[petsc-users] Regarding ksp ex42 - Citations
Fri Jul 15 22:54:48 CDT 2016
On Fri, Jul 15, 2016 at 10:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jul 14, 2016, at 12:21 PM, domenico lahaye <domenico_lahaye at yahoo.com>
> wrote:
> > Dear PETSc team,
> > 1) I am looking into ks/examples/tutorials/ex42.c
>    This example is really written as only a one level solver, making it
> work with geometric multigrid is not clean
> > I am still new to the DMDA structure
> >     and likely not giving it as much time as it deserves. However, I do
> not see immediately
> >     what function is responsible for calling PCMGSetSmoother and
> PCMGSetResidual.
> >      I tried to call PCMGGetCoarseSolve(pc, &kcpc) and subsequently
> >      KSPGetOperators (kspc, ... ) to check how the coarse grid operator
> is defined
> >      after calling DMCoarsenHierarchy, but that failed.
> >      I am solving Helmholtz with shifted Laplace, and managed to exploit
> DMDA to perform
> >      a multigrid solve on the preconditioner. In a next stage I want to
> implement the deflation
> >      using DMDA as well.
>   You should look at ex25.c in the same directory. Here
>   ierr = KSPSetDM(ksp,da);CHKERRQ(ierr);
>   ierr = KSPSetComputeRHS(ksp,ComputeRHS,&user);CHKERRQ(ierr);
>   ierr = KSPSetComputeOperators(ksp,ComputeMatrix,&user);CHKERRQ(ierr);
> make it straight forward to work with multigrid. The KSP object can mange
> the hierarchy of grids since it is provided with the DM
> and the ComputeRHS and ComputeMatrix provide a way for the multigrid
> preconditioner to automatically generate the needed matrix on each level
> without you having to manage it yourself. For example the rule in the
> makefile
> runex25:
>         -@${MPIEXEC} -n 1 ./ex25 -pc_type mg -ksp_type fgmres -da_refine 2
> -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type
> unpreconditioned -ksp_view -pc_mg_type full  > ex25_1.tmp 2>&1;       \
>            if (${DIFF} output/ex25_1.out ex25_1.tmp) then true; \
>            else printf "${PWD}\nPossible problem with ex25_1, diffs
> above\n=========================================\n"; fi; \
>            ${RM} -f ex25_1.tmp
> shows how to run with two levels. etc.
> > 2) On http://www.mcs.anl.gov/petsc/documentation/referencing.html I see
> > @Misc{petsc-web-page,
> >             author = {Satish Balay and Shrirang Abhyankar and Mark~F.
> Adams and Jed Brown and Peter Brune
> >                       and Kris Buschelman and Lisandro Dalcin and Victor
> Eijkhout and William~D. Gropp
> >                       and Dinesh Kaushik and Matthew~G. Knepley
> >                       and Lois Curfman McInnes and Karl Rupp and
> Barry~F. Smith
> >                       and Stefano Zampini and Hong Zhang and Hong Zhang},
> >             title =  {{PETS}c {W}eb page},
> >             url =    {http://www.mcs.anl.gov/petsc},
> >             howpublished = {\url{http://www.mcs.anl.gov/petsc}},
> >             year = {2016}
> > Is the last author mentioned twice intentionally?
That is actually two different people with the same name.
> > 3) On
> http://www.mcs.anl.gov/petsc/publications/petscapps-bib.html#OpenFOAM%202.2.1
> I see
> > @misc{OpenFOAM
> > title =       "OpenFOAM",
> > howpublished  =       "\url{http://www.openfoam.com}",
> > url   =       {http://www.openfoam.com},
> > note  =       "OpenFOAM is a free, open source CFD software package. It
> allows PETSc linear algebra and solvers to be used underneath.",
> > key   =       "OpenFOAM 2.2.1"
> > Do you have more information on the use of PETSc within OpenFoam?
They only use solvers, and not the DM stuff as far as I know.
> > 4) @matt in response to a question he raised in Vienna
> > MIPSE is a BEM solver. Details are on:
> http://www.g2elab.grenoble-inp.fr/plateforms/mipse-modeling-of-interconnected-power-systems-632862.kjsp?RH=G2ELAB_R-MAGE
>From what I can tell, the code is not open source. Is that right?
     Matt
> > Cheers, Domenico Lahaye.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160715/a22c6d96/attachment-0001.html>
