[petsc-users] Why use MATMPIBAIJ?
Hom Nath Gharti hng.email at gmail.com
Fri Jan 22 15:47:13 CST 2016
Hi Matt,
SPECFEM currently has only an explicit time scheme and does not have
full gravity implemented. I am adding implicit time scheme and full
gravity so that it can be used for interesting quasistatic problems
such as glacial rebound, post seismic relaxation etc. I am using Petsc
as a linear solver which I would like to see GPU implemented.
Hom Nath
On Fri, Jan 22, 2016 at 4:33 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 22, 2016 at 12:17 PM, Hom Nath Gharti <hng.email at gmail.com>
> wrote:
>> Thanks Matt for great suggestion. One last question, do you know
>> whether the GPU capability of current PETSC version is matured enough
>> to try for my problem?
> The only thing that would really make sense to do on the GPU is the SEM
> integration, which
> would not be part of PETSc. This is what SPECFEM has optimized.
>   Thanks,
>     Matt
>> Thanks again for your help.
>> Hom Nath
>> On Fri, Jan 22, 2016 at 1:07 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Fri, Jan 22, 2016 at 11:47 AM, Hom Nath Gharti <hng.email at gmail.com>
>> > wrote:
>> >> Thanks a lot.
>> >> With AMG it did not converge within the iteration limit of 3000.
>> >> In solid: elastic wave equation with added gravity term \rho \nabla\phi
>> >> In fluid: acoustic wave equation with added gravity term \rho
>> >> \nabla\phi
>> >> Both solid and fluid: Poisson's equation for gravity
>> >> Outer space: Laplace's equation for gravity
>> >> We combine so called mapped infinite element with spectral-element
>> >> method (higher order FEM that uses nodal quadrature) and solve in
>> >> frequency domain.
>> > 1) The Poisson and Laplace equation should be using MG, however you are
>> > using SEM, so
>> >     you would need to use a low order PC for the high order problem,
>> > also
>> > called p-MG (Paul Fischer), see
>> >       http://epubs.siam.org/doi/abs/10.1137/110834512
>> > 2) The acoustic wave equation is Helmholtz to us, and that needs special
>> > MG
>> > tweaks that
>> >      are still research material so I can understand using ASM.
>> > 3) Same thing for the elastic wave equations. Some people say they have
>> > this
>> > solved using
>> >     hierarchical matrix methods, something like
>> >       http://portal.nersc.gov/project/sparse/strumpack/
>> >     However, I think the jury is still out.
>> > If you can do 100 iterations of plain vanilla solvers, that seems like a
>> > win
>> > right now. You might improve
>> > the time using FS, but I am not sure about the iterations on the smaller
>> > problem.
>> >   Thanks,
>> >     Matt
>> >> Hom Nath
>> >> On Fri, Jan 22, 2016 at 12:16 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >> > On Fri, Jan 22, 2016 at 11:10 AM, Hom Nath Gharti
>> >> > wrote:
>> >> >> Thanks Matt.
>> >> >> Attached detailed info on ksp of a much smaller test. This is a
>> >> >> multiphysics problem.
>> >> > You are using FGMRES/ASM(ILU0). From your description below, this
>> >> > sounds
>> >> > like
>> >> > an elliptic system. I would at least try AMG (-pc_type gamg) to see
>> >> > how
>> >> > it
>> >> > does. Any
>> >> > other advice would have to be based on seeing the equations.
>> >> >   Thanks,
>> >> >     Matt
>> >> >> Hom Nath
>> >> >> On Fri, Jan 22, 2016 at 12:01 PM, Matthew Knepley
>> >> >> wrote:
>> >> >> > On Fri, Jan 22, 2016 at 10:52 AM, Hom Nath Gharti
>> >> >> > wrote:
>> >> >> >> Dear all,
>> >> >> >> I take this opportunity to ask for your important suggestion.
>> >> >> >> I am solving an elastic-acoustic-gravity equation on the planet.
>> >> >> >> I
>> >> >> >> have displacement vector (ux,uy,uz) in solid region, displacement
>> >> >> >> potential (\xi) and pressure (p) in fluid region, and
>> >> >> >> gravitational
>> >> >> >> potential (\phi) in all of space. All these variables are
>> >> >> >> coupled.
>> >> >> >> Currently, I am using MATMPIAIJ and form a single global matrix.
>> >> >> >> Does
>> >> >> >> using a MATMPIBIJ or MATNEST improve the convergence/efficiency
>> >> >> >> in
>> >> >> >> this case? For your information, total degrees of freedoms are
>> >> >> >> about
>> >> >> >> a
>> >> >> >> billion.
