[petsc-users] (edit GAMG) petsc 3.7.2 memory usage is much higher when compared to 3.6.1
Mark Adams mfadams at lbl.gov
Thu Jul 7 13:30:32 CDT 2016
> > GAMG: createProl       6 1.0 1.0036e+01 1.0 3.68e+07 1.2 1.5e+06 2.7e+03
> 1.3e+03  1  0 23  1 31   1  0 23  1 31  1332
> >   Graph               12 1.0 6.0783e+00 1.0 4.52e+06 1.1 3.8e+05 9.0e+02
> 2.5e+02  1  0  6  0  6   1  0  6  0  6   279
> >   MIS/Agg              6 1.0 9.5831e-02 1.2 0.00e+00 0.0 2.6e+05 1.1e+03
> 4.1e+01  0  0  4  0  1   0  0  4  0  1     0
> >   SA: col data         6 1.0 7.7358e-01 1.0 0.00e+00 0.0 6.7e+05 2.9e+03
> 7.8e+02  0  0 10  0 19   0  0 10  0 19     0
> >   SA: frmProl0         6 1.0 1.0759e+00 1.0 0.00e+00 0.0 6.2e+04 7.6e+03
> 6.0e+01  0  0  1  0  1   0  0  1  0  1     0
> > GAMG: partLevel        6 1.0 3.8136e+01 1.0 9.09e+08 1.1 3.8e+05 5.0e+04
> 5.4e+02  6  3  6  4 13   6  3  6  4 14  9013
> >   repartition          6 1.0 2.7910e+00 1.0 0.00e+00 0.0 4.6e+04 1.3e+02
> 1.6e+02  0  0  1  0  4   0  0  1  0  4     0
> >   Invert-Sort          6 1.0 2.5045e+00 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.4e+01  0  0  0  0  1   0  0  0  0  1     0
> >   Move A               6 1.0 1.4832e+01 1.0 0.00e+00 0.0 8.5e+04 1.7e+05
> 1.1e+02  2  0  1  3  3   2  0  1  3  3     0
> >   Move P               6 1.0 1.2023e+01 1.0 0.00e+00 0.0 2.4e+04 3.8e+03
> 1.1e+02  2  0  0  0  3   2  0  0  0  3     0
THe number of these calls (eg, 6) is the number of grids that are setup.
> > PCSetUp              100 1.0 1.1212e+02 1.0 1.84e+10 1.1 3.2e+06 1.3e+05
> 2.2e+03 17 52 49 84 54  17 52 49 84 54 62052
> > PCSetUpOnBlocks       40 1.0 1.0386e+00 1.2 1.95e+08 1.2 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0 67368
> > PCApply              380 1.0 2.0034e+01 1.1 8.60e+09 1.1 1.5e+06 9.9e+03
> 6.0e+01  3 24 22  3  1   3 24 22  3  1 161973
> > SFSetGraph            12 1.0 4.9813e-0310.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > SFBcastBegin          47 1.0 3.3110e-02 2.6 0.00e+00 0.0 2.6e+05 1.1e+03
> 6.0e+00  0  0  4  0  0   0  0  4  0  0     0
> > SFBcastEnd            47 1.0 1.3497e-02 3.6 0.00e+00 0.0 0.0e+00 0.0e+00
> > SFReduceBegin          6 1.0 1.8593e-02 4.2 0.00e+00 0.0 7.2e+04 4.9e+02
> 6.0e+00  0  0  1  0  0   0  0  1  0  0     0
> > SFReduceEnd            6 1.0 7.1628e-0318.5 0.00e+00 0.0 0.0e+00 0.0e+00
> > BuildTwoSided         12 1.0 3.5771e-02 2.5 0.00e+00 0.0 5.0e+04 4.0e+00
> 1.2e+01  0  0  1  0  0   0  0  1  0  0     0
> > Memory usage is given in bytes:
> > Object Type          Creations   Destructions     Memory  Descendants'
> Mem.
> > Reports information only for process 0.
> > --- Event Stage 0: Main Stage
> >               Matrix   302            299   1992700700     0.
> > Matrix Partitioning     6              6         3888     0.
> >       Matrix Coarsen     6              6         3768     0.
> >               Vector   600            600   1582204168     0.
> >       Vector Scatter    87             87      5614432     0.
> >        Krylov Solver    11             11        59472     0.
> >       Preconditioner    11             11        11120     0.
> >          PetscRandom     1              1          638     0.
> >               Viewer     1              0            0     0.
> >            Index Set   247            247      9008420     0.
> > Star Forest Bipartite Graph    12             12        10176     0.
