[petsc-users] Amortizing calls to PetscOptionsFindPair_Private()
Sat Jan 16 17:46:17 CST 2016
  Just as I feared. HPC software with bad dependencies, oh well charging ahead anyways
> On Jan 16, 2016, at 5:09 PM, Bhalla, Amneet Pal S <amneetb at live.unc.edu> wrote:
>> On Jan 16, 2016, at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Either way is fine so long as I don't have to install a ton of stuff; which it sounds like I won’t.
> http://hpctoolkit.org/download/hpcviewer/
> Unzip HPCViewer for MacOSX with command line and drag the unzipped folder to Applications. You will be able to
> fire HPCViewer from LaunchPad. Point it to this attached directory. You will be able to see three different kind of profiling
> under Calling Context View, Callers View and Flat View.
> <hpctoolkit-main2d-database.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160116/6cf16f46/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160116/6cf16f46/attachment-0001.png>
