[petsc-users] Using Petsc with Finite Elements Domain Decomposition
Tue Jul 12 04:13:26 CDT 2016
On Tue, Jul 12, 2016 at 3:35 AM, Ivano Barletta <ibarletta at inogs.it> wrote:
> Dear Petsc users
> my aim is to parallelize the solution of a linear
> system into a finite elements
> ocean model.
> The model has been almost entirely parallelized, with
> a partitioning of the domain made element-wise through
> the use of Zoltan libraries, so the subdomains
> share the nodes lying on the edges.
> The linear system includes node-to-node dependencies
> so my guess is that I need to create an halo surrounding
> each subdomain, to allow connections of edge nodes with
> neighbour subdomains ones
> Apart from that, my question is if Petsc accept a
> previously made partitioning (maybe taking into account of halo)
> using the data structures coming out of it
> Has anybody of you ever faced a similar problem?
If all you want to do is construct a PETSc Mat and Vec for the linear
system,
just give PETSc the non-overlapping partition to create those objects. You
can input values on off-process partitions automatically using
MatSetValues()
and VecSetValues().
    Matt
> Thanks in advance
> Ivano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160712/6f6149f8/attachment.html>