>> >> >> > 1) For any solver question, we need to see the output of
>> >> >> > -ksp_view,
>> >> >> > and
>> >> >> > we
>> >> >> > would also like
>> >> >> >   -ksp_monitor_true_residual -ksp_converged_reason
>> >> >> > 2) MATNEST does not affect convergence, and MATMPIBAIJ only in the
>> >> >> > blocksize
>> >> >> > which you
>> >> >> >     could set without that format
>> >> >> > 3) However, you might see benefit from using something like
>> >> >> > PCFIELDSPLIT
>> >> >> > if
>> >> >> > you have multiphysics here
>> >> >> >    Matt
>> >> >> >> Any suggestion would be greatly appreciated.
>> >> >> >> Thanks,
>> >> >> >> Hom Nath
>> >> >> >> On Fri, Jan 22, 2016 at 10:32 AM, Matthew Knepley
>> >> >> >> wrote:
>> >> >> >> > On Fri, Jan 22, 2016 at 9:27 AM, Mark Adams <mfadams at lbl.gov>
>> >> >> >> > wrote:
>> >> >> >> >>> I said the Hypre setup cost is not scalable,
>> >> >> >> >> I'd be a little careful here.  Scaling for the matrix triple
>> >> >> >> >> product
>> >> >> >> >> is
>> >> >> >> >> hard and hypre does put effort into scaling. I don't have any
>> >> >> >> >> data
>> >> >> >> >> however.
>> >> >> >> >> Do you?
>> >> >> >> > I used it for PyLith and saw this. I did not think any AMG had
>> >> >> >> > scalable
>> >> >> >> > setup time.
>> >> >> >> >    Matt
>> >> >> >> >>> but it can be amortized over the iterations. You can quantify
>> >> >> >> >>> this
>> >> >> >> >>> just by looking at the PCSetUp time as your increase the
>> >> >> >> >>> number
>> >> >> >> >>> of
>> >> >> >> >>> processes. I don't think they have a good
>> >> >> >> >>> model for the memory usage, and if they do, I do not know
>> >> >> >> >>> what
>> >> >> >> >>> it
>> >> >> >> >>> is.
>> >> >> >> >>> However, generally Hypre takes more
>> >> >> >> >>> memory than the agglomeration MG like ML or GAMG.
>> >> >> >> >> agglomerations methods tend to have lower "grid complexity",
>> >> >> >> >> that
>> >> >> >> >> is
>> >> >> >> >> smaller coarse grids, than classic AMG like in hypre. THis is
>> >> >> >> >> more
>> >> >> >> >> of a
>> >> >> >> >> constant complexity and not a scaling issue though.  You can
>> >> >> >> >> address
>> >> >> >> >> this
>> >> >> >> >> with parameters to some extent. But for elasticity, you want
>> >> >> >> >> to
>> >> >> >> >> at
>> >> >> >> >> least
>> >> >> >> >> try, if not start with, GAMG or ML.
>> >> >> >> >>>   Thanks,
>> >> >> >> >>>     Matt
>> >> >> >> >>>> Giang
>> >> >> >> >>>> On Mon, Jan 18, 2016 at 5:25 PM, Jed Brown
>> >> >> >> >>>> <jed at jedbrown.org>
>> >> >> >> >>>> wrote:
>> >> >> >> >>>>> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>> >> >> >> >>>>> > Why P2/P2 is not for co-located discretization?
>> >> >> >> >>>>> Matt typed "P2/P2" when me meant "P2/P1".
>> >> >> >> >>> What most experimenters take for granted before they begin
>> >> >> >> >>> their
>> >> >> >> >>> experiments is infinitely more interesting than any results
>> >> >> >> >>> to
>> >> >> >> >>> which
>> >> >> >> >>> their
>> >> >> >> >>> experiments lead.
>> >> >> >> >>> -- Norbert Wiener
>> >> >> >> > their
>> >> >> >> > experiments
>> >> >> >> > is infinitely more interesting than any results to which their
>> >> >> >> > experiments
>> >> >> >> > lead.
>> >> >> >> > -- Norbert Wiener
>> >> >> > What most experimenters take for granted before they begin their
>> >> >> > experiments
>> >> >> > experiments
>> >> >> > lead.
>> >> >> > -- Norbert Wiener
>> >> > experiments
>> >> > experiments
>> >> > lead.
>> >> > -- Norbert Wiener
>> > experiments
>> > experiments
>> > lead.
>> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
