[petsc-users] Amortizing calls to PetscOptionsFindPair_Private()
Bhalla, Amneet Pal S amneetb at live.unc.edu
Sat Jan 16 17:09:26 CST 2016
On Jan 16, 2016, at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
Either way is fine so long as I don't have to install a ton of stuff; which it sounds like I won’t.
http://hpctoolkit.org/download/hpcviewer/
Unzip HPCViewer for MacOSX with command line and drag the unzipped folder to Applications. You will be able to
fire HPCViewer from LaunchPad. Point it to this attached directory. You will be able to see three different kind of profiling
under Calling Context View, Callers View and Flat View.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160116/c8911b9f/attachment-0001.html>
Type: application/zip
Desc: hpctoolkit-main2d-database.zip
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160116/c8911b9f/attachment-0001.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160116/c8911b9f/attachment-0001.htm>
