[petsc-users] Diagonalization of a 3D dense matrix
Mon Jul 11 13:24:51 CDT 2016
On Mon, Jul 11, 2016 at 1:22 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> Matthew,
> I am probably not using the right language but I meant that each element
> has three indices associated with it: x, y, z.
> Here is a snapshot:
> 1 10 55    5.7113635929515209e-03
>  1 10 56    4.2977490038287334e-03
>  1 10 57    2.8719519782193204e-03
>  1 10 58    1.4380140927001712e-03
>  1 10 59    9.9299930690365083e-17
>  1 11  0    0.0000000000000000e+00
>  1 11  1    1.5658614070601917e-03
>  1 11  2    3.1272842098367562e-03
>  1 11  3    4.6798423857521204e-03
> Where the first three columns are the coordinates and the last one is
> value.
This is not a matrix. A matrix is a linear operator on some space with a
finite basis: https://en.wikipedia.org/wiki/Matrix_(mathematics)
This is just a set of data points.
Most people would call this a vector, since you have an index I (which
consists of each independent triple) and a value V.
> Could you clarify the meaning of "diagonalization is not a clear concept"
> if it is applicable to this case.
There is no one definition of tensor diagonalization.
   Matt
> Thank you,
> Ketan
> On Mon, Jul 11, 2016 at 1:15 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Jul 11, 2016 at 12:05 PM, Ketan Maheshwari <
>>> Hello PETSC-ers,
>>> I am a research faculty at Univ of Pittsburgh trying to use PETSC/SLEPC
>>> to
>>> obtain the diagonalization of a large matrix using Lanczos or Davidson
>>> method.
>>> The matrix is a 3 dimensional dense matrix with a total of 216000
>>> elements.
>>> After looking into some of the examples in PETSC as well SLEPC
>>> implementations
>>> it seems like most of the implementations are with 2 dimensional
>>> matrices.
>> You will have to explain what you mean by a "3D matrix". A matrix, by
>> definition, has only
>> rows and columns. You may mean a matrix generated from a 3D problem. That
>> should pose
>> no extra difficulty. You may mean a 3-index tensor, in which case
>> concept.
>>   Thanks,
>>      Matt
>>> So, I was wondering if it is possible to express a 3 dimensional matrix
>>> object
>>> compatible to PETSC so that the SLEPC API could be used to obtain
>>> diagonalization.
>>> Any suggestions or pointers to documentation or examples would be of
>>> great
>>> help.
>>> Best,
>>> Ketan
>> experiments lead.
>> -- Norbert Wiener
> Ketan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160711/f182f229/attachment.html>
