[petsc-users] Amortizing calls to PetscOptionsFindPair_Private()
Bhalla, Amneet Pal S amneetb at live.unc.edu
Fri Jan 15 17:33:21 CST 2016
Hi Barry,
In our code at each timestep we build MG level smoothers using PETSc KSP solvers. We are using a PETSc function KSPSetFromOptions()
after we set some default values to the KSP. However, the profiler is showing that PetscOptionsFindPair_Private() is taking about 14% of total runtime.
We ran the code for 100 timesteps, and preconditioner is built everytime step. I am posting a sequence of calls to KSPSolve_Richardson that shows
getting PETScOptions adds up to a lot of cost
"KSPSolve_Richardson" 	       8.80e+05 12.7%
   "PCApplyBAorAB" 	               5.25e+05  7.6%
     "PCApply" 	                               4.85e+05  7.0%
       "PCApply_ASM" 	               4.85e+05  7.0%
         "KSPSolve" 	                       4.53e+05  6.6%
           "KSPSolve_PREONLY"                      2.06e+05  3.0%
           "PetscObjectViewFromOptions" 	       3.19e+04  0.5%
           "PetscObjectViewFromOptions" 	       2.39e+04  0.3%
           "PetscOptionsGetBool" 	               2.39e+04  0.3%
           "PetscOptionsHasName" 	               2.39e+04  0.3%
          "PetscOptionsHasName" 	               1.60e+04  0.2%
          "PetscOptionsGetBool" 	               1.60e+04  0.2%
          "PetscObjectViewFromOptions" 	       1.60e+04  0.2%
          "KSPReasonViewFromOptions" 	       1.60e+04  0.2%
          "PetscOptionsGetBool" 	               1.56e+04  0.2%
          "PetscObjectViewFromOptions" 	        7.98e+03  0.1%
          "KSPSetUpOnBlocks" 	                        7.98e+03  0.1%
          "PetscOptionsGetBool" 	                7.98e+03  0.1%
          "VecSet" 	                                        7.97e+03  0.1%
          "PetscObjectViewFromOptions" 	        7.92e+03  0.1%
Do you have some suggestions as to doing it in a fast way -- maybe parsing options only once in the simulation and making populating KSP
options essentially a no-op?
--Amneet
