[petsc-users] repartition for dynamic load balancing
Dave May dave.mayhem23 at gmail.com
Thu Jan 28 13:37:49 CST 2016
On Thursday, 28 January 2016, Matthew Knepley <knepley at gmail.com
<javascript:_e(%7B%7D,'cvml','knepley at gmail.com');>> wrote:
> On Thu, Jan 28, 2016 at 11:36 AM, Xiangdong <epscodes at gmail.com> wrote:
>> What functions/tools can I use for dynamic migration in DMPlex framework?
> In this paper, http://arxiv.org/abs/1506.06194, we explain how to use the
> DMPlexMigrate() function to redistribute data.
> In the future, its likely we will add a function that wraps it up with
> determination of the new partition at the same time.
>> Can you also name some external mesh management systems? Thanks.
> I will note that if load balance in the solve is your only concern,
> PCTelescope can redistribute the DMDA solve.
Currently Telescope will only repartition 2d and 3d DMDA's. It does perform
data migration and allows users to specify the number of ranks to be used
in each I,j,k direction via -xxx_grid_x etc. I wouldn't say it
supports "load balancing", as there is no mechanism to define number of
points in each sub-domain
Cheers
  Dave
>   Thanks,
>     Matt
>> Xiangdong
>> On Thu, Jan 28, 2016 at 12:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > On Jan 28, 2016, at 11:11 AM, Xiangdong <epscodes at gmail.com> wrote:
>>> > Yes, it can be either DMDA or DMPlex. For example, I have 1D DMDA with
>>> Nx=10 and np=2. At the beginning each processor owns 5 cells. After some
>>> simulation time, I found that repartition the 10 cells into 3 and 7 is
>>> better for load balancing. Is there an easy/efficient way to migrate data
>>> from one partition to another partition? I am wondering whether there are
>>> some functions or libraries help me manage this redistribution.
>>>   For DMDA we don't provide tools for doing this, nor do we expect to.
>>> For this type of need for dynamic migration we recommend using DMPlex or
>>> some external mesh management system.
>>>   Barry
>>> > Thanks.
>>> > Xiangdong
>>> > On Thu, Jan 28, 2016 at 12:20 AM, Jed Brown <jed at jedbrown.org> wrote:
>>> > Xiangdong <epscodes at gmail.com> writes:
>>> > > I have a question on dynamic load balance in petsc. I started
>>> running a
>>> > > simulation with one partition. As the simulation goes on, that
>>> partition
>>> > > may lead to load imbalance since it is a non-steady problem. If it
>>> is worth
>>> > > to perform the load balance, is there an easy way to re-partition
>>> the mesh
>>> > > and continue the simulation?
>>> > Are you using a PETSc DM?  What "mesh"?  If you own it, then
>>> > repartitioning it is entirely your business.
>>> > In general, after adapting the mesh, you rebuild all algebraic data
>>> > structures.  Solvers can be reset (SNESReset, etc.).
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160128/fdb885f0/attachment.html>
