[petsc-users] Regarding ksp ex42 - Citations
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Jul 15 22:48:14 CDT 2016
> On Jul 14, 2016, at 12:21 PM, domenico lahaye <domenico_lahaye at yahoo.com> wrote:
> Dear PETSc team,
> 1) I am looking into ks/examples/tutorials/ex42.c
   This example is really written as only a one level solver, making it work with geometric multigrid is not clean
> I am still new to the DMDA structure
>     and likely not giving it as much time as it deserves. However, I do not see immediately
>     what function is responsible for calling PCMGSetSmoother and PCMGSetResidual.
>      I tried to call PCMGGetCoarseSolve(pc, &kcpc) and subsequently
>      KSPGetOperators (kspc, ... ) to check how the coarse grid operator is defined
>      after calling DMCoarsenHierarchy, but that failed.
>      I am solving Helmholtz with shifted Laplace, and managed to exploit DMDA to perform
>      a multigrid solve on the preconditioner. In a next stage I want to implement the deflation
>      using DMDA as well.
  You should look at ex25.c in the same directory. Here
  ierr = KSPSetDM(ksp,da);CHKERRQ(ierr);
  ierr = KSPSetComputeRHS(ksp,ComputeRHS,&user);CHKERRQ(ierr);
  ierr = KSPSetComputeOperators(ksp,ComputeMatrix,&user);CHKERRQ(ierr);
make it straight forward to work with multigrid. The KSP object can mange the hierarchy of grids since it is provided with the DM
and the ComputeRHS and ComputeMatrix provide a way for the multigrid preconditioner to automatically generate the needed matrix on each level without you having to manage it yourself. For example the rule in the makefile
runex25:
	-@${MPIEXEC} -n 1 ./ex25 -pc_type mg -ksp_type fgmres -da_refine 2 -ksp_monitor_short -mg_levels_ksp_monitor_short -mg_levels_ksp_norm_type unpreconditioned -ksp_view -pc_mg_type full  > ex25_1.tmp 2>&1;	  \
	   if (${DIFF} output/ex25_1.out ex25_1.tmp) then true; \
	   else printf "${PWD}\nPossible problem with ex25_1, diffs above\n=========================================\n"; fi; \
	   ${RM} -f ex25_1.tmp
shows how to run with two levels. etc.
> 2) On http://www.mcs.anl.gov/petsc/documentation/referencing.html I see
> @Misc{petsc-web-page,
>             author = {Satish Balay and Shrirang Abhyankar and Mark~F. Adams and Jed Brown and Peter Brune
>                       and Kris Buschelman and Lisandro Dalcin and Victor Eijkhout and William~D. Gropp
>                       and Dinesh Kaushik and Matthew~G. Knepley
>                       and Lois Curfman McInnes and Karl Rupp and Barry~F. Smith
>                       and Stefano Zampini and Hong Zhang and Hong Zhang},
>             title =  {{PETS}c {W}eb page},
>             url =    {http://www.mcs.anl.gov/petsc},
>             howpublished = {\url{http://www.mcs.anl.gov/petsc}},
>             year = {2016}
> Is the last author mentioned twice intentionally?
> 3) On http://www.mcs.anl.gov/petsc/publications/petscapps-bib.html#OpenFOAM%202.2.1 I see
> @misc{OpenFOAM
> title	=	"OpenFOAM",
> howpublished	=	"\url{http://www.openfoam.com}",
> url	=	{http://www.openfoam.com},
> note	=	"OpenFOAM is a free, open source CFD software package. It allows PETSc linear algebra and solvers to be used underneath.",
> key	=	"OpenFOAM 2.2.1"
> Do you have more information on the use of PETSc within OpenFoam?
> 4) @matt in response to a question he raised in Vienna
> MIPSE is a BEM solver. Details are on:
> http://www.g2elab.grenoble-inp.fr/plateforms/mipse-modeling-of-interconnected-power-systems-632862.kjsp?RH=G2ELAB_R-MAGE
> Cheers, Domenico Lahaye.
