[petsc-users] Questions for MatSolve
Tue Jul 19 22:03:55 CDT 2016
On Tue, Jul 19, 2016 at 8:17 PM, Eduardo Jourdan <eduardojourdan92 at gmail.com
> wrote:
> Hi all,
> I would like to perform a specific number (for instance 4 of forward and
> backward sweeps with a seqaij matrix with block size 4, vectors b and x.
> Also, I need to do this same procedure with another matrix seqaij block
> size 16. I would appreciate if someone knows the best way to do it.
It sounds like you want PCSOR and PCApply, not MatSolve.
     Matt
> 1 - I've been trying to use MatSolve. For the bs=4 it seems to work, but
> with the other matrix with bs=16 the residue diverges. When I call
> matConvert to convert the later matrix for a seqbaij with bs=16 the result
> changes and the linear residue is reduced. It is supposed to happen or it
> is more possible that i am doing something wrong?
> 2 - MatSolve for seqbaij and seqaij with the same block sizes gives the
> same results in terms of solution (not performace, memory) ?
> 3 - Can do I do a specific number of sweeps as told before with the KSP/PC
> interface?
> 4 - I saw the manual for the MatSolve and It says that it is for factored
> matrix. Can I use a matrix just after the MatAssembly calls?
> Best regards,
> Eduardo Jourdan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160720/e8dbd295/attachment-0001.html>
