[petsc-users] repartition for dynamic load balancing
Thu Jan 28 13:41:45 CST 2016
On Thu, Jan 28, 2016 at 1:37 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On Thursday, 28 January 2016, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 28, 2016 at 11:36 AM, Xiangdong <epscodes at gmail.com> wrote:
>>> What functions/tools can I use for dynamic migration in DMPlex framework?
>> In this paper, http://arxiv.org/abs/1506.06194, we explain how to use
>> the DMPlexMigrate() function to redistribute data.
>> In the future, its likely we will add a function that wraps it up with
>> determination of the new partition at the same time.
>>> Can you also name some external mesh management systems? Thanks.
>> I will note that if load balance in the solve is your only concern,
>> PCTelescope can redistribute the DMDA solve.
> Currently Telescope will only repartition 2d and 3d DMDA's. It
> does perform data migration and allows users to specify the number of ranks
> to be used in each I,j,k direction via -xxx_grid_x etc. I wouldn't say it
> supports "load balancing", as there is no mechanism to define number of
> points in each sub-domain
Let me be more precise. All I have suggested for any of this are
redistribution tools. You will have to determine
the right weights for "load balance", which I think is always true. Using
the default weights is crazy.
  Matt
> Cheers
>   Dave
>>   Thanks,
>>     Matt
>>> Xiangdong
>>> On Thu, Jan 28, 2016 at 12:21 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> > On Jan 28, 2016, at 11:11 AM, Xiangdong <epscodes at gmail.com> wrote:
>>>> > Yes, it can be either DMDA or DMPlex. For example, I have 1D DMDA
>>>> with Nx=10 and np=2. At the beginning each processor owns 5 cells. After
>>>> some simulation time, I found that repartition the 10 cells into 3 and 7 is
>>>> better for load balancing. Is there an easy/efficient way to migrate data
>>>> from one partition to another partition? I am wondering whether there are
>>>> some functions or libraries help me manage this redistribution.
>>>>   For DMDA we don't provide tools for doing this, nor do we expect to.
>>>> For this type of need for dynamic migration we recommend using DMPlex or
>>>> some external mesh management system.
>>>>   Barry
>>>> > Thanks.
>>>> > Xiangdong
>>>> > On Thu, Jan 28, 2016 at 12:20 AM, Jed Brown <jed at jedbrown.org> wrote:
>>>> > Xiangdong <epscodes at gmail.com> writes:
>>>> > > I have a question on dynamic load balance in petsc. I started
>>>> running a
>>>> > > simulation with one partition. As the simulation goes on, that
>>>> partition
>>>> > > may lead to load imbalance since it is a non-steady problem. If it
>>>> is worth
>>>> > > to perform the load balance, is there an easy way to re-partition
>>>> the mesh
>>>> > > and continue the simulation?
>>>> > Are you using a PETSc DM?  What "mesh"?  If you own it, then
>>>> > repartitioning it is entirely your business.
>>>> > In general, after adapting the mesh, you rebuild all algebraic data
>>>> > structures.  Solvers can be reset (SNESReset, etc.).
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160128/bfa8940a/attachment.html>
