[petsc-users] Regarding ksp ex42 - Citations
domenico lahaye domenico_lahaye at yahoo.com
Thu Jul 21 04:55:45 CDT 2016
Apologies for being not sufficient clear in my previous message.
I would like to be able to Galerkin coarsen A^h to obtain A^H and to separately Galerkin coarsen M^h to obtain M^H.
So, yes, the way in which I currently (partially) understand your description of the new DMCreateMatrices would do the job.
What is a sensible way to proceed?
Thanks, Domenico.
      From: Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk>
 To: domenico lahaye <domenico_lahaye at yahoo.com>
Cc: petsc-users at mcs.anl.gov
 Sent: Thursday, July 21, 2016 11:25 AM
 Subject: Re: [petsc-users] Regarding ksp ex42 - Citations
[Reintroducing petsc-users in cc]
On 21/07/16 10:18, domenico lahaye wrote:
> Thanks Lauwrence.
> Does the fact that the coarse level preconditioner M^H should be
> constructed
> by Galerkin coarse (rather then rediscretization) cause additional
> wrinkles?
Do you want to rediscretise A, but use a galerkin coarse grid M?
If so, that is currently unsupported in PCMG:  In PCSetUp_MG (mg.c,
line 660 or so):
if (mg->galerkin == 1) {
  /* Currently only handle case where mat and pmat are the same on
coarser levels */
I guess if you're managing the creation of the coarse grid operators
yourself via KSPSetComputeOperators and a putative (new)
DMCreateMatrices then you'd have the flexibility to do separate things
for A and M (including, I think, galerkin coarse M).  Since you have
access to the DM hierarchy inside your compute operators.
Make sense?
Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160721/0e385656/attachment.html>
