 0x14AE3C3C: VecScatterDestroy_PtoP (vpscat.c:225)
> #2) For the run with -vecscatter_alltoall it works...!
> As an "end user", should I ever modify these VecScatterCreate options? How
> do they change the performances of the code on large problems?
Yep, those options are there because the different variants are better on
different architectures, and you can't know which one to pick until runtime,
(and without experimentation).
    Matt
> Thanks,
> Eric
> On 25/07/16 02:57 PM, Matthew Knepley wrote:
>> On Mon, Jul 25, 2016 at 11:33 AM, Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca
>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>>     Hi,
>>     has someone tried OpenMPI 2.0 with Petsc 3.7.2?
>>     I am having some errors with petsc, maybe someone have them too?
>>     Here are the configure logs for PETSc:
>> http://www.giref.ulaval.ca/~cmpgiref/dernier_ompi/2016.07.25.01h16m02s_configure.log
>> http://www.giref.ulaval.ca/~cmpgiref/dernier_ompi/2016.07.25.01h16m02s_RDict.log
>>     And for OpenMPI:
>> http://www.giref.ulaval.ca/~cmpgiref/dernier_ompi/2016.07.25.01h16m02s_config.log
>>     (in fact, I am testing the ompi-release branch, a sort of
>>     petsc-master branch, since I need the commit 9ba6678156).
>>     For a set of parallel tests, I have 104 that works on 124 total tests.
>> It appears that the fault happens when freeing the VecScatter we build
>> for MatMult, which contains Request structures
>> for the ISends and  IRecvs. These looks like internal OpenMPI errors to
>> me since the Request should be opaque.
>> I would try at least two things:
>> 1) Run under valgrind.
>> 2) Switch the VecScatter implementation. All the options are here,
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreate.html#VecScatterCreate
>> but maybe use alltoall.
>>   Thanks,
>>      Matt
>>     And the typical error:
>>     *** Error in
>> `/pmi/cmpbib/compilation_BIB_dernier_ompi/COMPILE_AUTO/GIREF/bin/Test.ProblemeGD.dev':
>>     free(): invalid pointer:
>>     ======= Backtrace: =========
>>     /lib64/libc.so.6(+0x7277f)[0x7f80eb11677f]
>>     /lib64/libc.so.6(+0x78026)[0x7f80eb11c026]
>>     /lib64/libc.so.6(+0x78d53)[0x7f80eb11cd53]
>> /opt/openmpi-2.x_opt/lib/libopen-pal.so.20(opal_free+0x1f)[0x7f80ea8f9d60]
>> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16628)[0x7f80df0ea628]
>> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16c50)[0x7f80df0eac50]
>>     /opt/openmpi-2.x_opt/lib/libmpi.so.20(+0x9f9dd)[0x7f80eb7029dd]
>> /opt/openmpi-2.x_opt/lib/libmpi.so.20(MPI_Request_free+0xf7)[0x7f80eb702ad6]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4adc6d)[0x7f80f2fa6c6d]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecScatterDestroy+0x68d)[0x7f80f2fa1c45]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0xa9d0f5)[0x7f80f35960f5]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(MatDestroy+0x648)[0x7f80f35c2588]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x10bf0f4)[0x7f80f3bb80f4]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCReset+0x346)[0x7f80f3a796de]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(KSPReset+0x502)[0x7f80f3d19779]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x11707f7)[0x7f80f3c697f7]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCDestroy+0x5d1)[0x7f80f3a79fd9]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(KSPDestroy+0x7b6)[0x7f80f3d1a334]
>>     a similar one:
>>     *** Error in
>> `/pmi/cmpbib/compilation_BIB_dernier_ompi/COMPILE_AUTO/GIREF/bin/Test.ProbFluideIncompressible.dev':
>>     free(): invalid pointer: 0x00007f382a7c5bc0 ***
>>     /lib64/libc.so.6(+0x7277f)[0x7f3829f1c77f]
>>     /lib64/libc.so.6(+0x78026)[0x7f3829f22026]
>>     /lib64/libc.so.6(+0x78d53)[0x7f3829f22d53]
>> /opt/openmpi-2.x_opt/lib/libopen-pal.so.20(opal_free+0x1f)[0x7f38296ffd60]
>> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16628)[0x7f381deab628]
>> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x16c50)[0x7f381deabc50]
>>     /opt/openmpi-2.x_opt/lib/libmpi.so.20(+0x9f9dd)[0x7f382a5089dd]
>> /opt/openmpi-2.x_opt/lib/libmpi.so.20(MPI_Request_free+0xf7)[0x7f382a508ad6]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4adc6d)[0x7f3831dacc6d]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecScatterDestroy+0x68d)[0x7f3831da7c45]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x9f4755)[0x7f38322f3755]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(MatDestroy+0x648)[0x7f38323c8588]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCReset+0x4e2)[0x7f383287f87a]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(PCDestroy+0x5d1)[0x7f383287ffd9]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(KSPDestroy+0x7b6)[0x7f3832b20334]
>>     another one:
>>     *** Error in
>> `/pmi/cmpbib/compilation_BIB_dernier_ompi/COMPILE_AUTO/GIREF/bin/Test.MortierDiffusion.dev':
>>     free(): invalid pointer: 0x00007f67b6d37bc0 ***
>>     /lib64/libc.so.6(+0x7277f)[0x7f67b648e77f]
>>     /lib64/libc.so.6(+0x78026)[0x7f67b6494026]
>>     /lib64/libc.so.6(+0x78d53)[0x7f67b6494d53]
>> /opt/openmpi-2.x_opt/lib/libopen-pal.so.20(opal_free+0x1f)[0x7f67b5c71d60]
>> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x1adae)[0x7f67aa4cddae]
>> /opt/openmpi-2.x_opt/lib/openmpi/mca_pml_ob1.so(+0x1b4ca)[0x7f67aa4ce4ca]
>>     /opt/openmpi-2.x_opt/lib/libmpi.so.20(+0x9f9dd)[0x7f67b6a7a9dd]
>> /opt/openmpi-2.x_opt/lib/libmpi.so.20(MPI_Request_free+0xf7)[0x7f67b6a7aad6]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4adb09)[0x7f67be31eb09]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecScatterDestroy+0x68d)[0x7f67be319c45]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(+0x4574f7)[0x7f67be2c84f7]
>> /opt/petsc-3.7.2_debug_openmpi_2.x/lib/libpetsc.so.3.7(VecDestroy+0x648)[0x7f67be26e8da]
>>     I feel like I should wait until someone else from Petsc have tested
>>     it too...
>>     Thanks,
>>     Eric
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160725/5823a5ac/attachment.html>
