[petsc-users] Dose Petsc has DMPlex example
Hoang Giang Bui hgbk2008 at gmail.com
Sun Jul 3 03:49:05 CDT 2016
Thanks Justin. It works. The difference is these parameters:
-vel_petscspace_order 2 -pres_petscspace_order 1. Which is quite cool since
you can play with those orders to see how LBB condition affects the results.
Giang
Giang
On Sun, Jul 3, 2016 at 10:15 AM, Justin Chang <jychang48 at gmail.com> wrote:
> Hoang, if you run this example shown from the config/builder.py
> ./ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
> -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type
> fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
> -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full
> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres
> -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
> -ksp_converged_reason -snes_view -show_solution 0
> it should work
> On Sun, Jul 3, 2016 at 9:06 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
> wrote:
>> Hi Matt
>> I tried to run ex62 with 1 proc (petsc 3.7.2), but it all produces zero
>> The output is:
>> hbui at bermuda:~/workspace/petsc/snes$ es$ ./ex62 run_type full -bc_type
>> dirichlet -refinement_limit 0.00625 -interpolate 1 -snes_monitor_short
>> -snes_converged_reason -snes_view -ksp_type fgmres -ksp_gmres_restart 100
>> -ksp_rtol 1.0e-9 -ksp_monitor_short -pc_type fieldsplit -pc_fieldsplit_type
>> -fieldsplit_velocity_ksp_type gmres -fieldsplit_velocity_pc_type lu
>> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_pressure_pc_type jacobi
>>   0 SNES Function norm 0.265165
>>     0 KSP Residual norm 0.265165
>> Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
>> SNES Object: 1 MPI processes
>>   type: newtonls
>>   maximum iterations=50, maximum function evaluations=10000
>>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>>   total number of linear solver iterations=0
>>   total number of function evaluations=1
>>   norm schedule ALWAYS
>>   SNESLineSearch Object:   1 MPI processes
>>     type: bt
>>       interpolation: cubic
>>       alpha=1.000000e-04
>>     maxstep=1.000000e+08, minlambda=1.000000e-12
>>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
>> lambda=1.000000e-08
>>     maximum iterations=40
>>   KSP Object:   1 MPI processes
>>     type: fgmres
>>       GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>       GMRES: happy breakdown tolerance 1e-30
>>     maximum iterations=10000, initial guess is zero
>>     tolerances:  relative=1e-09, absolute=1e-50, divergence=10000.
>>     right preconditioning
>>     using UNPRECONDITIONED norm type for convergence test
>>   PC Object:   1 MPI processes
>>     type: fieldsplit
>>       FieldSplit with Schur preconditioner, factorization FULL
>>       Preconditioner for the Schur complement formed from A11
>>       Split info:
>>       Split number 0 Defined by IS
>>       Split number 1 Defined by IS
>>       KSP solver for A00 block
>>         KSP Object:        (fieldsplit_velocity_)         1 MPI processes
>>           type: gmres
>>             GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>           tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>           left preconditioning
>>           using PRECONDITIONED norm type for convergence test
>>         PC Object:        (fieldsplit_velocity_)         1 MPI processes
>>           type: lu
>>             LU: out-of-place factorization
>>             tolerance for zero pivot 2.22045e-14
>>             matrix ordering: nd
>>             factor fill ratio given 5., needed 1.
>>               Factored matrix follows:
>>                 Mat Object:                 1 MPI processes
>>                   type: seqaij
>>                   rows=512, cols=512, bs=2
>>                   package used to perform factorization: petsc
>>                   total: nonzeros=1024, allocated nonzeros=1024
>>                   total number of mallocs used during MatSetValues calls
>> =0
>>                     using I-node routines: found 256 nodes, limit used is
>> 5
>>           linear system matrix = precond matrix:
>>           Mat Object:          (fieldsplit_velocity_)           1 MPI
>> processes
>>             type: seqaij
>>             total number of mallocs used during MatSetValues calls =0
>>               using I-node routines: found 256 nodes, limit used is 5
>>       KSP solver for S = A11 - A10 inv(A00) A01
>>         KSP Object:        (fieldsplit_pressure_)         1 MPI processes
>>           type: gmres
>>           tolerances:  relative=1e-10, absolute=1e-50, divergence=10000.
>>         PC Object:        (fieldsplit_pressure_)         1 MPI processes
>>           type: jacobi
>>           linear system matrix followed by preconditioner matrix:
>>           Mat Object:          (fieldsplit_pressure_)           1 MPI
>> processes
>>             type: schurcomplement
>>             rows=256, cols=256
>>               has attached null space
>>               Schur complement A11 - A10 inv(A00) A01
>>               A11
>>                 Mat Object:
>>                   type: seqaij
>>                   rows=256, cols=256
>>                   total: nonzeros=256, allocated nonzeros=256
>> =0
>>                     not using I-node routines
>>               A10
>>                   type: seqaij
>>                   rows=256, cols=512
>>                   total: nonzeros=512, allocated nonzeros=512
>> =0
>>               KSP of A00
>>                 KSP Object:
>>                   type: gmres
>> Gram-Schmidt Orthogonalization with no iterative refinement
>> divergence=10000.
>>                 PC Object:
>>                   type: lu
>>                     matrix ordering: nd
>>                         Mat Object:                         1 MPI
>> processes
>>                           type: seqaij
>> used is 5
>>                   Mat Object:
>>                     type: seqaij
>> calls =0
>> is 5
>>               A01
>>                   type: seqaij
>>                   rows=512, cols=256, rbs=2, cbs = 1
>> =0
>> 5
>> processes
>>             type: seqaij
>>             rows=256, cols=256
>>       type: seqaij
>>       rows=768, cols=768
>>       total: nonzeros=2304, allocated nonzeros=2304
>> Number of SNES iterations = 0
>> L_2 Error: 1.01 [0.929, 0.407]
>> Solution
>> Vec Object: 1 MPI processes
>>   type: seq
>> 0.
>> 0.
>> Am I doing something wrong?
>> Giang
>> Giang
>> On Tue, May 3, 2016 at 4:44 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, May 2, 2016 at 8:29 PM, ztdepyahoo at 163.com <ztdepyahoo at 163.com>
>>> wrote:
>>>> Dear professor:
>>>>       I want to write a parallel 3D CFD code based on unstructred grid,
>>>> does Petsc has DMPlex examples to start with.
>>> SNES ex62 is an unstructured grid Stokes problem discretized with
>>> low-order finite elements.
>>> Of course, all the different possible choices will impact the design.
>>>    Matt
>>>> Regards
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160703/4d5d3d73/attachment-0001.html>