> > And for  petsc 3.6.1:
> > Using Petsc Development GIT revision: v3.6.1-307-g26c82d3  GIT Date:
> > 2015-08-06 11:50:34 -0500
> >                          Max       Max/Min        Avg      Total
> > Time (sec):           5.515e+02      1.00001   5.515e+02
> > Objects:              1.231e+03      1.00490   1.226e+03
> > Flops:                3.431e+10      1.12609   3.253e+10  1.301e+13
> > Flops/sec:            6.222e+07      1.12609   5.899e+07  2.359e+10
> > MPI Messages:         4.432e+04      7.84165   1.504e+04  6.016e+06
> > MPI Message Lengths:  2.236e+09     12.61261   5.027e+04  3.024e+11
> > MPI Reductions:       4.012e+03      1.00150
> > Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> >                             e.g., VecAXPY() for real vectors of length N
> --> 2N flops
> >                             and VecAXPY() for complex vectors of
> > length N --> 8N flops
> > Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
> >                         Avg     %Total     Avg     %Total   counts
>  %Total     Avg         %Total   counts   %Total
> > 0:      Main Stage: 5.5145e+02 100.0%  1.3011e+13 100.0%  6.007e+06
> 99.9%  5.020e+04       99.9%  3.999e+03  99.7%
> > See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> > Phase summary info:
> >    Count: number of times phase was executed
> >    Time and Flops: Max - maximum over all processors
> >                    Ratio - ratio of maximum to minimum over all
> processors
> >    Mess: number of messages sent
> >    Avg. len: average message length (bytes)
> >    Reduct: number of global reductions
> >    Global: entire computation
> >    Stage: stages of a computation. Set stages with PetscLogStagePush()
> and PetscLogStagePop().
> >       %T - percent time in this phase         %F - percent flops in this
> phase
> >       %M - percent messages in this phase     %L - percent message
> lengths in this phase
> >       %R - percent reductions in this phase
> >    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
> > Event                Count      Time (sec)     Flops
>          --- Global ---  --- Stage ---   Total
> >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > MatMult              500 1.0 1.0172e+01 1.2 6.68e+09 1.1 1.9e+06 9.9e+03
> 0.0e+00  2 19 31  6  0   2 19 31  6  0 247182
> > MatMultTranspose     120 1.0 6.9889e-01 1.2 3.56e+08 1.1 2.5e+05 1.4e+04
> 0.0e+00  0  1  4  1  0   0  1  4  1  0 197492
> > MatSolve             380 1.0 3.9310e+00 1.1 1.17e+09 1.1 1.3e+04 5.7e+01
> 6.0e+01  1  3  0  0  1   1  3  0  0  2 112069
> > MatSOR               120 1.0 1.3915e+01 1.1 6.73e+09 1.1 9.5e+05 7.4e+03
> 0.0e+00  2 20 16  2  0   2 20 16  2  0 182405
> > MatLUFactorSym         2 1.0 2.1180e-01 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
> > MatLUFactorNum        60 1.0 7.9378e+00 1.0 1.95e+08 1.2 0.0e+00 0.0e+00
> 0.0e+00  1  1  0  0  0   1  1  0  0  0  8814
> > MatILUFactorSym        1 1.0 2.3076e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatConvert             6 1.0 3.2693e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.8e+01  0  0  0  0  0   0  0  0  0  0     0
> > MatScale               6 1.0 2.1923e-02 1.7 4.50e+06 1.1 2.4e+04 1.5e+03
> 0.0e+00  0  0  0  0  0   0  0  0  0  0 77365
> > MatAssemblyBegin     266 1.0 1.0337e+01 4.4 0.00e+00 0.0 1.8e+05 3.8e+03
> 4.2e+02  1  0  3  0 10   1  0  3  0 10     0
> > MatAssemblyEnd       266 1.0 3.0336e+00 1.0 0.00e+00 0.0 4.1e+05 8.6e+02
> 4.7e+02  1  0  7  0 12   1  0  7  0 12     0
> > MatGetRow        6730366 1.1 8.6473e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetRowIJ            3 3.0 5.2931e-035550.2 0.00e+00 0.0 0.0e+00
> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > MatGetSubMatrix       12 1.0 2.2689e+01 1.0 0.00e+00 0.0 1.1e+05 1.3e+05
