[petsc-users] Profile a matrix-free solver.
Zou (Non-US), Ling ling.zou at inl.gov
Fri Jan 15 15:02:42 CST 2016
Thank you very much!
Ling
On Fri, Jan 15, 2016 at 1:58 PM, Song Gao <song.gao2 at mail.mcgill.ca> wrote:
> Yes.
> http://www.sciencedirect.com/science/article/pii/S0021999198960764
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.sciencedirect.com_science_article_pii_S0021999198960764&d=BQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=kuHHom1yjd94zUrBWecnYg&m=Z6JmjYd7euHq--9l5maVEB6hJHAkMcMNyc8rnVhgDC8&s=wfmA2PxK68XsQhc1PzBC4HCsxtwNAhBAmxe5VvnLj8Q&e=>
> It's on page 668 equation 4.6.
> Thanks
> 2016-01-15 15:39 GMT-05:00 Zou (Non-US), Ling <ling.zou at inl.gov>:
>> Hi Song, I wonder if you have a reference paper on the preconditioning
>> algorithm you are working on, i.e., using the 1st order flux for
>> preconditioning purpose when your 'true' fluxes are evaluated using the 2nd
>> order AUSM scheme.
>> Best,
>> Ling
>> On Fri, Jan 15, 2016 at 1:34 PM, Song Gao <song.gao2 at mail.mcgill.ca>
>> wrote:
>>> Thanks. I'll try to improve "my code"
>>> 2016-01-15 14:56 GMT-05:00 Jed Brown <jed at jedbrown.org>:
>>>> Matthew Knepley <knepley at gmail.com> writes:
>>>> > The way I read this, you are taking about 23 iterates/solve, and most
>>>> of
>>>> > your work is residual computation which should
>>>> > be highly parallelizable/vectorizable. This seems great to me.
>>>> This in the sense that it's up to you to determine whether your
>>>> matrix-free residual and preconditioning code is fast.  This profile
>>>> merely says that almost all of the run-time is in *your code*.  If your
>>>> code is fast, then this is good performance.  If you can use a different
>>>> algorithm to converge in fewer iterations, or a different representation
>>>> to apply the operator faster, then you could do better.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160115/4f0b18f2/attachment.html>
