[petsc-users] Why use MATMPIBAIJ?
Hom Nath Gharti hng.email at gmail.com
Fri Jan 22 11:47:47 CST 2016
Thanks a lot.
With AMG it did not converge within the iteration limit of 3000.
In solid: elastic wave equation with added gravity term \rho \nabla\phi
In fluid: acoustic wave equation with added gravity term \rho \nabla\phi
Both solid and fluid: Poisson's equation for gravity
Outer space: Laplace's equation for gravity
We combine so called mapped infinite element with spectral-element
method (higher order FEM that uses nodal quadrature) and solve in
frequency domain.
Hom Nath
On Fri, Jan 22, 2016 at 12:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 22, 2016 at 11:10 AM, Hom Nath Gharti <hng.email at gmail.com>
> wrote:
>> Thanks Matt.
>> Attached detailed info on ksp of a much smaller test. This is a
>> multiphysics problem.
> You are using FGMRES/ASM(ILU0). From your description below, this sounds
> like
> an elliptic system. I would at least try AMG (-pc_type gamg) to see how it
> does. Any
> other advice would have to be based on seeing the equations.
>   Thanks,
>     Matt
>> Hom Nath
>> On Fri, Jan 22, 2016 at 12:01 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Fri, Jan 22, 2016 at 10:52 AM, Hom Nath Gharti <hng.email at gmail.com>
>> > wrote:
>> >> Dear all,
>> >> I take this opportunity to ask for your important suggestion.
>> >> I am solving an elastic-acoustic-gravity equation on the planet. I
>> >> have displacement vector (ux,uy,uz) in solid region, displacement
>> >> potential (\xi) and pressure (p) in fluid region, and gravitational
>> >> potential (\phi) in all of space. All these variables are coupled.
>> >> Currently, I am using MATMPIAIJ and form a single global matrix. Does
>> >> using a MATMPIBIJ or MATNEST improve the convergence/efficiency in
>> >> this case? For your information, total degrees of freedoms are about a
>> >> billion.
>> > 1) For any solver question, we need to see the output of -ksp_view, and
>> > we
>> > would also like
>> >   -ksp_monitor_true_residual -ksp_converged_reason
>> > 2) MATNEST does not affect convergence, and MATMPIBAIJ only in the
>> > blocksize
>> > which you
>> >     could set without that format
>> > 3) However, you might see benefit from using something like PCFIELDSPLIT
>> > if
>> > you have multiphysics here
>> >    Matt
>> >> Any suggestion would be greatly appreciated.
>> >> Thanks,
>> >> Hom Nath
>> >> On Fri, Jan 22, 2016 at 10:32 AM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >> > On Fri, Jan 22, 2016 at 9:27 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> >> >>> I said the Hypre setup cost is not scalable,
>> >> >> I'd be a little careful here.  Scaling for the matrix triple product
>> >> >> is
>> >> >> hard and hypre does put effort into scaling. I don't have any data
>> >> >> however.
>> >> >> Do you?
>> >> > I used it for PyLith and saw this. I did not think any AMG had
>> >> > scalable
>> >> > setup time.
>> >> >    Matt
>> >> >>> but it can be amortized over the iterations. You can quantify this
>> >> >>> just by looking at the PCSetUp time as your increase the number of
>> >> >>> processes. I don't think they have a good
>> >> >>> model for the memory usage, and if they do, I do not know what it
>> >> >>> is.
>> >> >>> However, generally Hypre takes more
>> >> >>> memory than the agglomeration MG like ML or GAMG.
>> >> >> agglomerations methods tend to have lower "grid complexity", that is
>> >> >> smaller coarse grids, than classic AMG like in hypre. THis is more
>> >> >> of a
>> >> >> constant complexity and not a scaling issue though.  You can address
>> >> >> this
>> >> >> with parameters to some extent. But for elasticity, you want to at
>> >> >> least
>> >> >> try, if not start with, GAMG or ML.
>> >> >>>   Thanks,
>> >> >>>     Matt
>> >> >>>> Giang
>> >> >>>> On Mon, Jan 18, 2016 at 5:25 PM, Jed Brown <jed at jedbrown.org>
>> >> >>>> wrote:
>> >> >>>>> Hoang Giang Bui <hgbk2008 at gmail.com> writes:
>> >> >>>>> > Why P2/P2 is not for co-located discretization?
>> >> >>>>> Matt typed "P2/P2" when me meant "P2/P1".
>> >> >>> What most experimenters take for granted before they begin their
>> >> >>> experiments is infinitely more interesting than any results to
>> >> >>> which
>> >> >>> their
>> >> >>> experiments lead.
>> >> >>> -- Norbert Wiener
>> >> > experiments
>> >> > is infinitely more interesting than any results to which their
>> >> > experiments
>> >> > lead.
>> >> > -- Norbert Wiener
>> > experiments
>> > experiments
>> > lead.
>> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