> 1.9e+02  4  0  2  5  5   4  0  2  5  5     0
> > MatGetOrdering         3 3.0 6.5000e-03 5.4 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatPartitioning        6 1.0 2.9801e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.4e+01  1  0  0  0  0   1  0  0  0  0     0
> > MatCoarsen             6 1.0 9.5374e-02 1.1 0.00e+00 0.0 2.5e+05 1.1e+03
> 3.8e+01  0  0  4  0  1   0  0  4  0  1     0
> > MatZeroEntries        22 1.0 6.1185e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatTranspose           6 1.0 1.9780e-01 1.1 0.00e+00 0.0 1.9e+05 8.6e+02
> 7.8e+01  0  0  3  0  2   0  0  3  0  2     0
> > MatPtAP              120 1.0 5.2996e+01 1.0 1.70e+10 1.1 9.7e+05 2.1e+05
> 4.2e+02 10 49 16 67 10  10 49 16 67 11 120900
> > MatPtAPSymbolic       12 1.0 5.8209e+00 1.0 0.00e+00 0.0 2.2e+05 3.7e+04
> 8.4e+01  1  0  4  3  2   1  0  4  3  2     0
> > MatPtAPNumeric       120 1.0 4.7185e+01 1.0 1.70e+10 1.1 7.6e+05 2.6e+05
> 3.4e+02  9 49 13 64  8   9 49 13 64  8 135789
> > MatTrnMatMult          3 1.0 1.1679e+00 1.0 3.22e+07 1.2 8.2e+04 8.0e+03
> 5.7e+01  0  0  1  0  1   0  0  1  0  1  9997
> > MatTrnMatMultSym       3 1.0 6.8366e-01 1.0 0.00e+00 0.0 6.9e+04 3.9e+03
> 5.1e+01  0  0  1  0  1   0  0  1  0  1     0
> > MatTrnMatMultNum       3 1.0 4.8513e-01 1.0 3.22e+07 1.2 1.3e+04 3.0e+04
> 6.0e+00  0  0  0  0  0   0  0  0  0  0 24069
> > MatGetLocalMat       126 1.0 1.1939e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
> > MatGetBrAoCol        120 1.0 5.9887e-01 2.7 0.00e+00 0.0 5.7e+05 3.3e+04
> 0.0e+00  0  0  9  6  0   0  0  9  6  0     0
> > MatGetSymTrans        24 1.0 1.4878e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecDot               320 1.0 1.5860e+00 1.5 2.04e+08 1.1 0.0e+00 0.0e+00
> 3.2e+02  0  1  0  0  8   0  1  0  0  8 49574
> > VecMDot              260 1.0 1.8154e+00 2.5 3.70e+08 1.1 0.0e+00 0.0e+00
> 2.6e+02  0  1  0  0  6   0  1  0  0  7 78497
> > VecNorm              440 1.0 2.8876e+00 1.8 5.88e+08 1.1 0.0e+00 0.0e+00
> 4.4e+02  0  2  0  0 11   0  2  0  0 11 78281
> > VecScale             320 1.0 2.2738e-01 1.2 7.88e+07 1.1 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0 133517
> > VecCopy              220 1.0 7.1162e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecSet               862 1.0 7.0683e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecAXPY              440 1.0 9.0657e-01 1.2 3.83e+08 1.1 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0 162612
> > VecAYPX              280 1.0 5.8935e-01 1.5 1.92e+08 1.1 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0 125070
> > VecMAXPY             300 1.0 9.7644e-01 1.2 4.98e+08 1.1 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0 196269
> > VecAssemblyBegin     234 1.0 5.0308e+00 5.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 6.8e+02  1  0  0  0 17   1  0  0  0 17     0
> > VecAssemblyEnd       234 1.0 1.8253e-03 8.8 0.00e+00 0.0 0.0e+00 0.0e+00
> > VecScatterBegin     1083 1.0 2.8195e-01 4.7 0.00e+00 0.0 3.8e+06 8.4e+03
> 2.0e+01  0  0 64 11  0   0  0 64 11  1     0
> > VecScatterEnd       1063 1.0 3.4924e+00 6.9 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPGMRESOrthog        20 1.0 1.5598e+00 3.2 1.28e+08 1.1 0.0e+00 0.0e+00
> 2.0e+01  0  0  0  0  0   0  0  0  0  1 31503
> > KSPSetUp             222 1.0 9.7521e-02 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.2e+01  0  0  0  0  0   0  0  0  0  0     0
> > KSPSolve              60 1.0 1.3742e+02 1.0 3.42e+10 1.1 5.7e+06 4.4e+04
> 3.2e+03 25100 95 83 79  25100 95 83 79 94396
> > PCGAMGGraph_AGG        6 1.0 5.7683e+00 1.0 4.50e+06 1.1 3.8e+05 9.1e+02
> 2.5e+02  1  0  6  0  6   1  0  6  0  6   294
