[petsc-users] Dose Petsc has DMPlex example
Justin Chang jychang48 at gmail.com
Sun Jul 3 03:15:09 CDT 2016
Hoang, if you run this example shown from the config/builder.py
./ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
-interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type
fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
-pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type full
-fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres
-fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
-snes_monitor_short -ksp_monitor_short -snes_converged_reason
-ksp_converged_reason -snes_view -show_solution 0
it should work
On Sun, Jul 3, 2016 at 9:06 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
> Hi Matt
> I tried to run ex62 with 1 proc (petsc 3.7.2), but it all produces zero
> The output is:
> hbui at bermuda:~/workspace/petsc/snes$ es$ ./ex62 run_type full -bc_type
> dirichlet -refinement_limit 0.00625 -interpolate 1 -snes_monitor_short
> -snes_converged_reason -snes_view -ksp_type fgmres -ksp_gmres_restart 100
> -ksp_rtol 1.0e-9 -ksp_monitor_short -pc_type fieldsplit -pc_fieldsplit_type
> -fieldsplit_velocity_ksp_type gmres -fieldsplit_velocity_pc_type lu
> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_pressure_pc_type jacobi
>   0 SNES Function norm 0.265165
>     0 KSP Residual norm 0.265165
> Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
> SNES Object: 1 MPI processes
>   type: newtonls
>   maximum iterations=50, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=0
>   total number of function evaluations=1
>   norm schedule ALWAYS
>   SNESLineSearch Object:   1 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
>   KSP Object:   1 MPI processes
>     type: fgmres
>       GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>       GMRES: happy breakdown tolerance 1e-30
>     maximum iterations=10000, initial guess is zero
>     tolerances:  relative=1e-09, absolute=1e-50, divergence=10000.
>     right preconditioning
>     using UNPRECONDITIONED norm type for convergence test
>   PC Object:   1 MPI processes
>     type: fieldsplit
>       FieldSplit with Schur preconditioner, factorization FULL
>       Preconditioner for the Schur complement formed from A11
>       Split info:
>       Split number 0 Defined by IS
>       Split number 1 Defined by IS
>       KSP solver for A00 block
>         KSP Object:        (fieldsplit_velocity_)         1 MPI processes
>           type: gmres
>             GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>           tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>           left preconditioning
>           using PRECONDITIONED norm type for convergence test
>         PC Object:        (fieldsplit_velocity_)         1 MPI processes
>           type: lu
>             LU: out-of-place factorization
>             tolerance for zero pivot 2.22045e-14
>             matrix ordering: nd
>             factor fill ratio given 5., needed 1.
>               Factored matrix follows:
>                 Mat Object:                 1 MPI processes
>                   type: seqaij
>                   rows=512, cols=512, bs=2
>                   package used to perform factorization: petsc
>                   total: nonzeros=1024, allocated nonzeros=1024
>                   total number of mallocs used during MatSetValues calls =0
>                     using I-node routines: found 256 nodes, limit used is 5
>           linear system matrix = precond matrix:
>           Mat Object:          (fieldsplit_velocity_)           1 MPI
> processes
>             type: seqaij
>       KSP solver for S = A11 - A10 inv(A00) A01
>         KSP Object:        (fieldsplit_pressure_)         1 MPI processes
>           type: gmres
>           tolerances:  relative=1e-10, absolute=1e-50, divergence=10000.
>         PC Object:        (fieldsplit_pressure_)         1 MPI processes
>           type: jacobi
>           linear system matrix followed by preconditioner matrix:
>           Mat Object:          (fieldsplit_pressure_)           1 MPI
> processes
>             type: schurcomplement
>             rows=256, cols=256
>               has attached null space
>               Schur complement A11 - A10 inv(A00) A01
>               A11
>                 Mat Object:
>                   type: seqaij
>                   rows=256, cols=256
>                   total: nonzeros=256, allocated nonzeros=256
>                     not using I-node routines
>               A10
>                   type: seqaij
>                   rows=256, cols=512
>                   total: nonzeros=512, allocated nonzeros=512
>               KSP of A00
>                 KSP Object:
>                   type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> divergence=10000.
>                 PC Object:
>                   type: lu
>                     matrix ordering: nd
>                           type: seqaij
> calls =0
> used is 5
>                   Mat Object:
>                     type: seqaij
> =0
> is 5
>               A01
>                   type: seqaij
>                   rows=512, cols=256, rbs=2, cbs = 1
> processes
>             type: seqaij
>             rows=256, cols=256
>       type: seqaij
>       rows=768, cols=768
>       total: nonzeros=2304, allocated nonzeros=2304
> Number of SNES iterations = 0
> L_2 Error: 1.01 [0.929, 0.407]
> Solution
> Vec Object: 1 MPI processes
>   type: seq
> 0.
> 0.
> Am I doing something wrong?
> Giang
> Giang
> On Tue, May 3, 2016 at 4:44 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, May 2, 2016 at 8:29 PM, ztdepyahoo at 163.com <ztdepyahoo at 163.com>
>> wrote:
>>> Dear professor:
>>>       I want to write a parallel 3D CFD code based on unstructred grid,
>>> does Petsc has DMPlex examples to start with.
>> SNES ex62 is an unstructured grid Stokes problem discretized with
>> low-order finite elements.
>> Of course, all the different possible choices will impact the design.
>>    Matt
>>> Regards
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160703/1e49aea3/attachment.html>
