[petsc-users] Regarding ksp ex42 - Citations
domenico lahaye domenico_lahaye at yahoo.com
Thu Jul 21 09:09:02 CDT 2016
Thank you for sharing the additional insight.
The separate Galerkin coarsening of A and M will be part of the overall algorithm only.
I think it is wise to implement in two stages: first a fragile implementation and later
a more stable one.
Kind wishes, Domenico.
      From: Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk>
 To: domenico lahaye <domenico_lahaye at yahoo.com>
Cc: PETSc Users List <petsc-users at mcs.anl.gov>
 Sent: Thursday, July 21, 2016 1:09 PM
 Subject: Re: [petsc-users] Regarding ksp ex42 - Citations
> On 21 Jul 2016, at 10:55, domenico lahaye <domenico_lahaye at yahoo.com> wrote:
> Apologies for being not sufficient clear in my previous message.
> I would like to be able to Galerkin coarsen A^h to obtain A^H
> and to separately Galerkin coarsen M^h to obtain M^H.
> So, yes, the way in which I currently (partially) understand your
> description of the new DMCreateMatrices would do the job.
If you want to separately coarsen A and M via Galerkin, I think it will be easier to just change the code in PCSetUp_MG to handle the case where A and M are different on the coarse levels.  Effectively you just need to replicate the code that computes the coarse grid "B" matrix to separately compute coarse grid A and B matrices and pass them in to KSPSetOperators.
Cheers,
Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160721/c958970d/attachment.html>
