[petsc-users] Questions for MatSolve
Eduardo Jourdan eduardojourdan92 at gmail.com
Tue Jul 19 13:17:52 CDT 2016
Hi all,
I would like to perform a specific number (for instance 4 of forward and
backward sweeps with a seqaij matrix with block size 4, vectors b and x.
Also, I need to do this same procedure with another matrix seqaij block
size 16. I would appreciate if someone knows the best way to do it.
1 - I've been trying to use MatSolve. For the bs=4 it seems to work, but
with the other matrix with bs=16 the residue diverges. When I call
matConvert to convert the later matrix for a seqbaij with bs=16 the result
changes and the linear residue is reduced. It is supposed to happen or it
is more possible that i am doing something wrong?
2 - MatSolve for seqbaij and seqaij with the same block sizes gives the
same results in terms of solution (not performace, memory) ?
3 - Can do I do a specific number of sweeps as told before with the KSP/PC
interface?
4 - I saw the manual for the MatSolve and It says that it is for factored
matrix. Can I use a matrix just after the MatAssembly calls?
Best regards,
Eduardo Jourdan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160719/9f757f3b/attachment.html>