> > PCGAMGCoarse_AGG       6 1.0 1.4101e+00 1.0 3.22e+07 1.2 4.0e+05 3.2e+03
> 1.4e+02  0  0  7  0  4   0  0  7  0  4  8280
> > PCGAMGProl_AGG         6 1.0 1.8976e+00 1.0 0.00e+00 0.0 7.2e+05 3.4e+03
> 8.6e+02  0  0 12  1 22   0  0 12  1 22     0
> > PCGAMGPOpt_AGG         6 1.0 5.7220e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
> > GAMG: createProl       6 1.0 9.0840e+00 1.0 3.67e+07 1.2 1.5e+06 2.7e+03
> 1.3e+03  2  0 25  1 31   2  0 25  1 31  1472
> >   Graph               12 1.0 5.7669e+00 1.0 4.50e+06 1.1 3.8e+05 9.1e+02
> >   MIS/Agg              6 1.0 9.5481e-02 1.1 0.00e+00 0.0 2.5e+05 1.1e+03
> >   SA: col data         6 1.0 8.5414e-01 1.0 0.00e+00 0.0 6.6e+05 3.0e+03
> 7.8e+02  0  0 11  1 19   0  0 11  1 20     0
> >   SA: frmProl0         6 1.0 1.0123e+00 1.0 0.00e+00 0.0 6.2e+04 7.6e+03
> 6.0e+01  0  0  1  0  1   0  0  1  0  2     0
> > GAMG: partLevel        6 1.0 3.6150e+01 1.0 8.41e+08 1.1 3.5e+05 5.0e+04
> 5.3e+02  7  2  6  6 13   7  2  6  6 13  8804
> >   repartition          6 1.0 3.8351e+00 1.0 0.00e+00 0.0 4.7e+04 1.3e+02
> 1.6e+02  1  0  1  0  4   1  0  1  0  4     0
> >   Invert-Sort          6 1.0 4.4953e+00 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.4e+01  1  0  0  0  1   1  0  0  0  1     0
> >   Move A               6 1.0 1.0806e+01 1.0 0.00e+00 0.0 8.5e+04 1.6e+05
> 1.0e+02  2  0  1  5  3   2  0  1  5  3     0
> >   Move P               6 1.0 1.1953e+01 1.0 0.00e+00 0.0 2.5e+04 3.6e+03
> 1.0e+02  2  0  0  0  3   2  0  0  0  3     0
> > PCSetUp              100 1.0 1.0166e+02 1.0 1.72e+10 1.1 2.7e+06 8.3e+04
> 2.2e+03 18 50 44 73 54  18 50 44 73 54 63848
> > PCSetUpOnBlocks       40 1.0 1.0812e+00 1.2 1.95e+08 1.2 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0 64711
> > PCApply              380 1.0 1.9359e+01 1.1 8.58e+09 1.1 1.4e+06 9.6e+03
> 6.0e+01  3 25 24  5  1   3 25 24  5  2 167605
> > SFSetGraph            12 1.0 3.5203e-03 6.8 0.00e+00 0.0 0.0e+00 0.0e+00
> > SFBcastBegin          44 1.0 2.4242e-02 3.0 0.00e+00 0.0 2.5e+05 1.1e+03
> > SFBcastEnd            44 1.0 3.0994e-02 8.6 0.00e+00 0.0 0.0e+00 0.0e+00
> > SFReduceBegin          6 1.0 1.6784e-02 3.8 0.00e+00 0.0 7.1e+04 5.0e+02
> > SFReduceEnd            6 1.0 8.6989e-0332.0 0.00e+00 0.0 0.0e+00 0.0e+00
> Mem.
> >               Matrix   246            243   1730595756     0
> > Matrix Partitioning     6              6         3816     0
> >       Matrix Coarsen     6              6         3720     0
> >               Vector   602            602   1603749672     0
> >       Vector Scatter    87             87      4291136     0
> >        Krylov Solver    12             12        60416     0
> >       Preconditioner    12             12        12040     0
> >               Viewer     1              0            0     0
> >            Index Set   247            247      9018060     0
> > Star Forest Bipartite Graph    12             12        10080     0
> > Any idea why there are more matrix created with version 3.7.2? I only
> have 2 MatCreate calls and 4 VecCreate calls in my code!, so I assume the
> others are internally created.
> > Thank you,
> > Hassan Raiesi, PhD
> > Advanced Aerodynamics Department
> > Bombardier Aerospace
> > hassan.raiesi at aero.bombardier.com
> > 2351 boul. Alfred-Nobel (BAN1)
> > Ville Saint-Laurent, Québec, H4S 2A9
> > Tél.
> >   514-855-5001    # 62204
> > <image001.png>
> > CONFIDENTIALITY NOTICE - This communication may contain privileged or
> confidential information.
> > If you are not the intended recipient or received this communication
> > by error, please notify the sender and delete the message without
> copying, forwarding and/or disclosing it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160707/914f1776/attachment-0001.html>
